00-Preface
Preface
This guide describes the procedures for installing, registering, uninstalling, and upgrading the SNA Center.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C VNF Manager app.
Conventions
This section describes the conventions used in the documentation.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Documentation feedback
We appreciate your comments.
