01-Basic MPLS commands | 141.86 KB |
Basic MPLS commands
display mpls forwarding ilm
Use display mpls forwarding ilm to display Incoming Label Map (ILM) entries.
display mpls forwarding ilm [ label ] [ slot slot-number ]
label: Displays the ILM entry with the specified incoming label. The value range for this argument is 16 to 250000. If you do not specify an incoming label, this command displays ILM entry information for all incoming labels.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ILM entries on the active MPU.
An ILM entry records the label operation type, outgoing label, and other forwarding information.
After an LSR receives a labeled packet, it performs the following operations:
1. Identifies the ILM entry that matches the top label of the packet.
2. Performs the specified label operation.
3. Forwards the packet.
# Display all ILM entries.
<Sysname> display mpls forwarding ilm
Total ILM entries: 3
Flags: T - Forwarded through a tunnel
N - Forwarded through the outgoing interface to the nexthop IP address
B - Backup forwarding information
A - Active forwarding information
M – P2MP forwarding information
InLabel Oper VRF Flag SwapLabel Forwarding Info
30 SWAP 0 T 1000 1024
1279 POP 0 - - -
1407 SWAP 0 NA 1271 HGE1/0/3 50.2.0.2
NB 1270 Tun0 0.0.0.0
Total ILM entries |
Total number of ILM entries. |
InLabel |
Incoming label. |
Oper |
Operation type: · POP—Pops the label. · POPGO—Pops the label and forwards the packet to another tunnel. · SWAP—Swaps the label. |
VRF |
Index of a VPN instance. |
Flag |
Forwarding flag: · T—Forwarded through a tunnel. · N—Forwarded through the outgoing interface to the next hop IP address. · B—Backup forwarding information. · A—Active forwarding information. · M—P2MP forwarding information. |
SwapLabel |
Outgoing label value. |
Forwarding Info |
Forwarding information: · When the forwarding flag is N, the forwarding information records the outgoing interface and the next hop. · When the forwarding flag is T, the forwarding information records the NID. |
display mpls forwarding nhlfe
Use display mpls forwarding nhlfe to display Next Hop Label Forwarding Entry (NHLFE) entries.
display mpls forwarding nhlfe [ nid ] [ slot slot-number ]
nid: Displays the NHLFE entry with the specified NID. The NID value range is 0 to 4294967294. If you do not specify an NID, this command displays NHLFE entry information for all NIDs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NHLFE entries on the active MPU.
An NHLFE entry records label forwarding information, such as the outgoing label and outgoing interface. NHLFE entries are mainly used to add multiple labels to packets.
To add multiple labels to a packet, an LSR performs the following operations:
1. Obtains the bottom label and NID in the matching FIB or ILM entry.
2. Obtains the outer label in the NHLFE entry identified by the NID.
# Display the NHLFE entry with NID 2048.
<Sysname> display mpls forwarding nhlfe 2048
NID Tnl-Type Flag OutLabel Forwarding Info
2048 LSP NA 2025 HGE1/0/2 10.11.112.26
# Display all NHLFE entries.
Total NHLFE entries: 5
10 - TA - 2049
20 - TA - 2050
2049 LSP NA 3024 HGE1/0/2 10.11.112.26
TB 3026 20
2050 LSP NA 3025 HGE1/0/1 10.11.113.2
Total NHLFE entries |
Total number of NHLFE entries. |
NID |
NHLFE entry index. |
Tnl-Type |
Tunnel type: · LOCAL—Direct LSP tunnel. · LSP—Static LSP tunnel, or LSP tunnel signaled using LDP or BGP. · TE—TE tunnel. · CRLSP—Static CRLSP tunnel or CRLSP tunnel signaled using RSVP. · SRLSP—Static SRLSP tunnel or SRLSP tunnel signaled using IS-IS or OSPF. · - (a hyphen)—The tunnel type is invalid. |
Flag |
OutLabel |
Outgoing label. |
Forwarding Info |
display mpls interface
Use display mpls interface to display MPLS interface information, including the interface name, interface status, and interface MPLS MTU.
display mpls interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by the interface type and number. If you do not specify an interface, this command displays MPLS information for all MPLS-enabled interfaces.
# Display all MPLS interfaces.
<Sysname> display mpls interface
Interface Status MPLS MTU
HGE1/0/1 Up 1500
HGE1/0/2 Up 1500
Interface name. |
Status |
Interface state. |
MPLS MTU |
MPLS MTU (in bytes) of the interface. This field displays a hyphen (-) if the interface is not configured with an MPLS MTU. |
mpls enable
mpls mtu
display mpls label
Use display mpls label to display MPLS label usage information.
display mpls label { label-value1 [ to label-value2 ] | all }
label-value1: Specifies a label value. The value range for this argument is 16 to 250000. If used with the label-value2 argument, the label-value1 argument represents the start label of a label range.
to label-value2: Specifies the end label of the label range. The value range for the end label is 16 to 250000. If you specify a label range by using the label-value1 argument and the to label-value2 option, this command displays usage information for the specified range of labels.
all: Specifies all labels.
# Display usage information for labels 1025 through 1027.
<Sysname> display mpls label 1025 to 1027
Label Owner State
1025 LDP Alloc
1026 LDP Alloc
1027 LDP Inuse
Label |
Label value. |
Owner |
Protocol that is using the label: · Static—Static LSP. · LDP. · BGP. · StaticCR—Static CRLSP or static SRLSP. · RSVP. · L2VPN. · ISIS. · OSPF. This field displays a hyphen (-) when the label state is Idle. |
State |
Usage state of the label: · Idle—The label is idle. · Alloc—The label has been allocated. · Pending—The label has been released but is still used by an LSP entry. · Inuse—The label has been allocated and used by an LSP entry. |
display mpls lsp
Use display mpls lsp to display LSP information.
display mpls lsp [ egress | in-label label-value | ingress | outgoing-interface interface-type interface-number | protocol { bgp | isis | ldp | local | ospf | sr-te | sr-policy | rsvp-te [ p2mp ] | static | static-cr } | transit ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6 [ ipv6-address prefix-length ] ] [ verbose ]
egress: Displays the LSPs taking the current LSR as egress.
in-label label-value: Displays the LSPs using the specified label as the incoming label. The value range for the label-value argument is 0 to 250000.
ingress: Displays the LSPs taking the current LSR as ingress.
outgoing-interface interface-type interface-number: Displays the LSPs using the specified interface as the outgoing interface. The interface-type interface-number argument specifies an interface by its type and number.
protocol: Displays the LSPs established by a protocol.
bgp: Displays BGP LSPs.
isis: Displays IS-IS SRLSPs.
ldp: Displays LDP LSPs.
local: Displays LSPs destined for the direct next hops, or displays LSPs that use the local MPLS TE tunnel interfaces or tunnel bundle interfaces as the LSP heads.
ospf: Displays OSPF SRLSPs.
sr-te: Displays SRLSPs established by SR-TE.
sr-policy: Displays SRLSPs established by SR policies.
rsvp-te: Displays CRLSPs established by RSVP-TE.
p2mp: Displays P2MP CRLSPs established by RSVP-TE. If you do not specify this keyword, the command displays information about P2P CRLSPs and P2MP CRLSPs established by RSVP-TE.
static: Displays static LSPs.
static-cr: Displays static CRLSPs and static SRLSPs.
transit: Displays the LSPs taking the current LSR as a transit LSR.
vpn-instance vpn-instance-name: Displays LSPs for the specified MPLS L3VPN instance. The vpn-instance-name is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays LSPs for the public network.
ipv4-address mask-length: Displays the IPv4 LSP for an FEC specified by an IPv4 address and a mask length. The value range for the mask length is 0 to 32.
ipv6: Displays IPv6 LSP information. If you do not specify this keyword, the command displays IPv4 LSP information.
ipv6-address prefix-length: Displays the IPv6 LSP for an FEC specified by an IPv6 address and a prefix length. The value range for the prefix length is 0 to 128.
verbose: Displays detailed LSP information. If you do not specify this keyword, the command displays brief LSP information.
If you do not specify any parameters, this command displays brief information about all LSPs. If you specify only the verbose keyword, this command displays detailed information about all LSPs.
# Display brief information about all IPv4 LSPs.
<Sysname> display mpls lsp
FEC Proto In/Out Label Out Inter/NHLFE/LSINDEX
100.100.100.100/24 LDP -/1049 HGE1/0/1
Backup -/1050 HGE1/0/2
100.100.100.10/24 LDP -/1051 HGE1/0/3
100.100.100.10/24 LDP -/1049 HGE1/0/4
101.100.100.10/24 LDP 1026/1049 HGE1/0/1
102.100.100.10/24 LDP 1027/- -
103.100.100.10/24 LDP 1028/1049 Tun10
110.100.100.20/24 BGP -/1049 HGE1/0/1
111.100.100.10/24 BGP 2028/1049 HGE1/0/1
112.100.100.10/24 BGP 2029/- HGE1/0/1
113.100.100.10/24 BGP 2030/1049 NHLFE1500
114.100.100.10/24 BGP 2031/1050 Tun100
100.100.100.100 Local -/- HGE1/0/1
101.101.101.101/32 Static -/100 HGE1/0/1
- Static 100/200 HGE1/0/1
- Static 101/- HGE1/0/1
200.200.200.200/64000/64000 RSVP -/1030 HGE1/0/5
201.200.200.200/64000/64000 RSVP 1024/1031 HGE1/0/5
202.200.200.200/64000/64000 RSVP 1025/- -
150.140.150.100/64001/0 StaticCR -/1000 HGE1/0/5
- StaticCR 50/1001 HGE1/0/5
- StaticCR 51/- -
110.100.100.20/32 ISIS -/16000 HGE1/0/5
Backup -/17000 LSINDEX100
20.0.0.20/32/100 ISIS -/17000 HGE1/0/1
100.100.100.100/16000 BGP 16000/- HGE1/0/1
Table 5 Command output
FEC |
Forwarding equivalence class: · IP address/mask—Classifies FECs by destination address. · IP address/mask/LSINDEX—Classifies FECs by label stack index. · IP address/In Label—The LSP is created through BGP Peer-Set-SID. · IP address—Classifies FECs by next hop. · IP address/Out Label—Classifies FECs by next hop and outgoing label. · Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE or static SRLSP FEC. · Endpoint/Color—Classifies FECs by the IP address and color value of the destination node of the SR policy. · - (a hyphen)—The LSP is a static transit LSP, static egress LSP, static transit CRLSP, static egress CRLSP, adjacency segment for static SRLSPs, or adjacency path for aggregation group member interfaces. · Backup—The LSP is a backup LSP of the previous LSP. |
Proto |
Label distribution protocol: · LDP. · BGP. · IS-IS. · RSVP. · Static. · StaticCR—Static CRLSP or static SRLSP. · Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · OSPF. · SR-TE—SRLSP established by SR-TE. · RSVP-P2MP—P2MP CRLSP established by RSVP-TE. · SRPolicy—SRLSP established by SR policies. |
In/Out Label |
Incoming label/outgoing label. |
Out Inter/NHLFE/LSINDEX |
Outgoing interface name, NHLFE entry index, or label stack index of the LSP. NHLFEnumber specifies the ingress LSP selected for the current LSP after route recursion. The ingress LSP is the one that matches the NHLFE entry with an NID of number. LSINDEXnumber specifies the ingress LSP selected for the current LSP after route recursion. The ingress LSP is the one that matches the LSINDEX entry with a label stack index of number. |
# Display IPv6 LSP information.
<Sysname> display mpls lsp ipv6
FEC : 100:100:100:100:100:100:100:100/128
Protocol : BGP In-Label : 1200
Out-Label: 1300 Out-Interface: HGE1/0/1
BkLabel : 1400 BkInterface : HGE1/0/2
Table 6 Command output
FEC |
Forwarding equivalence class: · IP address/mask—Classifies FECs by destination address. · IP address—Classifies FECs by next hop. · IP address/Out Label—Classifies FECs by next hop and outgoing label. · Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC. · Endpoint/Color—Classifies FECs by the IP address and color value of the destination node of the SR policy. · - (a hyphen)—The LSP is a static transit LSP, static egress LSP, static transit CRLSP, or static egress CRLSP. |
Protocol |
Label distribution protocol: · LDP. · BGP. · RSVP. · Static. · StaticCR—Static CRLSP. · Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · RSVP-P2MP—P2MP CRLSP established by RSVP-TE. |
BkLabel |
Outgoing label of the backup LSP. |
BkInterface |
Outgoing interface of the backup LSP. |
# Display detailed information about all LSPs.
<Sysname> display mpls lsp verbose
Destination : 56.10.10.2
FEC : 56.10.10.2/32
Protocol : LDP
LSR Type : Egress
Service : -
In-Label : 1024
State : Active
Destination : 56.10.10.4
FEC : 56.10.10.2/32
Protocol : LDP
LSR Type : Transit
Service : Statistics
In-Label : 1026
Path ID : 0x40000000.1
State : Active
Out-Label : 1800
Nexthop : 10.1.1.2
BkLabel : 1900
BkNexthop : 20.1.1.2
FEC : 56.10.10.2/32
Protocol : LDP
LSR Type : Ingress
Service : -
NHLFE ID : 2000
State : Active
Out-Label : 1800
Nexthop : 10.1.1.2
Destination : 110.100.100.20
FEC : 110.100.100.20/32
Protocol : ISIS
LSR Type : Ingress
Service :
State : Active
Out-Label : 16000
Nexthop : 10.1.1.2
Out-Interface: HGE1/0/5
BkLabel : 17000
BkLsIndex : 100
Destination : 20.0.0.20
FEC : 20.0.0.20/32/100
Protocol : ISIS
LSR Type : Ingress
Service :
Out-Label : 17000,2175,16001
Nexthop : 10.1.1.2
LsIndex : 100
Destination : -
FEC : -
Protocol : BGP
LSR Type : Transit
Service : -
In-Label : 16000
State : Active
Out-Label : -
OriginNexthop: 100.100.100.100
Nexthop : 10.1.1.2
Path ID : 0x40000000.2
State : Active
Out-Label : -
OriginNexthop: 101.101.101.101
Nexthop : 11.1.1.2
Out-Interface: HGE1/0/2
Path ID : 0x40000000.3
State : Active
Out-Label : -
OriginNexthop: 102.102.102.102
Nexthop : 12.1.1.2
Out-Interface: HGE1/0/3
Table 7 Command output
Destination |
LSP destination address. |
FEC |
Forwarding equivalence class: · IP address/mask—Classifies FECs by destination address. · IP address—Classifies FECs by next hop. · IP address/Out Label—Classifies FECs by next hop and outgoing label. · Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC. · - (a hyphen)—The LSP is a static transit LSP, static egress LSP, static transit CRLSP, static egress CRLSP, or adjacency path for aggregation group member interfaces. |
Protocol |
Label distribution protocol: · LDP. · BGP (instance-name)—The instance-name specifies a BGP instance name. The value of default represents the default BGP instance. · IS-IS. · RSVP. · Static. · StaticCR—Static CRLSP or static SRLSP. · Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · OSPF. · SR-TE. · RSVP-P2MP—P2MP CRLSP established by RSVP-TE. |
LSR Type |
LSR type: · Ingress—The current LSR is the ingress node of the LSP. · Transit—The current LSR is a transit node of the LSP. · Egress—The current LSR is the egress node of the LSP. |
Service |
Service deployed on the LSP. |
Path ID |
Forwarding path. The value is in the format of 0xnn.m. The nn represents the NHLFE group ID of the outer LSPs that carry the current LSP, and m represents the sequence number of the equivalence path. |
NHLFE ID |
State |
LSP state: · Active—The LSP is in use. · Inactive—The LSP is idle. |
LsIndex |
Label stack index of the LSP. |
BkLabel |
BkNexthop |
Next hop address of the backup LSP. |
BkInterface |
BkLsIndex |
Label stack index of the backup LSP. |
display mpls lsp statistics
Use display mpls lsp statistics to display LSP statistics.
display mpls lsp statistics [ ipv6 ]
ipv6: Displays IPv6 LSP statistics. If you do not specify this keyword, the command displays IPv4 LSP statistics.
# Display IPv4 LSP statistics.
<Sysname> display mpls lsp statistics
LSP Type Ingress/Transit/Egress Active
Static LSP 0/0/0 0/0/0
Static CRLSP 0/0/0 0/0/0
LDP LSP 2/2/1 2/2/1
RSVP CRLSP 0/0/0 0/0/0
BGP LSP 0/0/0 0/0/0
Local LSP 2/0/0 2/0/0
ISIS LSP 0/0/0 0/0/0
OSPF LSP 3/3/1 3/3/1
SR LSP 1/0/0 1/0/0
SR Policy LSP 1/1/0 1/1/0
Total 4/2/1 4/2/1
# Display IPv6 LSP statistics.
<Sysname> display mpls lsp statistics ipv6
LDP LSP 6/6/2 6/6/2
BGP LSP 0/0/0 0/0/0
OSPF LSP 0/0/0 0/0/0
SR LSP 0/0/0 0/0/0
SR Policy LSP 0/0/0 0/0/0
Total 8/6/2 8/6/2
Table 8 Command output
LSP Type |
LSP types: · Static LSP. · Static CRLSP—Static CRLSP or static SRLSP. · LDP LSP. · Local LSP—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head. · RSVP CRLSP. · BGP LSP. · IS-IS. · OSPF. · SR LSP—Dynamic SRLSPs established by SR and stateful PCE. · SR Policy LSP—SRLSP established by SR policies. |
Total |
Total number of LSPs. |
Ingress |
Number of LSPs that take the local device as the ingress node. |
Transit |
Number of LSPs that take the local device as a transit node. |
Egress |
Number of LSPs that take the local device as the egress node. |
Active |
Number of active LSPs of a type. |
display mpls nib
Use display mpls nib to display MPLS Nexthop Information Base (NIB) information.
display mpls nib [ nib-id ]
nib-id: Specifies a next hop ID in the range of 1 to FFFFFFFFFFFFFFFE. If you do not specify a next hop, this command displays information about all MPLS next hops.
# Display information about all MPLS next hops.
<Sysname> display mpls nib
NIB ID: 0x40000000
Users: 1
Status: Active
ECMP number: 1
Outgoing NHLFE ID: 1024
Backup outgoing NHLFE ID: 1027
Table 9 Command output
NIB ID |
ID of the next hop. |
Users |
Number of ILM entries that use this next hop. |
Status |
Next hop status: · Active—The next hop is active. · Dummy—The next hop is inactive. |
ECMP number |
Number of equal-cost NHLFE entries. |
Outgoing NHLFE ID |
ID of the NHLFE entry to which the next hop corresponds. |
Backup outgoing NHLFE ID |
ID of the backup NHLFE entry. |
display mpls nid
Use display mpls nid to display usage information for NIDs.
display mpls nid [ nid-value1 [ to nid-value2 ] ]
nid-value1: Specifies an NID. The value range for this argument is 0 to 65535. If used with the nid-value2 argument, the nid-value1 argument represents the start NID of an NID range.
to nid-value2: Specifies the end NID of the NID range. The value range for the end NID is 0 to 65535. If you specify an NID range by using the nid-value1 argument and the to nid-value2 option, this command displays usage information for the specified range of NIDs.
NIDs are 32-bit binary numbers. They include fixed NIDs and dynamic NIDs.
· Fixed NIDs—Generated for tunnel interfaces or tunnel bundle interfaces. The highest four bits are a value other than 0000.
· Dynamic NIDs—NIDs except fixed NIDs. The highest four bits are 0s.
This command displays usage information only for dynamic NIDs.
If you do not specify any parameters, this command displays usage information for all dynamic NIDs.
# Display usage information for dynamic NIDs 1028 through 1500.
<Sysname> display mpls nid 1028 to 1500
NID alloc state: '.' means not used, '$' means used
1028 :...$.... ........ ........ ........ ........ ........ ........ ........
1092 :........ ........ ........ ........ ........ ........ ........ ........
1156 :........ ........ ........ ........ ........ ........ ........ ........
1220 :........ ........ ........ ........ ........ ........ ........ ........
1284 :........ ........ ........ ........ ........ ........ ........ ........
1348 :........ ........ ........ ........ ........ ........ ........ ........
1412 :........ ........ ........ ........ ........ ........ ........ ........
1476 :........ ........ ........ .
display mpls summary
Use display mpls summary to display MPLS summary information.
# Display MPLS summary information.
<Sysname> display mpls summary
MPLS LSR ID : 1.1.1.1
Egress Label Type: Non-null
Labels:
Range Idle Owner
16-14999 14984 StaticPW
Static
StaticCR
Static SR Adj
TE
15000-15999(default SRLB) 1000 Default SR Adj
Static
StaticCR
Static SR Adj
TE
16000-18000 0 LDP
RSVP
BGP
BGP SR EPE
OSPF SR Adj
ISIS SR Adj
mLDP
VPWS
VPLS
Static
StaticCR
Static SR Adj
TE
16000-24000(SRGB) 8001 OSPF-1 SR Prefix
16000-55999(default SRGB, reusable) 40000 Default SR Prefix
Static
StaticCR
Static SR Adj
TE
Protocols:
Type State
LDP Normal
RSVP Normal
BGP(default) Normal
Static Normal
CCC Normal
StaticCR Normal
TE Normal
ISIS Normal
OSPF Normal
SRPolicy Normal
mLDP Normal
Table 10 Command output
Egress Label Type |
Label type that the egress node assigns to the penultimate hop: · Implicit-null. · Explicit-null. · Non-null. |
Labels |
Label information. |
Range |
Label range. · If labels within the label range can be reused, this field displays (reusable) behind the label range. · If the default label range is used, this field displays (default) behind the label range. · If the configured global label range is used, this field displays (global) behind the label range. · If the label range is the SRGB range, this field displays (SRGB) behind the label range. · If the label range is the SRLB range, this field displays (SRLB) behind the label range. |
Idle |
Number of idle labels in the label range. |
Owner |
Label range owner. · LDP. · mLDP.This option is not supported in the current software version. · BGP. · RSVP. · Static—Static LSP. · StaticCR—Static CRLSP. · StaticPW—Static PW. · Static SR Adj—Static SR adjacency SID. · Default SR Adj—Default SR adjacency SID. · SR Adj—Configured global SR adjacency SID. · Default SR Prefix—Default SR prefix SID. · SR Prefix—Configured global SR prefix SID. · OSPF SR Adj—SR adjacency SID automatically allocated to OSPF. · ISIS SR Adj—SR adjacency SID automatically allocated to IS-IS. · ISIS-1 SR Prefix—SR prefix SID of IS-IS process 1. · OSPF-1 SR Prefix—SR prefix SID of OSPF process 1. · VPWS. · VPLS. · BGP SR EPE—BGP PeerNode SID, PeerAdj SID, or PeerSet SID. · VRF—Label range specified for all VPN instances. |
Protocols |
Label distribution protocols that generated LSPs and their running states. |
Type |
Protocol type: · LDP. · mLDP.This option is not supported in the current software version. · BGP (instance-name). The instance-name specifies a BGP instance name. The value of default represents the default BGP instance. · RSVP. · Static—Static LSP. · StaticCR—Static CRLSP. · TE. · CCC. · ISIS. · OSPF. · SRPolicy. |
State |
Label distribution protocol running state: · Normal—The protocol is in normal state. · Recover—The protocol is in the GR process. |
mpls bandwidth-based-sharing
Use mpls bandwidth-based-sharing to enable bandwidth-based load sharing on an MPLS transit node.
Use undo mpls bandwidth-based-sharing to disable bandwidth-based load sharing on an MPLS transit node.
Bandwidth-based load sharing is disabled on an MPLS transit node.
If equal-cost LDP LSPs exist on a transit node, the node evenly transmits MPLS packets through the LSPs. After you enable this feature, MPLS packets are transmitted through the LSPs in the proportion calculated based on the bandwidth of the egress interfaces.
# Enable bandwidth-based load sharing on an MPLS transit node.
[Sysname] mpls bandwidth-based-sharing
mpls enable
Use mpls enable to enable MPLS on an interface.
Use undo mpls enable to disable MPLS on an interface.
mpls enable
undo mpls enable
MPLS is disabled on an interface.
Interface view
# Enable MPLS on HundredGigE 1/0/1.
<Sysname> System-view
[Sysname-HundredGigE1/0/1] mpls enable
mpls forwarding split-horizon
Use mpls forwarding split-horizon to enable split horizon for MPLS forwarding.
Use undo mpls forwarding split-horizon to disable split horizon for MPLS forwarding.
Split horizon is disabled for MPLS forwarding.
# Enable split horizon for MPLS forwarding.
[Sysname] mpls forwarding split-horizon
mpls label advertise
Use mpls label advertise to specify the type of label the egress node will advertise to the penultimate hop.
Use undo mpls label advertise to restore the default.
mpls label advertise { explicit-null | implicit-null | non-null }
As egress, the device advertises an implicit null label to the penultimate hop.
explicit-null: Specifies the egress node to advertise an explicit null label of 0 or 2 to the penultimate hop. The explicit null label value is 0 in IPv4 networks and 2 in IPv6 networks.
implicit-null: Specifies the egress node to advertise an implicit null label of 3 to the penultimate hop.
non-null: Specifies the egress node to advertise a non-null label to the penultimate hop.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels.
As a penultimate hop, the device accepts the implicit null label, explicit null label, or non-null label advertised by the egress node.
For LDP LSPs, the mpls label advertise command triggers LDP to delete the LSPs established before the command is executed and re-establishes new LSPs.
For BGP LSPs, the mpls label advertise command takes effect only on the BGP LSPs established after the command is executed. To apply the new setting to BGP LSPs established before the command is executed, delete the routes corresponding to the BGP LSPs, and then redistribute the routes.
# Configure the egress node to advertise an implicit null label to the penultimate hop.
[Sysname] mpls label advertise implicit-null
reset mpls ldp
mpls label range
Use mpls label range to set the value range for dynamic labels that the device can allocate.
Use undo mpls label range to restore the default.
mpls label range minimum maximum
No value range is configured for dynamic labels that the device can allocate.
minimum: Specifies the minimum label value that the device can allocate. The value range for this argument is 15000 to 249999.
maximum: Specifies the maximum label value that the device can allocate. The value range for this argument is 15001 to 250000.
This command sets the value range in which label distribution protocols can dynamically allocate labels.
This command does not take effect on static LSP labels, static CRLSP labels, static SRLSP labels, static PW labels, or SRGBs. For more information about static LSP labels, see "Configuring a static LSP." For more information about static CRLSP labels, see "Configuring a static CRLSP." For more information about static PW labels, see "Configuring VPLS" and "Configuring MPLS L2VPN." For more information about static SRLSPs and SRGBs, see MPLS SR configuration in Segment Routing Configuration Guide.
If you configure this command multiple times, the most recent configuration takes effect.
# Set the value range to 10000 to 15000 for dynamic labels that the device can allocate.
[Sysname] mpls label range 10000 15000
mpls lsr-id
Use mpls lsr-id to configure an LSR ID for the local LSR.
Use undo mpls lsr-id to restore the default.
mpls lsr-id lsr-id
undo mpls lsr-id
An LSR has no LSR ID.
lsr-id: Specifies an ID for identifying the LSR, in dotted decimal notation.
As a best practice, use the address of a loopback interface on the LSR as the LSR ID.
If no LDP LSR ID is configured for the public network or a VPN instance, LDP uses the MPLS LSR ID configured by the mpls lsr-id command. If you modify the MPLS LSR ID, the LDP sessions in the public network or VPN instance will be re-established. To configure an LDP LSR ID for the public network or a VPN instance, use the lsr-id command in LDP view or LDP-VPN instance view.
# Configure the LSR ID as 3.3.3.3 for the local node.
[Sysname] mpls lsr-id 3.3.3.3
# Change the LSR ID to 4.4.4.4.
[Sysname] mpls lsr-id 4.4.4.4
All LDP sessions using the MPLS LSR ID will be reset. Continue? [Y/N]:Y
lsr-id
mpls mtu
Use mpls mtu to set the MPLS MTU for an interface.
Use undo mpls mtu to restore the default.
mpls mtu size
undo mpls mtu
The MPLS MTU of an interface is not configured. Fragmentation for MPLS packets is based on the MTU set on the interface by the ip mtu command. If no MTU is set by the ip mtu command, the fragmentation is based on the MTU of the interface. The length of a fragment does not include that of the MPLS label. Thus, after an MPLS label is added into a fragment, the length of the MPLS fragment might exceed the interface MTU.
Interface view
size: Specifies the MPLS MTU of the interface, in the range of 46 to 65535 bytes.
This command is effective only when MPLS is enabled on the interface.
If the MPLS MTU is larger than the interface MTU, data forwarding might fail.
MPLS TE tunnel interfaces do not support this command.
# Set the MPLS MTU of HundredGigE 1/0/1 to 1000 bytes.
[Sysname-HundredGigE1/0/1] mpls mtu 1000
mpls ttl expiration enable
Use mpls ttl expiration enable to enable sending MPLS TTL-expired messages.
Use undo mpls ttl expiration enable to disable sending MPLS TTL-expired messages.
The MPLS TTL-expired messages sending feature is enabled.
This command enables an LSR to generate an ICMP TTL-expired message upon receiving an MPLS packet with TTL being 1.
· If the MPLS packet has only one label, the LSR sends the ICMP TTL-expired message back to the source through IP routing.
· If the MPLS packet has multiple labels, the LSR forwards the ICMP TTL-expired message along the LSP of the MPLS packet to the egress node. Then, the egress node sends the message back to the source.
# Disable sending MPLS TTL-expired messages.
[Sysname] undo mpls ttl expiration enable
mpls ttl propagate
Use mpls ttl propagate to enable TTL propagation.
Use undo mpls ttl propagate to disable TTL propagation.
mpls ttl propagate public
undo mpls ttl propagate public
TTL propagation is enabled for public network packets.
public: Specifies public network packets.
When TTL propagation is enabled, MPLS performs the following operations:
· Copies the IP TTL to the label TTL for packets entering the MPLS network.
· Copies the label TTL to the IP TTL for packets leaving the MPLS network.
If you enable TTL propagation on both ingress and egress, the IP tracert facility can show the real path in the MPLS network.
When TTL propagation is disabled, MPLS performs the following operations:
· Sets the label TTL to 255 for packets entering the MPLS network.
· Pops the label for packets leaving the MPLS network, without copying the label TTL value to the IP TTL.
The IP tracert facility cannot show the real path in the MPLS network.
Within an MPLS network, TTL is always copied between the labels of an MPLS packet. The mpls ttl propagate command affects only the propagation between IP TTL and label TTL.
As a best practice, set the same TTL processing mode on all LSRs of an LSP.
To forward packets for a VPN, configure the TTL propagation feature and the diffserv-mode command as described in Table 11.
Table 11 TTL propagation feature and diffserv-mode command configuration
TTL propagation state of the public network |
diffserv-mode command configuration |
TTL propagation state of the VPN |
Enable |
Do not execute the command. |
Enable |
Enable |
Execute the command with the uniform keyword. |
Enable |
Enable |
Execute the command with the pipe keyword. |
Disable |
# Enable TTL propagation for public network packets.
[Sysname] mpls ttl propagate public
diffserv-mode (ACL and QoS Command Reference)
snmp-agent trap enable mpls
Use snmp-agent trap enable mpls to enable SNMP notifications for MPLS.
Use undo snmp-agent trap enable mpls to disable SNMP notifications for MPLS.
SNMP notifications for MPLS are disabled.
To report critical MPLS events to an NMS, enable SNMP notifications for MPLS. For MPLS event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for MPLS.
[Sysname] snmp-agent trap enable mpls
