- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-GIR commands
- 10-Preprovisioning commands
- 11-Device management commands
- 12-Tcl commands
- 13-Python commands
- 14-License management commands
14-License management commands | 71.68 KB |
All commands in this chapter are supported only on the default MDC. Features licensed to the default MDC are also licensed to non-default MDCs. For information about MDCs, see Virtual Technologies Configuration Guide.
display license
Use display license to display detailed license information.
In standalone mode:
display license [ activation-file ]
In IRF mode:
display license [ activation-file ] [ chassis chassis-number ]
activation-file: Displays license information about activation files.
chassis chassis-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices. (In IRF mode.)
# (In standalone mode.) Display detailed information about all licenses.
<Sysname> display license
flash:/license/210231S12500XSUPSUPC2015010415352158495.ak
Feature: LISP EVB evi mdc SPBM TRILL FCoE
Product Description: H3C S12500X Advanced Data Center License
Registered at: 2021-10-11 14:49:17
License Type: Permanent
Current State: In use
Feature |
Feature name. The device does not support the LISP, EVB, EVI, SPBM, or TRILL feature in the current software version. |
Product Description |
License description. |
Registered at |
Time when the license was installed. |
License Type |
License type by validity period: · NA—The system cannot obtain the license type. · Permanent—Purchased license that never expires and is always valid. · Days restricted—Purchased license that is valid for a period of days, for example, 30 days. · Date restricted—Purchased license that is valid for an absolute date range, for example, 2013-05-01 to 2013-05-30. · Trial (days restricted)—Free trial license that is valid for a period of days. · Trial (date restricted)—Free trial license that is valid for an absolute date range. |
Time Left (days) |
Remaining days of the license. This field is available for a purchased license. |
Trial Time Left (days) |
Remaining days of the trial period. This field is available for a trial license. |
Validity Period |
Start date and end state for a date restricted purchased license. If the license is permanent, this field displays No limit. |
Trial Validity Period |
Start date and end state for a date restricted trial license. If the license is permanent, this field displays No limit. |
Current State |
State of the license: · In use—The license is being used. · Usable—The license is available for use. ¡ If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state. ¡ A date restricted license is in this state if its start date is not reached. · Expired—The license has expired. · Uninstalled—The license has been uninstalled. · Unusable—The license cannot be used. · Invalid—The license is invalid and cannot be used. |
Uninstall Key |
Uninstall key. This field is available for licenses that have been uninstalled. |
Uninstall Date |
Date when the activation file was uninstalled. |
display license device-id
Use display license device-id to display SN and DID information.
In standalone mode:
In IRF mode:
display license device-id chassis chassis-number
chassis chassis-number: Specifies the member ID of an IRF member device. (In IRF mode.)
Each device has a unique SN and DID. When you register a license for a device, you must provide its SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# (In standalone mode.) Display the device SN and DID.
<Sysname> display license device-id
SN: 210235A1LFX176000002
Device ID:jFvq-zRGA-DpJy-VK@d-$Zz+-QjA7-$pLP-xvzR
display license feature
Use display license feature to display brief license information for features.
# (In standalone mode.) Display brief feature license information.
<Sysname> display license feature
Total: 5 Usage: 5
Feature Licensed State
EVB Y Formal
FCoE Y Formal
LISP Y Formal
OPENXCVR Y Formal
SPBM Y Formal
TRILL Y Formal
evi Y Formal
mdc Y Formal
Total |
Total number of licenses that can be installed. |
Usage |
Number of licenses stored in the license storage. |
Feature |
Feature that must be licensed before being used. The device does not support FCoE, EVB, TRILL, or EVI in the current software version. |
Licensed |
Licensing state of the feature: · N—Not licensed. · Y—Licensed. |
State |
License type by purchasing state: · Formal—Purchased license. · Trial—Trial license. If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file. |
license activation-file install
Use license activation-file install to install an activation file.
In standalone mode:
license activation-file install file-name
In IRF mode:
license activation-file install file-name chassis chassis-number
file-name: Specifies the file path, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
(In standalone mode.) License registration requires the device's hardware SN and DID.
In IRF mode:
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the IRF member device.
A licensed feature can run on the IRF member device where its activation file is installed even after the IRF member device joins another IRF fabric.
# (In standalone mode.) Install activation file 20130810.ak.
[Sysname] license activation-file install flash:/license/20130810.ak
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...
display license
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
In standalone mode:
license activation-file uninstall file-name
In IRF mode:
license activation-file uninstall file-name chassis chassis-number
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# (In standalone mode.) Uninstall activation file flash:/license/20130810.ak.
[Sysname] license activation-file uninstall flash:/license/20130810.ak
Uninstall file: flash:/license/20130810.uak
display license
license compress
Use license compress to compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress chassis chassis-number
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# (In standalone mode.) Compress the license storage.
[Sysname] license compress
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
