12-Security Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R0821-6W50112-Security Command Reference
29-Crypto engine commands
29-Crypto engine commands 52.07 KB
The following compatibility matrixes show the support of hardware platforms for crypto engines:
Hardware
Crypto engine compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
Yes
MSR810-LMS, MSR810-LUS
Yes
MSR810-LMS-EA, MSR810-LME
Yes
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR3610-I-IG, MSR3610-IE-IG
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
Yes
display crypto-engine
Use display crypto-engine to display crypto engine information.
If the device does not have hardware crypto engines, this command displays information only about software crypto engines.
# Display crypto engine information.
<Sysname> display crypto-engine
  Crypto engine name: Cavium crypto driver
  Crypto engine state: Enabled
  Crypto engine type: Hardware
  Slot ID: 0
  CPU ID: 0
  Crypto engine ID: 0
  Crypto device name: cavium crypto
  Crypto device serial number:
  Symmetric algorithms: des-cbc des-ecb 3des-cbc 3des-ecb aes-cbc aes-ecb aes-ctr md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc-hmac
  Asymmetric algorithms: dh-group1 dh-group2 dh-group5 dh-group14
  Random number generation function: Supported
  Crypto engine name: Software crypto engine
  Crypto engine type: Software
  Slot ID: 0
  CPU ID: 0
  Crypto engine ID: 1
  Crypto device name: Software
  Symmetric algorithms:  des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac sm3 sm3-hmac sm4-cbc
  Slot ID: 1
  CPU ID:0
  Crypto engine ID: 0
Crypto engine state
Hardware crypto engine state:
·     Enabled.
·     Disabled.
This field always displays Enabled for software crypto engines.
Crypto engine type
Crypto engine type:
·     Hardware.
·     Software.
Crypto device name
Name of the crypto device.
This field displays Software for software crypto engines.
For hardware crypto engines, the value of this field varies by device model.
Serial number of the crypto device.
This field is always empty for software crypto engines.
This field is always empty for hardware crypto engines.
Supported symmetric algorithms.
Supported asymmetric algorithms.
Whether random number generation function is supported:
·     Supported.
·     Not supported.
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
In standalone mode:
display crypto-engine statistics [ engine-id engine-id ]
In IRF mode:
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
engine-id engine-id: Specifies a crypto engine by its ID.The value range for the engine-id argument is 0 to 4294967295.
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
If hardware crypto engines are not enabled or the device does not have hardware crypto engines, this command displays statistics only for software crypto engines.
(In standalone mode.) If you do not specify any parameters, this command displays statistics for all crypto engines.
(In IRF mode.) If you do not specify any parameters, this command displays crypto engine statistics for all member devices.
# (In standalone mode.) Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
  Submitted sessions: 0
  Failed sessions: 0
  Symmetric operations: 0
  Symmetric errors: 0
  Asymmetric operations: 0
  Asymmetric errors: 0
  Get-random operations: 0
  Get-random errors: 0
# (In IRF mode.) Display all crypto engine statistics.
  Slot ID: 1
  CPU ID: 0
  Crypto engine ID: 0
  Failed sessions: 0
  Symmetric errors: 0
# (In standalone mode.) Display statistics for crypto engine 1.
<Sysname> display crypto-engine statistics engine-id 1
  Failed sessions: 0
  Symmetric errors: 0
# (In IRF mode.) Display statistics for crypto engine 1 on the specified slot.
<Sysname> display crypto-engine statistics engine-id 1 slot 1
  Failed sessions: 0
  Symmetric errors: 0
Submitted sessions
Number of established sessions.
Failed sessions
Number of failed sessions.
Number of operations using symmetric algorithms.
Symmetric errors
Number of failed operations using symmetric algorithms.
Number of operations using asymmetric algorithms.
Asymmetric errors
Number of failed operations using asymmetric algorithms.
Number of operations for obtaining random numbers.
Get-random errors
Number of failed operations for obtaining random numbers.
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
In standalone mode:
reset crypto-engine statistics [ engine-id engine-id ]
In IRF mode:
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
(In standalone mode.) If you do not specify any parameters, this command clears statistics for all crypto engines.
(In IRF mode.) If you do not specify any parameters, this command clears crypto engine statistics for all member devices.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
# Clear statistics for crypto engine 1 on the specified slot.
<Sysname> reset crypto-engine statistics engine-id 1 slot 1
  • Become a Partner
  • Partner Resources
