05-Layer 3—IP Services Configuration Guide
HomeSupportSwitchesH3C S12500G-AF Switch SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release759X-6W10005-Layer 3—IP Services Configuration Guide
12-IPv6 basics configuration
12-IPv6 basics configuration 489.17 KB
Configuring basic IPv6 settings· 1
About IPv6· 1
IPv6 features· 1
IPv6 addresses· 2
IPv6 path MTU discovery· 4
IPv6 transition technologies· 5
Protocols and standards· 6
IPv6 basics tasks at a glance· 6
Configuring an IPv6 global unicast address· 6
About IPv6 global unicast address· 6
Restrictions and guidelines· 7
Generating an EUI-64 IPv6 address· 7
Manually assigning an IPv6 global unicast address· 7
Stateless address autoconfiguration· 8
Configuring prefix-specific address autoconfiguration· 9
Configuring an IPv6 link-local address· 9
About IPv6 link-local address· 9
Restrictions and guidelines· 9
Configuring automatic generation of an IPv6 link-local address for an interface· 10
Manually assigning an IPv6 link-local address to an interface· 10
Configuring an IPv6 anycast address· 11
Configuring path MTU discovery· 11
Setting the interface MTU for IPv6 packets· 11
Setting a static path MTU for an IPv6 address· 11
Setting the aging time for dynamic path MTUs· 12
Controlling sending ICMPv6 messages· 12
Configuring the rate limit for ICMPv6 error messages· 12
Enabling replying to multicast echo requests· 12
Enabling sending ICMPv6 destination unreachable messages· 13
Enabling sending ICMPv6 time exceeded messages· 13
Enabling sending ICMPv6 redirect messages· 14
Specifying the source address for unsolicited ICMPv6 packets· 14
Specifying the source IPv6 address for outgoing ICMPv6 replies· 15
Enabling Layer 3 packet statistics counting· 15
Enabling IPv6 local fragment reassembly· 15
Enabling discarding IPv6 packets that contain extension headers· 16
Display and maintenance commands for IPv6 basics· 16
Basic IPv6 settings configuration examples· 18
Example: Configuring basic IPv6 settings· 18
Configuring IPv6 neighbor discovery· 23
About IPv6 neighbor discovery· 23
ICMPv6 messages used by IPv6 neighbor discovery· 23
Address resolution· 23
Neighbor reachability detection· 24
Duplicate address detection· 24
Router/prefix discovery and stateless address autoconfiguration· 25
Redirection· 25
Protocols and standards· 25
IPv6 neighbor discovery tasks at a glance· 25
Configuring a static neighbor entry· 26
Setting the dynamic neighbor learning limit on an interface· 27
Enabling unsolicited NA learning· 27
Setting the aging timer for ND entries in stale state· 28
Minimizing link-local ND entries· 29
Setting the hop limit 29
Configuring RA message sending and parameters· 29
About RA message parameters· 29
Restrictions and guidelines· 30
Enabling the sending of RA messages· 30
Configuring parameters for RA messages· 31
Specifying DNS server information in RA messages· 32
Specifying DNS suffix information in RA messages· 33
Suppressing advertising DNS information in RA messages· 33
Setting the maximum number of attempts to send an NS message for DAD·· 34
Configuring ND snooping in a VLAN· 35
About ND snooping in a VLAN· 35
Enabling ND snooping· 36
Setting the ND snooping entry learning limit 36
Configuring ND snooping entry related parameters· 36
Configuring ND snooping in a VXLAN· 37
About ND snooping in a VXLAN· 37
Procedure· 37
Enabling ND proxy· 38
About ND proxy· 38
Enabling common ND proxy· 39
Enabling local ND proxy· 39
Enabling ND proxy forwarding· 40
Configuring a customer-side or a network-side port 40
Configuring IPv6 ND direct route advertisement 41
About IPv6 ND direct route advertisement 41
Application in Layer 3 access networks· 41
Application in L2VPN access to L3VPN networks· 41
Procedure· 42
Enabling recording user IPv6 address conflicts· 42
Enabling recording user port migrations· 43
Enabling ND logging for user online and offline events· 43
Display and maintenance commands for IPv6 ND·· 43
IPv6 ND configuration examples· 45
Example: Configuring ND snooping· 45
About IPv6
IPv6, also called IP next generation (IPng), was designed by the IETF as the successor to IPv4. One significant difference between IPv6 and IPv4 is that IPv6 increases the IP address size from 32 bits to 128 bits.
IPv6 features
Simplified header format
IPv6 removes several IPv4 header fields or moves them to the IPv6 extension headers to reduce the length of the basic IPv6 packet header. The basic IPv6 packet header has a fixed length of 40 bytes to simplify IPv6 packet handling and improve forwarding efficiency. Although the IPv6 address size is four times the IPv4 address size, the basic IPv6 packet header size is only twice the size of the option-less IPv4 packet header.
Figure 1 IPv4 packet header format and basic IPv6 packet header format
Larger address space
IPv6 can provide 3.4 x 1038 addresses to meet the requirements of hierarchical address assignment for both public and private networks.
Hierarchical address structure
IPv6 uses a hierarchical address structure to speed up route lookup and reduce the IPv6 routing table size through route aggregation.
Address autoconfiguration
To simplify host configuration, IPv6 supports stateful and stateless address autoconfiguration.
·     Stateful address autoconfiguration enables a host to acquire an IPv6 address and other configuration information from a server (for example, a DHCPv6 server). For more information about DHCPv6 server, see "Configuring the DHCPv6 server."
·     Stateless address autoconfiguration enables a host to automatically generate an IPv6 address and other configuration information by using its link-layer address and the prefix information advertised by a router.
To communicate with other hosts on the same link, a host automatically generates a link-local address based on its link-layer address and the link-local address prefix (FE80::/10).
Built-in security
IPv6 defines extension headers to support IPsec. IPsec provides end-to-end security and enhances interoperability among different IPv6 applications.
QoS support
The Flow Label field in the IPv6 header allows the device to label the packets of a specific flow for special handling.
Enhanced neighbor discovery mechanism
The IPv6 neighbor discovery protocol uses a group of ICMPv6 messages to manage information exchange among neighboring nodes on the same link. The group of ICMPv6 messages replaces ARP messages, ICMPv4 router discovery messages, and ICMPv4 redirect messages and provides a series of other functions.
Flexible extension headers
IPv6 eliminates the Options field in the header and introduces optional extension headers to provide scalability and improve efficiency. The Options field in the IPv4 packet header contains a maximum of 40 bytes, whereas the IPv6 extension headers are restricted to the maximum size of IPv6 packets.
IPv6 addresses
IPv6 address format
An IPv6 address is represented as a set of 16-bit hexadecimals separated by colons (:). An IPv6 address is divided into eight groups, and each 16-bit group is represented by four hexadecimal numbers, for example, 2001:0000:130F:0000:0000:09C0:876A:130B.
To simplify the representation of IPv6 addresses, you can handle zeros in IPv6 addresses by using the following methods:
·     The leading zeros in each group can be removed. For example, the above address can be represented in a shorter format as 2001:0:130F:0:0:9C0:876A:130B.
·     If an IPv6 address contains one or more consecutive groups of zeros, they can be replaced by a double colon (::). For example, the above address can be represented in the shortest format as 2001:0:130F::9C0:876A:130B.
IMPORTANT
IMPORTANT:
A double colon can appear once or not at all in an IPv6 address. This limit allows the device to determine how many zeros the double colon represents and correctly convert it to zeros to restore a 128-bit IPv6 address.
An IPv6 address consists of an address prefix and an interface ID, which are equivalent to the network ID and the host ID of an IPv4 address.
An IPv6 address prefix is written in IPv6-address/prefix-length notation. The prefix-length is a decimal number indicating how many leftmost bits of the IPv6 address are in the address prefix.
IPv6 address types
IPv6 addresses include the following types:
·     Unicast address—An identifier for a single interface, similar to an IPv4 unicast address. A packet sent to a unicast address is delivered to the interface identified by that address.
·     Multicast address—An identifier for a set of interfaces (typically belonging to different nodes), similar to an IPv4 multicast address. A packet sent to a multicast address is delivered to all interfaces identified by that address.
Broadcast addresses are replaced by multicast addresses in IPv6.
·     Anycast address—An identifier for a set of interfaces (typically belonging to different nodes). A packet sent to an anycast address is delivered to the nearest interface among the interfaces identified by that address. The nearest interface is chosen according to the routing protocol's measure of distance.
The type of an IPv6 address is designated by the first several bits, called the format prefix.
Table 1 Mappings between address types and format prefixes
Format prefix (binary)
IPv6 prefix ID
Unicast address
Unspecified address
00...0 (128 bits)
::/128
Loopback address
00...1 (128 bits)
::1/128
Link-local address
1111111010
FE80::/10
Global unicast address
Other forms
N/A
Multicast address
11111111
FF00::/8
Anycast address
Anycast addresses use the unicast address space and have the identical structure of unicast addresses.
Unicast addresses
Unicast addresses include global unicast addresses, link-local unicast addresses, the loopback address, and the unspecified address.
·     Global unicast addresses—Equivalent to public IPv4 addresses, global unicast addresses are provided for Internet service providers. This type of address allows for prefix aggregation to restrict the number of global routing entries.
·     Link-local addresses—Used for communication among link-local nodes for neighbor discovery and stateless autoconfiguration. Packets with link-local source or destination addresses are not forwarded to other links.
·     A loopback address—0:0:0:0:0:0:0:1 (or ::1). It has the same function as the loopback address in IPv4. It cannot be assigned to any physical interface. A node uses this address to send an IPv6 packet to itself.
·     An unspecified address—0:0:0:0:0:0:0:0 (or ::). It cannot be assigned to any node. Before acquiring a valid IPv6 address, a node fills this address in the source address field of IPv6 packets. The unspecified address cannot be used as a destination IPv6 address.
Multicast addresses
IPv6 multicast addresses listed in Table 2 are reserved for special purposes.
Table 2 Reserved IPv6 multicast addresses
Address
Application
FF01::1
Node-local scope all-nodes multicast address.
FF02::1
Link-local scope all-nodes multicast address.
FF01::2
Node-local scope all-routers multicast address.
FF02::2
Link-local scope all-routers multicast address.
Multicast addresses also include solicited-node addresses. A node uses a solicited-node multicast address to acquire the link-layer address of a neighboring node on the same link and to detect duplicate addresses. Each IPv6 unicast or anycast address has a corresponding solicited-node address. The format of a solicited-node multicast address is FF02:0:0:0:0:1:FFXX:XXXX. FF02:0:0:0:0:1:FF is fixed and consists of 104 bits, and XX:XXXX is the last 24 bits of an IPv6 unicast address or anycast address.
EUI-64 address-based interface identifiers
An interface identifier is 64 bits long and uniquely identifies an interface on a link.
On an IEEE 802 interface (such as a VLAN interface), the interface identifier is derived from the link-layer address (typically a MAC address) of the interface. The MAC address is 48 bits long.
To obtain an EUI-64 address-based interface identifier, follow these steps:
1.     Insert the 16-bit binary number 1111111111111110 (hexadecimal value of FFFE) behind the 24th high-order bit of the MAC address.
2.     Invert the universal/local (U/L) bit (the seventh high-order bit). This operation makes the interface identifier have the same local or global significance as the MAC address.
Figure 2 Converting a MAC address into an EUI-64 address-based interface identifier
On a tunnel interface, the lower 32 bits of the EUI-64 address-based interface identifier are the source IPv4 address of the tunnel interface. The higher 32 bits of the EUI-64 address-based interface identifier of an ISATAP tunnel interface are 0000:5EFE, whereas those of other tunnel interfaces are all zeros. For more information about tunnels, see "Configuring tunneling."
On an interface of another type (such as a serial interface) the EUI-64 address-based interface identifier is generated randomly by the device.
The links that a packet passes from a source to a destination can have different MTUs, among which the minimum MTU is the path MTU. If a packet exceeds the path MTU, the source end fragments the packet to reduce the processing pressure on intermediate devices and to use network resources effectively.
A source end uses path MTU discovery to find the path MTU to a destination, as shown in Figure 3.
1.     The source host sends a packet no larger than its MTU to the destination host.
2.     If the MTU of an intermediate device's output interface is smaller than the packet, the device performs the following operations:
¡     Discards the packet.
¡     Returns an ICMPv6 error message containing the interface MTU to the source host.
3.     Upon receiving the ICMPv6 error message, the source host performs the following operations:
¡     Uses the returned MTU to limit the packet size.
¡     Performs fragmentation.
¡     Sends the fragments to the destination host.
4.     Step 2 and step 3 are repeated until the destination host receives the packet. In this way, the source host finds the minimum MTU of all links in the path to the destination host.
Figure 3 Path MTU discovery process
IPv6 transition technologies enable communication between IPv4 and IPv6 networks.
Dual stack
Dual stack is the most direct transition approach. A network node that supports both IPv4 and IPv6 is a dual-stack node. A dual-stack node configured with an IPv4 address and an IPv6 address can forward both IPv4 and IPv6 packets. An application that supports both IPv4 and IPv6 prefers IPv6 at the network layer.
Dual stack is suitable for communication between IPv4 nodes or between IPv6 nodes. It is the basis of all transition technologies. However, it does not solve the IPv4 address depletion issue because each dual-stack node must have a globally unique IPv4 address.
Tunneling
Tunneling uses one network protocol to encapsulate the packets of another network protocol and transfers them over the network. For more information about tunneling, see "Configuring tunneling."
6PE
6PE enables communication between isolated IPv6 networks over an IPv4 backbone network.
6PE adds labels to the IPv6 routing information about customer networks and advertises the information into the IPv4 backbone network over internal Border Gateway Protocol (IBGP) sessions. IPv6 packets are labeled and forwarded over tunnels on the backbone network. The tunnels can be GRE tunnels or MPLS LSPs.
Figure 4 Network diagram
6PE is a highly efficient solution. When an ISP wants to utilize the existing IPv4/MPLS network to provide IPv6 traffic switching, it only needs to upgrade the PE routers. In addition, the operation risk of 6PE is very low.
·     RFC 1881, IPv6 Address Allocation Management
·     RFC 1887, An Architecture for IPv6 Unicast Address Allocation
·     RFC 1981, Path MTU Discovery for IP version 6
·     RFC 2375, IPv6 Multicast Address Assignments
·     RFC 2460, Internet Protocol, Version 6 (IPv6) Specification
·     RFC 2464, Transmission of IPv6 Packets over Ethernet Networks
·     RFC 2526, Reserved IPv6 Subnet Anycast Addresses
·     RFC 3307, Allocation Guidelines for IPv6 Multicast Addresses
·     RFC 4191, Default Router Preferences and More-Specific Routes
·     RFC 4291, IP Version 6 Addressing Architecture
·     RFC 4443, Internet Control Message Protocol (ICMPv6) for the Internet Protocol Version 6 (IPv6) Specification
·     RFC 4862, IPv6 Stateless Address Autoconfiguration
To configure basic IPv6 settings, perform the following tasks:
1.     Configuring an IPv6 address
¡     Configuring an IPv6 global unicast address
¡     Configuring an IPv6 link-local address
¡     Configuring an IPv6 anycast address
2.     (Optional.) Configuring path MTU discovery
¡     Setting the interface MTU for IPv6 packets
¡     Setting a static path MTU for an IPv6 address
¡     Setting the aging time for dynamic path MTUs
3.     (Optional.) Controlling sending ICMPv6 messages
¡     Configuring the rate limit for ICMPv6 error messages
¡     Enabling replying to multicast echo requests
¡     Enabling sending ICMPv6 destination unreachable messages
¡     Enabling sending ICMPv6 time exceeded messages
¡     Enabling sending ICMPv6 redirect messages
¡     Specifying the source address for unsolicited ICMPv6 packets
¡     Specifying the source IPv6 address for outgoing ICMPv6 replies
4.     (Optional.) Enabling IPv6 local fragment reassembly
5.     (Optional.) Enabling discarding IPv6 packets that contain extension headers
Use one of the following methods to configure an IPv6 global unicast address for an interface:
·     EUI-64 IPv6 address—The IPv6 address prefix of the interface is manually configured, and the interface ID is generated automatically by the interface.
·     Manual configuration—The IPv6 global unicast address is manually configured.
·     Stateless address autoconfiguration—The IPv6 global unicast address is generated automatically based on the address prefix information contained in the RA message.
·     Prefix-specific address autoconfiguration—The IPv6 global unicast address is generated automatically based on the prefix specified by its ID. The prefix can be manually configured or obtained through DHCPv6.
You can configure multiple IPv6 global unicast addresses on an interface.
Manually configured global unicast addresses (including EUI-64 IPv6 addresses) take precedence over automatically generated ones. If you manually configure a global unicast address with the same address prefix as an existing global unicast address on an interface, the manually configured one takes effect. However, it does not overwrite the automatically generated address. If you delete the manually configured global unicast address, the device uses the automatically generated one.
An interface ID is used in EUI-64 IPv6 address configuration and stateless address autoconfiguration. The interface ID is derived from the MAC address of the interface. If the MAC address changes, the interface ID, global unicast address, and link-local address will also change. This will cause the entry table to rebuild for some protocols, such as MLD, IPv6 PIM, and OSPFv3. If you do not want this situation to occur, use other IPv6 address configuration methods that do not use MAC addresses, for example, manually specify an IPv6 address.
2.     Enter interface view.
3.     Configure an EUI-64 IPv6 address on the interface.
By default, no EUI-64 IPv6 address is configured on an interface.
3.     Assign an IPv6 global unicast address to the interface.
By default, no IPv6 global unicast address is configured on an interface.
Stateless address autoconfiguration enables an interface to automatically generate an IPv6 global unicast address by using the address prefix in the received RA message and the interface ID. On an IEEE 802 interface (such as an Ethernet interface or a VLAN interface), the interface ID is generated based on the interface's MAC address and is globally unique. An attacker can exploit this rule to identify the sending device easily.
To fix the vulnerability, you can configure the temporary address feature. With this feature, an IEEE 802 interface generates the following addresses:
·     Public IPv6 address—Includes the address prefix in the RA message and a fixed interface ID generated based on the MAC address of the interface.
·     Temporary IPv6 address—Includes the address prefix in the RA message and a random interface ID generated through MD5.
You can also configure the interface to preferentially use the temporary IPv6 address as the source address of sent packets. When the valid lifetime of the temporary IPv6 address expires, the interface deletes the address and generates a new one. This feature enables the system to send packets with different source addresses through the same interface. If the temporary IPv6 address cannot be used because of a DAD conflict, the public IPv6 address is used.
The preferred lifetime and valid lifetime for a temporary IPv6 address are determined as follows:
·     The preferred lifetime of a temporary IPv6 address takes the smaller of the following values:
¡     The preferred lifetime of the address prefix in the RA message.
¡     The preferred lifetime configured for temporary IPv6 addresses minus DESYNC_FACTOR (a random number in the range of 0 to 600 seconds).
·     The valid lifetime of a temporary IPv6 address takes the smaller of the following values:
¡     The valid lifetime of the address prefix.
¡     The valid lifetime configured for temporary IPv6 addresses.
If the IPv6 prefix in the RA message is not 64 bits long, stateless address autoconfiguration fails to generate an IPv6 global unicast address.
To generate a temporary address, an interface must be enabled with stateless address autoconfiguration. Temporary IPv6 addresses do not overwrite public IPv6 addresses, so an interface can have multiple IPv6 addresses with the same address prefix but different interface IDs.
If an interface fails to generate a public IPv6 address because of a prefix conflict or other reasons, it does not generate any temporary IPv6 address.
Executing the undo ipv6 address auto command on an interface deletes all IPv6 global unicast addresses and link-local addresses that are automatically generated on the interface.
Enabling stateless address autoconfiguration
3.     Enable stateless address autoconfiguration on an interface, so that the interface can automatically generate a global unicast address.
ipv6 address auto
By default, the stateless address autoconfiguration feature is disabled on an interface.
Configuring the temporary address feature and preferentially using the temporary IPv6 address as the source address of outgoing packets
2.     Enable the temporary IPv6 address feature.
By default, the temporary IPv6 address feature is disabled.
3.     Enable the system to preferentially use the temporary IPv6 address as the source address of the outgoing packets.
ipv6 prefer temporary-address
By default, the system does not preferentially use the temporary IPv6 address as the source address of the outgoing packets.
2.     Configure an IPv6 prefix.
Choose one option as needed:
¡     Configure a static IPv6 prefix.
By default, no static IPv6 prefixes exist.
¡     Use DHCPv6 to obtain a dynamic IPv6 prefix.
For more information about IPv6 prefix acquisition, see "Configuring the DHCPv6 client."
3.     Enter interface view.
4.     Specify an IPv6 prefix for an interface to automatically generate an IPv6 global unicast address and advertise the prefix.
By default, no IPv6 prefix is specified for the interface to automatically generate an IPv6 global unicast address.
Configure IPv6 link-local addresses using one of the following methods:
·     Automatic generation—The device automatically generates a link-local address for an interface according to the link-local address prefix (FE80::/10) and the link-layer address of the interface.
·     Manual assignment—Manually configure an IPv6 link-local address for an interface.
After you configure an IPv6 global unicast address for an interface, the interface automatically generates a link-local address. This link-local address is the same as the one generated by using the ipv6 address auto link-local command. If a link-local address is manually assigned to an interface, this manual assigned link-local address takes effect. If the manually assigned link-local address is deleted, the automatically generated link-local address takes effect.
Using the undo ipv6 address auto link-local command on an interface deletes only the link-local address generated by the ipv6 address auto link-local command. If the interface has an IPv6 global unicast address, it still has a link-local address. If the interface has no IPv6 global unicast address, it has no link-local address.
An interface can have only one link-local address. As a best practice, use the automatic generation method to avoid link-local address conflicts. If both the automatic generation and manual assignment methods are used, the manual assignment takes precedence.
·     If you first use automatic generation and then manual assignment, the manually assigned link-local address overwrites the automatically generated one.
·     If you first use manual assignment and then automatic generation, both of the following occur:
¡     The link-local address is still the manually assigned one.
¡     The automatically generated link-local address does not take effect. If you delete the manually assigned address, the automatically generated link-local address takes effect.
An interface ID is used for generating the link-local address for an interface. On an IEEE 802 interface (such as an Ethernet interface or a VLAN interface), the interface ID is derived from the MAC address of the interface. If the MAC address changes, the interface ID, global unicast address, and link-local address will also change. This will cause the entry table to rebuild for some protocols, such as MLD, IPv6 PIM, and OSPFv3. If you do not want this situation to occur, use other IPv6 address configuration methods that do not use MAC addresses, for example, manually specify a link-local address.
3.     Configure the interface to automatically generate an IPv6 link-local address.
By default, no link-local address is configured on an interface.
After an IPv6 global unicast address is configured on the interface, a link-local address is generated automatically.
3.     Manually assign an IPv6 link-local address to the interface.
ipv6 address { ipv6-address [ prefix-length ] | ipv6-address/prefix-length } link-local
4.     Enter system view.
5.     Enter interface view.
6.     Configure an IPv6 anycast address.
By default, no IPv6 anycast address is configured on an interface.
If the size of a packet exceeds the MTU of the sending interface, the device discards the packet. If the device is an intermediate device, it also sends the source host an ICMPv6 Packet Too Big message with the MTU of the sending interface. The source host fragments the packets according to the MTU. To avoid this situation, set a proper interface MTU.
3.     Set the interface MTU for IPv6 packets.
ipv6 mtu size
By default, no interface MTU is set.
You can set a static path MTU for an IPv6 address. Before sending a packet to the IPv6 address, the device compares the output interface MTU with the static path MTU. If the packet size exceeds the smaller one of the two values, the device fragments the packet according to the smaller value. After sending the fragmented packets, the device dynamically finds the path MTU to a destination host (see "IPv6 path MTU discovery").
2.     Set a static path MTU for an IPv6 address.
By default, no path MTU is set for any IPv6 address.
After the device dynamically discovers the path MTU to a destination host (see "IPv6 path MTU discovery"), it performs the following operations:
·     Sends packets to the destination host based on this path MTU.
·     Starts the aging timer for this path MTU.
When the aging timer expires, the device removes the dynamic path MTU and discovers the path MTU again.
The aging time is invalid for a static path MTU.
2.     Set the aging time for dynamic path MTUs.
ipv6 pathmtu age age-time
The default setting is 10 minutes.
To avoid sending excessive ICMPv6 error messages within a short period that might cause network congestion, you can limit the rate at which ICMPv6 error messages are sent. A token bucket algorithm is used with one token representing one ICMPv6 error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMPv6 error message is sent. When the bucket is empty, ICMPv6 error messages are not sent until a new token is placed in the bucket.
2.     Set the bucket size and the interval for tokens to arrive in the bucket for ICMPv6 error messages.
By default, the bucket allows a maximum of 10 tokens. A token is placed in the bucket at an interval of 100 milliseconds.
To disable the ICMPv6 rate limit, set the interval to 0 milliseconds.
2.     Enable replying to multicast echo requests.
The device sends the source the following ICMPv6 destination unreachable messages:
·     ICMPv6 No Route to Destination message—A packet to be forwarded does not match any route.
·     ICMPv6 Communication with Destination Administratively Prohibited message—An administrative prohibition is preventing successful communication with the destination. This is typically caused by a firewall or an ACL on the device.
·     ICMPv6 Beyond Scope of Source Address message—The destination is beyond the scope of the source IPv6 address. For example, a packet's source IPv6 address is a link-local address, and its destination IPv6 address is a global unicast address.
·     ICMPv6 Address Unreachable message—The device fails to resolve the link layer address for the destination IPv6 address of a packet.
·     ICMPv6 Port Unreachable message—No port process on the destination device exists for a received UDP packet.
An ICMPv6 destination unreachable message indicates that the destination is not reachable from the source device. Attackers can launch malicious attacks to make the device generate incorrect ICMPv6 destination unreachable messages, which will affect the function of the network. To protect the network from malicious attacks and decrease unnecessary network traffic, you can disable the sending of ICMPv6 destination unreachable messages.
2.     Enable sending ICMPv6 destination unreachable messages.
ipv6 unreachables enable
The device sends the source ICMPv6 time exceeded messages as follows:
·     If a received packet is not destined for the device and its hop limit is 1, the device sends an ICMPv6 hop limit exceeded in transit message to the source.
·     Upon receiving the first fragment of an IPv6 datagram destined for the device, the device starts a timer. If the timer expires before all fragments arrive, the device sends an ICMPv6 fragment reassembly time exceeded message to the source.
If the device receives large numbers of malicious packets, its performance degrades greatly because it must send back ICMP time exceeded messages. To prevent such attacks, disable sending ICMPv6 time exceeded messages.
2.     Enable sending ICMPv6 time exceeded messages.
ipv6 hoplimit-expires enable
By default, sending ICMPv6 time exceeded messages is enabled.
Upon receiving a packet from a host, the device sends an ICMPv6 redirect message to inform the host of a better next hop when the following conditions are met:
·     The interface receiving the packet is the interface forwarding the packet.
·     The selected route is not created or modified by any ICMPv6 redirect messages.
·     The selected route is not a default route.
·     The forwarded packet does not contain the routing extension header.
The ICMPv6 redirect feature simplifies host management by enabling hosts that hold few routes to optimize their routing table gradually. However, to avoid adding too many routes on hosts, this feature is disabled by default.
2.     Enable sending ICMPv6 redirect messages.
ipv6 redirects enable
By default, sending ICMPv6 redirect messages is disabled.
Perform this task to specify the source IPv6 address for outgoing ping echo requests and ICMPv6 error messages. It is a good practice to specify the IPv6 address of a loopback interface as the source IPv6 address. This feature helps users easily locate the sending device.
For ICMPv6 echo requests, the source IPv6 address specified in the ping ipv6 command has higher priority than the source IPv6 address specified in the ipv6 icmpv6 source command.
2.     Specify a source IPv6 address for unsolicited ICMPv6 packets.
By default, no source address is specified for unsolicited ICMPv6 packets.
To help receiver hosts identify sources of ICMPv6 replies, you can specify the IPv6 address of a loopback interface or a local interface as the source IPv6 address for ICMPv6 replies.
2.     Specify a source IPv6 address for ICMPv6 replies.
ipv6 icmpv6 reply source [ vpn-instance vpn-instance-name ]  { address ipv6-address | interface interface-type [ interface-number ] }
By default, no source IP address is specified for outgoing ICMPv6 replies.
The Layer 3 packet statistics counting feature counts statistics about incoming and outgoing IPv6 packets on an interface. To display the collected statistics, execute the display ipv6 statistics command.
When the interface is processing a large number of packets, the Layer 3 packet statistics counting will cause high CPU usage and degrade the forwarding performance. If the statistics are not necessary, disable this feature to ensure the device performance.
3.     Enable Layer 3 packet statistics counting.
statistics l3-packet enable { inbound | outbound }
By default, Layer 3 packet statistics counting is disabled.
Use this feature on a device to improve fragment reassembly efficiency. This feature enables the LPU to reassemble the IPv6 fragments of a packet if all the fragments arrive at it. If this feature is disabled, all IPv6 fragments are delivered to the active MPU for reassembly.
Use this feature on a multichassis IRF fabric to improve fragment reassembly efficiency. This feature enables a subordinate to reassemble the IPv6 fragments of a packet if all the fragments arrive at it. If this feature is disabled, all IPv6 fragments are delivered to the master device for reassembly.
The IPv6 local fragment reassembly feature applies only to fragments destined for the same LPU.
The IPv6 local fragment reassembly feature applies only to fragments destined for the same subordinate.
2.     Enable IPv6 local fragment reassembly.
ipv6 reassemble local enable
By default, IPv6 local fragment reassembly is disabled.
This feature enables a device to discard a received IPv6 packet in which the extension headers cannot be processed by the device.
1.     Enter system view
2.     Enable the device to discard IPv6 packets that contain extension headers.
ipv6 extension-header drop enable
By default, the device does not discard IPv6 packets that contain extension headers.
For information about the display tcp statistics, display udp statistics, reset tcp statistics, and reset udp statistics command, see the IP performance commands in Layer 3—IP Services Command Reference.
Display IPv6 FIB entries.
display ipv6 fib [ vpn-instance vpn-instance-name ]  [ ipv6-address [ prefix-length ] ]
Display the IPv6 FIB table usage.
display ipv6 fib usage
Display ICMPv6 traffic statistics.
In standalone mode:
In IRF mode:
display ipv6 icmp statistics [ chassis chassis-number slot slot-number ]
Display IPv6 information about the interface.
Display IPv6 prefix information about the interface.
Display the IPv6 path MTU information.
display ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] }
Display the IPv6 prefix information.
Display brief information about IPv6 RawIP connections.
In standalone mode:
display ipv6 rawip [ slot slot-number  ]
In IRF mode:
display ipv6 rawip [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display detailed information about IPv6 RawIP connections.
In standalone mode:
In IRF mode:
display ipv6 rawip verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
Display IPv6 and ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
display ipv6 statistics [ chassis chassis-number slot slot-number ]
Display brief information about IPv6 TCP connections.
In standalone mode:
In IRF mode:
display ipv6 tcp [ chassis chassis-number slot slot-number ]
Display detailed information about IPv6 TCP connections.
In standalone mode:
In IRF mode:
display ipv6 tcp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
Display brief information about IPv6 UDP connections.
In standalone mode:
In IRF mode:
display ipv6 udp [ chassis chassis-number slot slot-number ]
Display detailed information about IPv6 UDP connections.
In standalone mode:
In IRF mode:
display ipv6 udp verbose [ chassis chassis-number slot slot-number [ pcb pcb-index ] ]
Display IPv6 TCP traffic statistics.
In standalone mode:
In IRF mode:
display tcp statistics [ chassis chassis-number slot slot-number ]
Display IPv6 UDP traffic statistics.
In standalone mode:
In IRF mode:
display udp statistics [ chassis chassis-number slot slot-number ]
Clear path MTUs.
Clear IPv6 and ICMPv6 packet statistics.
In standalone mode:
In IRF mode:
reset ipv6 statistics [ chassis chassis-number slot slot-number ]
Clear IPv6 TCP traffic statistics.
Clear IPv6 UDP traffic statistics.
As shown in Figure 5, a host, Switch A, and Switch B are connected through Ethernet ports. Add the Ethernet ports to corresponding VLANs. Configure IPv6 addresses for the VLAN interfaces and verify that they are connected. Switch B can reach the host.
Enable IPv6 on the host to automatically obtain an IPv6 address through IPv6 ND.
Figure 5 Network diagram
This example assumes that the VLAN interfaces have been created on the switches.
1.     Configure Switch A:
# Specify a global unicast address for VLAN-interface 2.
[SwitchA-Vlan-interface2] ipv6 address 3001::1/64
# Specify a global unicast address for VLAN-interface 1, and allow it to advertise RA messages (no interface advertises RA messages by default).
[SwitchA-Vlan-interface1] ipv6 address 2001::1/64
[SwitchA-Vlan-interface1] undo ipv6 nd ra halt
2.     Configure Switch B:
# Configure a global unicast address for VLAN-interface 2.
[SwitchB-Vlan-interface2] ipv6 address 3001::2/64
# Configure an IPv6 static route with destination IPv6 address 2001::/64 and next hop address 3001::1.
[SwitchB] ipv6 route-static 2001:: 64 3001::1
3.     Configure the host:
Enable IPv6 for the host to automatically obtain an IPv6 address through IPv6 ND.
# Display neighbor information for HundredGigE 3/0/2 on Switch A.
[SwitchA] display ipv6 neighbors interface hundredgige 3/0/2
Type: S-Static    D-Dynamic    O-Openflow     R-Rule    IS-Invalid static
IPv6 address              MAC address    VLAN/VSI   Interface     State T  Aging
FE80::215:E9FF:FEA6:7D14  0015-e9a6-7d14 1          HGE3/0/2      STALE D  1238
2001::15B:E0EA:3524:E791  0015-e9a6-7d14 1          HGE3/0/2      STALE D  1248
The output shows that the IPv6 global unicast address that Host obtained is 2001::15B:E0EA:3524:E791.
# Display the IPv6 interface settings on Switch A. All IPv6 global unicast addresses configured on the interface are displayed.
[SwitchA] display ipv6 interface vlan-interface 2
Vlan-interface2 current state: UP
IPv6 is enabled, link-local address is FE80::20F:E2FF:FE00:2
  Global unicast address(es):
    3001::1, subnet is 3001::/64
  Joined group address(es):
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FF00:2
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                    25829
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    47
  OutRequests:                   89
  OutForwDatagrams:              48
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   6
  InMcastNotMembers:             25747
  OutMcastPkts:                  48
  InAddrErrors:                  0
[SwitchA] display ipv6 interface vlan-interface 1
Vlan-interface1 current state: UP
    2001::1, subnet is 2001::/64
    FF02::1
    FF02::2
    FF02::1:FF00:1
    FF02::1:FF00:1C0
  MTU is 1500 bytes
  InReceives:                    272
  InTooShorts:                   0
  InTruncatedPkts:               0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    159
  OutRequests:                   1012
  OutForwDatagrams:              35
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   79
  InMcastNotMembers:             65
  OutMcastPkts:                  938
# Display the IPv6 interface settings on Switch B. All IPv6 global unicast addresses configured on the interface are displayed.
[SwitchB] display ipv6 interface vlan-interface 2
Vlan-interface2 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::20F:E2FF:FE00:1234
    3001::2, subnet is 3001::/64
    FF02::1
    FF02::2
    FF02::1:FF00:2
    FF02::1:FF00:1234
  MTU is 1500 bytes
  InReceives:                    117
  InTooShorts:                   0
  InTruncatedPkts:               0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    117
  OutRequests:                   83
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   28
  InMcastNotMembers:             0
  OutMcastPkts:                  7
# Ping Switch A and Switch B on the host, and ping Switch A and the host on Switch B to verify that they are connected.
When you ping a link-local address, use the -i parameter to specify an interface for the link-local address.
[SwitchB] ping ipv6 -c 1 3001::1
Ping6(56 data bytes) 3001::2 --> 3001::1, press CTRL+C to break
56 bytes from 3001::1, icmp_seq=0 hlim=64 time=4.404 ms
--- Ping6 statistics for 3001::1 ---
1 packet(s) transmitted, 1 packet(s) received, 0.0% packet loss
round-trip min/avg/max/std-dev = 4.404/4.404/4.404/0.000 ms
[SwitchB] ping ipv6 -c 1 2001::15B:E0EA:3524:E791
Ping6(56 data bytes) 3001::2 --> 2001::15B:E0EA:3524:E791, press CTRL+C to break
56 bytes from 2001::15B:E0EA:3524:E791, icmp_seq=0 hlim=64 time=5.404 ms
--- Ping6 statistics for 2001::15B:E0EA:3524:E791 ---
round-trip min/avg/max/std-dev = 5.404/5.404/5.404/0.000 ms
The output shows that Switch B can ping Switch A and the host. The host can also ping Switch B and Switch A.
The IPv6 neighbor discovery (ND) process uses ICMP messages for address resolution, neighbor reachability verification, and neighboring device tracking.
Table 3 describes the ICMPv6 messages used by the IPv6 ND protocol.
Table 3 ICMPv6 messages used by ND
ICMPv6 message
Function
Neighbor Solicitation (NS)
135
Acquires the link-layer address of a neighbor on the local link.
Verifies the reachability of a neighbor.
Detects duplicate addresses.
Neighbor Advertisement (NA)
136
Responds to an NS message.
Notifies the neighboring nodes of link layer changes.
Router Solicitation (RS)
133
Requests an address prefix and other configuration information for autoconfiguration after startup.
Router Advertisement (RA)
134
Responds to an RS message.
Advertises information, such as the Prefix Information options and flag bits.
Redirect
137
Informs the source host of a better next hop on the path to a particular destination when certain conditions are met.
Address resolution
This function is similar to ARP in IPv4. An IPv6 node acquires the link-layer addresses of neighboring nodes on the same link through NS and NA messages.
Figure 6 shows how Host A acquires the link-layer address of Host B on the same link. The address resolution procedure is as follows:
1.     Host A multicasts an NS message. The source address of the NS message is the IPv6 address of the sending interface of Host A. The destination address is the solicited-node multicast address of Host B. The NS message body contains the link-layer address of Host A and the target IPv6 address.
2.     After receiving the NS message, Host B determines whether the target address of the packet is its IPv6 address. If it is, Host B learns the link-layer address of Host A, and then unicasts an NA message containing its link-layer address.
3.     Host A acquires the link-layer address of Host B from the NA message.
Figure 6 Address resolution
After Host A acquires the link-layer address of its neighbor Host B, Host A can use NS and NA messages to test the reachability of Host B as follows:
1.     Host A sends an NS message whose destination address is the IPv6 address of Host B.
2.     If Host A receives an NA message from Host B, Host A decides that Host B is reachable. Otherwise, Host B is unreachable.
After Host A acquires an IPv6 address, it performs Duplicate Address Detection (DAD) to check whether the address is being used by any other node. This is similar to gratuitous ARP in IPv4. DAD is accomplished through NS and NA messages.
The DAD procedure is as follows:
1.     Host A sends an NS message. The source address is the unspecified address and the destination address is the corresponding solicited-node multicast address of the IPv6 address to be detected. The NS message body contains the detected IPv6 address.
2.     If Host B uses this IPv6 address, Host B returns an NA message that contains its IPv6 address.
3.     Host A knows that the IPv6 address is being used by Host B after receiving the NA message from Host B. If receiving no NA message, Host A decides that the IPv6 address is not in use and uses this address.
Figure 7 Duplicate address detection
Router/prefix discovery allows an IPv6 node to find the neighboring routers and learn the prefix and network configuration parameters of the network from receiving RA messages.
Stateless address autoconfiguration allows an IPv6 node to automatically generate an IPv6 address based on the information learned through router/prefix discovery.
A node performs router/prefix discovery and stateless address autoconfiguration as follows:
1.     At startup, a node sends an RS message to request configuration information from a router.
2.     The router returns an RA message containing the Prefix Information option and other configuration information. (The router also periodically sends an RA message.)
3.     The node automatically generates an IPv6 address and other configuration parameters according to the configuration information in the RA message.
The Prefix Information option contains an address prefix and the preferred lifetime and valid lifetime of the address prefix. A node updates the preferred lifetime and valid lifetime upon receiving a periodic RA message.
The generated IPv6 address is valid within the valid lifetime and becomes invalid when the valid lifetime expires.
After the preferred lifetime expires, the node cannot use the generated IPv6 address to establish new connections, but can receive packets destined for the IPv6 address. The preferred lifetime cannot be greater than the valid lifetime.
Redirection
Upon receiving a packet from a host, the gateway sends an ICMPv6 redirect message to inform the host of a better next hop when the following conditions are met:
·     The interface receiving the packet is the same as the interface forwarding the packet.
·     The selected route is not created or modified by an ICMPv6 redirect message.
·     The selected route is not a default route on the device.
·     The forwarded IPv6 packet does not contain the routing extension header.
·     RFC 4861, Neighbor Discovery for IP Version 6 (IPv6)
·     RFC 8106, IPv6 Router Advertisement Options for DNS Configuration
All IPv6 neighbor discovery tasks are optional.
·     Configuring ND entry related features
¡     Configuring a static neighbor entry
¡     Setting the dynamic neighbor learning limit on an interface
¡     Setting the aging timer for ND entries in stale state
¡     Minimizing link-local ND entries
·     Setting the hop limit
·     Configuring RA message sending and parameters
·     Setting the maximum number of attempts to send an NS message for DAD
·     Configuring ND snooping
¡     Configuring ND snooping in a VLAN
¡     Configuring ND snooping in a VXLAN
·     Enabling ND proxy
·     Enabling ND proxy forwarding
·     Configuring a customer-side or a network-side port
·     Configuring IPv6 ND direct route advertisement
·     Configuring user information recording
¡     Enabling recording user IPv6 address conflicts
¡     Enabling recording user port migrations
¡     Enabling ND logging for user online and offline events
A neighbor entry stores information about a link-local node. The entry can be created dynamically through NS and NA messages, or configured statically.
The device uniquely identifies a static neighbor entry by using the neighbor's IPv6 address and the number of the Layer 3 interface that connects to the neighbor. You can configure a static neighbor entry by using one of the following methods:
·     Method 1—Associate a neighbor's IPv6 address and link-layer address with the local Layer 3 interface.
·     Method 2—Associate a neighbor's IPv6 address and link-layer address with a Layer 2 port in a VLAN.
·     Method 3—Specify a neighbor IPv6 address, MAC address, input interface (VSI interface), output interface (tunnel interface), and VSI name.
·     Method 4—Specify a neighbor IPv6 address, MAC address, input interface (VSI interface), output interface (determined by a Layer 2 interface and Ethernet service instance), and VSI name.
To configure a static neighbor entry for a VLAN interface, use Method 1 or Method 2.
·     If you use Method 1, the device is required to resolve the Layer 2 port in the related VLAN.
·     If you use Method 2, make sure the Layer 2 port belongs to the specified VLAN and the corresponding VLAN interface already exists. After the configuration, the device associates the VLAN interface with the neighbor IPv6 address to identify the static neighbor entry.
If the device and its neighbor are connected through a VSI interface, use Method 3 or Method 4 to configure the neighbor entry.
·     If Method 3 is used, the neighbor entry is in REACH state. This method is applicable to the network where VXLAN gateways are connected through tunnel interfaces. In the network, a VXLAN gateway is identified by both the VSI and VSI interface. A VSI interface is associated with multiple tunnel interfaces. To create a neighbor entry, you must specify the VSI interface, VSI, and tunnel interface.
·     If Method 4 is used, the neighbor entry is in REACH state. This method is applicable to the network where VXLAN gateways are associated with local sites. A VXLAN gateway is identified by both the VSI and VSI interface. One VXLAN gateway might have multiple local sites. Local sites access the VXLAN network through Layer 2 interfaces where Ethernet service instance and VSI mappings are configured. To create a neighbor entry, you must specify the VSI interface, Layer 2 interface connected to the local site, Ethernet service instance, and VSI.
For more information about VSI, VSI interfaces, and Ethernet service instances, see VXLAN overview in VXLAN Configuration Guide.
For more information about tunnel interfaces, see "Configuring tunneling."
To delete a static neighbor entry for a VSI interface, specify only the VSI interface.
To delete a static neighbor entry for a VLAN interface, specify only the VLAN interface.
You can use the undo ipv6 neighbor command to delete both static and dynamic neighbor entries.
2.     Configure a static neighbor entry.
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number | vsi-interface vsi-interface-id tunnel number vsi vsi-name | vsi-interface vsi-interface-id interface-type interface-number service-instance instance-id vsi vsi-name } [ vpn-instance vpn-instance-name ]
By default, no static neighbor entries exist.
The device can dynamically acquire the link-layer address of a neighboring node through NS and NA messages and add it into the neighbor table. When the number of dynamic neighbor entries reaches the limit, the interface stops learning neighbor information.
This feature limits the neighbor table size. A large neighbor table will degrade the forwarding performance.
3.     Set the dynamic neighbor learning limit on the interface.
By default, the dynamic neighbor learning limit on the interface is determined by the available resources on the device.
On some networks, a server multicasts NA messages to two peer devices for link backup. The peer devices cannot learn ND entry for the server from these NA messages by default. If no ND learning is triggered by data exchange between the server and peer devices, the peer devices learn the entry for the server only when the server unicasts messages to them.
This feature enables an interface to learn ND entries from unsolicited NA messages. The ND entries generated by using this method are in stale state.
To ensure that the device learns ND entries from trusted NA messages, enable this feature only on a secure network.
This feature might cause the device to learn excessive ND entries that consume too many system resources. As a best practice, execute the ipv6 neighbor stale-aging command to set a smaller aging timer before you enable this feature. The smaller aging timer accelerates the aging of ND entries in stale state.
This feature is available only on Layer 3 interfaces.
2.     Enter Layer 3 interface view.
3.     Enable unsolicited NA learning.
ipv6 nd unsolicited-na-learning enable
By default, unsolicited NA learning is disabled.
ND entries in stale state have an aging timer. If an ND entry in stale state is not refreshed before the timer expires, the ND entry changes to the delay state. If it is still not refreshed in 5 seconds, the ND entry changes to the probe state, and the device sends an NS message three times. If no response is received, the device deletes the ND entry.
You can set the aging timer for ND entries in stale state in system view and interface view. For ND entries in stale state on an interface, the aging timer in interface view has higher priority than the aging timer in system view.
2.     Set the aging timer for ND entries in stale state.
¡     Set the aging timer for ND entries in stale state in system view.
ipv6 neighbor stale-aging { aging-minutes | second aging-seconds }
The default setting is 240 minutes.
¡     Execute the following commands in sequence to set the aging timer in interface view.
ipv6 neighbor timer stale-aging { aging-minutes | second aging-seconds }
By default, the aging timer of ND entries in stale state is not configured on an interface. The aging timer is determined by the configuration of the ipv6 neighbor stale-aging command in system view.
Perform this task to minimize link-local ND entries assigned to the hardware. Link-local ND entries refer to ND entries that contain link-local addresses.
By default, the device assigns all ND entries to the hardware. With this feature enabled, the newly learned link-local ND entries are not assigned to the hardware if the link-local addresses of the entries are not the next hops of any routes. This feature saves hardware resources.
This feature takes effect only on newly learned link-local ND entries.
2.     Minimize link-local ND entries.
You can set the hop limit value to fill in the Hop Limit field for IPv6 packets to be sent.
2.     Set the value for the Hop Limit field in the IP header.
ipv6 hop-limit value
The default setting is 64.
You can enable an interface to send RA messages, and configure the interval for sending RA messages and parameters in RA messages. After receiving an RA message, a host can use these parameters to perform corresponding operations. Table 4 describes the configurable parameters in an RA message.
Table 4 Parameters in an RA message and their descriptions
Parameter
Hop Limit
Maximum number of hops in RA messages. A host receiving the RA message fills the value in the Hop Limit field of sent IPv6 packets.
Prefix information
After receiving the prefix information, the hosts on the same link can perform stateless autoconfiguration.
MTU
Guarantees that all nodes on the link use the same MTU.
Boot file URL
Specifies the URL address for downloading the boot file in RA messages. The device can use the ND protocol to obtain both the IPv6 address and the boot file URL for automatic configuration instead of using DHCPv6.
M flag
Determines whether a host uses stateful autoconfiguration to obtain an IPv6 address.
If the M flag is set to 1, the host uses stateful autoconfiguration (for example, from a DHCPv6 server) to obtain an IPv6 address. Otherwise, the host uses stateless autoconfiguration to generate an IPv6 address according to its link-layer address and the prefix information in the RA message.
O flag
Determines whether a host uses stateful autoconfiguration to obtain configuration information other than the IPv6 address.
If the O flag is set to 1, the host uses stateful autoconfiguration (for example, from a DHCPv6 server) to obtain configuration information other than the IPv6 address. Otherwise, the host uses stateless autoconfiguration.
Router Lifetime
Tells the receiving hosts how long the advertising router can live. If the lifetime of a router is 0, the router cannot be used as the default gateway.
Retrans Timer
If the device does not receive a response message within the specified time after sending an NS message, it retransmits the NS message.
Reachable Time
If the neighbor reachability detection shows that a neighbor is reachable, the device considers the neighbor reachable within the specified reachable time. If the device needs to send a packet to the neighbor after the specified reachable time expires, the device reconfirms whether the neighbor is reachable.
Router Preference
Specifies the router preference in an RA message. A host selects a router as the default gateway according to the router preference. If router preferences are the same, the host selects the router from which the first RA message is received.
DNS server option
DNS server information for IPv6 hosts. Hosts can obtain DNS server information from received RA messages instead of using DHCPv6.
DNS suffix information in DNS Search List (DNSSL) option
DNS suffix information for IPv6 hosts. Hosts can obtain DNS suffix information from received RA messages instead of using DHCPv6.
The maximum interval for sending RA messages should be less than (or equal to) the router lifetime in RA messages. In this way, the router can be updated by an RA message before expiration.
The values of the NS retransmission timer and the reachable time configured for an interface are sent in RA messages to hosts. This interface sends NS messages at the interval of the NS retransmission timer and considers a neighbor reachable within the reachable time.
3.     Enable the sending of RA messages.
The default setting is disabled.
4.     Set the maximum and minimum intervals for sending RA messages.
By default, the maximum interval for sending RA messages is 600 seconds, and the minimum interval is 200 seconds.
The device sends RA messages at random intervals between the maximum interval and the minimum interval.
The minimum interval should be less than or equal to 0.75 times the maximum interval.
3.     Configure the prefix information in RA messages.
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } [ valid-lifetime preferred-lifetime [ no-autoconfig | off-link | prefix-preference level ] * | no-advertise ]
By default, no prefix information is configured for RA messages, and the IPv6 address of the interface sending RA messages is used as the prefix information. If the IPv6 address is manually configured, the prefix uses a fixed valid lifetime of 2592000 seconds (30 days) and a preferred lifetime of 604800 seconds (7 days). If the IPv6 address is automatically obtained, the prefix uses the valid lifetime and preferred lifetime configured for the IPv6 address.
4.     Configure the default settings for prefixes advertised in RA messages.
ipv6 nd ra prefix default [ valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] * | no-advertise ]
By default, no default settings are configured for prefixes advertised in RA messages.
5.     Turn off the MTU option in RA messages.
ipv6 nd ra no-advlinkmtu
By default, RA messages contain the MTU option.
6.     Specify unlimited hops in RA messages.
ipv6 nd ra hop-limit unspecified
By default, the maximum number of hops in RA messages is 64.
7.     Specify the URL of the boot file in RA messages.
ipv6 nd ra boot-file-url url-string
By default, RA messages do not contain the URL of the boot file.
8.     Set the M flag bit to 1.
By default, the M flag bit is set to 0 in RA advertisements. Hosts receiving the advertisements will obtain IPv6 addresses through stateless autoconfiguration.
9.     Set the O flag bit to 1.
ipv6 nd autoconfig other-flag
By default, the O flag bit is set to 0 in RA advertisements. Hosts receiving the advertisements will acquire other configuration information through stateless autoconfiguration.
10.     Set the router lifetime in RA messages.
By default, the router lifetime is three times as long as the maximum interval for advertising RA messages.
11.     Set the NS retransmission timer.
By default, an interface sends NS messages every 1000 milliseconds, and the value of the Retrans Timer field in RA messages is 0.
12.     Set the router preference in RA messages.
By default, the router preference is medium.
13.     Set the reachable time.
By default, the neighbor reachable time is 1200000 milliseconds, and the value of the Reachable Time field in sent RA messages is 0.
Specifying DNS server information in RA messages
The DNS server options in RA messages provide DNS server information for IPv6 hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS server through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
One DNS server option contains one DNS server. All DNS server options are sorted in ascending order of the DNS server sequence number.
After you execute the ipv6 nd ra dns server command, the device immediately sends an RA message with the existing and newly specified DNS server information.
After you execute the undo ipv6 nd ra dns server command, the device immediately sends two RA messages.
·     The first RA message contains information about all DNS servers, including the DNS servers specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message contains information about remaining DNS servers.
Each time the device sends an RA message from an interface, it immediately refreshes the RA message advertisement interval for that interface.
You can configure a maximum of eight DNS servers on an interface.
The default lifetime of a DNS server is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
3.     Specify DNS server information to be advertised in RA messages.
By default, no DNS server information is specified and RA messages do not contain DNS server options.
Specifying DNS suffix information in RA messages
The DNSSL option in RA messages provides suffix information for IPv6 hosts. The RA messages allow hosts to obtain their IPv6 addresses and the DNS suffix through stateless autoconfiguration. This method is useful in a network where DHCPv6 infrastructure is not provided.
One DNSSL option contains one DNS suffix. All DNSSL options are sorted in ascending order of the sequence number of the DNS suffix.
After you execute the ipv6 nd ra dns search-list command, the device immediately sends an RA message with the existing and newly specified DNS suffix information.
After you execute the undo ipv6 nd ra dns search-list command, the device immediately sends two RA messages.
·     The first RA message contains information about all DNS suffixes, including DNS suffixes specified in the undo command with their lifetime set to 0 seconds.
·     The second RA message contains information about remaining DNS suffixes.
You can configure a maximum of eight DNS suffixes on an interface.
The default lifetime of a DNS suffix is three times the maximum interval for advertising RA messages. To set the maximum interval, use the ipv6 nd ra interval command.
3.     Specify DNS suffix information to be advertised in RA messages.
By default, no DNS suffix information is specified and RA messages do not contain DNS suffix options.
Suppressing advertising DNS information in RA messages
Perform this task to suppress the device from advertising information about DNS server addresses and DNS suffixes in RA messages.
Whether enabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends two RA messages. In the first message, the lifetime for DNS server addresses is 0 seconds. The second RA message does not contain any DNS server options.
·     If the interface has no DNS server information specified or no AAA-authorized DNS server address assigned, no RA messages are triggered.
If you specify a new DNS server or remove a DNS server on the interface after enabling DNS server suppression, the device immediately sends an RA message without any DNS server options.
Whether disabling this feature on an interface will trigger sending RA message immediately depends on the interface configuration:
·     If the interface has DNS server information configured or has obtained an AAA-authorized DNS server address, the device immediately sends an RA message containing the DNS server information.
The same suppression mechanism applies when you enable or disable DNS suffix suppression in RA messages.
3.     Enable DNS server suppression in RA messages.
ipv6 nd ra dns server suppress
By default, DNS server suppression in RA messages is disabled.
4.     Enable DNS suffix suppression in RA messages.
ipv6 nd ra dns search-list suppress
By default, DNS suffix suppression in RA messages is disabled.
An interface sends an NS message for DAD for an obtained IPv6 address. The interface resends the NS message if it does not receive a response within the time specified by the ipv6 nd ns retrans-timer command. If the interface receives no response after making the maximum attempts specified by the ipv6 nd dad attempts command, the interface uses the IPv6 address.
3.     Set the number of attempts to send an NS message for DAD.
ipv6 nd dad attempts times
The default setting is 1. When the times argument is set to 0, DAD is disabled.
About ND snooping in a VLAN
The ND snooping feature is used in Layer 2 switching networks. It learns the source MAC addresses, source IPv6 addresses, input interfaces, and VLANs of arriving ND messages and data packets to build the ND snooping table.
ND snooping entries can be used by ND detection to prevent spoofing attacks.
ND detection processes the ND messages received on ND trusted and untrusted interfaces as follows:
·     ND detection forwards all ND messages received on an ND trusted interface.
·     ND detection compares all ND messages received on an ND untrusted interface with the ND snooping entries except for RA and redirect messages.
You can use the ipv6 nd detection trust command to specify a Layer 2 Ethernet or aggregate port as an ND trusted interface. For more information about the ipv6 nd detection trust command, see Security Command Reference.
ND snooping entries can be used by IPv6 source guard to prevent spoofing attacks. For more information about IPv6 source guard, see Security Configuration Guide.
ND snooping provides device liveness tracking so that the ND snooping table can be updated in a timely manner. After ND snooping is enabled for a VLAN, the device uses the following mechanisms to create, update, and delete ND snooping entries. The following example uses ND messages for illustration.
Creation of ND snooping entries
Upon receiving an ND message or data packet from an unknown source, the device creates an ND snooping entry in INVALID status and performs DAD for the source IPv6 address. The device sends NS messages out of the ND trusted interfaces in the receiving VLAN twice. The sending interval is set by the ipv6 nd snooping dad retrans-timer command.
·     If the device does not receive an NA message within the invalid entry lifetime (set by the ipv6 nd snooping lifetime invalid command), the entry becomes valid.
·     If the device receives an NA message within the invalid entry lifetime, it deletes this entry.
Updating of ND snooping entries
When the ND untrusted interface that receives an ND message is different from that in the entry for an IPv6 address, the device performs DAD for the entry. It sends NS messages twice. The sending interval is set by the ipv6 nd snooping dad retrans-timer command.
·     If the device does not receive an NA message within the invalid entry lifetime, it updates the entry with the new receiving interface.
·     If the device receives an NA message within the invalid entry lifetime, the ND snooping entry remains unchanged.
Deletion of ND snooping entries
·     When an ND trusted interface in the VLAN receives an ND message from the IPv6 address in a learned ND snooping entry, it performs DAD for the entry. The device sends NS messages twice. The sending interval is set by the ipv6 nd snooping dad retrans-timer command.
¡     If the device does not receive an NA message within the invalid entry lifetime, it deletes the entry.
¡     If the device receives an NA message within the invalid entry lifetime, the ND snooping entry remains unchanged.
·     If an ND snooping entry has no matching ND messages within the valid entry lifetime (set by the ipv6 nd snooping lifetime valid command), the entry becomes invalid. The device then performs DAD for the entry by sending NS messages out of the interface in the entry. The device sends NS messages twice by default.
¡     If the device receives an NA message within the invalid entry lifetime, the ND snooping entry remains unchanged and becomes valid.
Enabling ND snooping
2.     Enter VLAN view.
vlan vlan-id
3.     Enable ND snooping for IPv6 addresses. Choose the options to configure as needed:
¡     Enable ND snooping for global unicast addresses.
ipv6 nd snooping enable global
¡     Enable ND snooping for link-local addresses.
ipv6 nd snooping enable link-local
By default, ND snooping is disabled for IPv6 global unicast addresses and link-local addresses.
4.     (Optional.) Enable ND snooping for data packets from unknown sources.
ipv6 nd snooping glean source
By default, ND snooping is disabled for data packets from unknown sources.
After executing this command for a VLAN, you must configure IPv6 source guard on all untrusted interfaces in the VLAN to ensure correct forwarding of the data packets received on these interfaces.
Setting the ND snooping entry learning limit
2.     Enter Layer 2 Ethernet or Layer 2 aggregate interface view.
3.     (Optional.) Set the ND snooping entry learning limit on the interface.
ipv6 nd snooping max-learning-num max-number
By default, an interface can learn a maximum of 1024 ND snooping entries.
Configuring ND snooping entry related parameters
3.     (Optional.) Configure the port as an ND snooping uplink port. The ND snooping uplink port cannot learn ND snooping entries.
ipv6 nd snooping uplink
By default, the port is not an ND snooping uplink port. After ND snooping is enabled, the port can learn ND snooping entries.
4.     Return to system view.
5.     (Optional.) Set timeout timers for ND snooping entries.
ipv6 nd snooping lifetime { invalid invalid-lifetime | valid valid-lifetime }
The default settings are as follows:
¡     The timeout timer for ND snooping entries in INVALID status (TENTATIVE, TESTING_TPLT, or TESTING_VP) is 500 milliseconds.
¡     The timeout timer for ND snooping entries in VALID status is 300 seconds.
6.     (Optional.) Set the DAD NS message retransmission interval for ND snooping entry creation or update.
ipv6 nd snooping dad retrans-timer interval
The default value is 250 milliseconds.
About ND snooping in a VXLAN
The ND snooping feature in a VXLAN learns the source MAC addresses, source IPv6 addresses, VSI name, and link IDs to build the ND snooping table. For more information about VXLAN, see VXLAN overview in VXLAN Configuration Guide.
ND snooping entries can be used by ND detection to prevent spoofing attacks. For more information about the ND attack detection, see Security Configuration Guide.
After ND snooping is enabled in a VSI, the device uses the following mechanisms to create and maintain ND snooping entries.
With this feature enabled in a VXLAN, all receiving ND messages are delivered to the CPU. The CPU obtains the source IPv6 addresses, source MAC addresses, VSI name, and link IDs to create ND snooping entries.
Aging of ND snooping entries
The aging time of an ND snooping entry is 5 minutes. If no matching packet is received within 30 seconds before the end of the entry aging time, the entry is set to TENTATIVE status. At the same time, the device sends a NS message for the entry. If the source IP and source MAC in the received ND message matches the ND snooping entry, the device sets the entry to VALID and resets the aging time.
When the aging time of an ND snooping entry is reached, the entry is deleted.
2.     Create a VSI and enter its view.
vsi vsi-name
Enabling ND proxy
About ND proxy
ND proxy enables a device to answer an NS message requesting the hardware address of a host on another network. With ND proxy, hosts in different broadcast domains can communicate with each other as they would on the same network.
ND proxy includes common ND proxy and local ND proxy.
Common ND proxy
As shown in Figure 8, Interface A with IPv6 address 4:1::99/64 and Interface B with IPv6 address 4:2::99/64 belong to different subnets. Host A and Host B reside on the same network but in different broadcast domains.
Figure 8 Application environment of ND proxy
Because Host A's IPv6 address is on the same subnet as Host B's, Host A directly sends an NS message to obtain Host B's MAC address. However, Host B cannot receive the NS message because they belong to different broadcast domains.
To solve this problem, enable common ND proxy on Interface A and Interface B of the device. The device replies to the NS message from Host A, and forwards packets from other hosts to Host B.
Local ND proxy
As shown in Figure 9, Host A belongs to VLAN 2 and Host B belongs to VLAN 3. Host A and Host B connect to Port B1 and Port B3, respectively.
Figure 9 Application environment of local ND proxy
Because Host A's IPv6 address is on the same subnet as Host B's, Host A directly sends an NS message to obtain Host B's MAC address. However, Host B cannot receive the NS message because they belong to different VLANs.
To solve this problem, enable local ND proxy on Interface A of Device A so that Device A can forward messages between Host A and Host B.
Local ND proxy implements Layer 3 communication for two hosts in the following cases:
·     The two hosts connect to ports of the same device and the ports must be in different VLANs.
·     The two hosts connect to isolated Layer 2 ports in the same isolation group of a VLAN.
·     If super VLAN is used, the two hosts must belong to different sub VLANs.
·     If Private VLAN is used, the two hosts must belong to different secondary VLANs.
Enabling common ND proxy
3.     Enable common ND proxy.
proxy-nd enable
By default, common ND proxy is disabled.
Enabling local ND proxy
3.     Enable local ND proxy.
local-proxy-nd enable
By default, local ND proxy is disabled.
With this feature enabled on an interface, the device issues dynamic and static ND entries that use the interface as the output interface only to proxy service modules. When a principal service module receives a packet whose destination IPv6 address resides on the same subnet with the interface, it delivers the packet to a proxy service module based on load sharing. The proxy service module will re-encapsulate and forward the packet out of the interface.
This feature allows only proxy service modules to learn ND entries and forward packets. To ensure ND learning and packet forwarding, you must specify a proxy service module before you enable this feature. As a best practice, specify a service module with high performance as a proxy service module.
3.     Enable ND proxy forwarding.
ipv6 nd proxy-forwarding
By default, ND proxy forwarding is disabled.
By default, a port operates as the network-side port. The device associates an ND entry with routing information when the interface learns an ND entry. The ND entry provides the next hop information for routing. Restricted to the hardware next hop resources on the device, the maximum number of dynamic ND entries that a network-side port can learn might be smaller than the value you set.
When the port operates as the customer-side port, the device will not associate the routing information with the learned ND entries, thus saving hardware resources.
The maximum number of dynamic ND entries that a customer-side port can learn is different than a network-side port. Select the operating mode for a port according to the port location in your live network.
2.     Create a VLAN interface and enter VLAN interface view.
interface vlan-interface vlan-interface-id
3.     Specify the interface as a customer-side or network-side port.
¡     Specify the interface as a customer-side port.
ipv6 nd mode uni
¡     Specify the interface as a network-side port.
undo ipv6 nd mode uni
By default, a port acts as a network-side port.
About IPv6 ND direct route advertisement
This feature generates 128-bit host routes based on ND entries for packet forwarding and route advertisement. The route preference value determines the match order of a route. Dynamic routing protocols use the tag value as the route identifier when redistributing the route.
After you enable this feature, the routing table might be populated with excessive host routes. To reduce the routing table size, execute the ipv6 nd route-direct prefix convert-length command for the device to generate network routes for identified ND entries instead of host routes.
Application in Layer 3 access networks
As shown in Figure 10, ND direct route advertisement is enabled on Interface A and Interface B. This feature generates a host route to Server A and a host route to Server B for the routing protocols to advertise. So each device forwards only the traffic destined to the server within the network, which saves bandwidth.
Figure 10 Application in a Layer 3 access network
Application in L2VPN access to L3VPN networks
As shown in Figure 11, the PE in the L3VPN has ECMP routes destined to a base station in the L2VPN. Traffic from the PE in the L3VPN to the base station can be load shared by PE-agg 1 and PE-agg 2. If PE-agg 1 fails, the PE uses the host route through PE-agg 2 to forward traffic.
Figure 11 Application in an L2VPN access to L3VPN network
2.     Enter interface view.
3.     Enable ND direct route advertisement.
ipv6 nd route-direct advertise [ preference preference-value | tag tag-value ] *
By default, ND direct route advertisement is disabled.
4.     (Optional.) Specify a prefix length for generating a network route for identified ND entries.
ipv6 nd route-direct prefix ipv6-prefix prefix-length convert-length convert-length
By default, no prefix length is specified for generating a network route for identified ND entries, and the device generates 128-bit host routes based on ND entries.
This feature detects and records user IPv6 address conflicts. A conflict occurs if an incoming NA packet has the same source IP address as an existing ND entry but a different source MAC address. The device generates a user IPv6 address conflict record, logs the conflict, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
2.     Enable recording user IPv6 address conflicts.
ipv6 nd user-ip-conflict record enable
By default, recording user IPv6 address conflicts is disabled.
This feature enables the device to detect and record user port migrations. A user port migrates if an incoming NA packet has the same source IPv6 address and source MAC address as an existing ND entry but a different ingress port. The device generates a user port migration record, logs the migration event, and sends the log to the information center. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
2.     Enable recording user port migrations.
ipv6 nd user-move record enable
By default, recording user port migrations is disabled.
This feature enables the device to generate user online or offline logs upon such events and send these logs to the information center. For information about the log destination and output rule configuration in the information center, see the information center in Network Management and Monitoring Configuration Guide.
A higher log output rate consumes more CPU resources. Adjust the log output rate based the CPU performance and usage.
2.     Enable ND logging for user online and offline events.
ipv6 nd online-offline-log enable [ rate rate ]
By default, ND logging for user online and offline events is disabled.
Display and maintenance commands for IPv6 ND
Display statistics for ND proxy reply packets.
display ipv6 nd proxy statistics
Display information about direct routes generated advertised by the ND module.
display ipv6 nd route-direct advertise interface interface-type interface-number
Display the number of IPv6 ND snooping entries in VLANs.
display ipv6 nd snooping count vlan [ interface interface-type interface-number ]
Display the number of IPv6 ND snooping entries in a VSI.
display ipv6 nd snooping count vsi [ vsi-name ]
Display IPv6 ND snooping entries in VLANs.
display ipv6 nd snooping vlan [ [ vlan-id | interface interface-type interface-number ] [ global | link-local ] | ipv6-address ] [ verbose ]
Display IPv6 ND snooping entries in a VSI.
In standalone mode:
display ipv6 nd snooping vsi [ vsi-name ] [ slot slot-number
In IRF mode:
display ipv6 nd snooping vsi [ vsi-name ] [ chassis chassis-number slot lot-number
Display user IPv6 address conflict records.
In standalone mode:
display ipv6 nd user-ip-conflict record [slot slot-number ]
In IRF mode:
display ipv6 nd user-ip-conflict record [chassis chassis-number slot slot-number ]
Display user port migration records.
In standalone mode:
display ipv6 nd user-move record [ slot slot-number ]
In IRF mode:
display ipv6 nd user-move record [chassis chassis-number slot slot-number  ]
Display the total number of neighbor entries.
In standalone mode:
In IRF mode:
display ipv6 neighbors { { all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } count
Display neighbor information.
In standalone mode:
In IRF mode:
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ chassis chassis-number slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ verbose ]
Display the maximum number of ND entries that a device supports.
display ipv6 neighbors entry-limit
Display the ND table usage.
display ipv6 neighbors usage
Display neighbor information for a VPN.
display ipv6 neighbors vpn-instance vpn-instance-name [ count ]
Clear IPv6 ND snooping entries in a VLAN.
reset ipv6 nd snooping vlan { [ vlan-id ] [ global | link-local ] | vlan-id ipv6-address }
Clear IPv6 ND snooping entries in a VSI.
reset ipv6 nd snooping vsi [ vsi-name ]
Clear IPv6 neighbor information.
In standalone mode:
In IRF mode:
reset ipv6 neighbors { all | dynamic | interface interface-type interface-number | chassis chassis-number slot slot-number | static }
IPv6 ND configuration examples
Example: Configuring ND snooping
As shown in Figure 12, Host A and Host B are connected to the gateway through Device B. Enable ND snooping on Device B to learn ND snooping entries about Host A and Host B.
Figure 12 Network diagram
1.     Configure Device A:
# Create VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] quit
# Configure HundredGigE 3/0/3 to trunk VLAN 10.
[DeviceA] interface hundredgige 3/0/3
[DeviceA-HundredGigE3/0/3] port link-type trunk
[DeviceA-HundredGigE3/0/3] port trunk permit vlan 10
[DeviceA-HundredGigE3/0/3] quit
# Assign IPv6 address 10::1/64 to VLAN-interface 10.
[DeviceA-Vlan-interface10] ipv6 address 10::1/64
2.     Configure Device B:
# Create VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] quit
# Configure HundredGigE 3/0/1, HundredGigE 3/0/2, and HundredGigE 3/0/3 to trunk VLAN 10.
[DeviceB] interface hundredgige 3/0/1
[DeviceB-HundredGigE3/0/1] port link-type access
[DeviceB-HundredGigE3/0/1] port access vlan 10
[DeviceB-HundredGigE3/0/1] quit
[DeviceB] interface hundredgige 3/0/2
[DeviceB-HundredGigE3/0/2] port link-type access
[DeviceB-HundredGigE3/0/2] port access vlan 10
[DeviceB-HundredGigE3/0/2] quit
[DeviceB] interface hundredgige 3/0/3
[DeviceB-HundredGigE3/0/3] port link-type trunk
[DeviceB-HundredGigE3/0/3] port trunk permit vlan 10
[DeviceB-HundredGigE3/0/3] quit
# Enable ND snooping for global unicast addresses and link-local addresses in VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] ipv6 nd snooping enable global
[DeviceB-vlan10] ipv6 nd snooping enable link-local
# Enable ND snooping for data packets from unknown sources in VLAN 10.
[DeviceB-vlan10] ipv6 nd snooping glean source
# Configure HundredGigE 3/0/3 as ND trusted interface.
[DeviceB-HundredGigE3/0/3] ipv6 nd detection trust
# Configure HundredGigE 3/0/1 to learn a maximum number of 200 ND snooping entries.
[DeviceB-HundredGigE3/0/1] ipv6 nd snooping max-learning-num 200
# Configure HundredGigE 3/0/2 to learn a maximum number of 200 ND snooping entries.
[DeviceB-HundredGigE3/0/2] ipv6 nd snooping max-learning-num 200
# Verify that Device B has learned ND snooping entries for Host A and Host B.
[DeviceB] display ipv6 nd snooping vlan 10
IPv6 address              MAC address     VID  Interface     Status       Age
10::5                     0001-0203-0405  10   HGE3/0/1      VALID        157
10::6                     0001-0203-0607  10   HGE3/0/2      VALID        105
  • Become a Partner
  • Partner Resources
