- 11-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PoE commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-NETCONF commands
- 10-SmartMC commands
- 11-EPA commands
- 12-CWMP commands
- 13-EAA commands
- 14-Process monitoring and maintenance commands
- 15-Mirroring commands
- 16-sFlow commands
- 17-Information center commands
- 18-Packet capture commands
- 19-VCF fabric commands
- 20-Cloud connection commands
- 21-EPS agent commands
- 22-eMDI commands
- 23-SQA commands
- 24-Sampler commands
- 25-NetStream commands
- 26-IPv6 NetStream commands
19-VCF fabric commands | 128.56 KB |
display vcf-fabric underlay autoconfigure
display vcf-fabric underlay template-version
vcf-fabric underlay netconf-username
vcf-fabric underlay netconf-password
vpn-target export-extcommunity
vpn-target import-extcommunity
VCF fabric commands
The ES5500, S5500V2-EI, and MS4520V2 switch series do not support VCF fabric.
border enable
Use border enable to enable the border node service.
Use undo border enable to disable the border node service.
border enable
undo border enable
The device is not a border node.
Neutron view
The external network and routers are created and deleted on the OpenStack Dashboard. Use this command to configure the device as a border node. The device automatically deploys the routing configurations made on the OpenStack Dashboard and implements connectivity between tenant networks and the external network.
On a VXLAN network with a centralized IP gateway or on a VLAN network, use this command on spine nodes. On a VXLAN network with distributed IP gateways, use this command on leaf nodes.
# Enable the border node service.
[Sysname] neutron
[Sysname-neutron] border enable
display vcf-fabric role
Use display vcf-fabric role to display the role of the device in the VCF fabric.
Use this command to display the default role and the current role of the device in the VCF fabric. To change the current role of the device, use the vcf-fabric role command.
# Display the role of the device in the VCF fabric.
<System> display vcf-fabric role
Default role: leaf
Current role: leaf
Default role |
Default role of the device: · spine—The device is a spine node. · aggr—The device is an aggregate node. · leaf—The device is a leaf node. · access—The device is an access node. |
Current role |
Current role of the device: · spine—The device is a spine node. · aggr—The device is an aggregate node. · leaf—The device is a leaf node. · access—The device is an access node. |
vcf-fabric role
display vcf-fabric topology
Use display vcf-fabric topology to display VCF fabric topology information.
This command displays VCF fabric topology information only when it is executed on the master spine node.
Before you display VCF fabric topology information, make sure VCF fabric topology discovery and automated underlay network deployment are enabled.
# Display VCF fabric topology information.
<Sysname> display vcf-fabric topology
Topology Information
* indicates the master spine role among all spines
SpineIP Interface Link LeafIP Status
*10.11.113.51 GigabitEthernet1/0/1 Up 10.11.113.52 Deploying
GigabitEthernet1/0/2 Down -- --
GigabitEthernet1/0/3 Down -- --
GigabitEthernet1/0/4 Down -- --
GigabitEthernet1/0/5 Up 10.11.113.53 Deploying
GigabitEthernet1/0/6 Down -- --
GigabitEthernet1/0/7 Down -- --
GigabitEthernet1/0/8 Down -- --
SpineIP |
IPv4 address of the management Ethernet interface on the spine node. This field displays an asterisk (*) before the IP address if the device is the master spine node. |
Interface through which the spine node connects to a leaf node. If the device is a master spine node, all interfaces on the device are displayed. |
Link |
Physical link state of the interface. |
LeafIP |
IPv4 address of the interface through which a leaf node connects to the spine node. |
Status |
Status of automated underlay network deployment on the leaf node. This field displays two hyphens (--) if automated underlay network deployment is not started. This field displays Deploying if automated underlay network deployment is in progress. |
vcf-fabric topology enable
Use display vcf-fabric underlay autoconfigure to display information about automated underlay network deployment.
Before you execute this command, make sure automated underlay network deployment is enabled.
# Display information about automated underlay network deployment.
<Sysname> display vcf-fabric underlay autoconfigure
success command:
system
clock timezone beijing add 08:00:00
system
lldp global enable
lldp compliance cdp
system
ospf 1
non-stop-routing
area 0.0.0.0
system
interface LoopBack0
system
l2vpn enable
system
vxlan tunnel arp-learning disable
system
ovsdb server ptcp port 6632
ovsdb server enable
system
vtep enable
system
stp global enable
system
ntp-service enable
ntp-service unicast-server 85.0.0.10 vpn-instance mgmt
system
netconf soap https enable
netconf ssh server enable
restful https enable
system
info-center loghost vpn-instance mgmt 85.0.0.10
system
local-user admin
password ******
service-type https
system
line vty 0 63
authentication-mode scheme
system
system
snmp-agent
snmp-agent community read public
snmp-agent community write private
snmp-agent sys-info version all
snmp-agent packet max-size 4096
snmp-agent target-host trap address udp-domain 85.0.0.10 params secur
ityname public v2c
snmp-agent target-host trap address udp-domain 85.0.0.10 vpn-instance
mgmt params securityname public v2c
system
telnet server enable
local-user admin
password ******
service-type telnet http https
system
ssh server enable
local-user admin
password ******
service-type ssh http https
system
netconf soap http enable
local-user admin
password ******
service-type http https
system
bgp 100
non-stop-routing
address-family l2vpn evpn
Uplink interface:
Ten-GigabitEthernet1/0/25
Ten-GigabitEthernet1/0/26
Ten-GigabitEthernet5/0/25
Ten-GigabitEthernet5/0/26
Downlink interface:
GigabitEthernet1/0/19
GigabitEthernet5/0/19
GigabitEthernet5/0/20
Aggregation configurations:
AggrID: 1024
interface: GigabitEthernet1/0/19
interface: GigabitEthernet5/0/19
IRF allocation:
Self Bridge Mac: 00e7-fc52-5100
IRF Status: Yes
Member List: [1, 5]
BFD Mad-port pairs: GE1/0/17 , GE5/0/18
BGP peer configuration:
145.16.17.253
145.16.17.254
success command |
Commands that have been successfully executed during automated underlay network deployment. |
Uplink interface |
Uplink interfaces of the device. |
Downlink interface |
Downlink interfaces of the device. |
Loopback0 IP allocation |
IP addresses assigned to Loopback 0. |
Loopback1 IP allocation |
IP addresses assigned to Loopback 1. |
Aggregation configuration |
Information about Layer 2 aggregation groups. |
IRF allocation |
IRF configurations, including IRF bridge MAC address of the IRF fabric, IRF status, and the IRF member ID of the device. |
BGP peer configuration |
Information about BGP peers of the device. NOTE: BGP peer information on all spine and leaf nodes is displayed only when this command is executed on the master spine node in a spine-aggregate-leaf VCF fabric. |
Use display vcf-fabric underlay template-version to display the supported version and the current version of the template file for automated VCF fabric deployment.
The version format of a template file for automated VCF fabric deployment is x.y. Only the x part is examined during a version compatibility check. For successful automated deployment, make sure x in the version of the template file to be used is not greater than x in the supported version.
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment is not started.
<Sysname> display vcf-fabric underlay template-version
Supported template version: 6.0
Current template version: Not available
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment has finished.
Current template version: 6.0
Supported template version |
Supported version of the template file for automated VCF fabric deployment. |
Current template version |
Current version of the template file for automated VCF fabric deployment. This field displays Not available if automated VCF fabric deployment has not started. This field displays None if automated VCF fabric deployment has finished but the template file does not contain a version number. |
gateway ip
Use gateway ip to specify the IPv4 address of the border gateway.
Use undo gateway ip to restore the default.
gateway ip ipv4-address
undo gateway ip
No IPv4 address is specified for the border gateway.
Neutron view
ipv4-address: Specifies the IPv4 address of the border gateway.
Use this command to specify the border gateway IP address for VMs to access the external network. On a VXLAN network with a centralized IP gateway or on a VLAN network, use this command on spine nodes. On a VXLAN network with distributed IP gateways, use this command on leaf nodes.
If you configure this command multiple times, the most recent configuration takes effect.
# Specify IPv4 address 100.1.1.1 for the border gateway.
[Sysname] neutron
[Sysname-neutron] gateway ip 100.1.1.1
l2agent enable
Use l2agent enable to enable Layer 2 (L2) agent.
Use undo l2agent enable to disable L2 agent.
l2agent enable
undo l2agent enable
L2 agent is disabled.
Neutron view
On a VLAN network, use this command on spine nodes and leaf nodes.
On a VXLAN network with a centralized IP gateway, use this command on spine nodes and leaf nodes.
# Enable L2 agent.
[Sysname] neutron
[Sysname-neutron] l2agent enable
l3agent enable
Use l3agent enable to enable Layer 3 (L3) agent.
Use undo l3agent enable to disable L3 agent.
l3agent enable
undo l3agent enable
L3 agent is disabled.
Neutron view
On a VLAN network or on a VXLAN network with a centralized IP gateway, use this command only on spine nodes.
# Enable L3 agent.
[Sysname] neutron
[Sysname-neutron] l3agent enable
network-type
Use network-type to specify the network type.
Use undo network-type to restore the default.
network-type { centralized-vxlan | distributed-vxlan | vlan }
undo network-type
The network type is VLAN.
Neutron view
centralized-vxlan: Specifies the VXLAN network with a centralized IP gateway.
distributed-vxlan: Specifies the VXLAN network with distributed IP gateways.
vlan: Specifies the VLAN network.
# Specify the network type as VXLAN network with a centralized IP gateway.
[Sysname] neutron
[Sysname-neutron] network-type centralized-vxlan
neutron
Use neutron to enable Neutron and enter Neutron view.
Use undo neutron to disable Neutron and delete all configurations in Neutron view.
neutron
undo neutron
Neutron is disabled.
# Enable Neutron and enter Neutron view.
[Sysname] neutron
[Sysname-neutron]
proxy-arp enable
Use proxy-arp enable to enable local proxy ARP for VSI interfaces.
Use undo proxy-arp enable to restore the default.
proxy-arp enable
Local proxy ARP is disabled for VSI interfaces. The device uses ARP flood suppression entries to answer ARP requests for MAC addresses of VMs on a different site from the requesting VMs.
Neutron view
Use this command only on leaf nodes on a VXLAN network with distributed IP gateways.
This feature enables the device to use the MAC address of VSI interfaces to answer ARP requests for MAC addresses of VMs on a different site from the requesting VMs. To configure the MAC address of VSI interfaces, use the vsi-mac command.
This command takes effect on VSI interfaces that are created after this command is executed. It does not take effect on existing VSI interfaces.
# Enable local ARP proxy for VSI interfaces.
[Sysname] neutron
[Sysname-neutron] proxy-arp enable
rabbit durable-queue enable
Use rabbit durable-queue enable to enable creation of RabbitMQ durable queues.
Use undo rabbit durable-queue enable to disable creation of RabbitMQ durable queues.
Creation of RabbitMQ durable queues is disabled. RabbitMQ non-durable queues are created and stored in the memory of RabbitMQ servers.
Neutron view
In a Neutron network, the device communicates with the Neutron server through RabbitMQ to obtain the configuration for deploying the overlay network. You must configure RabbitMQ server-related settings on the device and make sure the settings are the same as those on the Neutron server. If the durable attribute of RabbitMQ queues is set on the Neutron server, you must enable creation of RabbitMQ durable queues on the device so that RabbitMQ queues can be correctly created. The created RabbitMQ durable queues are stored in the disk of the RabbitMQ servers.
# Enable creation of RabbitMQ durable queues.
[Sysname] neutron
[Sysname-neutron] rabbit durable-queue enable
rabbit host
Use rabbit host to specify the IPv4 address, MPLS L3VPN instance, and port number of a RabbitMQ server.
Use undo rabbit host to restore the default.
rabbit host ip ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo rabbit host ip ipv4-address [ vpn-instance vpn-instance-name ]
No IPv4 address or MPLS L3VPN instance is specified for a RabbitMQ server, and the port number of a RabbitMQ server is 5672.
Neutron view
ip ipv4-address: Specifies the IPv4 address of a RabbitMQ server.
port port-number: Specifies the port number for the device to communicate with a RabbitMQ server. The value range for the port-number argument is 1 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If a RabbitMQ server is on the public network, do not specify this option.
The device communicates with the Neutron server through RabbitMQ servers.
Before you configure this command, make sure the controller where the Neutron server resides has been installed with RabbitMQ components.
If the device connects to a RabbitMQ server cluster, you can repeat this command to specify the IPv4 addresses of multiple RabbitMQ servers in the cluster.
You can specify the IPv4 address for a maximum of 32 RabbitMQ servers.
# Specify 10.11.113.143 as the IPv4 address of a RabbitMQ server.
[Sysname] neutron
[Sysname-neutron] rabbit host ip 10.11.113.143
rabbit password
Use rabbit password to configure the password for the device to establish connections with RabbitMQ servers.
Use undo rabbit password to restore the default.
rabbit password { cipher | plain } string
The device uses the plaintext password guest to establish connections with RabbitMQ servers.
Neutron view
string: Specifies the password. Its plaintext form is a case-sensitive string of 4 to 64 characters. Its encrypted form is a case-sensitive string of 36 to 256 characters.
# Configure the device to use the plaintext password aaaa to establish connections with RabbitMQ servers.
[Sysname] neutron
[Sysname-neutron] rabbit password plain aaaa
rabbit source-ip
Use rabbit source-ip to specify the source IPv4 address for the device to communicate with RabbitMQ servers.
Use undo rabbit source-ip to restore the default.
rabbit source-ip ipv4-address [ vpn-instance vpn-instance-name ]
No source IPv4 address is specified for the device to communicate with RabbitMQ servers. The device automatically selects the source IPv4 address through the routing protocol to communicate with RabbitMQ servers.
Neutron view
ipv4-address: Specifies the source IPv4 address with which the device communicates with RabbitMQ servers.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the specified source IPv4 address is on the public network, do not specify this option.
Use this command if multiple equal-cost routes exist between the device and RabbitMQ servers. For example, assume that two equal-cost routes exist, and the outgoing interface in one route is a logical interface and that in the other route is a physical interface. If the device automatically selects the physical interface, communications with RabbitMQ servers might be interrupted and Neutron services will be further affected when the physical interface goes down. To avoid this problem, specify the IPv4 address of the logical interface as the source IPv4 address.
# Specify 1.1.1.1 as the source IPv4 address for the device to communicate with RabbitMQ servers.
[Sysname] neutron
[Sysname-neutron] rabbit source-ip 1.1.1.1
rabbit user
Use rabbit user to configure the username for the device to establish connections with RabbitMQ servers.
Use undo rabbit user to restore the default.
rabbit user username
undo rabbit user
The device uses username guest to establish connections with RabbitMQ servers.
Neutron view
username: Specifies the username for the device to establish connections with RabbitMQ servers, a case-sensitive string of 1 to 63 characters.
# Configure the device to use username aaa to establish connections with RabbitMQ servers.
[Sysname] neutron
[Sysname-neutron] rabbit user aaa
rabbit virtual-host
Use rabbit virtual-host to specify a virtual host on a RabbitMQ server to provide services for the device.
Use undo rabbit virtual-host to restore the default.
rabbit virtual-host hostname
The virtual host with the name / provides RabbitMQ services for the device.
Neutron view
hostname: Specifies the name of a virtual host on a RabbitMQ server. The hostname is a case-sensitive string of 1 to 63 characters.
Multiple virtual hosts might exist on a RabbitMQ server. Each virtual host can independently provide RabbitMQ services for the device. For the device to correctly communicate with the Neutron server, specify the same virtual host with the Neutron server.
# Specify the virtual host with the name aaa to provide RabbitMQ services for the device.
[Sysname] neutron
[Sysname-neutron] rabbit virtual-host aaa
restful user
Use restful user to configure the username and password for the device to deploy configurations through a RESTful API.
Use undo restful user to restore the default.
restful user username password { plain | cipher } string
undo restful user
No username and password is specified for the device to deploy configurations through a RESTful API.
Neutron view
username: Specifies the username for the device to deploy configurations through a RESTful AP. The username is a case-sensitive string of 1 to 63 characters.
string: Specifies the password. Its plaintext form is a case-sensitive string of 3 to 64 characters. Its encrypted form is a case-sensitive string of 36 to 256 characters.
You must specify an existing pair of username and password.
# Configure the device to use username aaa and plaintext password aaaa to deploy configurations through a RESTful API.
[Sysname] neutron
[Sysname-neutron] restful user aaa password plain aaaa
vcf-fabric role
Use vcf-fabric role to specify the role of the device.
Use undo vcf-fabric role to restore the default.
vcf-fabric role { access | aggr | leaf | spine }
Neutron view
access: Specifies the access node.
aggr: Specifies the aggregate node.
leaf: Specifies the leaf node.
spine: Specifies the spine node.
If you change the role of the device, the new role takes effect after the device restarts.
# Specify the device as a spine node.
[Sysname] vcf-fabric role spine
vcf-fabric spine-role master
Use vcf-fabric spine-role master to specify the device as a master spine node.
Use undo vcf-fabric spine-role master to restore the default.
The device is not a master spine node.
You must execute this command on a spine node.
When multiple spines nodes exist in the VCF fabric, you must specify a device as the master spine node to collect the topology for the entire VCF fabric.
For the new role to take effect, you must restart the automated underlay network deployment. To restart the automated underlay network deployment, execute the undo vcf-fabric underlay autoconfigure command and then the vcf-fabric underlay autoconfigure command.
# Specify the device as a master spine.
[Sysname] vcf-fabric spine-role master
For this configuration to take effect, you must execute the undo vcf-fabric underlay autoconfigure and vcf-fabric underlay autoconfigure commands in sequence.
vcf-fabric role
Use vcf-fabric topology enable to enable VCF fabric topology discovery.
Use undo vcf-fabric topology enable to disable VCF fabric topology discovery.
VCF fabric topology discovery is disabled.
# Enable VCF fabric topology discovery.
[Sysname] vcf-fabric topology enable
Use vcf-fabric underlay autoconfigure to specify the template file for automated underlay network deployment.
Use undo vcf-fabric underlay autoconfigure to restore the default.
vcf-fabric underlay autoconfigure template
No template file is specified for automated underlay network deployment.
template: Specifies a template file by its name, a case-insensitive string of 1 to 127 characters. A template file is a file ending with the .template file extension.
After this command is executed, the device uses the specified template file to deploy the underlay network.
# Specify template file vxlan_leaf.template for automated underlay network deployment.
[Sysname] vcf-fabric underlay autoconfigure vxlan_leaf.template
Use vcf-fabric underlay netconf-username to set the NETCONF username.
Use undo vcf-fabric underlay netconf-username to restore the default.
vcf-fabric underlay netconf-username username
The device uses the NETCONF username defined in the template file for automated VCF fabric deployment.
username: Specifies the username used by the spine device to collect the global topology through NETCONF, a case-sensitive string of 1 to 63 characters.
This command is supported only in R6515P06 and later.
This command is available on spine nodes.
During automated underlay network deployment, a spine node establishes NETCONF sessions with other devices in the underlay network to collect the global topology. If a user changes the username or password on a device in the undelay network, the NETCONF session between the device and the spine node is disconnected. Thun, the spine node fails to sense the topology change. To resolve the issue, use this command to change the NETCONF username on the spine node.
Make sure all devices in the underlay network use the same username and password for NETCONF session establishment.
# Set the NETCONF username to aaa.
[Sysname] vcf-fabric underlay netconf-username aaa
Use vcf-fabric underlay netconf-password to set the NETCONF password.
Use undo vcf-fabric netconf-underlay password to restore the default.
vcf-fabric underlay netconf-password { cipher | simple } string
undo vcf-fabric underlay netconf-password
The device uses the NETCONF password defined in the template file for automated VCF fabric deployment.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. Its plaintext form is a string of 1 to 63 characters. Its encrypted form is a string of 1 to 127 characters.
During automated underlay network deployment, a spine node establishes NETCONF sessions with other devices in the underlay network to collect the global topology. If a user changes the username or password on a device in the undelay network, the NETCONF session between the device and the spine node is disconnected. Thun, the spine node fails to sense the topology change. To resolve the issue, use this command to change the NETCONF password on the spine node.
# Set the NETCONF password to aaa in plaintext form.
[Sysname] vcf-fabric underlay netconf-password simple aaa
vcf-fabric underlay pause
Use vcf-fabric underlay pause to pause automated underlay network deployment.
Use undo vcf-fabric underlay pause to continue automated underlay network deployment.
Automated underlay network deployment is not paused.
You can use this command to pause automated underlay network deployment if the device is in the process of automated underlay network deployment.
# Pause automated underlay network deployment.
[Sysname] vcf-fabric underlay pause
Use vpn-target export-extcommunity to configure export route targets for a tenant VPN instance.
Use undo vpn-target export-extcommunity to restore the default.
vpn-target target export-extcommunity
undo vpn-target target export-extcommunity
No export route targets are configured for a tenant VPN instance.
Neutron view
target: Specifies a route target, a string of 3 to 21 characters in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the AS number must not be less than 65536. For example, 65536:1.
The border node connects to the external network through an interface which belongs to the global VPN instance. For the traffic from the external network to reach a tenant network, the border node needs to add the routes of the tenant VPN instance into the routing table of the global VPN instance. Use this command to configure export route targets of the tenant VPN instance as import route targets of the global VPN instance. This setting enables the global VPN instance to import routes of the tenant VPN instance.
# Configure export route targets for a tenant VPN instance.
[Sysname] neutron
[Sysname-neutron] vpn-target 1:1 export-extcommunity
Use vpn-target import-extcommunity to configure import route targets for a tenant VPN instance.
Use undo vpn-target import-extcommunity to restore the default.
vpn-target target import-extcommunity
undo vpn-target target import-extcommunity
No import route targets are configured for a tenant VPN instance.
Neutron view
You do not need to execute this command if you have used the gateway ip or border enable command to create the default route to the external network.
In a data center, the border node connects to the external network through an interface which belongs to the global VPN instance. For tenant network data to reach the external network, use this command to configure import targets of the tenant VPN instance as export targets of the global VPN instance. This setting enables the tenant VPN instance to import routes of the global VPN instance.
# Configure import route targets for a tenant VPN instance.
[Sysname] neutron
[Sysname-neutron] vpn-target 1:1 import-extcommunity
vsi-mac
Use vsi-mac to configure a MAC address for VSI interfaces.
Use undo vsi-mac to delete the MAC address for VSI interfaces.
vsi-mac mac-address
undo vsi-mac
No MAC address is specified for VSI interfaces.
Neutron view
mac-address: Specifies a MAC address in the H-H-H format.
This command assigns the MAC address to all VSI interfaces newly created by automated overlay network deployment on the device.
This command takes effect only on VSI interfaces newly created after this command is executed.
# Configure the MAC address of all VSI interfaces as 1-1-1.
[Sysname] neutron
[Sysname-neutron] vsi-mac 1-1-1
