00-Preface | 100.54 KB |
Preface
This configuration guide describes FCoE fundamentals and configuration. In an FCoE solution, the server uses an FCoE-capable Ethernet adapter. The FCoE forwarder integrates the functions of both the traditional IP switch and the FC switch. The FCoE solution reduces the number of network adapters, switches, and cables, and reduces the network operation and maintenance workload.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500G-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
