- 05-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
11-IPv6 policy-based routing commands | 116.97 KB |
apply default-output-interface
apply fail-action-drop next-hop
display ipv6 policy-based-route
display ipv6 policy-based-route apply
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
reset ipv6 policy-based-route statistics
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-2> ]
No default next hop is set.
IPv6 policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ipv6-address: Specifies the IPv6 address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered up to two times.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface interface-type interface-number [ track track-entry-number ]
undo apply default-output-interface [ interface-type interface-number ]
No default output interface is set.
# Specify VLAN-interface 2 as the default output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply default-output-interface vlan-interface 2
Use apply fail-action-drop next-hop to set the action that drops matching packets when all next hops on an IPv6 policy node are invalid.
Use undo apply fail-action-drop next-hop to restore the default.
The drop action is not configured. The matching packets are forwarded based on the typical packet forwarding process if all next hops on the IPv6 policy node are invalid.
By default, the device uses the typical packet forwarding process to route matching packets when all next hops on the IPv6 policy node are unavailable. To drop all matching packets when all next hops on the IPv6 policy node are unavailable, use this command. This command is typically used in scenarios that require strict routing paths.
If no next hops are specified on the IPv6 policy node, this command drops all packets that match the node.
This command does not apply to software-forwarded packets.
# Set next hop 1::1 on IPv6 policy node 10 and configure the IPv6 policy node to drop matching packets when the next hop is invalid.
[Sysname] ipv6 policy-based-route policy1 permit node 10
[Sysname-pbr6-policy1-1] apply next-hop 1::1
[Sysname-pbr6-policy1-1] apply fail-action-drop next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] } &<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-2> ]
No next hop is set.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1::1.
[Sysname-pbr6-aa-11] apply next-hop 1::1
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface interface-type interface-number [ track track-entry-number ]
undo apply output-interface [ interface-type interface-number ]
No output interface is set.
# Specify VLAN-interface 2 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface vlan-interface 2
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
description
Use description to configure a description for an IPv6 policy node.
No description is configured for an IPv6 policy node.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for IPv6 policy node 1.
[Sysname] ipv6 policy-based-route 1 permit node 1
[Sysname-pbr6-1-1] description Officeuse
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
apply next-hop 1000::1
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares IPv6 packets with IPv6 ACL. |
apply next-hop |
Specifies a next hop for permitted IPv6 packets. |
Use display ipv6 policy-based-route apply to display the IPv6 PBR configuration and statistics for a VLAN interface.
In standalone mode:
display ipv6 policy-based-route apply vlan-interface interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route apply vlan-interface interface-number [ chassis chassis-number slot slot-number ]
vlan-interface interface-number: Specifies a VLAN interface by its number.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for the specified VLAN interface on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for the specified VLAN interface on the global active MPU. (In IRF mode.)
This command displays configuration and statistics for IPv6 PBR that is configured with the ipv6 policy-based-route apply command. To display configuration and statistics for IPv6 PBR that is configured in VLAN interface view, use the display ipv6 policy-based-route interface command.
# Display the IPv6 PBR configuration and statistics for VLAN-interface 100.
<Sysname> display ipv6 policy-based-route apply vlan-interface 100
Policy-based routing information for Vlan-interface 100:
Policy name: aaa
node 2 permit:
if-match acl 3000
apply next-hop 2::2
Matched: 0
Total matched: 0
Policy-based routing information for Vlan-interface xxx |
IPv6 PBR configuration and statistics for the VLAN interface. |
node 2 permit |
Match mode of the node: permit. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
Matched: 0 |
Number of successful matches on the node. |
Total matched |
Total number of successful matches on all nodes. |
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ipv6 policy-based-route interface Vlan-inerface2
Policy based routing information for interface Vlan-inerface2:
Policy name: aaa
node 0 deny(not support):
Matched: 0
node 1 permit:
if-match acl 3999
Matched: 0
node 2 permit(no resource):
if-match acl 2000
apply output-interface Vlan-inerface3 track 1 (down)
apply output-interface Vlan-inerface4 track 2 (inactive)
Matched: 0
node 5 permit:
if-match acl 3101
Matched: 0 (no statistics resource)
Total matched: 0
Policy based routing information for interface XXXX (failed) |
IPv6 PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
node 0 deny(not support) node 2 permit(no resource) |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
Compares IPv6 packets with the IPv6 ACL. |
apply next-hop |
apply output-interface track 1 (down) |
Specifies an output interface for permitted packets. The interface status includes the following: · up—The interface is up. · down—The interface is down at network layer. · inactive—The interface is not in position. |
Matched: 0 (no statistics resource) |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
Total matched |
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route local [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
Matched: 0
node 1 permit:
if-match acl 3999
Matched: 0
node 2 permit:
if-match acl 2000
apply next-hop 1::1
Matched: 0
node 5 permit:
if-match acl 3101
apply next-hop 2::2
Matched: 0
Total matched: 0
Table 5 Command output
Policy based routing information for local |
IPv6 local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node, permit or deny. |
if-match acl |
apply next-hop |
Matched: 0 |
Total matched |
ipv6 local policy-based-route
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name Type Interface
pr01 Forward Vlan-interface 2
pr02 Local N/A
Table 6 Command output
Policy name |
Policy name. |
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. |
Interface where the policy is applied. This field displays N/A for IPv6 local PBR. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic or advanced ACL.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name [ share-mode ]
No IPv6 policy is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
share-mode: Applies the IPv6 policy in resource sharing mode. In this mode, all interfaces on an interface card with the same IPv6 policy applied share one hardware resource. If you do not specify this keyword, each interface occupies one independent hardware resource. You can apply only one ACL, QoS policy, or PBR policy with the share-mode keyword specified to one direction of an interface. For information about ACL and QoS policies, see ACL commands and QoS policy commands in ACL and QoS Command Reference.
You can set only one mode for the policy on an interface. Before you change the mode of the policy, you must first remove the current policy from the interface.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 2047.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use ipv6 policy-based-route apply to specify an IPv6 policy for a list of VLAN interfaces.
Use undo ipv6 policy-based-route apply to restore the default.
ipv6 policy-based-route policy-name apply vlan-interface interface-list &<1-8>
undo ipv6 policy-based-route policy-name apply [ vlan-interface interface-list &<1-8> ]
No IPv6 policy is specified for the VLAN interfaces.
policy-name: Specifies an IPv6 policy by its name, a case-sensitive string of 1 to 19 characters. The IPv6 policy must already exist.
vlan-interface interface-list: Specifies a space-separated list of up to eight VLAN interface items. Each item specifies a VLAN interface or a range of VLAN interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for interface-number2 must be greater than or equal to the value for interface-number1. The interface type is VLAN interface.
You cannot specify different policies for a VLAN interface. You can use either of the following commands to specify a policy for a VLAN interface:
· ipv6 policy-based-route apply
· ipv6 policy-based-route (interface view)
To specify an IPv6 policy for multiple VLAN interfaces, you can use either of the following methods:
· Method 1—Execute the ip policy-based-route apply command. The policy is issued to the driver for all interfaces at the same time. This method reduces hardware entries and saves system resources. You can use this method to specify an IPv6 policy for VLAN interfaces that do not exist.
· Method 2—Use the interface range command to create an interface range, and specify a policy for the interface range. The policy is issued to the driver for each interface. The system creates a hardware entry for each interface.
# Specify IPv6 policy aaa for VLAN-interface 100 through VLAN-interface 200.
[Sysname] ipv6 policy-based-route aaa apply vlan-interface 100 to 200
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
