- 08-Security Configuration Guide
- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Web authentication configuration
- 06-Port security configuration
- 07-User profile configuration
- 08-Password control configuration
- 09-Keychain configuration
- 10-Public key management
- 11-PKI configuration
- 12-IPsec configuration
- 13-SSH configuration
- 14-SSL configuration
- 15-Attack detection and prevention configuration
- 16-TCP attack prevention configuration
- 17-IP source guard configuration
- 18-ARP attack protection configuration
- 19-ND attack defense configuration
- 20-MFF configuration
- 21-Crypto engine configuration
- 22-FIPS configuration
- 23-Object group configuration
- 24-SAVI configuration
- 25-SAVA configuration
23-Object group configuration | 52.66 KB |
Restrictions: Software version compatibility with object group
Configuring an IPv4 address object group
Configuring an IPv6 address object group
Configuring a port object group
Display and maintenance commands for object groups
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
· IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
· IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
· Port object group—A group of port objects used to match the protocol port number in a packet.
This feature is supported only in Release 6616P01 and later.
1. Enter system view.
2. Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3. (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4. Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask } | group-object object-group-name }
2. Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3. (Optional.) Configure a description for the IPv6 address object group.
4. Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | group-object object-group-name }
2. Configure a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3. (Optional.) Configure a description for the port object group.
4. Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
Task |
Command |
Display information about object groups. |
display object-group [ { { ip | ipv6 } address | port } [ default ] [ name object-group-name ] | name object-group-name ] |
