03-Telemetry stream commands | 69.37 KB |
Telemetry stream and INT are mutually exclusive on the device.
You can enable sampling for only one of the following features on the device:
· Telemetry stream.
· NetStream.
· IPv6 NetStream.
· Mirroring.
· sFlow.
· INT.
For more information about NetStream, IPv6 NetStream, mirroring, and sFlow, see Network Management and Monitoring Configuration Guide. For more information about INT, see Telemetry Configuration Guide.
display telemetry stream
Use display telemetry stream to display telemetry stream configuration.
# Display telemetry stream configuration.
[Sysname] display telemetry stream
Telemetry stream status : Enabled
Telemetry stream timestamp status: Disabled
Telemetry stream device ID : 10.0.0.3
Telemetry stream action:
HundredGigE1/1/1:
Telemetry stream action 1:
ACL : user-defined abc
Sampler: samp
Telemetry stream action 2:
ACL : user-defined abcd
Sampler: samp
Telemetry stream collector:
Source IP : 20.0.0.2
Destination IP : 30.0.0.1
Source port : 12
Destination port: 14
VPN instance : abc
Destination MAC : 0CDA-411D-9F4C
VLAN ID : 20
Output Index : 2
Truncation : Enable
Telemetry stream status |
Telemetry stream status: · Enabled. · Disabled. |
Telemetry stream timestamp status |
Telemetry stream timestamp status: · Enabled. · Disabled. |
Telemetry stream action |
Telemetry stream action: · Inactive indicates that the action is not issued because telemetry stream is disabled. · Failed indicates that the action fails to be issued. |
Telemetry stream collector |
Encapsulation parameters for telemetry stream packets. The following fields appear only if telemetry stream timestamp is disabled: · Destination MAC. · VLAN ID. · Output Index—Output interface index. · Truncation—This field is displayed only if the packet truncation function is enabled. This value is supported only in Release 6635 and later. The Destination MAC, VLAN ID, and Output Index fields appear only if telemetry stream timestamp is disabled. |
telemetry stream action
Use telemetry stream action to configure a telemetry stream action.
Use undo telemetry stream action to delete a telemetry stream action.
telemetry stream action action-id [ acl [ mac | user-defined ] { acl-number | name acl-name } | sampler sampler-name ] *
undo telemetry stream action action-id
No telemetry stream action is configured.
action-id: Specifies an action ID in the range of 1 to 32.
acl: Specifies an ACL.
· mac: Specifies the Layer 2 ACL type.
· user-defined: Specifies the user-defined ACL type.
· acl-number: Specifies the ACL number. The following are available value ranges:
¡ 2000 to 2999 for basic ACLs.
¡ 3000 to 3999 for advanced ACLs.
¡ 4000 to 4999 for Layer 2 ACLs.
¡ 5000 to 5999 for user-defined ACLs.
· name acl-name: Specifies the ACL name, a case-insensitive string of 1 to 63 characters.
sampler sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a sampler, all matching packets are copied.
When receiving a packet on an interface configured with a telemetry stream action, the device performs the following operations:
1. Copies the packet.
2. Encapsulates the copied packet with the configured addressing parameters.
3. Sends it to the collector.
Specifying an ACL limits telemetry stream to the traffic that matches the ACL. To specify an IPv4 ACL, do not specify the mac or user-defined keyword. To specify a Layer 2 or user-defined ACL, you must specify the mac or user-defined keyword before specifying the ACL number or name.
If the specified ACL does not exist or does not contain rules, no packets match the ACL and no packets are copied.
Specifying a sampler reduces the number of packets copied and sent to the collector, but provides less granular monitoring.
If you configure multiple telemetry stream actions on an interface, you can only specify the same sampler for all of them.
# Configure telemetry stream action 1 on HundredGigE 1/1/1 to use sampler samp.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] telemetry stream 1 sampler samp
telemetry stream collector
Use telemetry stream collector to configure the addressing parameters to encapsulate in telemetry stream packets sent to the collector.
Use undo telemetry stream collector to restore the default.
telemetry stream collector source source-address destination destination-address source-port source-port destination-port destination-port [ vpn-instance vpn-instance-name ] [ truncation ]
No addressing parameters are configured for telemetry stream packets.
source source-address: Specifies the source IP address for telemetry stream packets.
destination destination-address: Specifies the destination IP address for telemetry stream packets.
source-port source-port: Specifies the source port number for telemetry stream packets.
destination-port destination-port: Specifies the destination port number for telemetry stream packets.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the device forwards the telemetry stream packets to the collector according to the routes of the public network.
truncation: Enables packet truncation. If you do not specify this keyword, packet truncation is disabled.
NOTE: The truncation keyword is supported only in Release 6635 and later. |
The device uses the addressing parameters to route the telemetry stream packets to the collector.
The destination IP address must be the IP address of the collector, and the destination port number must be the listening port number on the collector.
The vpn-instance vpn-instance-name option of this command is mutually exclusive with the telemetry stream timestamp enable command.
The packet truncation function truncates the packets before sending them to the collector. The truncated packets retain complete input interface, output interface, and timestamp information.
# Specify source IP address 10.10.10.10, destination IP address 20.20.20.20, source port number 10, and destination port number 20 for telemetry stream packets.
[Sysname] telemetry stream collector source 10.10.10.10 destination 20.20.20.20 source-port 10 destination-port 20
telemetry stream device-id
Use telemetry stream device-id to specify a device ID.
Use undo telemetry stream device-id to restore the default.
telemetry stream device-id address
No device ID is specified.
address: Specifies an IPv4 address as the device ID. You can specify any IPv4 address other than 0.0.0.0. The specified IP address is encapsulated in a copied packet for the collector to identify the source of the packet.
This command takes effect only if telemetry stream timestamp is enabled.
# Specify IPv4 address 10.10.10.10 as the device ID.
[Sysname] telemetry stream device-id 10.10.10.10
telemetry stream enable
Use telemetry stream enable to enable telemetry stream.
Use undo telemetry stream enable to disable telemetry stream.
Telemetry stream is enabled.
# Enable telemetry stream.
[Sysname] telemetry stream enable
Use telemetry stream timestamp enable to enable telemetry stream timestamping.
Use undo telemetry stream timestamp enable to disable telemetry stream timestamping.
Telemetry stream timestamping is disabled.
This command enables the device to add to a copied packet the timestamps when the original packet enters and leaves the device.
This command is mutually exclusive with the vpn-instance vpn-instance-name option in the telemetry stream collector command.
This command takes effect only after you create a service loopback group and assign a Layer 2 Ethernet interface to the group. For more information about service loopback groups, see Layer 2—LAN Switching Configuration Guide.
# Enable telemetry stream timestamping.
[Sysname] telemetry stream timestamp enable
service-loopback group (Layer 2—LAN Switching Command Reference)
