05-Layer 2—WAN Access Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810[830][2600][3600] Routers Command Reference(V7)-R0821-6W50105-Layer 2—WAN Access Command Reference
06-Modem management commands
06-Modem management commands 84.29 KB
This feature is supported only on the following interface modules and AUX interfaces operating in asynchronous mode:
·     AM inteface modules
·     ASE interface modules
·     AUX interfaces
·     SAE interface modules
country-code
Use country-code to set the modem country code on an AM interface.
Use undo country-code to restore the default.
country-code area-name
undo country-code
The country code is united-states.
AM interface view
area-name: Specifies a country code. The following are available country codes:
australia
france
korea
russia
austria
germany
luxembourg
singapore
belgium
greece
malaysia
southafrica
brazil
hongkong
mexico
spain
bulgaria
hungary
netherlands
sweden
canada
india
new-zealand
switzerland
china
ireland
norway
taiwan
czechoslovakia
israel
philippines
united-kingdom
denmark
italy
poland
united-states
finland
japan
portugal
CAUTION
CAUTION:
Executing this command disconnects the modem connection that has been established on the interface.
Modem encoding format varies by country/region. Use this command to set the modem encoding format for a country/region.
# Set the country code to china on AM interface 2/4/0.
[Sysname] interface analogmodem 2/4/0
[Sysname-Analogmodem2/4/0] country-code china
modem answer-timer
Use modem answer-timer to set a dial-up connection timer.
Use undo modem answer-timer to restore the default.
modem answer-timer time
The dial-up connection timer is 60 seconds.
User line view
time: Sets the dial-up connection timer in the range of 1 to 65535, in seconds.
When the timer expires, the modem disconnects the call.
·     If the modem is on the calling party side, the timer starts when the modem starts to dial.
·     If the modem is on the called party side, the timer starts when the modem goes off hook.
This command is available on the following user lines:
·     TTY lines for the following interfaces:
¡     AM interface
¡     Asynchronous serial interface
¡     Asynchronous/synchronous serial interface operating in asynchronous mode
·     AUX line
This command is not available on the console or VTY lines.
To display the user line for an interface, use the display line command.
# Set the dial-up connection timer to 50 seconds.
[Sysname] line aux 0
[Sysname-line-aux0] modem answer-timer 50
modem auto-answer
Use modem auto-answer to enable auto-answer mode.
Use undo modem auto-answer to restore the default.
modem auto-answer
Auto-answer mode is disabled. The modem answers a call only when it receives the AT command from the router.
User line view
To ensure correct operation of the modem, set the auto-answer mode on the user line to be the same as the modem.
·     Enable auto-answer mode if the modem is in auto-answer mode (the AA LED of the modem lights up). This setting prevents the router from issuing a duplicate answer command after the modem answers a call.
·     Disable auto-answer mode if the modem is not in auto-answer mode.
¡     AM interface
·     AUX line
# Enable auto-answer mode on TTY 1.
[Sysname] line tty 1
[Sysname-line-tty1] modem auto-answer
modem caller-number resolve
modem callback
Use modem callback to enable callback.
Use undo modem callback to disable callback.
modem callback
undo modem callback
Callback is disabled.
The callback function enables a modem to disconnect an incoming call and call back the calling party upon request.
# Enable the callback function.
[Sysname] modem callback
Use modem caller-number resolve to enable the modem to obtain the call numbers of calling terminals.
Use undo modem caller-number resolve to disable the modem from obtaining the call number of calling terminals.
modem caller-number resolve [ ata-waiting-time time ]
The modem does not obtain caller numbers when it accepts calls from terminals.
User line view
ata-waiting-time time: Specifies the maximum amount of time that the modem waits for a calling terminal to send the call number. The value range for the time argument is 10 to 10000, in milliseconds. The default value is 1000. When this timer expires, the modem does not receive the call number of the terminal. Increase the timer value on a slow link for the router to obtain caller numbers successfully.
CAUTION
CAUTION:
Executing this command disconnects the modem connection that has been established on the user line.
This command is for point of sale (POS) terminal access services. It is available only on TTY lines for AM interfaces.
Configure this command if a bank front end processor requires the router to send the call numbers of POS terminals for acknowledgment before it accepts data from the terminals.
For more information about POS terminal access services and caller number sending, see Terminal Access Configuration Guide.
# Enable the modem to obtain caller numbers on TTY 81, and set the caller number waiting timer to 10 seconds.
[Sysname] line tty 81
[Sysname-line-tty81] modem caller-number resolve ata-waiting-time 10000
modem auto-answer
modem enable
Use modem enable to enable the modem to answer incoming calls, initiate outgoing calls, or both.
Use undo modem enable to disable the modem from answering incoming calls and initiating outgoing calls .
modem enable { both | call-in | call-out }
undo modem enable
The modem is disabled from answering incoming calls and initiating outgoing calls.
User line view
both: Enables the modem to answer incoming calls and initiate outgoing calls.
call-in: Enables the modem to answer incoming calls.
call-out: Enables the modem to initiate outgoing calls.
CAUTION
CAUTION:
¡     AM interface
·     AUX line
# On user line TTY 1, enable the modem to answer incoming calls.
[Sysname-line-tty1] modem enable call-in
sendat
Use sendat to issue an AT command to a modem.
sendat at-string
Interface view
at-string: Specifies an AT command, a case-insensitive string of 1 to 300 characters. The router automatically converts lowercase characters to uppercase when it sends the command to the modem. Enter the AT prefix before all commands except A/ (Repeat Last Command) and +++ (Escape code). For more information about AT commands that begin with AT, see Table 1.
CAUTION
CAUTION:
This command changes the modem operating state. Incorrect use of this command can cause problems such as dial-up failure. When you use this command, make sure you understand the impact of this command.
This command is available on the following interfaces:
·     Asynchronous serial interface
·     Asynchronous/synchronous serial interface in asynchronous mode
·     AM interface
·     AUX interface
To send AT commands to a modem, you must first place the modem in AT command mode. To confirm that you can send AT commands, enter sendat at. The modem will return OK or 0 if it is ready to accept AT commands.
One sendat command can issue one AT command. To send multiple AT commands to a modem, you must repeat the sendat command.
This command does not verify the validity of AT commands. To verify the AT command execution result, enable modem debugging on the interface. To view the AT commands sent to the modem, issue the E1 command to the modem.
Table 1 describes commonly used AT commands. Support for AT commands varies by modems.
Table 1 AT commands in common use
A
Forces the modem to go off-hook in answer mode. If a call is coming in, the modem will try to answer it without waiting for the ringtone. This command is useful when manual answer mode is used.
Bn
Sets the modulation protocol preference.
Available options:
·     B0—Selects the ITU V.22 mode. The transmission speed is 1200 bps.
·     B1—Selects the Bell 212 mode. The default transmission speed is 1200 bps.
·     B2/B3—Cancels the ITU V.23 backward channel.
·     B15—Selects the ITU V.21 mode. The transmission speed is 300 bps.
·     B16—Selects the 103J mode. The transmission speed is 300 bps. This setting is the default for Compaq Presario 192-VS and Compaq Presario 288-VS modems.
Dn
Dials a telephone number. The n argument represents the dial string. In pulse dialing mode, the modem ignores nonnumeric characters.
En
Controls echo of commands to the configuration terminal.
Available options:
·     E0—Disables echo of commands to the configuration terminal.
·     E1—Enables echo of commands to the configuration terminal. This option is the default.
Hn
Sets the method to terminate a call.
Available options:
·     H0—Forces modem on-hook to hang up the line (the default).
·     H1—Forces modem off-hook to answer or dial.
In
Displays modem information and results of checksum tests on firmware.
Available options:
·     I0/I3—Displays the default transmission speed and controller firmware version.
·     I1—Runs a checksum on the ROM and displays the result.
·     I2—Runs a checksum on the ROM and displays the checksum status:
¡     OK—The checksum is correct.
¡     ERROR—The checksum is incorrect.
·     I4—Displays the hardware version of the data pump.
·     I5—Displays the product code, software version, hardware version, and country code.
·     I9—Displays the country code.
Ln
Sets the speaker loudness for fax and data communication.
Available options:
·     L0/L1—Low volume.
·     L2—Medium volume (the default).
·     L3—High volume.
Mn
Sets the speaker mode for fax and data communication.
Available options:
·     M0—Speaker is always off.
·     M1—Speaker is on until the carrier is detected. This option is the default.
·     M2—Speaker is on when the modem is off-hook.
·     M3—Speaker is on after a dial until the carrier is detected.
Nn
Sets the modulation negotiation mode for the modem to establish a connection with a remote modem operating at a different speed.
Available options:
·     N0—Forces the modem to connect at the speed specified in the S37 register and the ATBn command.
·     N1—Enables the modem to start connecting at the speed specified in the S37 register and ATBn command. However, the speed may drop during the negotiation. This option is the default.
On
Forces the modem to return to data mode.
Available options:
·     O0—Returns to data mode.
·     O1—Initiates an equalizer retrain sequence before returning to data mode.
·     O3—Negotiates the transmission speed before returning to data mode.
After you use the +++ command to place the command in command mode, you can use an ATOn command to change the modem to data mode.
Qn
Enables or disables the modem to send result and status codes to the configuration terminal.
Available options:
·     Q0—The modem sends result and status codes. This option is the default.
·     Q1—The modem does not send result and status codes.
Sr=n
Sets the contents of S register r to value n.
·     Value range for the r argument—0 to 27, 29, 31 to 33, 35, 37, and 89.
·     Value range for the n argument—0 to 255.
T
Sets tone dialing (the default). This command can also be used as a dialing modifier.
P
Sets pulse dialing. After you execute this command, the modem performs pulse dialing for all calls until you execute the T command. The P command can also be used as a dialing modifier.
Vn
Specifies the result code format.
Available options:
·     V0—Sends numeric result codes.
·     V1—Sends text-form result codes (the default).
# On Async 2/4/0, instruct the modem to dial 169.
[Sysname] interface async 2/4/0
[Sysname-Async2/4/0] sendat ATD169
# On Serial 2/1/0, instruct the modem to dial 169.
[Sysname] interface serial 2/1/0
[Sysname-Serial2/1/0] physical-mode async
[Sysname-Serial2/1/0] sendat ATD169
  • Become a Partner
  • Partner Resources
