- 06-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-Basic BGP commands
- 07-Advanced BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-DCN commands
08-Policy-based routing commands | 114.27 KB |
apply default-output-interface
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
ip policy-based-route-log enable
reset ip policy-based-route statistics
apply access-vpn vpn-instance
NOTE: This command is available in Release R5111 and later. |
Use apply access-vpn vpn-instance to set VPN instances.
Use undo apply access-vpn vpn-instance to remove VPN instances.
apply access-vpn vpn-instance vpn-instance-name
undo apply access-vpn vpn-instance [ vpn-instance-name ]
No VPN instances are specified for a node.
Policy node view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist.
You can specify a maximum of 1 VPN instances for a node. The matching packets are forwarded according to the forwarding table of the first available VPN instance.
With a VPN instance specified, the undo apply access-vpn vpn-instance command removes the VPN instance.
Without any VPN instance specified, the undo apply access-vpn vpn-instance command removes all VPN instances.
# Set VPN 1 for node 10. (VPN 1 already exist.)
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1
apply remark-vpn
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No default next hops are set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ip-address: Specifies the IP address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered up to two times.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }
undo apply default-output-interface [ interface-type interface-number]
No default output interfaces are set.
Policy node view
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and non-broadcast multi-access (NBMA) interfaces such as Ethernet and virtual-template interfaces. In NBMA networks, packets are sent in unicast.
With a default output interface specified, the undo apply default-output-interface command removes the default output interface.
Without any default output interface specified, the undo apply default-output-interface command removes all default output interfaces.
As a best practice, do not specify the interface of a VXLAN tunnel automatically created by EVPN for this command.
# Specify HundredGigE1/0/1 as the default output interface for IP packets.
[Sysname-pbr-aa-11] apply default-output-interface hundredgige 1/0/1
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No next hops are set.
Policy node view
ip-address: Specifies the IP address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }
undo apply output-interface [ interface-type interface-number ]
No output interfaces are set.
Policy node view
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
# Specify HundredGigE1/0/1 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface hundredgige 1/0/1
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
apply remark-vpn
NOTE: This feature is available in Release R5111 and later. |
Use apply remark-vpn to enable VPN remark action.
Use undo apply remark-vpn to restore the default.
apply remark-vpn
VPN remark action is not configured.
Policy node view
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of PBR handle the packets as belonging to the re-marked VPN instance.
If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received.
VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command.
# Forward packets that match ACL 3000 based on the forwarding table of VPN instance vpn1 and perform VPN remark action on the successfully forwarded packets.
[Sysname] policy-based-route aaa permit node 10
[Sysname-pbr-aaa-10] if-match acl 3000
[Sysname-pbr-aaa-10] apply access-vpn vpn-instance vpn1
[Sysname-pbr-aaa-10] apply remark-vpn
apply statistics
Use apply statistics to enable match counting on a policy node.
Use undo apply statistics to restore the default.
apply statistics
Match counting is disabled on a policy node.
Policy node view
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command. As a best practice to conserve hardware resources, disable this counting function.
This apply clause is always executed for the policy node.
After enabling match counting, you cannot specify the share-mode keyword when applying the policy to an interface for interface PBR.
# Enable match counting on policy node 11.
[Sysname-pbr-aa-11] apply statistics
description
Use description to configure a description for a policy node.
No description is configured for a policy node.
Policy node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] policy-based-route 1 permit node 1
[Sysname-pbr-1-1] description Officeuse
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
policy-based-route
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information on all cards.
# Display PBR configuration and statistics on HundredGigE 1/0/1.
<Sysname> display ip policy-based-route interface hundredgige 1/0/1
Policy based routing information for interface HundredGigE1/0/1:
Policy name: aaa
node 0 deny:
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 2.2.2.2
node 5 permit:
if-match acl 3101
apply output-interface HundredGigE1/0/2 track 1
apply output-interface HundredGigE1/0/3 track 2
Total matches: 0, total bytes: 0
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for interface XXXX(failed) |
PBR configuration and statistics on the
interface. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
node 0 deny(not support) node 2 permit(no resource) |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
apply next-hop |
apply output-interface track 1 (down) |
Specifies an output interface and its associated track entry for permitted packets. This field displays the interface status in brackets. · up—The interface is up. · down—The interface is down at network layer. · inactive—The card that hosts the interface is not in position. |
Matches: 0 (no statistics resource) |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
Bytes |
Number of matching bytes on the node. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on the node. |
Total matches |
Total number of successful matches on all nodes. This field displays N/A if the device does not support counting successful matches on a node. This field is not displayed if match counting is disabled on all nodes. |
total bytes |
Total number of matching bytes on all nodes. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on all nodes. |
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays local PBR configuration and statistics for the active MPU.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for local |
Local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node: permit or deny. |
if-match acl |
apply next-hop |
Matches |
Number of successful matches on the node. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. |
bytes |
Total matches |
total bytes |
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy name Type Interface
aaa Forward HundredGigE1/0/1
aaa Forward HundredGigE1/0/2
aaa Local N/A
Table 5 Command output
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. |
Interface where the policy is applied. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
ip local policy-based-route
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is referenced for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
Before you apply a new policy, you must first remove the current policy.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
policy-based-route
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name [ share-mode ]
No policy is applied to an interface.
Interface view
share-mode: Applies the policy in resource sharing mode. In this mode, all interfaces on an interface card with the same policy applied share one hardware resource. If you do not specify this keyword, each interface occupies one independent hardware resource. You can apply only one ACL, QoS policy, or PBR policy with the share-mode keyword specified to one direction of an interface. For information about ACL and QoS policies, see ACL commands and QoS policy commands in ACL and QoS Command Reference.
Typically, each interface on a card uses different hardware resources for a policy. To avoid resource usage overhead, you can specify the resource sharing mode when applying the policy to each interface. The interfaces will use the same hardware resources.
You cannot specify the share-mode keyword for the command if you have configured the apply statistics command for the policy.
You can specify only one mode for the policy on an interface. Before you change the mode of the policy, you must first remove the current policy from the interface.
# Apply policy aaa to HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ip policy-based-route aaa
policy-based-route
Use ip policy-based-route-log enable to enable the PBR logging feature.
Use undo ip policy-based-route-log enable to disable the PBR logging feature.
The PBR logging feature is disabled.
The PBR logging feature helps the administrator locate and fix faults. The feature logs PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see System Management Configuration Guide.
Excessive PBR log messages degrade the performance of the device. To avoid this problem, disable the PBR logging feature.
# Enable the PBR logging feature.
[Sysname] ip policy-based-route-log enable
apply next-hop
policy-based-route
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 255.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
· If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
· If a match mode is specified, the command deletes all nodes configured with the match mode.
· If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
