01-Fundamentals Command Reference
HomeSupportSwitchesS5560X-EI SeriesReference GuidesCommand ReferencesH3C S5560X-EI & S5500V2-EI & MS4520V2 & ES5500 Command References- R6615Pxx-6W10101-Fundamentals Command Reference
09-Automatic configuration commands
09-Automatic configuration commands 32.38 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is supported only if the device has a USB interface.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
  • Become a Partner
  • Partner Resources
