- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-Dual-stack PBR commands
| 07-Policy-based routing commands | 111.95 KB |
display ip policy-based-route global
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
reset ip policy-based-route statistics
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops.
Use undo apply loadshare to restore the default.
apply loadshare next-hop
undo apply loadshare next-hop
Multiple next hops operate in primary/backup mode.
Policy node view
next-hop: Enables load sharing among multiple next hops.
Multiple next hop options operate in either primary/backup or load sharing mode.
· Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over.
· Load sharing mode—Matching traffic is distributed across the available options. Mulitple next hops load share traffic in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
# Enable load sharing among multiple next hops.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
apply next-hop
apply mirror-to-destination
Use apply mirror-to-destination to set a mirroring action that mirrors packets to the specified destination IP address.
Use undo apply mirror-to-destination to restore the default.
apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ip-address [ source-ip source-ip-address ] [ dscp dscp-value ]
undo apply mirror-to-destination [ vpn-instance vpn-instance-name ] destination-ip-address
The mirroring action is not set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. If the destination IP address belongs to the public network, do not specify this option.
destination-ip-address: Specifies the destination IP address encapsulated in the outer header of mirrored packets.
source-ip source-ip-address: Specifies the source IP address encapsulated in the outer header of mirrored packets. If you do not specify this option, the primary IP address for the output interface of the mirrored packets is encapsulated.
dscp dscp-value: Specifies the DSCP value encapsulated in the outer header of mirrored packets. The value range for the dscp-value argument is 0 to 63, and the default value is 63.
This command enables the device to mirror packets to a specific destination device through a tunnel (for example, a GRE tunnel) for packet analysis and monitoring. The device will encapsulate the parameters set for this command in the outer header of the mirrored packets.
This apply clause is always executed for packets matching the policy node.
# Set a mirroring action by specifying source IP address 2.2.2.2 and destination IP address 1.1.1.1 in the outer header of mirrored packets.
[Sysname-pbr-aa-11] apply mirror-to-destination 1.1.1.1 source-ip 2.2.2.2
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-patch-index ] ] }&<1-6>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-6> ]
No next hops are set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ip-address: Specifies the IP address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
service-chain path-id service-path-id: Specifies a service chain by its path ID. A path ID uniquely identifies a service chain, and its value range is 1 to 16777215.
path-index service-path-index: Specifies a node in the service chain as a next hop by its index in the range of 1 to 255.
&<1-6>: Indicates that the argument before it can be entered up to six times.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
To set multiple next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
· If the next hops are used in different service chains, use the apply next-hop command to specify the service chain parameters.
· If the next hops are used in the same service chain, use the apply service-chain command to specify the service chain parameters as a best practice.
· On a policy node, you cannot configure both the apply next-hop command with the service chain parameters and the apply service-chain command.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
apply service-chain
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface null 0
undo apply output-interface [ null 0 ]
No output interfaces are set.
Policy node view
null 0: Specifies the Null 0 interface.
# Specify Null 0 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface null 0
apply service-chain
Use apply service-chain to set service chain information.
Use undo apply service-chain to restore the default.
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
Policy node view
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 16777215. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
# Set service chain path ID 1 and node index 10.
[Sysname] policy-based-route aa permit node 5
[Sysname-pbr-aa-5] apply service-chain path-id 1 path-index 10
description
Use description to configure a description for a policy node.
No description is configured for a policy node.
Policy node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] policy-based-route 1 permit node 1
[Sysname-pbr-1-1] description Officeuse
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
policy-based-route
Use display ip policy-based-route global to display information about global PBR, including its configuration and statistics.
display ip policy-based-route global [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information about global PBR on the master device.
# Display information about global PBR.
<Sysname> display ip policy-based-route global
Global policy-based routing information:
Policy name: aaa
node 0 deny:
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 2.2.2.2
node 5 permit:
if-match acl 3101
Total matches: 0, total bytes: 0
Global policy-based routing information |
Global PBR configuration and statistics. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy and then apply it again. |
node 0 deny node 2 permit |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. |
if-match acl |
apply next-hop |
apply output-interface XXXX track 1 |
Specifies an output interface for permitted packets. This field displays the interface status in brackets. · down—The interface is down at the network layer. · inactive—The card that hosts the interface is not in position. |
Matches |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. |
bytes |
Number of matching bytes on the node. |
Total matches |
Total number of successful matches on all nodes. |
total bytes |
Total number of matching bytes on all nodes. |
ip global policy-based-route
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on the master device.
# Display PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ip policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for interface XXXX |
PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
apply next-hop |
Matches |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
bytes |
Total matches |
total bytes |
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays local PBR configuration and statistics for the master device.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for local |
Local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node: permit or deny. |
if-match acl |
apply next-hop |
Matches |
Number of successful matches on the node. |
bytes |
Total matches |
total bytes |
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy name Type Interface
pr01 Forward Vlan-interface2
aaa Local N/A
pr01 Global N/A
Table 5 Command output
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. · Global—Global PBR. |
Interface where the policy is applied. This field displays N/A for local PBR and global PBR. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
When setting an ACL match criterion, follow these restrictions and guidelines:
· If the specified ACL does not exist or has no rules configured, all packets will match the ACL.
· If the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public network and private network packets.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
if-match service-chain
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain path-id service-path-id [ path-index service-patch-index ]
undo if-match service-chain [ path-id service-path-id ]
No service chain match criteria are set.
Policy node view
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr-aa-5] if-match service-chain path-id 1 path-index 10
Use ip global policy-based-route to specify a PBR policy as the global PBR policy.
Use undo ip global policy-based-route to restore the default.
ip global policy-based-route policy-name
No policy is specified for global PBR.
policy-name: Specifies a PBR policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Global PBR guides the forwarding of packets on all interfaces of the device.
You can specify only one policy for global PBR on the device. Before you apply a new policy, you must first remove the current policy.
Interface PBR takes precedence over global PBR on an interface. When they are both configured and packets fail to match the interface PBR policy, global PBR applies.
# Specify PBR policy aaa for global PBR.
[Sysname] ip global policy-based-route aaa
policy-based-route
ip local policy-based-route
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is specified for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
policy-based-route
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ip policy-based-route aaa
policy-based-route
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
· If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
· If a match mode is specified, the command deletes all nodes configured with the match mode.
· If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
