- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-Crypto engine commands
- 23-FIPS commands
17-IP source guard commands | 93.70 KB |
display ipv6 source binding pd
ip source binding (interface view)
ip source binding (system view)
ipv6 source binding (interface view)
ipv6 source binding (system view)
display ip source binding
Use display ip source binding to display IPv4SG bindings.
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ arp-snooping-vlan | arp-snooping-vsi | dhcp-relay | dhcp-server | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
static: Displays static IPv4SG bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv4SG bindings for the public network, do not specify a VPN instance.
arp-snooping-vlan: Specifies IPv4SG bindings generated based on ARP snooping for VLANs.
arp-snooping-vsi: Specifies IPv4SG bindings generated based on ARP snooping for VSIs.
dhcp-relay: Specifies IPv4SG bindings generated based on DHCP relay agent.
dhcp-server: Specifies IPv4SG bindings generated based on DHCP server.
dhcp-snooping: Specifies IPv4SG bindings generated based on DHCP snooping.
dot1x: Specifies IPv4SG bindings generated based on 802.1X. To display dynamic IPv4SG bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
ip-address ip-address: Specifies an IPv4 address.
mac-address mac-address: Specifies a MAC address in H-H-H format.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4SG bindings for the master device.
# Display all IPSG bindings on the public network.
<Sysname> display ip source binding
Total entries found: 5
IP Address MAC Address Interface VLAN Type
10.1.0.5 040a-0000-4000 HGE1/0/1 1 DHCP snooping
10.1.0.6 040a-0000-3000 HGE1/0/1 1 DHCP snooping
10.1.0.7 040a-0000-2000 HGE1/0/1 1 DHCP snooping
10.1.0.8 040a-0000-1000 HGE1/0/2 N/A DHCP relay
10.1.0.9 040a-0000-2000 HGE1/0/2 N/A Static
Total entries found |
Total number of IPv4SG bindings. |
IP Address |
IPv4 address in the IPv4SG binding. If no IP address is bound in the binding, this field displays N/A. |
MAC Address |
MAC address in the IPv4SG binding. If no MAC address is bound in the binding, this field displays N/A. |
Interface of the binding. This field displays N/A for a global IPv4SG binding. |
VLAN |
VLAN information in the IPv4SG binding. If the binding contains no VLAN information, this field displays N/A. |
Type |
IPSG binding type: · Static—Manually configured by using the ip source binding command. Static bindings are for packet filtering in IPSG or used by other modules to provide security services. · ARP snooping vlan—Dynamically generated based on ARP snooping for the VLAN. The binding is for packet filtering in IPSG. · ARP snooping vsi—Dynamically generated based on ARP snooping for the VSI. The binding is for packet filtering in IPSG. · 802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPSG. · DHCP relay—Dynamically generated based on DHCP relay agent. The binding is for packet filtering in IPSG. · DHCP server—Dynamically generated based on DHCP server. The binding is used by other modules to provide security services. · DHCP snooping—Dynamically generated based on DHCP snooping. The binding is for packet filtering in IPSG. |
ip source binding
ip verify source
Use display ipv6 source binding to display IPv6SG address bindings.
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-relay | dhcpv6-server | dhcpv6-snooping | dot1x | nd-snooping-vlan ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
static: Displays static IPv6SG address bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv6SG address bindings for the public network, do not specify a VPN instance.
dhcpv6-relay: Specifies IPv6SG bindings generated based on DHCPv6 relay agent.
dhcpv6-server: Specifies IPv6SG bindings generated based on DHCPv6 server.
dhcpv6-snooping: Specifies IPv6SG bindings generated based on DHCPv6 snooping.
dot1x: Specifies IPv6SG bindings generated based on 802.1X. To display dynamic IPv6SG address bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
nd-snooping-vlan: Specifies IPv6SG bindings generated based on ND snooping for VLANs.
ip-address ipv6-address: Specifies an IPv6 address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6SG address bindings for the master device.
# Display all IPv6SG address bindings on the public network.
<Sysname> display ipv6 source binding
Total entries found: 2
IPv6 Address MAC Address Interface VLAN Type
2012:1222:2012:1222: 000f-2202-0435 HGE1/0/1 1 DHCPv6 snooping
2012:1222:2012:1222
2012:1222:2012:1222: 000f-2202-0436 HGE1/0/1 N/A Static
2012:1222:2012:1223
Total number of IPv6SG address bindings. |
IPv6 Address |
IPv6 address in the IPv6SG address binding. If no IPv6 address is bound in the binding, this field displays N/A. |
MAC Address |
MAC address in the IPv6SG address binding. If no MAC address is bound in the binding, this field displays N/A. |
Interface of the IPv6SG address binding. This field displays N/A for a global IPv6SG binding. |
VLAN |
VLAN information in the IPv6SG address binding. If the binding contains no VLAN information, this field displays N/A. |
Type |
Type of the IPv6SG address binding: · Static—Manually configured by using the ipv6 source binding command. Static bindings are for packet filtering in IPv6SG or used by other modules to provide security services. · DHCPv6 relay—Dynamically generated based on DHCPv6 relay agent. The binding is for packet filtering in IPv6SG. · DHCPv6 sever—Dynamically generated based on DHCPv6 server. The binding is reported to the controller for the controller to understand the information about online and offline users. The binding is not for packet filtering. · DHCPv6 snooping—Dynamically generated based on DHCPv6 snooping. The binding is for packet filtering in IPv6SG. · 802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPv6SG. · ND snooping vlan—Dynamically generated based on ND snooping for the VLAN. The binding is for packet filtering in IPv6SG. |
ipv6 source binding
ipv6 verify source
Use display ipv6 source binding pd to display IPv6SG prefix bindings.
display ipv6 source binding pd [ vpn-instance vpn-instance-name ] [ prefix prefix/prefix-length ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
Any views
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display IPv6SG prefix bindings for the public network, do not specify a VPN instance.
prefix prefix/prefix-length: Specifies an IPv6 prefix. The value range for the prefix-length argument is 1 to 128. If you do not specify an IPv6 prefix, this command displays all IPv6SG prefix bindings.
mac-address mac-address: Specifies a MAC address in H-H-H format. If you do not specify a MAC address, this command displays IPv6SG prefix bindings for all MAC addresses.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6SG prefix bindings for all VLANs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6SG prefix bindings for all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6SG prefix bindings for the master device.
IPv6SG prefix bindings are dynamically obtained from the DHCPv6 snooping module.
# Display all IPv6SG prefix bindings.
<Sysname> display ipv6 source binding pd
Total entries found: 3
IPv6 prefix MAC address Interface VLAN Type
2012:1111::/64 000f-2202-0435 HGE1/0/1 1 DHCPv6 snooping
2012:2222::/64 000f-2202-0436 HGE2/0/1 2 DHCPv6 snooping
Total number of IPv6SG prefix bindings. |
IPv6 prefix |
IPv6 prefix and prefix length in the IPv6SG prefix binding. |
MAC address |
MAC address in the IPv6SG prefix binding. This field displays N/A if the MAC address is invalid. |
Interface to which the IPv6SG prefix binding belongs. This field displays N/A for a global IPv6SG prefix binding. |
VLAN |
VLAN information in the IPv6SG prefix binding. This field displays N/A if the IPv6SG prefix binding does not contain the VLAN information. |
Type |
Type of the IPv6SG prefix binding: DHCPv6 snooping—The binding is generated based on a DHCPv6 snooping entry. |
ipv6 source binding
ipv6 verify source
Use ip source binding to configure a static IPv4SG binding on an interface.
Use undo ip source binding to delete the static IPv4SG bindings configured on an interface.
ip source binding { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ip source binding { all | ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv4SG bindings exist on an interface.
VLAN interface view
all: Removes all static IPv4SG bindings on the interface.
ip-address ip-address: Specifies an IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies a MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
vlan vlan-id: Specifies a VLAN ID for the static binding. The value range is 1 to 4094. This option is supported only in Layer 2 Ethernet interface view.
Static IPv4SG bindings on an interface implement the following functions:
· Filter incoming IPv4 packets on the interface.
· Check user validity by cooperating with the ARP attack detection feature.
You cannot configure static IPv4SG bindings on a service loopback interface.
# Configure a static IPv4SG binding on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
Use ip source binding to configure a global static IPv4SG binding.
Use undo ip source binding to delete one or all global static IPv4SG bindings.
undo ip source binding { all | ip-address ip-address mac-address mac-address }
No global static IPv4SG bindings exist.
ip-address ip-address: Specifies the IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies the MAC address for the static binding. The MAC address is in the format H-H-H but cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
all: Removes all global static IPv4SG bindings.
A global static IPv4SG binding takes effect on all interfaces.
# Configure a global static IPv4SG binding.
[Sysname] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
ip verify source
Use ip verify source to enable IPv4SG on an interface.
Use undo ip verify source to disable IPv4SG on an interface.
The IPv4SG feature is disabled on an interface.
VLAN interface view
ip-address: Filters incoming packets by source IPv4 addresses.
ip-address mac-address: Filters incoming packets by source IPv4 addresses and source MAC addresses.
mac-address: Filters incoming packets by source MAC addresses.
After you enable IPv4SG on an interface, this feature uses static and dynamic IPv4SG bindings to match incoming packets on the interface. Packets that match an IPv4SG binding are forwarded and packets that do not match any IPv4SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPSG. Static IPv4SG uses static bindings configured by using the ip source binding command.
You cannot enable dynamic IPv4SG on a service loopback interface.
# Enable IPv4SG on Layer 2 Ethernet interface HundredGigE 1/0/1 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-HundredGigE1/0/1] ip verify source ip-address mac-address
# Enable IPv4SG on VLAN-interface 100 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Vlan-interface100] ip verify source ip-address mac-address
# Enable IPv4SG on Layer 3 Ethernet interface HundredGigE 1/0/2 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname] interface hundredgige 1/0/2
[Sysname-HundredGigE1/0/2] ip verify source ip-address mac-address
# Enable IPv4SG on Layer 3 Ethernet interface HundredGigE 1/0/2 and verify the source MAC address for dynamic IPSG.
[Sysname-HundredGigE1/0/2] ip verify source mac-address
Use ipv6 source binding to configure a static IPv6SG binding.
Use undo ipv6 source binding to delete the static IPv6SG bindings configured on an interface.
ipv6 source binding { ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ipv6 source binding { all | ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv6SG bindings exist on an interface.
VLAN interface view
all: Removes all the static IPv6SG bindings on the interface.
ip-address ipv6-address: Specifies an IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
Static IPv6SG bindings on an interface filter incoming IPv6 packets, and check user validity by cooperating with the ND attack detection feature.
You cannot configure static IPv6SG bindings on a service loopback interface.
# Configure a static IPv6SG binding on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] ipv6 source binding ip-address 2001::1 mac-address 0002-0002-0002
Use ipv6 source binding to configure a global static IPv6SG binding.
Use undo ipv6 source binding to delete one or all global static IPv6SG bindings.
undo ipv6 source binding { all | ip-address ipv6-address mac-address mac-address }
No global static IPv6SG bindings exist.
ipv6-address ipv6-address: Specifies the IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
mac-address mac-address: Specifies the MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
all: Removes all global static IPv6SG bindings.
A global static IPv6SG binding takes effect on all interfaces.
# Configure a global static IPv6SG binding.
[Sysname] ipv6 source binding ipv6-address 2001::1 mac-address 0002-0002-0002
ipv6 verify source
Use ipv6 verify source to enable IPv6SG on an interface.
Use undo ipv6 verify source to disable IPv6SG on an interface.
The IPv6SG feature is disabled on an interface.
VLAN interface view
ip-address: Filters incoming packets by source IPv6 addresses.
ip-address mac-address: Filters incoming packets by source IPv6 addresses and source MAC addresses.
After you enable IPv6SG on an interface, this feature uses static and dynamic IPv6SG bindings to match incoming packets on the interface. Packets that match an IPv6SG binding are forwarded and packets that do not match any IPv6SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPv6SG. Static IPv6SG uses static bindings configured by using the ipv6 source binding command.
You cannot enable dynamic IPv6SG on a service loopback interface.
# Enable IPv6SG on Layer 2 Ethernet interface HundredGigE 1/0/1 and verify the source IPv6 address and MAC address for dynamic IPv6SG.
[Sysname-HundredGigE1/0/1] ipv6 verify source ip-address mac-address
