- 05-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-mDNS relay commands
- 06-IP forwarding basics commands
- 07-Fast forwarding commands
- 08-Adjacency table commands
- 09-IRDP commands
- 10-IP performance optimization commands
- 11-UDP helper commands
- 12-IPv6 basics commands
- 13-DHCPv6 commands
- 14-IPv6 fast forwarding commands
- 15-Tunneling commands
- 16-GRE commands
- 17-HTTP redirect commands
00-Preface | 100.65 KB |
Preface
This command reference covers the commands for configuring and managing IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500G-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
