- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-Crypto engine commands
- 23-FIPS commands
- 24-Microsegmentation commands
- 25-Object group commands
- 26-SAVI commands
- 27-SAVA commands
20-uRPF commands | 47.87 KB |
uRPF commands
display ip urpf
Use display ip urpf to display uRPF configuration.
display ip urpf [ interface interface-type interface-number ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays uRPF configuration for all member devices.
# Display uRPF configuration for the specified slot.
<Sysname> display ip urpf slot 1
Global uRPF configuration information(failed):
Check type: strict
Allow default route
(failed) |
The system failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources. This field is not displayed if the delivery is successful. |
Check type |
uRPF check mode: loose or strict. |
Allow default route |
Using the default route is allowed. |
ip urpf
Use ip urpf to enable uRPF.
Use undo ip urpf to disable uRPF.
ip urpf { loose [ allow-default-route ] | strict [ allow-default-route ] }
undo ip urpf
uRPF is disabled.
Interface view
loose: Enables loose uRPF check. To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry.
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
allow-default-route: Allows using the default route for uRPF check.
uRPF can be deployed on a PE connected to a CE or an ISP, or on a CE.
Configure strict uRPF check for traffic that uses symmetric path and configure loose uRPF check for traffic that uses asymmetric path. A symmetric path exists for a session if the PE uses the same interface to receive upstream traffic and send downstream traffic. The path is asymmetric if the PE uses different interfaces to receive upstream traffic and send downstream traffic.
· Typically, symmetric path applies to traffic that goes through an ISP's PE interface connected to the CE. You can configure strict uRPF check on the PE interface.
· Asymmetric path might exist for traffic that goes through a PE interface connected to another ISP. In this case, configure loose uRPF check on the PE interface.
Typically, you do not need to configure the allow-default-route keyword on a PE device, because it has no default route pointing to a CE. If you enable uRPF on a CE interface and the CE interface has a default route pointing to the PE, specify the allow-default-route keyword.
# Enable strict uRPF check globally.
[Sysname] ip urpf strict
# Configure loose uRPF check on VLAN-interface 10.
[Sysname-Vlan-interface10] ip urpf loose
display ip urpf
