- 16-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-NTP commands
- 05-SNMP commands
- 06-RMON commands
- 07-Event MIB commands
- 08-Sampler commands
- 09-Mirroring commands
- 10-NetStream commands
- 11-IPv6 NetStream commands
- 12-sFlow commands
- 13-CWMP commands
- 14-PTP commands
09-Mirroring commands | 120.33 KB |
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 31.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
remote-destination: Specifies remote destination groups.
remote-source: Specifies remote source groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Sampler: samp (failed)
Mirroring port: HundredGigE1/0/1 Inbound
Monitor port: HundredGigE1/0/2 truncation
Mirroring group |
Number of the mirroring group. |
Type |
Type of the mirroring group: · Local. · Remote source. · Remote destination. |
Status |
Status of the mirroring group: · Active—The mirroring group has taken effect. · Incomplete—The mirroring group configuration is not complete and does not take effect. |
Sampler |
Sampler name. · If the mirroring group failed to use the sampler, this field displays sampler-name (failed). · If no sampler is configured, this field is not displayed. |
Mirroring port |
Source port. |
Mirroring CPU |
Source CPU. |
Monitor port |
Destination port. If truncation is displayed, the feature of truncating mirrored packets is enabled on the destination port. |
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id { local | remote-destination | remote-source } [ sampler sampler-name ]
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is 1 to 31.
sampler sampler-name: Specifies a sampler to be used by its name. The sampler-name argument is a case-insensitive string of 1 to 31 characters.
A sampler selects a packet from sequential packets. Port mirroring uses the sampler to limit the volume of traffic to be mirrored. You can specify a sampler that has not been created for a mirroring group. If you configure multiple samplers for a mirroring group, the most recent configuration takes effect. For more information about samplers, see Network Management and Monitoring Configuration Guide.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu
Use mirroring-group mirroring-cpu to configure source CPUs for a mirroring group.
Use undo mirroring-group mirroring-cpu to remove source CPUs from a mirroring group.
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu slot slot-number-list
No source CPU is configured for a mirroring group.
group-id: Specifies a mirroring group by its number. The specified mirroring group must already exist. The value range for this argument is 1 to 31.
slot slot-number-list: Specifies a space-separated list of up to eight slot number items. An item specifies a card by its slot number or specifies a range of cards in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number.
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
You can configure source CPUs only for local mirroring groups and remote source groups.
# Create local mirroring group 1 to monitor the inbound traffic of the CPU on the specified slot.
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
mirroring-group
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
You can configure source ports only for local mirroring groups and remote source groups.
Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
A port can act as a source port for only one mirroring group.
A source port cannot be used as a reflector port, monitor port, or egress port.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] mirroring-group 1 mirroring-port both
# Create remote source group 2 to monitor the bidirectional traffic of the port HundredGigE 1/0/2.
[Sysname] mirroring-group 2 remote-source
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] mirroring-group 2 mirroring-port both
mirroring-group
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of HundredGigE 1/0/1.
[Sysname] mirroring-group 1 mirroring-port hundredgige 1/0/1 both
# Create remote source group 2 to monitor the bidirectional traffic of HundredGigE 1/0/2.
[Sysname] mirroring-group 2 mirroring-port hundredgige 1/0/2 both
mirroring-group
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
· Spanning tree.
· Static ARP.
· MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
The member port of an aggregate interface cannot be configured as an egress port.
# Create remote source group 1. Configure HundredGigE 1/0/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress hundredgige 1/0/1
# Create remote source group 2. Configure HundredGigE 1/0/2 as its egress port in interface view.
[Sysname-HundredGigE1/0/2] mirroring-group 2 monitor-egress
mirroring-group
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port [ truncation ]
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
truncation: Truncates the specified length of a mirrored packet from the specified start position and sends the truncated part to the monitor port. For inbound mirroring, 220 bytes are truncated from the start of a packet. For outbound mirroring, n bytes are truncated from the start of a packet, where n is in the range of 128 to 256 and depends on the system header length.
You can configure monitor ports only for local mirroring groups and remote destination groups.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not perform either of the following tasks:
· Configure its member ports as source ports of the mirroring group.
For a Layer 2 or Layer 3 aggregate interface configured as the monitor port of a mirroring group, do not configure its member ports as source ports of the mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
With the truncation keyword specified, only the truncated part is sent to the data monitoring device. In this way, you can reduce the packet processing workload on the data monitoring device or prevent the payload in packets from be sent to the data monitoring device.
Only local mirroring groups support mirrored packet truncation.
To modify the mirrored packet truncation configuration, you must first execute the undo mirroring-group monitor-port command.
# Create local mirroring group 1 and configure HundredGigE 1/0/1 as its monitor port.
[Sysname-HundredGigE1/0/1] mirroring-group 1 monitor-port
# Create remote destination group 2 and configure HundredGigE 1/0/2 as its monitor port.
[Sysname] mirroring-group 2 remote-destination
[Sysname-HundredGigE1/0/2] mirroring-group 2 monitor-port
mirroring-group
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-list [ truncation ]
undo mirroring-group group-id monitor-port interface-list
No monitor port is configured for a mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not perform any of the following tasks:
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port hundredgige 1/0/1
[Sysname] mirroring-group 2 monitor-port hundredgige 1/0/2
# Create local mirroring group 3 and configure ports HundredGigE 1/0/1 through HundredGigE 1/0/3 and HundredGigE 1/0/5 as its monitor ports.
[Sysname] mirroring-group 3 local
[Sysname] mirroring-group 3 monitor-port hundredgige 1/0/1 to hundredgige 1/0/3 hundredgige 1/0/5
mirroring-group
Use mirroring-group reflector-port to configure the reflector port for a remote source group.
Use undo mirroring-group reflector-port to restore the default.
In system view:
mirroring-group group-id reflector-port interface-type interface-number
undo mirroring-group group-id reflector-port interface-type interface-number
In interface view:
No reflector port is configured for a mirroring group.
Interface view
CAUTION: · The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port. · When a port is configured as a reflector port, the port restores to the factory default settings. You cannot configure other features on a reflector port. |
You can configure reflector ports only for remote source groups.
You cannot change the duplex mode, MDI settings, or speed for a reflector port.
The member port of an aggregate interface cannot be configured as a reflector port.
# Create remote source group 1. Configure HundredGigE 1/0/1 as its reflector port in system view.
[Sysname] mirroring-group 1 reflector-port hundredgige 1/0/1
# Create remote source group 2. Configure HundredGigE 1/0/2 as its reflector port in interface view.
[Sysname-HundredGigE1/0/2] mirroring-group 2 reflector-port
mirroring-group
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
display monitoring-group
Use display monitoring-group to display monitoring group information.
display monitoring-group { group-id | all }
group-id: Specifies a monitoring group by its number. The value range for this argument is 1 to 31.
all: Specifies all monitoring groups.
# Display information about all monitoring groups.
<Sysname> display monitoring-group all
Monitoring group 1:
Truncation : Enabled
Monitoring ports:
HundredGigE1/0/4
HundredGigE1/0/5
Monitoring group |
ID of the monitoring group. |
Truncation |
Mirrored packet truncation status: · Enabled. · Disabled. |
Monitoring ports |
Monitoring ports in the monitoring group. |
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to ifa-processor
Use mirror-to ifa-processor to configure a mirroring action that mirrors traffic to the in-band network telemetry (INT) processor.
Use undo mirror-to ifa-processor to delete the mirroring action that mirrors traffic to the INT processor.
mirror-to ifa-processor [ sampler sampler-name ]
No mirroring action exists to mirror traffic to the INT processor.
sampler sampler-name: Specifies a sampler by its name. The sampler-name argument is a case-insensitive string of 1 to 31 characters. If you do not specify this option, packets are not sampled, and all matching packets are mirrored.
A sampler selects a packet from sequential packets. Flow mirroring uses the sampler to limit the volume of traffic to be mirrored. Flow mirroring supports using a sampler that has not been created. If you specify a sampler for a mirroring action multiple times, the most recent configuration takes effect. For more information about samplers, see Network Management and Monitoring Configuration Guide.
Example
# Create traffic behavior 1 and configure the action of mirroring traffic to the INT processor. Specify sampler samp for the mirroring action.
[Sysname-behavior-1] mirror-to ifa-processor sampler samp
sampler (Network Management and Monitoring Command Reference)
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
You can mirror traffic to only one interface. If you execute this command for a traffic behavior multiple times, the most recent configuration takes effect.
You can mirror traffic to only one Ethernet interface.
The device does not support multicard mirroring. The mirroring source and destination must reside on the same card.
# Create traffic behavior 1 and configure the action of mirroring traffic to HundredGigE 1/0/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface hundredgige 1/0/1
mirror-to monitoring-group
Use mirror-to monitoring-group to configure a mirroring action that mirrors traffic to a monitoring group.
Use undo mirror-to monitoring-group to delete a mirroring action that mirrors traffic to a monitoring group.
mirror-to monitoring-group group-id
undo mirror-to monitoring-group group-id
No mirroring actions exist to mirror traffic to a monitoring group.
# Create traffic behavior b1 and configure the action of mirroring traffic to monitoring group 1.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] mirror-to monitoring-group 1
monitoring-group
Use monitoring-group to create a monitoring group and enter its view, or enter the view of an existing monitoring group.
Use undo monitoring-group to delete monitoring groups.
monitoring-group group-id [ sampler sampler-name ]
undo monitoring-group { group-id | all }
No monitoring groups exist.
group-id: Specifies a number for the monitoring group. The value range for this argument is 1 to 31.
sampler sampler-name: Specifies a sampler by its name, a case-insensitive string of 1 to 31 characters.
# Create monitoring group 1.
[Sysname] monitoring-group 1
# Create monitoring group 2 and reference sampler a.
[Sysname] monitoring-group 2 sampler a
monitoring-port
Use monitoring-port to assign ports to a monitoring group.
Use undo monitoring-port to remove ports from a monitoring group.
Syntax I
monitoring-port interface-list [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ] ]
undo monitoring-port interface-list [ destination-ip destination-ip-address source-ip source-ip-address ]
Syntax II
monitoring-port destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo monitoring-port destination-ip destination-ip-address source-ip source-ip-address
A monitoring group does not contain any ports.
Monitoring group view
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the start interface number must be identical to or lower than the end interface number.
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 3.
Table 3 DSCP keywords and values
Keyword |
DSCP value in binary |
DSCP value in decimal |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094 for the mirrored packets.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
destination-mac mac-address: Specifies the destination MAC address for mirrored packets. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to obtain the destination MAC address. If the destination MAC address cannot be obtained, the default MAC address 000f-e241-5e5b is used.
Use the ports in a monitoring group only for flow mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
If you use syntax 1 to assign multiple ports to a monitoring group, the device encapsulates a mirrored packet with the specified encapsulation parameters in a GRE packet with a protocol number of 0x88BE. Then, a copy of the packet is sent of each port in the monitoring group.
If you use syntax II, the device encapsulates a mirrored packet with the specified encapsulation parameters in a GRE packet with a protocol number of 0x88BE. Then, the device looks up the source IP address and destination IP address of the packet in the routing table and forwards the packet based on the matching route. The outgoing interface of the route is the destination interface of the mirrored packet.
Through configuring load sharing in the routing protocols, you can specify multiple destination interfaces for the mirrored traffic. When the current mirroring destination interface fails, the mirrored traffic is forwarded to the outgoing interface re-calculated by the routing protocols.
# Create monitoring group 1 and assign HundredGigE 1/0/1 and HundredGigE 1/0/2 to it.
[Sysname-monitoring-group-1] monitoring-port hundredgige 1/0/1 to hundredgige 1/0/2
# Create monitoring group 2 and encapsulate the mirrored packets with destination IP address 1.1.1.1, source IP address 2.2.2.2, DSCP value 20, and VLAN ID 100. Forward the mirrored packets based on the routing table of the VPN instance named vrf1.
[Sysname-monitoring-group-2] monitoring-port destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
# Create monitoring group 3 and assign HundredGigE 1/0/1 to the monitoring group. Encapsulate the mirrored packets with destination IP address 1.1.1.1, source IP address 2.2.2.2, DSCP value 20, and VLAN ID 100. Forward the mirrored packets based on the routing table of the VPN instance named vrf2.
[Sysname] monitoring-group 3
[Sysname-monitoring-group-3] monitoring-port hundredgige 1/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf2
monitoring-group
truncation enable
Use truncation enable to enable mirrored packet truncation for a monitoring group.
Use undo truncation enable to disable mirrored packet truncation for a monitoring group.
truncation enable
Mirrored packet truncation is enabled for a monitoring group.
This feature truncates the specified length of a mirrored packet from the specified start position and sends the truncated part to the monitor port. For inbound mirroring, 220 bytes are truncated from the start of a packet. For outbound mirroring, n bytes are truncated from the start of a packet, where n is in the range of 128 to 256 and depends on the system header length.
This feature reduces the packet processing pressure on the data monitoring device or prevents the device from sending packet payloads to the server.
# Enable packet truncation for monitoring group 1.
[Sysname-monitoring-group-1] truncation enable
monitoring-group
