- 07-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-EIGRP configuration
- 07-BGP configuration
- 08-Policy-based routing configuration
- 09-IPv6 static routing configuration
- 10-RIPng configuration
- 11-OSPFv3 configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
- 14-MTR configuration
- 15-RIR configuration
02-Static routing configuration | 234.56 KB |
Configuring a static route group
Configuring the DHCP-designated default router as the next hop of a static route
Configuring BFD for static routes
Configuring BFD control packet mode
Configuring BFD echo packet mode
Restrictions and guidelines for static route FRR
Configuring static route FRR by specifying a backup next hop
Configuring static route FRR to automatically select a backup next hop
Enabling BFD echo packet mode for static route FRR
Enabling LDP and static route synchronization
Allowing static routes to recurse to LSP tunnels
Display and maintenance commands for static routing
Static route configuration examples
Example: Configuring basic static routes
Example: Configuring BFD for static routes (direct next hop)
Example: Configuring BFD for static routes (indirect next hop)
Example: Configuring static route FRR
Configuring static routing
About static routes
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
1. Enter system view.
2. Configure a static route.
Public network:
ip route-static dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured.
You can associate Track with a static route to monitor the reachability of the next hops. For more information about Track, see High Availability Configuration Guide.
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
MTR:
ip route-static topology topo-name dest-address { mask-length | mask } { next-hop-address | interface-type interface-number [ next-hop-address ] } [ preference preference ] [ tag tag-value ] [ description text ]
3. (Optional.) Configure the default preference for static routes.
ip route-static default-preference default-preference
The default setting is 60.
This task allows you to batch create static routes with different prefixes but the same output interface and next hop.
You can create a static route group, and specify the static group in the ip route-static command. All prefixes in the static route group will be assigned the next hop and output interface specified in the ip route-static command.
2. Create a static route group and enter its view.
ip route-static-group group-name
By default, no static route group is configured.
3. Add a static route prefix to the static route group.
prefix dest-address { mask-length | mask }
By default, no static route prefix is added to the static route group.
4. Return to system view.
5. Configure a static route.
Public network:
ip route-static group group-name { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name group group-name { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
MTR:
ip route-static topology topo-name group group-name { next-hop-address | interface-type interface-number [ next-hop-address ] } [ preference preference ] [ tag tag-value ] [ description text ]
After an interface obtains an IP address and gateway address through DHCP, the device automatically generates a static route with the interface as the output interface. The destination address of the static route is 0.0.0.0/0 and the next hop of the static route is the default router (the gateway address designated by the DHCP server). This static route cannot form ECMP routes with manually configured static routes. The device uses this static route to guide traffic forwarding only after the manually configured static routes become invalid.
Perform this task to use both the automatically generated static route and the manually configured static routes to guide traffic forwarding. The task is applicable when the device has dual egress WAN links.
This task enables the device to automatically generate a static route destined for the specified network with the DHCP-designated default router of the output interface as the next hop. This static route takes effect only after the output interface obtains an IP address and gateway address through DHCP, and becomes invalid upon the DHCP lease expiration. The next hop of this static route changes as the gateway address of the output interface changes. In addition, this static route can form ECMP routes with manually configured static routes.
When you configure the next hop of a static route as the DHCP-designated default router, make sure the output interface of the static route is a broadcast interface.
2. Configure a static route and specify the default router designated by the DHCP server for the output interface as the next hop of the static route.
Public network:
ip route-static { dest-address { mask-length | mask } | group group-name } interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured with the DHCP-designated default router as the next hop.
Deleting static routes
To delete a static route, use the undo ip route-static command. To delete all static routes including the default route, use the delete static-routes all command.
2. Delete all static routes.
Public network:
VPN:
delete vpn-instance vpn-instance-name static-routes all
MTR:
delete topology topo-name static-routes all
CAUTION: This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network. |
IMPORTANT: Enabling BFD for a flapping route could worsen the situation. |
About BFD
BFD provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and MPLS.
For more information about BFD, see High Availability Configuration Guide.
This mode uses BFD control packets to detect the status of a link bidirectionally at a millisecond level.
BFD control packet mode can be applied to static routes with a direct next hop or with an indirect next hop.
Restrictions and guidelines for BFD control packet mode
If you use BFD control packet mode at the local end, you must use this mode also at the peer end.
Configuring BFD control packet mode for a static route (direct next hop)
2. Configure BFD control packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { control-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { control-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control packet mode for a static route is not configured.
Configuring BFD control packet mode for a static route (indirect next hop)
Public network:
ip route-static dest-address { mask-length | mask } { next-hop-address bfd control-packet bfd-source ip-address | vpn-instance d-vpn-instance-name next-hop-address bfd { control-packet bfd-source ip-address | static session-name } } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { next-hop-address bfd { control-packet bfd-source ip-address | static session-name } | vpn-instance d-vpn-instance-name next-hop-address bfd { control-packet bfd-source ip-address | static session-name } } [ preference preference ] [ tag tag-value ] [ description text ]
With BFD echo packet mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
You do not need to configure BFD echo packet mode at the peer end.
Do not use BFD for a static route with the output interface in spoofing state.
2. Configure the source address of echo packets.
bfd echo-source-ip ip-address
By default, the source address of echo packets is not configured.
For more information about this command, see High Availability Command Reference.
3. Configure BFD echo packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { echo-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number { dhcp | next-hop-address } bfd { echo-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo packet mode for a static route is not configured.
About static route FRR
A link or router failure on a path can cause packet loss. Static route fast reroute (FRR) enables fast rerouting to minimize the impact of link or node failures.
As shown in Figure 1, upon a link failure, packets are directed to the backup next hop to avoid traffic interruption. You can either specify a backup next hop for FRR or enable FRR to automatically select a backup next hop (which must be configured in advance).
Do not use static route FRR and BFD (for a static route) at the same time.
Equal-cost routes do not support static route FRR.
Besides the configured static route for FRR, the device must have another route to reach the destination. When the state of the primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down, static route FRR quickly redirects traffic to the backup next hop. When the Layer 3 interfaces of the primary link are down, static route FRR temporarily redirects traffic to the backup next hop. In addition, the device searches for another route to reach the destination and redirects traffic to the new path if a route is found. If no route is found, traffic interruption occurs.
A static route does not take effect when the backup output interface is unavailable.
To change the backup output interface or next hop, you must first remove the current setting. The backup output interface and next hop must be different from the primary output interface and next hop.
2. Configure static route FRR.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number [ { dhcp | next-hop-address } [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ { dhcp | next-hop-address } [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
MTR:
ip route-static topology topo-name dest-address { mask-length | mask } { next-hop-address | interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number backup-nexthop backup-nexthop-address ] ] } [ preference preference ] [ tag tag-value ] [ description text ]
By default, static route FRR is disabled.
2. Configure static route FRR to automatically select a backup next hop.
ip route-static fast-reroute auto
By default, static route FRR is disabled from automatically selecting a backup next hop.
By default, static route FRR uses ARP to detect primary link failures. Perform this task to enable static route FRR to use BFD echo packet mode for fast failure detection on the primary link.
2. Configure the source IP address of BFD echo packets.
By default, the source IP address of BFD echo packets is not configured.
The source IP address cannot be on the same network segment as any local interface's IP address.
3. Enable BFD echo packet mode for static route FRR.
ip route-static primary-path-detect bfd echo
By default, BFD echo packet mode for static route FRR is disabled.
When LDP establishes LSPs based on static routes, if LDP and the static routes are not synchronized, MPLS traffic forwarding might be interrupted.
LDP is not synchronized with a static route when one of the following situations occurs:
· A static route uses a link in up state, but the LDP LSP on this link has not been established.
· A static route uses a link on which an LDP session is down and LDP LSPs on the link have been removed.
After LDP and static route synchronization is enabled, a static route becomes Active only when LDP is converged on the link used by the static route. Before LDP convergence is completed, the static route is in Inactive state. In this way, the device can avoid discarding MPLS packets when no LDP LSP is established on the static route.
On a network where primary and backup LDP LSPs are established based on static routes, LDP and static route synchronization helps minimize traffic interruption when the primary LSP fails:
1. When the primary LSP fails, LDP and static route synchronization places the static route of the primary LSP to Inactive state. MPLS traffic is switched to the backup LSP.
2. LDP and static route synchronization keeps the Inactive route state during the recovery of the primary LSP.
3. After the primary LSP completely recovers, LDP and static route synchronization places the static route to Active state, and then MPLS traffic is switched back to the primary LSP.
LDP and static route synchronization allows the primary LSP and the static route to become available synchronously. This ensures that when MPLS traffic arrives, the LSP has been established, so as to avoid MPLS traffic loss.
2. Enable LDP and static route synchronization.
Public network:
ip route-static { dest-address { mask-length | mask } | group group-name } interface-type interface-number [ dhcp | next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] ldp-sync [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ dhcp | next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] ldp-sync [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number [ dhcp | next-hop-address ] [ bfd { control-packet | echo-packet } | backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] ] ldp-sync [ preference preference ] [ tag tag-value ] [ description text ]
By default, LDP and static route synchronization is disabled.
Devices in the service provider network will learn a large number of routes if they perform IP forwarding for all customer network packets. To conserve resources on the devices, use this feature on the device through which customer network users access the service provider network. This feature allows static routes to recurse to LSP tunnels. As a result, devices in the provider network will forward customer network IP packets based on labels, without the need to learn customer network routes.
This feature allows a device to preferentially recurse static routes to LSP tunnels. If a static route cannot recurse to an LSP tunnel, the device recurses the static route to an output interface and next hop.
2. Enable the device to recurse static routes to LSP tunnels.
ip route-static recursive-lookup tunnel [ prefix-list ipv4-prefix-list-name ] [ tunnel-policy tunnel-policy-name ]
By default, static routes cannot recurse to LSP tunnels.
Task |
Command |
Display static route information. |
display ip routing-table protocol static [ inactive | verbose ] |
Display static route next hop information. |
display route-static nib [ nib-id ] [ verbose ] |
Display static routing table information. |
display route-static routing-table [ topology topo-name ] [ ip-address { mask-length | mask } ] display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ] |
For more information about the display ip routing-table protocol static [ inactive | verbose ] command, see basic IP routing in Layer 3—IP Routing Command Reference.
As shown in Figure 2, configure static routes on the routers for interconnections between any two hosts.
1. Configure IP addresses for interfaces. (Details not shown.)
2. Configure static routes:
# Configure a default route on Router A.
[RouterA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Router B.
<RouterB> system-view
[RouterB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[RouterB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Router C.
<RouterC> system-view
[RouterC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3. Configure the default gateways of Host A, Host B, and Host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
# Display the static route information on Router A.
[RouterA] display ip routing-table protocol static
Summary Count : 1
Static Routing table Status : <Active>
Summary Count : 1
0.0.0.0/0 Static 60 0 1.1.4.2 GE2/0/2
Static Routing table Status : <Inactive>
Summary Count : 0
# Display the static route information on Router B.
[RouterB] display ip routing-table protocol static
Summary Count : 2
Summary Count : 2
1.1.2.0/24 Static 60 0 1.1.4.1 GE2/0/1
1.1.3.0/24 Static 60 0 1.1.5.6 GE2/0/2
Summary Count : 0
# Use the ping command on Host B to test the reachability of Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test the reachability of Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 1.1.6.1
2 <1 ms <1 ms <1 ms 1.1.4.1
3 1 ms <1 ms <1 ms 1.1.2.2
Trace complete.
Configure the following, as shown in Figure 3:
· Configure a static route to subnet 120.1.1.0/24 on Router A.
· Configure a static route to subnet 121.1.1.0/24 on Router B.
· Enable BFD for both routes.
· Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on Router C.
When the link between Router A and Router B through the Layer 2 switch fails, BFD can detect the failure immediately. Router A then communicates with Router B through Router C.
Figure 3 Network diagram
Device |
IP address |
Router A |
GE2/0/1 |
12.1.1.1/24 |
Router A |
GE2/0/2 |
10.1.1.102/24 |
Router B |
GE2/0/1 |
12.1.1.2/24 |
Router B |
GE2/0/2 |
13.1.1.1/24 |
Router C |
GE2/0/1 |
10.1.1.100/24 |
Router C |
GE2/0/2 |
13.1.1.2/24 |
2. Configure static routes and BFD:
# Configure static routes on Route A and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[RouterA] interface gigabitethernet 2/0/1
[RouterA-GigabitEthernet2/0/1] bfd min-transmit-interval 500
[RouterA-GigabitEthernet2/0/1] bfd min-receive-interval 500
[RouterA-GigabitEthernet2/0/1] bfd detect-multiplier 9
[RouterA-GigabitEthernet2/0/1] quit
[RouterA] ip route-static 120.1.1.0 24 gigabitethernet 2/0/1 12.1.1.2 bfd control-packet
[RouterA] ip route-static 120.1.1.0 24 gigabitethernet 2/0/2 10.1.1.100 preference 65
[RouterA] quit
# Configure static routes on Router B and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[RouterB] interface gigabitethernet 2/0/1
[RouterB-GigabitEthernet2/0/1] bfd min-transmit-interval 500
[RouterB-GigabitEthernet2/0/1] bfd min-receive-interval 500
[RouterB-GigabitEthernet2/0/1] bfd detect-multiplier 9
[RouterB-GigabitEthernet2/0/1] quit
[RouterB] ip route-static 121.1.1.0 24 gigabitethernet 2/0/1 12.1.1.1 bfd control-packet
[RouterB] ip route-static 121.1.1.0 24 gigabitethernet 2/0/2 13.1.1.2 preference 65
[RouterB] quit
# Configure static routes on Router C.
[RouterC] ip route-static 120.1.1.0 24 13.1.1.1
[RouterC] ip route-static 121.1.1.0 24 10.1.1.102
# Display BFD sessions on Router A.
<RouterA> display bfd session
Total sessions: 1 Up sessions: 1 Init mode: Active
LD/RD SourceIP DestinationIP State Holdtime Interface
4/7 12.1.1.1 12.1.1.2 Up 2000ms GE2/0/1
The output shows that the BFD session has been created.
# Display static routes on Router A.
<RouterA> display ip routing-table protocol static
Summary Count : 1
Summary Count : 1
120.1.1.0/24 Static 60 0 12.1.1.2 GE2/0/1
Summary Count : 0
The output shows that Router A communicates with Router B through GigabitEthernet 2/0/1. Then the link over GigabitEthernet 2/0/1 fails.
Summary Count : 1
Summary Count : 1
120.1.1.0/24 Static 65 0 10.1.1.100 GE2/0/2
Summary Count : 0
The output shows that Router A communicates with Router B through GigabitEthernet 2/0/2.
Figure 4 shows the network topology as follows:
· Router A has a route to interface Loopback 1 (2.2.2.9/32) on Router B, with the output interface GigabitEthernet 2/0/1.
· Router B has a route to interface Loopback 1 (1.1.1.9/32) on Router A, with the output interface GigabitEthernet 2/0/1.
· Router D has a route to 1.1.1.9/32, with the output interface GigabitEthernet 2/0/1, and a route to 2.2.2.9/32, with the output interface GigabitEthernet 2/0/2.
Configure the following:
· Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on both Router C and Router D.
When the link between Router A and Router B through Router D fails, BFD can detect the failure immediately. Router A then communicates with Router B through Router C.
Device |
IP address |
Router A |
GE2/0/1 |
12.1.1.1/24 |
Router A |
GE2/0/2 |
10.1.1.102/24 |
Router A |
Loopback 1 |
1.1.1.9/32 |
Router B |
GE2/0/1 |
11.1.1.2/24 |
Router B |
GE2/0/2 |
13.1.1.1/24 |
Router B |
Loopback 1 |
2.2.2.9/32 |
Router C |
GE2/0/1 |
10.1.1.100/24 |
Router C |
GE2/0/2 |
13.1.1.2/24 |
Router D |
GE2/0/1 |
12.1.1.2/24 |
Router D |
GE2/0/2 |
11.1.1.2/24 |
# Configure static routes on Router A and enable BFD control packet mode for the static route that traverses Router D.
[RouterA] bfd multi-hop min-transmit-interval 500
[RouterA] bfd multi-hop min-receive-interval 500
[RouterA] bfd multi-hop detect-multiplier 9
[RouterA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[RouterA] quit
# Configure static routes on Router B and enable BFD control packet mode for the static route that traverses Router D.
[RouterB] bfd multi-hop min-transmit-interval 500
[RouterB] bfd multi-hop min-receive-interval 500
[RouterB] bfd multi-hop detect-multiplier 9
[RouterB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[RouterB] quit
# Configure static routes on Router D.
<RouterD> system-view
[RouterD] ip route-static 120.1.1.0 24 11.1.1.2
[RouterD] ip route-static 121.1.1.0 24 12.1.1.1
# Display the BFD session information on Router A.
4/7 1.1.1.9 2.2.2.9 Up 2000ms N/A
Summary Count : 1
Summary Count : 1
Summary Count : 0
Summary Count : 1
Summary Count : 1
Summary Count : 0
As shown in Figure 5, configure static routes on Router A, Router B, and Router C, and configure static route FRR. When Link A becomes unidirectional, traffic can be switched to Link B immediately.
Table 3 Interface and IP address assignment
Device |
IP address |
Router A |
GE2/0/1 |
12.12.12.1/24 |
Router A |
GE2/0/2 |
13.13.13.1/24 |
Router A |
Loopback 0 |
1.1.1.1/32 |
Router B |
GE2/0/1 |
24.24.24.4/24 |
Router B |
GE2/0/2 |
13.13.13.2/24 |
Router B |
Loopback 0 |
4.4.4.4/32 |
Router C |
GE2/0/1 |
12.12.12.2/24 |
Router C |
GE2/0/2 |
24.24.24.2/24 |
2. Configure static route FRR on link A by using one of the following methods:
¡ (Method 1.) Specify a backup next hop for static route FRR:
# Configure a static route on Router A, and specify GigabitEthernet 2/0/1 as the backup output interface and 12.12.12.2 as the backup next hop.
[RouterA] ip route-static 4.4.4.4 32 gigabitethernet 2/0/2 13.13.13.2 backup-interface gigabitethernet 2/0/1 backup-nexthop 12.12.12.2
# Configure a static route on Router B, and specify GigabitEthernet 2/0/1 as the backup output interface and 24.24.24.2 as the backup next hop.
[RouterB] ip route-static 1.1.1.1 32 gigabitethernet 2/0/2 13.13.13.1 backup-interface gigabitethernet 2/0/1 backup-nexthop 24.24.24.2
¡ (Method 2.) Configure static route FRR to automatically select a backup next hop:
# Configure static routes on Router A, and enable static route FRR.
[RouterA] ip route-static 4.4.4.4 32 gigabitethernet 2/0/1 12.12.12.2 preference 70
[RouterA] ip route-static fast-reroute auto
# Configure static routes on Router B, and enable static route FRR.
[RouterB] ip route-static 1.1.1.1 32 gigabitethernet 2/0/1 24.24.24.2 preference 70
[RouterB] ip route-static fast-reroute auto
3. Configure static routes on Router C.
[RouterC] ip route-static 4.4.4.4 32 gigabitethernet 2/0/2 24.24.24.4
[RouterC] ip route-static 1.1.1.1 32 gigabitethernet 2/0/1 12.12.12.1
# Display route 4.4.4.4/32 on Router A to view the backup next hop information.
[RouterA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
TableID: 0x2 OrigAs: 0
NibID: 0x26000002 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1008c OrigNextHop: 13.13.13.2
Label: NULL RealNextHop: 13.13.13.2
BkLabel: NULL BkNextHop: 12.12.12.2
SRLabel: NULL Interface: GigabitEthernet2/0/2
BkSRLabel: NULL BkInterface: GigabitEthernet2/0/1
SIDIndex: NULL InLabel: NULL
Tunnel ID: Invalid IPInterface: GigabitEthernet2/0/2
BkTunnel ID: Invalid BkIPInterface: GigabitEthernet2/0/1
FtnIndex: 0x0 ColorInterface: N/A
TrafficIndex: N/A BkColorInterface: N/A
Connector: N/A VpnPeerId: N/A
Dscp: N/A Exp: N/A
SRTunnelID: Invalid StatFlags: 0x0
SID Type: N/A SID: N/A
BkSID: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid
# Display route 1.1.1.1/32 on Router B to view the backup next hop information.
[RouterB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
Protocol: Static
Process ID: 0
Cost: 0 Preference: 10
Flags: 0x1008c OrigNextHop: 13.13.13.1
Label: NULL RealNextHop: 13.13.13.1
BkLabel: NULL BkNextHop: 24.24.24.2
Dscp: N/A Exp: N/A
BkFlushNID: Invalid
Configuring a default route
A default route is used to forward packets that do not match any specific routing entry in the routing table. Without a default route, packets that do not match any routing entries are discarded and an ICMP destination-unreachable packet is sent to the source.
A default route can be configured in either of the following ways:
· The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see "Configuring static routing."
· Some dynamic routing protocols (such as OSPF, IS-IS, and RIP) can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers. These routers install the default route with the next hop being the upstream router. For more information, see the respective chapters on these routing protocols in this configuration guide.
