- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-Dual-stack PBR commands
| 08-IPv6 static routing commands | 95.19 KB |
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all IPv6 static routes for the public network.
CAUTION: Deleting all IPv6 static routes with caution. This operation might cause network connectivity failure and packet forwarding failure. |
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
NibID: 0x21000000 Sequence: 0
Type: 0x41 Flushed: Yes
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: 2::3
IFIndex: 0x0 LocalAddr: ::
NewUK0: 0x0 NewUK1: 0x0
NewUK2: 0x0 NewUK3: 0x0
NewUK4: 0x0 NewUK5: 0x0
NewUK6: 0x0 NewUK7: 0x0
TopoNthp: Invalid ExtType: 0x0
NibID: 0x21000001 Sequence: 1
UserKey1: 0x0 Nexthop: 3::4
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
VrfNthp |
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index |
LocalAddr |
Local interface address. |
NewUK0 |
New reserved data 1. |
NewUK1 |
New reserved data 2. |
NewUK2 |
New reserved data 3. |
NewUK3 |
New reserved data 4. |
NewUK4 |
New reserved data 5. |
NewUK5 |
New reserved data 6. |
NewUK6 |
New reserved data 7. |
NewUK7 |
New reserved data 8. |
TopoNthp |
This field is not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies. |
ExtType |
NIB extension type. |
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
RefCnt: 1 FlushRefCnt: 0
Flag: 0x12 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 2::3
RelyDepth: 2 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 3::4
RelyDepth: 1 RealNexthop: ::
Interface: Vlan11 LocalAddr: ::
Weight: 0
x nexthop(s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
Vrf |
VPN instance name. For the public network, this field displays default-vrf. |
OrigNexthop |
Original next hop. |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
NewUK0 |
NewUK1 |
NewUK2 |
NewUK3 |
NewUK4 |
NewUK5 |
NewUK6 |
NewUK7 |
RelyDepth |
Recursion depth. |
TunnelCnt |
Number of tunnels after route recursion. |
TunnelID |
ID of the tunnel after route recursion. |
Topology |
This field is not supported in the current software version. Topology name. This field is blank for IPv6, because IPv6 does not support non-base topologies. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
ExtType |
display ipv6 route-static routing-table
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv6 static routing table information for the public network.
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
NibID: 0x21000000 NextHop: 2::2
MainNibID: N/A BkNextHop: N/A
BkNibID: N/A Interface: Vlan-interface11
TableID: 0xa BkInterface: N/A
Flag: 0x80d0a BfdSrcIp: N/A
DbIndex: 0x3 BfdIfIndex: 0x0
Type: Normal BfdVrfIndex: 0
TrackIndex: 0xffffffff Label: NULL
Preference: 60 vrfIndexDst: 0
BfdMode: N/A vrfIndexNH: 0
Permanent: 0 Tag: 0
*Destination: 1::1234/128
BkNibID: N/A Interface: NULL0
DbIndex: 0x1 BfdIfIndex: 0x0
Permanent: 0 Tag: 0
Destination |
Destination address/prefix. |
NibID |
ID of the NIB. |
MainNibID |
ID of the primary next hop for static route FRR. |
BkNibID |
ID of the backup next hop for static route FRR. |
NextHop |
Next hop address. |
BkNextHop |
Backup next hop address. |
Output interface of the route. |
BkInterface |
Backup output interface. |
TableID |
ID of the table to which the route belongs. |
DbIndex |
Index of the database to which the route belongs. |
Type |
Route type: · Normal. · DHCP. |
BfdSrcIp |
Source IPv6 address of the indirect BFD session. |
BfdIfIndex |
Index of the interface where BFD is enabled. |
BfdVrfIndex |
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network. |
BfdMode |
BFD session mode: · N/A—No BFD session is configured. · Ctrl—Control packet mode. · Echo—Echo packet mode. |
TrackIndex |
NQA Track index. |
vrfIndexDst |
Index of the VPN instance to which the destination belongs. For the public network, this field displays 0. |
vrfIndexNH |
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0. |
Permanent |
Permanent static route flag. 1 indicates a permanent static route. |
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } [ bfd-source ipv6-address ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text | recursive-lookup ]
ipv6 route-static ipv6-address prefix-length [ vpn-instance d-vpn-instance-name ] next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text | recursive-lookup ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | [ vpn-instance d-vpn-instance-name ] next-hop-address ] [ preference preference ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } [ bfd-source ipv6-address ] | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text | recursive-lookup ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { next-hop-address [ recursive-lookup host-route ] [ public ] [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ipv6-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text | recursive-lookup ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is an NBMA interface or broadcast interface and not a point-to-point (P2P) interface, the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
recursive-lookup: Enables support for next hop recursion loops for the IPv6 static route. If you do not specify this keyword, the device does not support next hop recursion loops for the IPv6 static route.
recursive-lookup host-route: Specifies only host routes for IPv6 static route recursion.
bfd: Enables BFD to detect reachability of the static route's next hop.
control-packet: Specifies the BFD control packet mode.
bfd-source ipv6-address: Specifies the source IPv6 address of BFD packets.
echo-packet: Specifies the BFD echo packet mode.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. If the output interface is down, the permanent IPv6 static route is still active.
track track-entry-number: Associates the IPv6 static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
public: Indicates the next hop is on the public network.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If a destination VPN is specified, packets will search for the output interface based on the specified next hop (IPv6 address) for the static route.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
description text: Configures a description for the IPv6 static route, which consists of 1 to 60 characters, including special characters such as the space, but excluding the question mark (?).
vpn-instance s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN has its own routing table, and the configured static route is installed in the routing tables of the specified VPNs.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
· If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
· If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
Follow these guidelines when you configure BFD for IPv6 static routes:
· If you specify a source IPv6 address for BFD packets on the local device, you must specify that IPv6 address as the next hop IPv6 address on the peer device.
· If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡ The address is the same as the IPv6 address of the output interface.
¡ The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
· Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see High Availability Configuration Guide.
· The next hop IPv6 address of echo packets must be a global unicast address.
To specify the recursive-lookup host-route keyword, you must use the ipv6 nd route-direct advertise command to enable ND direct route advertisement to advertise 128-bit host routes on the following interfaces:
· The output interface corresponding to the next hop of the static route.
· The peer interface connected to the output interface.
For IPv6 static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
A recursion loop occurs when an IPv6 static route recurses to a related route whose destination address contains the destination address of the IPv6 static route. For example, a recursion loop occurs when the IPv6 static route destined for 4::2/64 recurses to a related route whose destination address is 4::2/48.
· If the recursive-lookup keyword is not specified, the recursion loop results in route recursion failure. The device further looks up for a related route.
· If the recursive-lookup keyword is specified, the device determines that the recursion succeeds if the output interface of the related route is an interface directly connected to the device.
If the output interface of an IPv6 static route is found through recursion loops, routing protocols on the device cannot advertise the IPv6 static route to other devices.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive. You cannot specify both of the keywords.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
ipv6 nd route-direct advertise (Layer 3—IP Services Command Reference)
ipv6 route-static default-preference
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
ipv6 route-static nd-request
Use ipv6 route-static nd-request to enable periodic sending of ND requests to the next hops of IPv6 static routes.
Use undo ipv6 route-static nd-request to disable periodic sending of ND requests to the next hops of IPv6 static routes.
ipv6 route-static nd-request [ interval interval ]
Periodic sending of ND requests to the next hops of IPv6 static routes is disabled.
interval: Specifies an ND request sending interval in the range of 1 to 300 seconds. The default value is 5.
When the following conditions exist, a recursive IPv6 static route becomes inactive:
· The IPv6 static route uses a host route to reach its direct next hop.
· The host route is obtained by specifying the recursive-lookup host-route keyword in the ipv6 route-static command or by routing policy-based recursive lookup.
· The host route is unavailable because no ND entry exists for that host route on the device.
To resolve this issue, you can use this command to enable the device to periodically send ND requests to the direct next hop. When the device receives an ND response from the direct next hop, it stops sending ND requests and activates the recursive IPv6 static route.
This command applies only to a recursive IPv6 static route that meets the following requirements:
· The IPv6 static route has no output interface specified.
· The IPv6 static route fails the next-hop recursion.
For more information about ND, see IPv6 neighbor discovery in Layer 3—IP Services Configuration Guide.
# Enable sending of ND requests to the next hops of IPv6 static routes and set the sending interval to 10 seconds.
[Sysname] ipv6 route-static nd-request interval 10
ipv6 route-static
protocol nexthop recursive-lookup
