- 01-AAA configuration
- 02-802.1X configuration
- 04-Portal configuration
- 05-Web authentication configuration
- 06-Triple authentication configuration
- 07-Port security configuration
- 08-User profile configuration
- 10-Keychain configuration
- 11-Public key management
- 12-PKI configuration
- 13-IPsec configuration
- 14-SSH configuration
- 15-SSL configuration
- 16-Attack detection and prevention configuration
- 17-TCP attack prevention configuration
- 18-IP source guard configuration
- 19-ARP attack protection configuration
- 20-ND attack defense configuration
- 21-uRPF configuration
- 22-SAVI configuration
- 23-SAVA configuration
- 24-Crypto engine configuration
- 25-MFF configuration
- 26-FIPS configuration
- 27-802.1X client configuration
- 28-Microsegmentation configuration
27-802.1X client configuration | 83.97 KB |
802.1X client tasks at a glance
Enabling the 802.1X client feature
Configuring an 802.1X client username and password
Specifying an 802.1X client EAP authentication method
Configuring an 802.1X client MAC address
Specifying an 802.1X client mode for sending EAP-Response and EAPOL-Logoff packets
Configuring an 802.1X client anonymous identifier
Specifying an SSL client policy
Display and maintenance commands for 802.1X client
About 802.1X clients
As shown in Figure 1, the 802.1X client feature allows the access device to act as the supplicant in the 802.1X architecture. For information about the 802.1X architecture, see "802.1X overview."
Figure 1 802.1X client network diagram
To configure an 802.1X client, perform the following tasks:
1. Enabling the 802.1X client feature
2. Configuring an 802.1X client username and password
3. Specifying an 802.1X client EAP authentication method
4. (Optional.) Configuring an 802.1X client MAC address
5. (Optional.) Specifying an 802.1X client mode for sending EAP-Response and EAPOL-Logoff packets
6. (Optional.) Configuring an 802.1X client anonymous identifier
7. Specifying an SSL client policy
This task is required when you specify PEAP-MSCHAPv2, PEAP-GTC, TTLS-MSCHAPv2, or TTLS-GTC authentication as the 802.1X client EAP authentication method.
1. Enter system view.
2. Enter Ethernet interface view.
3. Enable the 802.1X client feature.
dot1x supplicant enable
By default, the 802.1X client feature is disabled.
To ensure successful authentication, make sure the username and password configured on the 802.1X client is consistent with the username and password configured on the authentication server.
3. Configure an 802.1X client username.
dot1x supplicant username username
By default, no 802.1X client username is configured.
4. Set an 802.1X client password.
dot1x supplicant password { cipher | simple } string
By default, no 802.1X client password is configured.
The following EAP authentication methods are available for the 802.1X client feature:
· MD5-Challenge.
· PEAP-MSCHAPv2.
· PEAP-GTC.
· TTLS-MSCHAPv2.
· TTLS-GTC.
The following matrix shows the restrictions for the selection of authentication methods on the 802.1X client and the authenticator:
Authentication method specified on the 802.1X client |
Packet exchange method specified on the authenticator |
MD5-Challenge |
· CHAP · EAP |
· PEAP-MSCHAPv2 · PEAP-GTC · TTLS-MSCHAPv2 · TTLS-GTC |
EAP |
For information about 802.1X packet exchange methods, see "Configuring 802.1X."
Make sure the specified 802.1X client EAP authentication method is supported by the authentication server.
3. Specify an 802.1X client EAP authentication method.
dot1x supplicant eap-method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
By default, the EAP authentication method is MD5-Challenge.
The authenticator adds the MAC address of an authenticated 802.1X client to the MAC address table and then assigns access rights to the client.
If the device has multiple Ethernet interfaces that act as 802.1X clients to seek MACsec protection, configure a unique MAC address for each interface to ensure successful 802.1X client authentication. For information about MACsec, see "Configuring MACsec."
You can use either of the following methods to configure a unique MAC address for each interface:
· Execute the mac-address command in Ethernet interface view. For information about this command, see Layer 2—LAN Switching Command Reference.
· Configure an 802.1X client MAC address.
3. Configure an 802.1X client MAC address.
dot1x supplicant mac-address mac-address
By default, an Ethernet interface uses the interface's MAC address for 802.1X client authentication. If the interface's MAC address is unavailable, the interface uses the device's MAC address for 802.1X client authentication.
802.1X client authentication supports unicast and multicast modes to send EAP-Response and EAPOL-Logoff packets. As a best practice, use multicast mode to avoid 802.1X client authentication failures if the NAS device in the network does not support receiving unicast EAP-Response or EAPOL-Logoff packets.
3. Specify a mode for 802.1X client authentication to send EAP-Response and EAPOL-Logoff packets.
dot1x supplicant transmit-mode { multicast | unicast }
By default, 802.1X client authentication uses unicast mode to send EAP-Response and EAPOL-Logoff packets.
At the first authentication phase, packets sent to the authenticator are not encrypted. The use of an 802.1X client anonymous identifier prevents the 802.1X client username from being disclosed at the first phase. The 802.1X client sends the anonymous identifier to the authenticator instead of the 802.1X client username. The 802.1X client username will be sent to the authenticator in encrypted packets at the second phase.
If no 802.1X client anonymous identifier is configured, the 802.1X client sends the 802.1X client username at the first authentication phase.
The configured 802.1X client anonymous identifier takes effect only if one of the following EAP authentication methods is used:
· PEAP-MSCHAPv2.
· PEAP-GTC.
· TTLS-MSCHAPv2.
· TTLS-GTC.
If the MD5-Challenge EAP authentication is used, the configured 802.1X client anonymous identifier does not take effect. The 802.1X client uses the 802.1X client username at the first authentication phase.
Do not configure the 802.1X client anonymous identifier if the vendor-specific authentication server cannot identify anonymous identifiers.
3. Configure an 802.1X client anonymous identifier.
dot1x supplicant anonymous identify identifier
By default, no 802.1X client anonymous identifier is configured.
If the PEAP-MSCHAPv2, PEAP-GTC, TTLS-MSCHAPv2, or TTLS-GTC authentication is used, the 802.1X client authentication process is as follows:
· The first phase—The 802.1X client acts as an SSL client to negotiate with the SSL server.
The SSL client uses the SSL parameters defined in the specified SSL client policy to establish a connection with the SSL server for negotiation. The SSL parameters include a PKI domain, supported cipher suites, and the SSL version. For information about SSL client policy configuration, see "Configuring SSL."
· The second phase—The 802.1X client uses the negotiated result to encrypt and transmit the interchanged authentication packets.
If the MD5-Challenge authentication is used, the 802.1X client does not use an SSL client policy during the authentication process.
3. Specify an SSL client policy.
dot1x supplicant ssl-client-policy policy-name
By default, the default SSL client policy is used.
Task |
Command |
Display 802.1X client information. |
display dot1x supplicant [ interface interface-type interface-number ] |
