- 02-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Bulk interface configuration
- 03-Ethernet interface configuration
- 04-Ethernet link aggregation configuration
- 05-DRNI configuration
- 06-Port isolation configuration
- 07-VLAN configuration
- 08-MVRP configuration
- 09-Loopback, null, and inloopback interface configuration
- 10-Loop detection configuration
- 11-Spanning tree configuration
- 12-LLDP configuration
- 13-L2PT configuration
- 14-Service loopback group configuration
- 15-Layer 2 forwarding configuration
14-Service loopback group configuration | 50.58 KB |
Configuring service loopback groups
Restrictions and guidelines: Service loopback group configuration
Configuring a service loopback group
Display and maintenance commands for service loopback groups
Service loopback group configuration examples
Example: Configuring a service loopback group
About service loopback groups
A service loopback group provides one of the following services:
· Tunnel—Supports unicast tunnel services.
· Multicast tunnel—Supports multicast tunnel services.
· Multiport—Supports multiport ARP services.
· Telemetry stream—Supports Telemetry streaming services.
When you add member ports to a service loopback group, follow these restrictions and guidelines:
· Make sure the ports support the service type of the service loopback group and are not members of any other service loopback group.
· The configuration on a port is removed when it is assigned to the service loopback group.
· For correct traffic processing, make sure the service loopback group has a minimum of one member port when it is being used by a feature.
When you apply service loopback groups to features, follow these restrictions and guidelines:
· One service loopback group can be used by multiple features.
· You cannot change the service type of a service loopback group.
· Do not delete a service loopback group that is being used by a feature.
1. Enter system view.
2. Create a service loopback group and specify its service type.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | telemetry-stream }
You can configure only one service loopback group for a service type.
3. Enter Layer 2 Ethernet interface view.
4. Assign the port to the service loopback group.
port service-loopback group group-id
By default, a port does not belong to a service loopback group.
You can assign a maximum of 64 ports to a service loopback group.
Task |
Command |
Display information about service loopback groups. |
display service-loopback group [ group-id ] |
All Ethernet ports on the device support unicast tunnel services. Assign HundredGigE 1/1/1 through HundredGigE 1/1/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
# Create service loopback group 1, and specify its service type as tunnel.
[Sysname] service-loopback group 1 type tunnel
# Assign HundredGigE 1/1/1 through HundredGigE 1/1/3 to service loopback group 1.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/1/1] quit
[Sysname] interface hundredgige 1/1/2
[Sysname-HundredGigE1/1/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/1/2] quit
[Sysname] interface hundredgige 1/1/3
[Sysname-HundredGigE1/1/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-HundredGigE1/1/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
