HomeSupportConfigure & DeployConfiguration GuidesH3C S6805 & S6825 & S6850 & S9850 Configuration Guides-Release 66xx-6W10301-Fundamentals Configuration Guide
15-GIR configuration
15-GIR configuration 68.69 KB
Configuring graceful insertion and removal
About graceful insertion and removal
Graceful insertion and removal (GIR) enables you to gracefully isolate the device from the network for device maintenance or upgrade. GIR minimizes service interruption by instructing the affected protocols (for example, routing protocols) to isolate the device and switch over to the redundant path. You do not need to configure graceful switchover protocol by protocol.
GIR modes
The device can operate in either of the following GIR modes:
·     Normal mode—The device can forward traffic.
·     Maintenance mode—The device is gracefully placed out of service for maintenance or upgrade purposes. In this mode, the device cannot forward traffic.
How GIR works
After you place the device in maintenance mode, GIR instructs each affected protocol (for example, BGP) to remove the device from the traffic path. Then, each protocol takes action as instructed to isolate the device and switch over to the redundant path.
To record the configuration before and after a GIR operation, GIR takes a snapshot of protocol data when the device enters maintenance mode and when the device changes back to normal mode. You can compare the snapshots to verify configuration data consistency for each protocol. GIR supports the following protocols: LACP, BGP, IS-IS, OSPF, and OSPFv3. For more information about how each protocol isolates the device, see its configuration guide.
GIR snapshots
GIR snapshots record the state and running data of the device in NETCONF format.
When the device enters maintenance mode, it generates a GIR snapshot named before_maintenance before each protocol switches over to the redundant path.
When the device returns to normal mode, it generates a GIR snapshot named after_maintenance immediately after all protocols insert the device back into the traffic path.
The device stores only the snapshots for the most recent GIR operation.
You can identify the configuration differences of the device before and after a GIR operation by comparing the two snapshots.
Software version compatibility with GIR
This feature is supported only in Release 6635 and later.
Restrictions and guidelines: GIR configuration
In GIR, the supported protocols automatically execute commands to achieve traffic switchover. Unsupported protocols cannot achieve traffic switchover through GIR.
Placing the device in maintenance mode
Perform this task before you maintain or upgrade the device.
The device enters maintenance mode regardless of whether a protocol has failed in switchover. The failure of one protocol in switchover does not affect other protocols.
To maintain configuration data consistency, do not modify the configuration for any affect protocols after you place the device in maintenance mode. If you modify the configuration of a protocol, the new configuration will overwrite the original configuration after the device changes back to normal mode.
If the device is comparing snapshots, you must wait the comparison to end before you can change the GIR mode.
1.     Verify that the system is stable.
display system stable state
The system is stable if the System State field displays Stable. For a successful GIR operation, you must make sure the system is stable.
2.     Enter system view.
3.     Place the device in maintenance mode.
gir system-mode maintenance
CAUTION
CAUTION:
·     Packet loss might occur during mode switching.
·     Do not restart the device or a process while GIR is switching mode. The system cannot roll back settings issued during mode switching. If you restart the device or a disruptive process, mode switching will be interrupted, with only some of the commands issued.
4.     If a protocol fails in switchover, use the following methods to identify and remove the issue:
¡     Remove the issue based on the error message.
¡     Compare the snapshots to identify configuration inconsistencies that might cause the issue.
Identify snapshot information:
display gir snapshot
Compare the snapshots:
display gir snapshot compare snapshot1-name snapshot2-name [ verbose ]
5.     Verify that no traffic traverses the device before you maintain or upgrade the device.
display counters
This command is available in any view. This step prevents the packet loss that might occur because a protocol is slow or fails in switchover.
Changing the device back to normal mode
Perform this task after you maintain or upgrade the device.
The device changes back to normal mode regardless of whether a protocol has failed in switchover. The failure of one protocol in switchover does not affect other protocols.
Before you change a DRNI system back to normal mode, execute the display drni mad verbose command to verify that no network interfaces are in DRNI MAD DOWN state. For more information about DRNI, see Layer 2—LAN Switching Configuration Guide.
3.     Change the device back to normal mode.
undo gir system-mode maintenance
CAUTION
CAUTION:
Identify the snapshot names:
Display and maintenance commands for GIR
Display all snapshots on the device.
Compare snapshots to view their differences.
Display the current GIR mode.
display gir system-mode
  • Become a Partner
  • Partner Resources
