- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-MFF commands
- 22-Crypto engine commands
- 23-FIPS commands
00-Preface | 100.78 KB |
Preface
This command reference describes security configuration commands, including:
· Commands for configuring identity authentication features (such as AAA and PKI).
· Commands for access security features (such as 802.1X, MAC authentication, portal, and port security).
· Commands for data security features (such as public key management, IPsec, SSL, SSH, crypto engine, and FIPS).
· Commands for attack protection features (such as IP source guard, ARP attack protection, MFF, uRPF, and attack detection and prevention).
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6861 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
