02-SR-TE policy commands | 154.88 KB |
display bgp routing-table ipv4 sr-policy
display segment-routing te forwarding
display segment-routing te policy
display segment-routing te policy statistics
display segment-routing te segment-list
forwarding statistics interval
reset segment-routing te forwarding statistics
address-family ipv4 sr-policy
Use address-family ipv4 sr-policy to create the BGP IPv4 SR-TE policy address family and enter its view, or enter the view of the existing BGP IPv4 SR-TE policy address family.
Use undo address-family ipv4 sr-policy to delete the BGP IPv4 SR-TE policy address family and all the configuration in the BGP IPv4 SR-TE policy address family.
The BGP IPv4 SR-TE policy address family does not exist.
BGP instance view
The configuration in BGP IPv4 SR-TE policy address family view applies only to routes and peers in the BGP IPv4 SR-TE policy address family.
# In BGP instance view, create the BGP IPv4 SR-TE policy address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 sr-policy
[Sysname-bgp-default-srpolicy-ipv4]
binding-sid
Use binding-sid to configure an BSID for an SR-TE policy.
Use undo binding-sid to delete the BSID.
binding-sid mpls mpls-label
undo binding-sid
No BSID is configured for an SR-TE policy.
SR-TE policy view
mpls mpls-label: Specifies the BSID value, which is an MPLS label value in the range of 16 to 1048575.
You can use this command to manually configure a BSID for an SR-TE policy or leave the SR-TE policy to obtain a BSID automatically. If an SR-TE policy has only color and endpoint configuration, the SR-TE policy will automatically request a BSID.
The manually configured BSID has a higher priority over the automatically obtained BSID.
If you configure an MPLS label as the BSID but the label is not in the range of the SRGB or SRLB or is already used by a protocol, the configuration does not take effect. For more information about SRGB or SRLB, see MPLS SR configuration in Segment Routing Configuration Guide.
The candidate paths of the same SR-TE policy have the same BSID.
# Set the BSID of SR-TE policy srpolicy to 20.
[Sysname] segment-routing
[Sysname-segment-routing] traffic-engineering
[Sysname-sr-te] policy srpolicy
[Sysname-sr-te-policy-srpolicy] binding-sid mpls 20
color end-point
candidate-paths
Use candidate-paths to create and enter the candidate path view for an SR-TE policy, or enter the existing candidate path view.
Use undo candidate-paths to delete the candidate path view and all the configurations in the view.
candidate-paths
The candidate path view for an SR-TE policy does not exist.
SR-TE policy view
# Create the SR-TE policy candidate paths instance and enter its view.
[Sysname-sr-te-policy-srpolicy] candidate-paths
[Sysname-sr-te-policy-srpolicy-path]
color end-point
Use color end-point to configure the color and endpoint attributes of an SR-TE policy.
Use undo color to delete the color and endpoint settings of an SR-TE policy.
color color-value end-point ipv4 ipv4-address
undo color
The color and endpoint attributes of an SR-TE policy are not configured.
SR-TE policy view
color-value: Specifies the color attribute value, in the range of 1 to 4294967295.
ipv4-address: Specifies the endpoint IP address.
Different SR-TE policies cannot have the same color and they can have the same endpoint IP address.
# Configure the color as 20 and endpoint IP address as 10.0.0.1 for SR-TE policy srpolicy.
[Sysname-sr-te-policy-srpolicy] color 20 end-point ipv4 10.0.0.1
binding-sid
Use display bgp routing-table ipv4 sr-policy to display route information of an BGP IPv4 SR-TE policy.
display bgp [ instance instance-name ] routing-table ipv4 sr-policy [ sr-policy-prefix [ advertise-info ] | peer ipv4-address { advertised-routes | received-routes } [ statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default instance.
sr-policy-prefix: Specifies a BGP SR-TE policy route prefix, which is a case-insensitive string of 1 to 512 characters in the format of SR-TE policy route/mask length.
advertise-info: Displays advertisement information about BGP IPv4 SR-TE policy routes.
peer ipv4-address: Specifies a peer by its IP address.
advertised-routes: Displays detailed information about the BGP IPv4 SR-TE policy routes advertised to the specified peer.
received-routes: Displays detailed information about the BGP IPv4 SR-TE policy routes received from the specified peer.
statistics: Displays route statistics.
If you do not specify any parameters, this command displays brief information about all BGP IPv4 SR-TE policy routes.
# Display brief information about all BGP IPv4 SR-TE policy routes.
<Sysname> display bgp routing-table ipv4 sr-policy
Total number of routes: 1
Status codes: * - valid, > - best, d - dampened, h - history
a – additional-path
* >i Network : [10][1][9.9.9.9]/96
NextHop : 2.1.1.2 LocPrf : 100
PrefVal : 0 OutLabel : NULL
MED : 0
Path/Ogn: i
Status codes |
Status codes of the route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. · e – EGP—Learned through an EGP. · ? – incomplete—Unknown origin. |
Network |
BGP IPv4 SR-TE policy route, comprised of the following elements: · SR-TE policy candidate path preference. · SR-TE policy color attribute value. · Endpoint IP address. |
NextHop |
Next hop IP address. |
LocPrf |
Local preference value. |
PrefVal |
Preferred value of the route. |
OutLabel |
Outgoing label of the route. |
MED |
Multi-Exit Discriminator attribute value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed. · ORIGIN—Identifies the origin of the route. |
# Display detailed information about BGP IPv4 SR-TE policy route [102][2][5.6.7.8]/96.
<Sysname> display bgp routing-table ipv4 sr-policy [102][2][5.6.7.8]/96
BGP local router ID: 2.2.2.2
Local AS number: 1
Paths: 1 available, 1 best
BGP routing table information of [102][2][5.6.7.8]:
Rely nexthop : 0.0.0.0
Original nexthop: 3.1.1.2
Route age : 00h33m33s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 2
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel Encaps : Type 15 (SR Policy)
Preference 20, BSID 150000,
Path 1, weight 1
SID lists: {1000} {2000} {3000}
Paths |
Route information: · available—Number of valid routes. · best—Number of optimal routes. |
BGP routing table information of [102][2][5.6.7.8] |
Information of the BGP IPv4 SR-TE policy route [102][2][5.6.7.8], where: · [102] is the SR-TE policy candidate path preference · [2] is the SR-TE policy color attribute value. · [5.6.7.8] is the endpoint IP address. |
From |
IP address of the BGP peer that advertised the route. |
Rely Nexthop |
Recursive nexthop IP address. If no next hop is found by route recursion, this field displays not resolved. |
Original nexthop |
Original nexthop IP address. If the route was obtained from a BGP update message, the original next hop is the nexthop IP address in the message. |
Route age |
Time elapsed since the last update for the route. |
OutLabel |
RxPathID |
Received Add-Path ID of the route. |
TxPathID |
Advertised Add-Path ID of the route. |
AS-path |
AS_PATH attribute of the route. |
Origin |
Origin of the route: · igp—Originated in the AS. · egp—Learned through an EGP. · incomplete—Unknown origin. |
Attribute value |
BGP path attributes: · MED—MED value. · localpref—Local preference value. · pref-val—Preferred value. · pre—Protocol preference. |
State |
Current state of the route. Options include: · valid—Valid route. · internal—Internal route. · external—External route. · local—Locally generated route. · synchronize—Synchronized route. · best—Optimal route. · delay—Delayed route. The route will be delayed for optimal route selection. This value is available only in detailed information of the route. · not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see Table 3. |
IP precedence |
IP precedence of the route, in the range of 0 to 7. N/A indicates that the route does not support this field. |
QoS local ID |
QoS local ID of the route, in the range of 1 to 4095. N/A indicates that the route does not support this field. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field. |
Type: 15 (SR Policy) |
The tunnel encryption type is 15, which represents SR-TE policy. |
Preference |
Candidate path preference. |
Binding SID |
BSID value |
Path |
Candidate path. |
Weight |
Weight of the SID list. |
SIDs |
List of SIDs. |
Table 3 Reason why the route is not selected as the optimal route
Reason |
preferred-value |
Routes with larger preferred values exist. |
local-preference |
Routes with larger local preference values exist. |
as-path |
Routes with smaller AS_PATH attribute values exist. |
origin |
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority. |
med |
Routes with smaller MED values exist. |
remote-route |
There are routes whose remote-route attribute has a higher priority. BGP selects the optimal route from remote routes in this order: · Route learned from an EBGP peer. · Route learned from a confederation EBGP peer. · Route learned from a confederation IBGP peer. · Route learned from an IBGP peer. |
igp-cost |
Routes with smaller IGP metrics exist. |
relydepth |
Routes with smaller recursion depth values exist. |
rfc5004 |
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers. |
router-id |
Routes with smaller router IDs exist. If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route. |
cluster-list |
Routes with smaller CLUSTER_LIST attribute values exist. |
peer-address |
Routes advertised by peers with lower IP addresses exist. |
received |
Earlier learned routes exist. |
# Displays advertisement information about the BGP IPv4 SR-TE policy route [102][2][5.6.7.8]/96.
<Sysname> display bgp routing-table ipv4 sr-policy [102][2][5.6.7.8]/96 advertise-info
Local AS number: 1
Paths: 1 best
BGP routing table information of [102][2][5.6.7.8]/96(TxPathID:0):
Advertised to peers (2 in total):
2.1.1.2
3.3.3.3
Paths |
Number of optimal paths to reach the destination network. |
BGP routing table information of [102][2][5.6.7.8]/96(TxPathID:0) |
Advertisement information about the BGP IPv4 SR-TE policy route [102][2][5.6.7.8]/96. TxPathID represents the advertised Add-Path ID of the route. |
Advertised to peers (2 in total) |
Indicates the peers to which the route has been advertised. The number in the parentheses indicates the total number of the peers. |
# Display statistics about the BGP IPv4 SR-TE policy routes advertised to peer 2.1.1.2.
<Sysname> display bgp routing-table ipv4 sr-policy peer 10.2.1.2 advertised-routes statistics
Advertised routes total: 2
# Display statistics about the BGP IPv4 SR-TE policy routes received from peer 2.1.1.2.
<Sysname> display bgp routing-table ipv4 sr-policy peer 2.1.1.2 received-routes statistics
Received routes total: 1
Table 5 Command output
Advertised routes total |
Total number of routes advertised to the specified peer. |
Received routes total |
Total number of routes received from the specified peer. |
# Display statistics about BGP IPv4 SR-TE policy routes.
<Sysname> display bgp routing-table ipv4 sr-policy statistics
Total number of routes: 3
Use display segment-routing te forwarding to display SR TE forwarding information.
display segment-routing te forwarding [ policy { policy-name | { color color-value | end-point ipv4 ip-address } * } ] [ verbose ]
policy: Displays SR TE forwarding information of the specified SR-TE policy. If you do not specify an SR-TE policy, this command displays SR TE forwarding information of all SR-TE policies.
policy-name: Specifies the name of an SR-TE policy, a string of 1 to 59 characters.
color color-value: Specifies the color of an SR-TE policy, in the range of 0 to 4294967295.
end-point ipv4 ip-address: Specifies the endpoint IPv4 address of an SR-TE policy.
verbose: Displays detailed SR TE forwarding information. If you do not specify this keyword, the command displays brief SR TE forwarding information.
To use this command to display SR TE traffic forwarding statistics, make sure SR TE traffic forwarding statistics is enabled.
# Display brief forwarding information of all SR-TE policies.
<Sysname> display segment-routing te forwarding
Total forwarding entries: 1
SR TE policy ID/name: 1/p3
BSID: 2169
SegList ID/name: 1/sl1
NID: 0x01400003
Outlabel: 3
Interface: HGE1/0/1
Nexthop: 1.1.2.2
SegList ID/name: 2/sl2
NID: 0x01400004
Outlabel: 3
Interface: HGE1/0/2
Nexthop: 1.1.3.3
# Display detailed forwarding information of all SR-TE policies.
<Sysname> display segment-routing te forwarding verbose
BSID: 2169
Inbound statistics:
Octets: 525
Packets: 1
Erroneous packets: 0
Dropped packets: 0
NID: 0x01400003
Outlabel: 3
Interface: HGE1/0/1
Nexthop: 1.1.2.2
Path ID: 1
Weight: 1
Label stack: {16200, 16300, 16400, 16500}
Outbound statistics:
Octets: 750
Packets: 1
Dropped packets: 0
Table 6 Command output
BSID |
Label value of the ingress node. |
Inbound statistics |
Inbound traffic statistics, that is, the traffic statistics about the BSID. |
Octets |
Number of forwarded bytes. |
Packets |
Number of forwarded packets. |
Erroneous packets |
Number of erroneous packets. |
Dropped packets |
Number of dropped packets. |
SegList ID/name |
SID list ID/name. |
NID |
NHLFE entry index |
OutLabel |
Outgoing label value. |
Brief name of the outgoing interface. |
Nexthop |
Nexthop IP address. |
Path ID |
ID of the SR-TE policy candidate path |
Weight |
Weight of the path. |
Label stack |
Stack of labels from top to bottom. |
Outbound statistics |
Outbound traffic statistics, that is, the traffic statistics about the NID. |
Use display segment-routing te policy to display SR-TE policy information.
display segment-routing te policy [ policy-name | down | up | { color color-value | end-point ipv4 ip-address } * ]
policy-name: Specifies an SR-TE policy by its name, a case-sensitive string of 1 to 59 characters.
down: Specifies the SR-TE policies in down state.
up: Specifies the SR-TE policies in up state.
color color-value: Specifies the color of an SR-TE policy, in the range of 1 to 4294967295.
If you do not specify any parameters, this command displays information about all SR-TE policies.
# Display information about all SR-TE policies.
<Sysname> display segment-routing te policy
Name/ID: abc/0
Color: 10
Endpoint: 4.4.4.4
BSID:
Mode: EXPLICIT Type: TYPE_1 Request state: SUCCESS
Current BSID: 15000 Explicit BSID: 15000 Dynamic BSID: -
Reference counts: 3
Flags: A/BS
Status: Up
Up/Down date: 2019-08-19 14:17:36
Candidate paths state: Configured
Candidate paths:
Preference : 10
Instance ID: 0 ASN: 0 Node address: 0.0.0.0
Peer address: 0.0.0.0
Optimal: Y Flags: V/A
Explict SID list:
ID: 1 Name: abc
Weight: 1
Table 7 Command output
Name/ID |
SR-TE policy name/ID. |
Color |
Color attribute of the SR-TE policy. A value of 0 means that the color attribute is not configured. |
Endpoint |
Endpoint IP address of the SR-TE policy. If the endpoint is not configured, this field displays None. |
BSID |
SID value of the ingress node. |
Mode |
BSID configuration mode: · Explicit—Manually configured. · Dynamic—Dynamically requested. · None—Not configured. |
Type |
BSID type: · None—Not configured. · TYPE_1—MPLS label. |
Request state |
BSID request state: · Failed. · Succeeded. |
Explicit BSID |
Manually configured BSID. |
Dynamic BSID |
Dynamically requested BSID. If the BSID is not dynamically requested, this field displays a hyphen (-). |
Reference counts |
Number of times that the SR-TE policy has been referenced. |
Flags |
SR-TE policy flags: · A—Active SR-TE policy. · C—Optimal SR-TE policy. · N—In optimal SR-TE policy selection progress. · BA—Requesting BSID. · BS—Optimal BSID. · D—Deleted SR-TE policy. · CF—Conflicted with an existing BSID. |
Status |
SR-TE policy status: · Up—Active state. · Down—Inactive state. |
Up/Down date |
Date and time when the SR-TE policy became up or down. |
Candidate paths status |
Whether candidate paths are configured: · Configured. · Not configured. |
Candidate paths |
SR-TE policy candidate path information. |
Preference |
SR-TE policy candidate path preference. |
Instance ID |
BGP instance ID. A value of 0 indicates that the device does not obtain SR-TE policy information from BGP peers. |
ASN |
AS number. A value of 0 indicates that the device does not obtain SR-TE policy information from BGP peers. |
Node address |
BGP node address. For a manually configured SR-TE policy, the node address is 0.0.0.0. For an SR-TE policy obtained from a BGP peer, the node address is the Router ID of the BGP peer. |
Peer address |
BGP peer address. For a manually configured SR-TE policy, the peer address is 0.0.0.0. For an SR-TE policy obtained from a BGP peer, the peer address is the address of the BGP peer. |
Optimal |
Whether the path is the optimal path: · Y—Yes. · N—No. |
Flags |
Flags of the SR-TE policy candidate path: · V—Valid candidate path. · A—Active candidate path. · None—No candidate path. |
Explict SID list |
Explicit SID list in the candidate path of the SR-TE policy. |
ID |
SID list index |
Name |
SID list name |
Weight |
Weight of the SID list in the candidate path. |
Use display segment-routing te policy statistics to display SR-TE policy statistics.
# Display SR-TE policy statistics.
<Sysname> display segment-routing te policy statistics
Total policies: 4 (2 up 2 down)
Configured: 2
From BGP: 2 (Added 2, deleted 0)
Total candidate paths: 6
Configured: 3
From BGP: 3 (Added 3, delete 0)
Total SID lists: 6
Configured: 3
From BGP: 3
Table 8 Command output
Total policies |
Total number of SR-TE policies: · up—Number of SR-TE policies in up state. · down—Number of SR-TE policies in down state. |
Configured |
Number of manually configured SR-TE policies. |
From BGP |
Number of SR-TE policies learned through BGP. · Added—Number of BGP-added SR-TE policies. · deleted—Number of BGP-deleted SR policies. |
Total candidate paths |
Total number of SR-TE policy candidate paths. |
Total SID lists |
Total number of SID lists. |
Use display segment-routing te segment-list to display SR-TE SID list information.
display segment-routing te segment-list [ name segment-list-name | id id-value ]
name segment-list-name: Specifies an SR-TE SID list by its name, a case-sensitive string of 1 to 128 characters.
id id-value: Specifies an SR-TE SID list by its ID in the range of 1 to 4294967295.
If you do not specify the name segment-list-name or id id-value option, the command displays information about all SR-TE SID lists.
To view the IDs of SR-TE SID lists, execute the display segment-routing te policy command.
# Display information about all SR-TE SID lists.
<Sysname> display segment-routing te segment-list
Total SID lists: 1
Name/ID: s1/1
Origin : CLI
Status : Up
Nodes : 2
Index: 10 Label: 17401
Type : TYPE_1 Flags: -
Index: 20 Label: 18101
Table 9 Command output
Total SID lists |
Name/ID |
SID list name and ID. |
Origin |
Source of the SID list: · CLI—The SID list was configured at the CLI. · BGP—The SID list was from BGP configuration deployment. · PCE—The SID list was from PCE configuration deployment. This value is not supported in the current software version. If there is no valid source, this field displays a hyphen (-). |
Status |
Status of the SID list, Down or Up. |
Nodes |
Number of nodes in the SID list. |
Index |
Index of the node. |
Label |
Label of the node. |
Type |
Type of the label. If the label is an MPLS label, this field displays TYPE_1. If the node does not have a label, this field displays None. |
Flags |
Flags of the node. This field always displays a hyphen (-) in the current software version. |
explicit segment-list
Use explicit segment-list to specify an SID list for a candidate path.
Use undo explicit segment-list to delete an SID list of a candidate path.
explicit segment-list segment-list-name [ weight weight-value ]
undo explicit segment-list segment-list-name [ weight ]
No SID lists are specified for an SR-TE policy candidate path.
Candidate path preference view
segment-list-name: Specifies an SID list name, a string of 1 to 128 characters.
weight weight-value: Specifies a weight for the SID list, in the range of 1 to 4294967295. The default weight is 1.
An SR-TE policy uses the SID list specified for the highest-preference candidate path as a traffic forwarding subpath.
An SR-TE policy candidate path can have multiple SID lists. All the SID lists can be used to forward traffic for load sharing based on their weights. Assume SID lists a, b, and c are assigned weights x, y, z, respectively. The load of SID list a is x/(x+y+z) of the total traffic.
If you assign weight values for the same SID list multiple times, the most recent configuration takes effect.
# Configure SID list abc for the SR-TE policy candidate path with preference 20, and the set the SID list weight to 20.
[Sysname-sr-te] policy a1
[Sysname-sr-te-policy-a1] candidate-paths
[Sysname-sr-te-policy-a1-path] preference 20
[Sysname-sr-te-policy-a1-path-pref20] explicit segment-list abc weight 20
segment-list
forwarding statistics enable
Use forwarding statistics enable to enable SR TE forwarding statistics.
Use undo forwarding statistics enable to disable SR TE forwarding statistics.
SR TE forwarding statistics is disabled.
SR TE view
# Enable SR TE forwarding statistics.
[Sysname-sr-te] forwarding statistics enable
Use forwarding statistics interval to set the SR TE forwarding statistics interval.
Use undo forwarding statistics interval to restore the default.
forwarding statistics interval interval
The SR TE forwarding statistics interval is 30 seconds.
SR TE view
Interval: Sets the SR TE forwarding statistics interval, in the range of 5 to 65535 seconds.
# Set the SR TE forwarding statistics interval to 90 seconds.
[Sysname-sr-te] forwarding statistics interval 90
import-route
Use import-route sr-policy to enable BGP to redistribute routes from the SR-TE policy.
Use undo import-route sr-policy to restore the default.
BGP does not redistribute SR-TE policy routes.
After you execute this command, the system will redistribute the local SR-TE policy routes to the BGP routing table and advertise the routes to peers. Then, the peers can forward traffic based on the SR-TE policy.
# In BGP SR-TE policy address family view, enable BGP to redistribute routes from the SR-TE policy.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv4] import-route sr-policy
index
Use index to add a node to a SID list.
Use undo index to delete a node from a SID list.
index index-number mpls label label-value
undo index index-number
No nodes exist in a SID list.
SID list view
index-number: Specifies the node index, in the range of 1 to 65535.
mpls label label-value: Specifies the MPLS label value of the node, in the range of 0, 3, and 16 to 1048575.
# Add a node to SID list abc, and set the node index to 1 and MPLS label to 1000.
[Sysname-sr-te] segment-list abc
[Sysname-sr-te-sl-abc] index 1 mpls label 1000
policy
Use policy to create an SR-TE policy and enter its view, or enter the view of an existing SR-TE policy.
Use undo policy to delete an SR-TE policy and all the configuration in the SR-TE policy.
policy policy-name
undo policy policy-name
No SR-TE policies exist.
SR TE view
policy-name: Specifies an SR-TE policy name, a case-sensitive string of 1 to 59 characters.
# Create an SR-TE policy named srpolicy and enter its view.
preference
Use preference to set the preference for a candidate path and enter candidate path preference view, or enter an existing candidate path preference view.
Use undo preference to delete a candidate path preference and all the configuration in the candidate path preference view.
preference preferenc-value
undo preference preferenc-value
No candidate path preferences are set.
Candidate path view
preferenc-value: Specifies a candidate path preference in the range of 1 to 65535. A bigger value represents a higher preference.
A preference represents a candidate path of an SR-TE policy.
# Set the preference of an SR-TE policy candidate path to 20, and enter candidate path preference view.
Use reset segment-routing te forwarding statistics to clear SR TE forwarding statistics.
# Clear SR TE forwarding statistics.
<Sysname> reset segment-routing te forwarding statistics
segment-list
Use segment-list to create a SID list and enter its view, or enter the view of an existing SID list.
Use undo segment-list to delete a SID list and all the configuration in the SID list.
undo segment-list segment-list-name
No SID lists exist.
SR TE view
segment-list-name: Specifies the SID list name, a case-sensitive string of 1 to 128 characters.
# Create a SID list named abc and enter its view.
traffic-engineering
Use traffic-engineering to create and enter the SR TE view, or enter the existing SR TE view.
Use undo traffic-engineering to delete the SR TE view and all the configuration in the view.
traffic-engineering
The SR TE view does not exist.
Segment routing view
# Create and enter the SR TE view.
[Sysname-sr-te]
