01-Fundamentals Command Reference
HomeSupportSwitchesS6860 SeriesReference GuidesCommand ReferencesH3C S6860 Switch Series Command References-Release 26xx-6W10301-Fundamentals Command Reference
14-Preprovisioning commands
14-Preprovisioning commands 48.35 KB
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
·     duplex
·     speed
·     sflow
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
 speed 10000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision model model
undo provision model
Preprovisioning is disabled.
Slot view
model model: Specifies the IRF member device to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
CAUTION
CAUTION:
When you disable preprovisioning on a slot, the device removes all preconfigured settings for the slot.
This command allows you to enable preprovisioning for member devices that have not joined the IRF fabric.
The device automatically creates interfaces when preprovisioning is enabled for a member device. The display interface command will not display these interfaces until the member device joins the IRF fabric.
# Enable preprovisioning for the S6860-54HF device on a slot.
[Sysname] slot 2
[Sysname-slot-2] provision model S6860-54HF
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned member devices that repeatedly join and leave the IRF fabric might leave a number of commands that were not applied in memory. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
slot
Use slot to select a slot to provision and enter slot view.
slot slot-number
slot-number: Specifies an IRF member device by its member ID.
# Enter the view of a slot.
[Sysname] slot 2
[Sysname-slot-2]
provision
  • Become a Partner
  • Partner Resources
