- 02-Layer 2-LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-Port isolation commands
- 06-VLAN commands
- 07-Loopback, null, and inloopback interface commands
- 08-VLAN mapping commands
- 09-VLAN termination commands
- 10-Loop detection commands
- 11-LLDP commands
- 12-Service loopback group commands
- 13-Spanning tree commands
- 14-Cut-through Layer 2 forwarding commands
14-Cut-through Layer 2 forwarding commands | 33.46 KB |
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
