02-H3C MDC+EVPN Configuration Examples | 193.00 KB |
H3C MDC + EVPN Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring MDC in combination with EVPN
Configuring MDCs on Switch A and Switch B
Configuring the IPTV and OTT networks
Verifying the MDC configuration
Verifying the multicast network
Introduction
This document provides configuration examples for deploying Multitenant Device Context (MDC) in combination with Ethernet Virtual Private Network (EVPN).
· The MDC technology can partition a physical device or an IRF fabric into multiple logical devices. Each of the logical devices is called an MDC.
· EVPN is a Layer 2 VPN technology. It uses MP-BGP to advertise EVPN routes in the control plane and can use VXLAN to forward traffic in the data plane.
By deploying MDC in combination with EVPN, you can quickly meet EVPN service requirements on traditional networks at a lower cost while isolating traditional services from EVPN services.
This document assumes that you have basic knowledge of MDC and EVPN.
As shown in Figure 1, a company needs to use its existing IP network to provide IPTV and OTT services for users.
To provide IPTV and OTT services while reducing cost, the company needs to deploy MDC in combination with EVPN on the network as follows:
· Virtualize Switch A into SWA-MDC1 and SWA-MDC2. Virtualize Switch B into SWB-MDC1 and SWB-MDC2. Configure SWA-MDC2 and SWB-MDC2 as RRs to reflect BGP EVPN routes on the EVPN network. Configure SWA-MDC1 as the gateway for the IPTV network. Configure SWB-MDC1 as the gateway for the OTT network.
· Configure Switch C and Switch D as distributed EVPN gateways.
· Configure Switch E as border gateway to the Internet.
· Assign Server 1 and Server 3 to VXLAN 10. Assign Server 2 and Server 4 to VXLAN 20. Achieve the following goals:
¡ The hosts in the same VXLAN can communicate at Layer 2.
¡ The hosts in different VXLANs can communicate at Layer 3 through the distributed EVPN gateways.
¡ Hosts in the VXLANs can access the Internet at Layer 3 through border gateways.
· The IPTV network needs to receive multicast information from Source through Switch F. Configure PIM on SWA-MDC1, SWA-MDC2, SWB-MDC2, Switch D, and Switch E to establish a multicast distribution tree. Configure SWA-MDC1 as the service gateway of the IPTV network.
· The OTT network needs to provide traditional services. Configure SWB-MDC1 as the gateway of the OTT network.
Device |
IP address |
Device |
IP address |
SWA-MDC1 |
Loopback0 |
6.6.6.6/32 |
Switch D |
Loopback0 |
4.4.4.4/32 |
Vlan-int10 |
17.1.1.6/24 |
Vlan-int10 |
14.1.1.4/24 |
Vlan-int20 |
18.1.1.6/24 |
Vlan-int20 |
13.1.1.4/24 |
SWA-MDC2 |
Loopback0 |
1.1.1.1/32 |
Vlan-int30 |
21.1.1.4/24 |
Vlan-int10 |
11.1.1.1/24 |
Switch E |
Loopback0 |
5.5.5.5/32 |
Vlan-int20 |
13.1.1.1/24 |
Vlan-int10 |
22.1.1.5/24 |
Vlan-int30 |
15.1.1.1/24 |
Vlan-int20 |
18.1.1.5/24 |
SWB-MDC1 |
Loopback0 |
7.7.7.7/32 |
Vlan-int30 |
15.1.1.5/24 |
Vlan-int10 |
20.1.1.7/24 |
Vlan-int40 |
16.1.1.5/24 |
Vlan-int50 |
19.1.1.7/24 |
Vlan-int50 |
19.1.1.5/24 |
SWB-MDC2 |
Loopback0 |
2.2.2.2/32 |
Switch F |
Loopback0 |
9.9.9.9/32 |
Vlan-int10 |
14.1.1.2/24 |
Vlan-int10 |
17.1.1.9/24 |
Vlan-int20 |
12.1.1.2/24 |
Vlan-int20 |
10.1.4.1/24 |
Vlan-int40 |
16.1.1.2/24 |
Switch C |
Loopback0 |
3.3.3.3/32 |
Vlan-int10 |
11.1.1.3/24 |
Vlan-int20 |
12.1.1.3/24 |
Analysis
To virtualize Switch A and Switch B into the required MDCs, configure MDCs on Switch A and Switch B.
For IP connectivity between SWA-MDC1, SWA-MDC2, SWB-MDC1, SWB-MDC2, Switch C, Switch D, and Switch E, configure a routing protocol on them and assign IP addresses to their interfaces, including loopback interfaces. In this example, OSPF is configured.
For Switch C and Switch D to use a VXLAN tunnel to communicate with each other, configure them as distributed EVPN gateways.
For the downlink ports of Switch C and Switch D to identify the VXLANs to which user network packets belong, configure Ethernet service instances and frame match criteria on the ports.
To enable SWA-MDC1, SWA-MDC2, SWB-MDC2, Switch D, and Switch E to establish a multicast distribution tree, configure PIM on them.
For the IPTV network and OTT network to access external networks, configure SWA-MDC1 as the IPTV network and configure SWB-MDC1 as the OTT network.
Procedures
1. Configure SWA-MDC1 on Switch A:
# Create SWA-MDC1.
[SwitchA] mdc SWA-MDC1
It will take some time to create MDC...
MDC created successfully.
[SwitchA-mdc-2-SWA-MDC1] quit
# Reclaim the LPUs in slot 3 and slot 4 from the default MDC.
[SwitchA] mdc Admin
[SwitchA-mdc-1-Admin] undo location slot 3
Performing this command is equivalent to removing the card from the MDC. Continue? [Y/N]:y
[SwitchA-mdc-1-Admin] undo location slot 4
[SwitchA-mdc-1-Admin] quit
# Assign interfaces HundredGigE 3/0/1 through HundredGigE 3/0/24 to SWA-MDC1.
[SwitchA-mdc-2-SWA-MDC1] allocate interface hundredgige 3/0/1 to hundredgige 3/0/24
This operation will allocate the specified interfaces and all interfaces in the listed groups to the MDC. Continue? [Y/N]:y
Configuration of the interfaces will be lost. Continue? [Y/N]:y
Execute the location slot command in the current view to place the configuration into effect.
# Assign LPU 1 to SWA-MDC1.
[SwitchA-mdc-2-SWA-MDC1] location slot 3
# Start SWA-MDC1.
[SwitchA-mdc-2-SWA-MDC1] mdc start
It will take some time to start MDC...
MDC started successfully.
2. Configure SWA-MDC2 on Switch A:
# Create SWA-MDC2.
[SwitchA] mdc SWA-MDC2
# Assign interfaces HundredGigE 4/0/1 through HundredGigE 4/0/24 to SWA-MDC2.
[SwitchA-mdc-3-SWA-MDC2] allocate interface hundredgige 4/0/1 to hundredgige 4/0/24
# Assign LPU 2 to SWA-MDC2.
[SwitchA-mdc-3-SWA-MDC2] location slot 4
# Start SWA-MDC2.
[SwitchA-mdc-3-SWA-MDC2] mdc start
[SwitchA-mdc-3-SWA-MDC2] quit
3. Configure SWB-MDC1 on Switch B:
# Create SWB-MDC1.
[SwitchB] mdc SWB-MDC1
[SwitchB-mdc-2-SWB-MDC1] quit
[SwitchB] mdc Admin
[SwitchB-mdc-1-Admin] undo location slot 3
[SwitchB-mdc-1-Admin] undo location slot 4
[SwitchB-mdc-1-Admin] quit
# Assign interfaces HundredGigE 3/0/1 through HundredGigE 3/0/24 to SWB-MDC1.
[SwitchB-mdc-2-SWB-MDC1] allocate interface hundredgige 3/0/1 to hundredgige 3/0/24
# Assign LPU 1 to SWB-MDC1.
[SwitchB-mdc-2-SWB-MDC1] location slot 3
# Start SWB-MDC1.
[SwitchB-mdc-2-SWB-MDC1] mdc start
4. Configure SWB-MDC2 on Switch B:
# Create SWB-MDC2.
[SwitchB] mdc SWB-MDC2
# Assign interfaces HundredGigE 4/0/1 through HundredGigE 4/0/24 to SWB-MDC2.
[SwitchB-mdc-3-SWB-MDC2] allocate interface hundredgige 4/0/1 to hundredgige 4/0/24
# Assign LPU 2 to SWB-MDC2.
[SwitchB-mdc-3-SWB-MDC2] location slot 4
# Start SWB-MDC2.
[SwitchB-mdc-3-SWB-MDC2] mdc start
[SwitchB-mdc-3-SWB-MDC2] quit
Assigning IP addresses to interfaces on the devices
# Log in to SWA-MDC1 and assign IP addresses to its interfaces.
[SwitchA] switchto mdc SWA-MDC1
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
Automatic configuration is running, press CTRL_D to break or press CTRL_B to
switch back to the default MDC.
<SWA-MDC1> system-view
[SWA-MDC1] interface loopback 0
[SWA-MDC1-Loopback0] ip address 6.6.6.6 32
[SWA-MDC1-Loopback0] quit
[SWA-MDC1] vlan 10
[SWA-MDC1-vlan10] port hundredgige 3/0/1
[SWA-MDC1-vlan10] quit
[SWA-MDC1] interface vlan-interface 10
[SWA-MDC1-Vlan-interface10] ip address 17.1.1.6 24
[SWA-MDC1-Vlan-interface10] quit
[SWA-MDC1] vlan 20
[SWA-MDC1-vlan20] port hundredgige 3/0/2
[SWA-MDC1-vlan20] quit
[SWA-MDC1] interface vlan-interface 20
[SWA-MDC1-Vlan-interface20] ip address 18.1.1.6 24
[SWA-MDC1-Vlan-interface20] quit
# Use the same method to log in to the other MDCs and assign IP addresses to interfaces. (Details not shown.)
# Assign IP addresses to interfaces on Switch C.
[SwitchC-Loopback0] ip address 3.3.3.3 32
[SwitchC-Loopback0] quit
[SwitchC] vlan 10
[SwitchC-vlan10] port hundredgige 3/0/3
[SwitchC-vlan10] quit
[SwitchC] interface vlan-interface 10
[SwitchC-Vlan-interface10] ip address 11.1.1.3 24
[SwitchC-Vlan-interface10] quit
[SwitchC] vlan 20
[SwitchC-vlan20] port hundredgige 3/0/4
[SwitchC-vlan20] quit
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 12.1.1.3 24
[SwitchC-Vlan-interface20] quit
# Use the same method to assign IP addresses to interfaces on the other switches. (Details not shown.)
Configuring the routing protocol
# On SWA-MDC1, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWA-MDC1] ospf 100 router-id 6.6.6.6
[SWA-MDC1-ospf-100] area 0
[SWA-MDC1-ospf-100-area-0.0.0.0] network 6.6.6.6 0.0.0.0
[SWA-MDC1-ospf-100-area-0.0.0.0] network 17.1.1.0 0.0.0.255
[SWA-MDC1-ospf-100-area-0.0.0.0] network 18.1.1.0 0.0.0.255
[SWA-MDC1-ospf-100-area-0.0.0.0] quit
[SWA-MDC1-ospf-100] quit
# On SWA-MDC2, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWA-MDC2] ospf 100 router-id 1.1.1.1
[SWA-MDC2-ospf-100] area 0
[SWA-MDC2-ospf-100-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[SWA-MDC2-ospf-100-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SWA-MDC2-ospf-100-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SWA-MDC2-ospf-100-area-0.0.0.0] network 15.1.1.0 0.0.0.255
[SWA-MDC2-ospf-100-area-0.0.0.0] quit
[SWA-MDC2-ospf-100] quit
# On SWB-MDC1, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWB-MDC1] ospf 100 router-id 7.7.7.7
[SWB-MDC1-ospf-100] area 0
[SWB-MDC1-ospf-100-area-0.0.0.0] network 7.7.7.7 0.0.0.0
[SWB-MDC1-ospf-100-area-0.0.0.0] network 19.1.1.0 0.0.0.255
[SWB-MDC1-ospf-100-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[SWB-MDC1-ospf-100-area-0.0.0.0] quit
[SWB-MDC1-ospf-100] quit
# On SWB-MDC2, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SWB-MDC2] ospf 100 router-id 2.2.2.2
[SWB-MDC2-ospf-100] area 0
[SWB-MDC2-ospf-100-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[SWB-MDC2-ospf-100-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SWB-MDC2-ospf-100-area-0.0.0.0] network 14.1.1.0 0.0.0.255
[SWB-MDC2-ospf-100-area-0.0.0.0] network 16.1.1.0 0.0.0.255
[SWB-MDC2-ospf-100-area-0.0.0.0] quit
[SWB-MDC2-ospf-100] quit
# On Switch C, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchC] ospf 100 router-id 3.3.3.3
[SwitchC-ospf-100] area 0
[SwitchC-ospf-100-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[SwitchC-ospf-100-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[SwitchC-ospf-100-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[SwitchC-ospf-100-area-0.0.0.0] quit
[SwitchC-ospf-100] quit
# On Switch D, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchD] ospf 100 router-id 4.4.4.4
[SwitchD-ospf-100] area 0
[SwitchD-ospf-100-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[SwitchD-ospf-100-area-0.0.0.0] network 13.1.3.0 0.0.0.255
[SwitchD-ospf-100-area-0.0.0.0] network 14.1.1.0 0.0.0.255
[SwitchD-ospf-100-area-0.0.0.0] network 21.1.1.0 0.0.0.255
[SwitchD-ospf-100-area-0.0.0.0] quit
[SwitchD-ospf-100] quit
# On Switch E, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchE] ospf 100 router-id 5.5.5.5
[SwitchE-ospf-100] area 0
[SwitchE-ospf-100-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[SwitchE-ospf-100-area-0.0.0.0] network 15.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] network 16.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] network 18.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] network 19.1.1.0 0.0.0.255
[SwitchE-ospf-100-area-0.0.0.0] quit
[SwitchE-ospf-100] quit
# On Switch F, configure OSPF and advertise the route information about the networks connected to the interfaces.
[SwitchF] ospf 100 router-id 9.9.9.9
[SwitchF-ospf-100] area 0
[SwitchF-ospf-100-area-0.0.0.0] network 9.9.9.9 0.0.0.0
[SwitchF-ospf-100-area-0.0.0.0] network 17.1.1.0 0.0.0.255
[SwitchF-ospf-100-area-0.0.0.0] quit
[SwitchF-ospf-100] quit
Configuring the multicast protocol
1. Configure Switch D:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface10, VLAN-interface 20, and VLAN-interface 30.
[SwitchD] multicast routing
[SwitchD-mrib] quit
[SwitchD] interface vlan-interface 10
[SwitchD-Vlan-interface10] pim sm
[SwitchD-Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD-Vlan-interface20] pim sm
[SwitchD-Vlan-interface20] quit
[SwitchD] interface vlan-interface 30
[SwitchD-Vlan-interface30] pim sm
[SwitchD-Vlan-interface30] quit
# Configure Loopback 0 of SWB-MDC2 as the static RP.
[SwitchD] pim
[SwitchD-pim] static-rp 2.2.2.2
[SwitchD-pim] quit
2. Configure SWA-MDC2:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 20 and VLAN-interface 30.
<SWA-MDC2> system-view
[SWA-MDC2] multicast routing
[SWA-MDC2-mrib] quit
[SWA-MDC2] interface vlan-interface 20
[SWA-MDC2-Vlan-interface20] pim sm
[SWA-MDC2-Vlan-interface20] quit
[SWA-MDC2] interface vlan-interface 30
[SWA-MDC2-Vlan-interface30] pim sm
[SWA-MDC2-Vlan-interface30] quit
# Configure Loopback 0 of SWA-MDC2 as a C-BSR and C-RP, and configure Loopback 0 of SWB-MDC2 as the static RP.
[SWA-MDC2] pim
[SWA-MDC2-pim] c-bsr 1.1.1.1
[SWA-MDC2-pim] c-rp 1.1.1.1
[SWA-MDC2-pim] static-rp 2.2.2.2
[SWA-MDC2-pim] quit
3. Configure SWB-MDC2:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 10 and VLAN-interface 40.
<SWB-MDC2> system-view
[SWB-MDC2] multicast routing
[SWB-MDC2-mrib] quit
[SWB-MDC2] interface vlan-interface 10
[SWB-MDC2-Vlan-interface10] pim sm
[SWB-MDC2-Vlan-interface10] quit
[SWB-MDC2] interface vlan-interface 40
[SWB-MDC2-Vlan-interface40] pim sm
[SWB-MDC2-Vlan-interface40] quit
[SWB-MDC2] pim
[SWB-MDC2-pim] static-rp 2.2.2.2
[SWB-MDC2-pim] quit
4. Configure Switch E:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 20, VLAN-interface 30, and VLAN-interface 40.
[SwitchE] multicast routing
[SwitchE-mrib] quit
[SwitchE] interface vlan-interface 20
[SwitchE-Vlan-interface20] pim sm
[SwitchE-Vlan-interface20] quit
[SwitchE] interface vlan-interface 30
[SwitchE-Vlan-interface30] pim sm
[SwitchE-Vlan-interface30] quit
[SwitchE] interface vlan-interface 40
[SwitchE-Vlan-interface40] pim sm
[SwitchE-Vlan-interface40] quit
[SwitchE] pim
[SwitchE-pim] static-rp 2.2.2.2
[SwitchE-pim] quit
5. Configure SWA-MDC1:
# Enable IP multicast routing and enable PIM-SM on VLAN-interface 10 and VLAN-interface 20.
[SWA-MDC1] multicast routing
[SWA-MDC1-mrib] quit
[SWA-MDC1-Vlan-interface10] pim sm
[SWA-MDC1-Vlan-interface20] pim sm
[SWA-MDC1] pim
[SWA-MDC1-pim] static-rp 2.2.2.2
[SWA-MDC1-pim] quit
6. Configure Switch F:
# Enable IP multicast routing, enable IGMP on VLAN-interface 20 (the host-side interface), and enable PIM-SM on VLAN-interface 10.
[SwitchF] multicast routing
[SwitchF-mrib] quit
[SwitchF] interface vlan-interface 10
[SwitchF-Vlan-interface10] pim sm
[SwitchF-Vlan-interface10] quit
[SwitchF] interface vlan-interface 20
[SwitchF-Vlan-interface20] igmp enable
[SwitchF-Vlan-interface20] quit
[SwitchF] pim
[SwitchF-pim] static-rp 2.2.2.2
[SwitchF-pim] quit
Configuring the EVPN network
Creating VSIs, EVPN instances, and VXLANs
1. Configure Switch C:
# Enable L2VPN.
[SwitchC] l2vpn enable
# Disable remote MAC address learning and remote ARP learning.
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] evpn encapsulation vxlan
[SwitchC-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
# Create an EVPN instance on VSI vpnb, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] evpn encapsulation vxlan
[SwitchC-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchC-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchC-vsi-vpnb] vxlan 20
[SwitchC-vsi-vpnb-vxlan-20] quit
[SwitchC-vsi-vpnb] quit
2. Configure Switch D:
# Enable L2VPN.
[SwitchD] l2vpn enable
[SwitchD] vxlan tunnel mac-learning disable
[SwitchD] vxlan tunnel arp-learning disable
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] evpn encapsulation vxlan
[SwitchD-vsi-vpna-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchD-vsi-vpna] vxlan 10
[SwitchD-vsi-vpna-vxlan-10] quit
[SwitchD-vsi-vpna] quit
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] evpn encapsulation vxlan
[SwitchD-vsi-vpnb-evpn-vxlan] route-distinguisher auto
[SwitchD-vsi-vpnb-evpn-vxlan] vpn-target auto
[SwitchD-vsi-vpnb-evpn-vxlan] quit
# Create VXLAN 20.
[SwitchD-vsi-vpnb] vxlan 20
[SwitchD-vsi-vpnb-vxlan-20] quit
[SwitchD-vsi-vpnb] quit
Configuring Ethernet service instances to match packets and mapping the instances to VSIs
# On HundredGigE 3/0/1, create Ethernet service instance 1000 to match VLAN 10 (Server 1), and map the Ethernet service instance to VSI vpna (VXLAN 10).
[SwitchC] interface hundredgige 3/0/1
[SwitchC-HundredGigE3/0/1] service-instance 1000
[SwitchC-HundredGigE3/0/1-srv1000] encapsulation s-vid 10
[SwitchC-HundredGigE3/0/1-srv1000] xconnect vsi vpna
[SwitchC-HundredGigE3/0/1-srv1000] quit
[SwitchC-HundredGigE3/0/1] quit
# On HundredGigE 3/0/2, create Ethernet service instance 1000 to match VLAN 11 (Server 2), and map the Ethernet service instance to VSI vpnb (VXLAN 20).
[SwitchC] interface hundredgige 3/0/2
[SwitchC-HundredGigE3/0/2] service-instance 1000
[SwitchC-HundredGigE3/0/2-srv1000] encapsulation s-vid 11
[SwitchC-HundredGigE3/0/2-srv1000] xconnect vsi vpnb
[SwitchC-HundredGigE3/0/2-srv1000] quit
[SwitchC-HundredGigE3/0/2] quit
# On HundredGigE 3/0/1, create Ethernet service instance 1000 to match VLAN 12 (Server 3), and map the Ethernet service instance to VSI vpna (VXLAN 10).
[SwitchD] interface hundredgige 3/0/1
[SwitchD-HundredGigE3/0/1] service-instance 1000
[SwitchD-HundredGigE3/0/1-srv1000] encapsulation s-vid 12
[SwitchD-HundredGigE3/0/1-srv1000] xconnect vsi vpna
[SwitchD-HundredGigE3/0/1-srv1000] quit
[SwitchD-HundredGigE3/0/1] quit
# On HundredGigE 3/0/2, create Ethernet service instance 1000 to match VLAN 13 (Server 4), and map the Ethernet service instance to VSI vpnb (VXLAN 20).
[SwitchD] interface hundredgige 3/0/2
[SwitchD-HundredGigE3/0/2] service-instance 1000
[SwitchD-HundredGigE3/0/2-srv1000] encapsulation s-vid 13
[SwitchD-HundredGigE3/0/2-srv1000] xconnect vsi vpnb
[SwitchD-HundredGigE3/0/2-srv1000] quit
[SwitchD-HundredGigE3/0/2] quit
Configuring BGP to advertise BGP EVPN routes
1. Configure SWA-MDC2:
# Configure SWA-MDC2 to establish BGP connections to other devices.
[SWA-MDC2] bgp 100
[SWA-MDC2-bgp-default] group evpn
[SWA-MDC2-bgp-default] peer 3.3.3.3 group evpn
[SWA-MDC2-bgp-default] peer 4.4.4.4 group evpn
[SWA-MDC2-bgp-default] peer 5.5.5.5 group evpn
[SWA-MDC2-bgp-default] peer evpn as-number 100
[SWA-MDC2-bgp-default] peer evpn connect-interface loopback 0
[SWA-MDC2-bgp-default] peer 2.2.2.2 as-number 100
[SWA-MDC2-bgp-default] peer 2.2.2.2 connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering for BGP EVPN routes.
[SWA-MDC2-bgp-default] address-family l2vpn evpn
[SWA-MDC2-bgp-default-evpn] peer evpn enable
[SWA-MDC2-bgp-default-evpn] peer 2.2.2.2 enable
[SWA-MDC2-bgp-default-evpn] undo policy vpn-target
# Configure SWA-MDC2 as the RR.
[SWA-MDC2-bgp-default-evpn] reflector cluster-id 8.8.8.8
[SWA-MDC2-bgp-default-evpn] peer evpn reflect-client
[SWA-MDC2-bgp-default-evpn] quit
[SWA-MDC2-bgp-default] quit
2. Configure SWB-MDC2:
# Configure SWB-MDC2 to establish BGP connections to other devices.
[SWB-MDC2] bgp 100
[SWB-MDC2-bgp-default] group evpn
[SWB-MDC2-bgp-default] peer 3.3.3.3 group evpn
[SWB-MDC2-bgp-default] peer 4.4.4.4 group evpn
[SWB-MDC2-bgp-default] peer 5.5.5.5 group evpn
[SWB-MDC2-bgp-default] peer evpn as-number 100
[SWB-MDC2-bgp-default] peer evpn connect-interface loopback 0
[SWB-MDC2-bgp-default] peer 1.1.1.1 as-number 100
[SWB-MDC2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SWB-MDC2-bgp-default] address-family l2vpn evpn
[SWB-MDC2-bgp-default-evpn] peer evpn enable
[SWB-MDC2-bgp-default-evpn] peer 1.1.1.1 enable
[SWB-MDC2-bgp-default-evpn] undo policy vpn-target
# Configure SWB-MDC2 as the RR.
[SWB-MDC2-bgp-default-evpn] reflector cluster-id 8.8.8.8
[SWB-MDC2-bgp-default-evpn] peer evpn reflect-client
[SWB-MDC2-bgp-default-evpn] quit
[SWB-MDC2-bgp-default] quit
3. Configure Switch C:
# Configure Switch C to establish BGP connections to other devices.
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 1.1.1.1 as-number 100
[SwitchC-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchC-bgp-default] peer 2.2.2.2 as-number 100
# Configure BGP to advertise BGP EVPN routes.
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchC-bgp-default-evpn] peer 2.2.2.2 enable
4. Configure Switch D:
# Configure Switch D to establish BGP connections to other devices.
[SwitchD] bgp 100
[SwitchD-bgp-default] peer 1.1.1.1 as-number 100
[SwitchD-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchD-bgp-default] peer 2.2.2.2 as-number 100
[SwitchD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchD-bgp-default-evpn] peer 2.2.2.2 enable
5. Configure Switch E:
# Configure Switch E to establish BGP connections to other devices.
[SwitchE] bgp 100
[SwitchE-bgp-default] peer 1.1.1.1 as-number 100
[SwitchE-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchE-bgp-default] peer 2.2.2.2 as-number 100
[SwitchE-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchE-bgp-default] address-family l2vpn evpn
[SwitchE-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchE-bgp-default-evpn] peer 2.2.2.2 enable
Configuring the distributed EVPN gateways
# Configure RD and route target settings for VPN instance vpna.
[SwitchC] ip vpn-instance vpna
[SwitchC-vpn-instance-vpna] route-distinguisher 1:1
[SwitchC-vpn-instance-vpna] address-family ipv4
[SwitchC-vpn-ipv4-vpna] vpn-target 2:2
[SwitchC-vpn-ipv4-vpna] quit
[SwitchC-vpn-instance-vpna] address-family evpn
[SwitchC-vpn-evpn-vpna] vpn-target 1:1
[SwitchC-vpn-evpn-vpna] quit
[SwitchC-vpn-instance-vpna] quit
# Configure VSI-interface 1.
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance vpna
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] mac-address 1-1-1
[SwitchC-Vsi-interface1] distributed-gateway local
[SwitchC-Vsi-interface1] local-proxy-arp enable
[SwitchC-Vsi-interface1] quit
# Configure VSI-interface 2.
[SwitchC] interface vsi-interface 2
[SwitchC-Vsi-interface2] ip binding vpn-instance vpna
[SwitchC-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchC-Vsi-interface2] mac-address 2-2-2
[SwitchC-Vsi-interface2] distributed-gateway local
[SwitchC-Vsi-interface2] local-proxy-arp enable
[SwitchC-Vsi-interface2] quit
# Create VSI-interface 3. Associate VSI-interface 3 with VPN instance vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna (the VSI of VXLAN 10).
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
# Specify VSI-interface 2 as the gateway interface for VSI vpnb (the VSI of VXLAN 20).
[SwitchC] vsi vpnb
[SwitchC-vsi-vpnb] gateway vsi-interface 2
[SwitchD] ip vpn-instance vpna
[SwitchD-vpn-instance-vpna] route-distinguisher 1:1
[SwitchD-vpn-instance-vpna] address-family ipv4
[SwitchD-vpn-ipv4-vpna] vpn-target 2:2
[SwitchD-vpn-ipv4-vpna] quit
[SwitchD-vpn-instance-vpna] address-family evpn
[SwitchD-vpn-evpn-vpna] vpn-target 1:1
[SwitchD-vpn-evpn-vpna] quit
[SwitchD-vpn-instance-vpna] quit
[SwitchD] interface vsi-interface 1
[SwitchD-Vsi-interface1] ip binding vpn-instance vpna
[SwitchD-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchD-Vsi-interface1] mac-address 1-1-1
[SwitchD-Vsi-interface1] distributed-gateway local
[SwitchD-Vsi-interface1] local-proxy-arp enable
[SwitchD-Vsi-interface1] quit
[SwitchD] interface vsi-interface 2
[SwitchD-Vsi-interface2] ip binding vpn-instance vpna
[SwitchD-Vsi-interface2] ip address 10.1.2.1 255.255.255.0
[SwitchD-Vsi-interface2] mac-address 2-2-2
[SwitchD-Vsi-interface2] distributed-gateway local
[SwitchD-Vsi-interface2] local-proxy-arp enable
[SwitchD-Vsi-interface2] quit
[SwitchD] interface vsi-interface 3
[SwitchD-Vsi-interface3] ip binding vpn-instance vpna
[SwitchD-Vsi-interface3] l3-vni 1000
[SwitchD-Vsi-interface3] quit
[SwitchD] vsi vpna
[SwitchD-vsi-vpna] gateway vsi-interface 1
[SwitchD] vsi vpnb
[SwitchD-vsi-vpnb] gateway vsi-interface 2
Configuring border gateway Switch E
# Enable L2VPN.
<SwitchE> system-view
[SwitchE] l2vpn enable
[SwitchE] vxlan tunnel mac-learning disable
[SwitchE] vxlan tunnel arp-learning disable
[SwitchE] ip vpn-instance vpna
[SwitchE-vpn-instance-vpna] route-distinguisher 1:1
[SwitchE-vpn-instance-vpna] address-family ipv4
[SwitchE-vpn-ipv4-vpna] vpn-target 2:2
[SwitchE-vpn-ipv4-vpna] quit
[SwitchE-vpn-instance-vpna] address-family evpn
[SwitchE-vpn-evpn-vpna] vpn-target 1:1
[SwitchE-vpn-evpn-vpna] quit
[SwitchE-vpn-instance-vpna] quit
[SwitchE] interface vsi-interface 3
[SwitchE-Vsi-interface3] ip binding vpn-instance vpna
[SwitchE-Vsi-interface3] l3-vni 1000
[SwitchE-Vsi-interface3] quit
# Configure a default route. Set the next hop to 22.1.1.100 (the IP address of a device in the Internet).
[SwitchE] ip route-static vpn-instance vpna 0.0.0.0 0 22.1.1.100
# Redistribute the default route to the BGP IPv4 unicast routing table of VPN instance vpna.
[SwitchE] bgp 100
[SwitchE-bgp-default] ip vpn-instance vpna
[SwitchE-bgp-default-vpna] address-family ipv4 unicast
[SwitchE-bgp-default-ipv4-vpna] default-route imported
[SwitchE-bgp-default-ipv4-vpna] import-route static
[SwitchE-bgp-default-ipv4-vpna] quit
[SwitchE-bgp-default-vpna] quit
[SwitchE-bgp-default] quit
# Associate VLAN-interface 10 (the interface connected to the Internet) with VPN instance vpna.
[SwitchE] interface vlan-interface 10
[SwitchE-Vlan-interface20] ip binding vpn-instance vpna
[SwitchE-Vlan-interface20] ip address 22.1.1.5 24
# Verify that the MDCs on Switch A exist and are operating correctly.
[SwitchA] display mdc
ID Name Status
1 Admin active
2 SWA-MDC1 active
3 SWA-MDC2 active
The output shows that the MDCs have been created and are operating correctly.
# Log in to SWA-MDC2.
[SwitchA] switchto mdc SWA-MDC2
<SWA-MDC2>%Mar 2 10:43:04:214 2019 SWA-MDC2 SHELL/5/SHELL_LOGIN: -MDC=3; Console logged in from con0.
# Display the interfaces assigned to SWA-MDC2.
<SWA-MDC2> display interface brief
Protocol: (s) - spoofing
InLoop0 UP UP(s) --
Loop0 UP UP(s) 1.1.1.1
MGE0/0/0 DOWN DOWN --
NULL0 UP UP(s) --
REG0 UP -- --
Vlan10 UP UP 11.1.1.1
Vlan20 UP UP 13.1.1.1
Vlan30 UP UP 15.1.1.1
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
HGE4/0/1 UP 1G(a) F A 30
HGE4/0/2 ADM auto F A 1
HGE4/0/3 UP 1G(a) F A 10
HGE4/0/4 UP 1G(a) F A 20
HGE4/0/5 ADM auto F A 1
HGE4/0/6 ADM auto F A 1
HGE4/0/7 ADM auto F A 1
HGE4/0/8 ADM auto F A 1
HGE4/0/9 ADM auto F A 1
HGE4/0/10 ADM auto F A 1
HGE4/0/11 ADM auto F A 1
HGE4/0/12 ADM auto F A 1
HGE4/0/13 ADM auto F A 1
HGE4/0/14 ADM auto F A 1
HGE4/0/15 ADM auto F A 1
HGE4/0/16 ADM auto F A 1
HGE4/0/17 ADM auto F A 1
HGE4/0/18 ADM auto F A 1
HGE4/0/19 ADM auto F A 1
HGE4/0/20 ADM auto F A 1
HGE4/0/21 ADM auto F A 1
HGE4/0/22 ADM auto F A 1
HGE4/0/23 ADM auto F A 1
HGE4/0/24 ADM auto F A 1
# Use the same method to verify the MDC configuration on Switch B. (Details not shown.)
Verifying the EVPN network
# Display EVPN routing information on distributed EVPN gateway Switch C.
[SwitchC] display bgp l2vpn evpn
Status codes: * - valid, > - best, d - dampened, h - history
a - additional-path
Total number of routes from all PEs: 10
Route distinguisher: 1:1(vpna)
Total number of routes: 6
* >i [2][0][48][a21a-36c9-0806][32][10.1.1.20]/136
4.4.4.4 0 100 0 i
* >i [2][0][48][a21a-39de-0907][32][10.1.2.20]/136
4.4.4.4 0 100 0 i
* >i [5][0][0][0.0.0.0]/80
5.5.5.5 0 100 0 ?
* i 5.5.5.5 0 100 0 ?
* > [5][0][24][10.1.1.0]/80
0.0.0.0 0 100 32768 i
* > [5][0][24][10.1.2.0]/80
Route distinguisher: 1:10
* > [2][0][48][a21a-2df1-0606][32][10.1.1.10]/136
4.4.4.4 0 100 0 i
* i 4.4.4.4 0 100 0 i
* > [3][0][32][3.3.3.3]/80
* >i [3][0][32][4.4.4.4]/80
4.4.4.4 0 100 0 i
Route distinguisher: 1:20
* > [2][0][48][a21a-3300-0707][32][10.1.2.10]/136
4.4.4.4 0 100 0 i
4.4.4.4 0 100 0 i
# Verify that the VXLAN tunnel interfaces are up.
[SwitchC] display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 4.4.4.4
Input: 10 packets, 980 bytes, 0 drops
Output: 19 packets, 1520 bytes, 0 drops
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64 kbps
Tunnel source 3.3.3.3, destination 5.5.5.5
Output: 0 packets, 0 bytes, 0 drops...
# Verify that the VSI interfaces are up on Switch C.
[SwitchC] display interface vsi-interface
Vsi-interface1
Current state: UP
Description: Vsi-interface1 Interface
Bandwidth: 1000000 kbps
Maximum transmission unit: 1444
IP packet frame type: Ethernet II, hardware address: 0001-0001-0001
IPv6 packet frame type: Ethernet II, hardware address: 0001-0001-0001
Output: 192 packets, 18816 bytes, 0 drops
Vsi-interface2
Current state: UP
Description: Vsi-interface2 Interface
IP packet frame type: Ethernet II, hardware address: 0002-0002-0002
IPv6 packet frame type: Ethernet II, hardware address: 0002-0002-0002
Output: 128 packets, 8960 bytes, 0 drops
Vsi-interface3
Current state: UP
Description: Vsi-interface3 Interface
IP packet frame type: Ethernet II, hardware address: a21a-0861-0300
IPv6 packet frame type: Ethernet II, hardware address: a21a-0861-0300
# Verify that the VXLAN tunnels have been assigned to the VXLANs, and the VSI interfaces are the gateway interfaces of their respective VXLANs.
[SwitchC] display l2vpn vsi verbose
VSI Name: Auto_L3VNI1000_3
VSI Index : 2
VSI State : Down
MTU : 1500
Bandwidth : -
Broadcast Restrain : Unlimited
Multicast Restrain : Unlimited
Unknown Unicast Restrain: Unlimited
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
Gateway Interface : VSI-interface 3
VXLAN ID : 1000
VSI Name: vpna
VSI Index : 0
VSI State : Up
MTU : 1500
Bandwidth : Unlimited
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 1
VXLAN ID : 10
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000000 UP Auto Disabled
ACs:
AC Link ID State Type
HGE3/0/1 srv1000 0 Up Manual
VSI Name: vpnb
VSI Index : 1
VSI State : Up
MTU : 1500
Bandwidth : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 2
VXLAN ID : 20
Tunnels:
ACs:
HGE3/0/2 srv1000 0 Up Manual
# Verify that Switch C has created ARP entries for the VMs.
[SwitchC] display arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN/VSI Interface Aging Type
11.1.1.1 a210-9a1c-0182 10 HGE3/0/3 240 D
12.1.1.2 a21a-01b9-0242 20 HGE3/0/5 240 D
10.1.1.10 a21a-2df1-0606 0 HGE3/0/1 489 D
10.1.2.10 a21a-3300-0707 1 HGE3/0/2 414 D
4.4.4.4 a21a-0fb2-0400 2 Tunnel1 -- R
5.5.5.5 a21a-17fd-0500 2 Tunnel2 -- R
# Verify that Switch C has created EVPN ARP entries for the local VMs.
[SwitchC] display evpn route arp
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping
VPN instance: vpna Interface: Vsi-interface1
IP address MAC address Router MAC VSI index Flags
10.1.1.1 0001-0001-0001 a21a-0861-0300 0 GL
10.1.1.10 a21a-2df1-0606 a21a-0861-0300 0 DL
10.1.1.20 a21a-36c9-0806 a21a-0fb2-0400 0 B
VPN instance: vpna Interface: Vsi-interface2
10.1.2.1 0002-0002-0002 a21a-0861-0300 1 GL
10.1.2.10 a21a-3300-0707 a21a-0861-0300 1 DL
10.1.2.20 a21a-39de-0907 a21a-0fb2-0400 1 B
<SwitchC>
# Verify that the servers can communicate with one another and can communicate with the Internet. (Details not shown.)
# On Switch F, display RP information in the PIM-SM domain.
[SwitchF] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 225.1.1.0/24
RP address Priority HoldTime Uptime Expires
1.1.1.1 192 180 00:51:45 00:02:22
Static RP information:
RP address ACL Mode Preferred
2.2.2.2 ---- pim-sm No
[SwitchF] display pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:01:44
Elected BSR address: 1.1.1.1
Priority: 64
Hash mask length: 30
Uptime: 00:11:18
[SwitchF]disp pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
Vlan10 0 30 1 10.1.4.1 (local)
Vlan20 1 30 1 1.1.1.1
# On SWA-MDC2, display BSR information in the PIM-SM domain.
[SWA-MDC2] display pim bsr-info
Scope: non-scoped
State: Elected
Priority: 64
Uptime: 00:11:18
Candidate BSR address: 1.1.1.1
Priority: 64
# On SWA-MDC2, display C-RP information in the PIM-SM domain.
[SWA-MDC2] display pim c-rp
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4
C-RP address Priority HoldTime Uptime Expires
1.1.1.1 (local) 192 150 03:01:36 00:02:29
Configuration files
· Switch A:
mdc Admin id 1
mdc SWA-MDC1 id 2
location slot 3
mdc start
allocate interface HundredGigE3/0/1 to HundredGigE 3/0/24
mdc SWA-MDC2 id 3
location slot 4
mdc start
allocate interface HundredGigE 4/0/1 to HundredGigE 4/0/24
· SWA-MDC1:
area 0.0.0.0
vlan 10
vlan 20
interface LoopBack0
ip address 6.6.6.6 255.255.255.255
interface Vlan-interface10
ip address 17.1.1.6 255.255.255.0
pim sm
interface Vlan-interface20
ip address 18.1.1.6 255.255.255.0
pim sm
port link-mode bridge
port access vlan 10
interface HundredGigE3/0/2
port access vlan 20
multicast routing
pim
static-rp 2.2.2.2
· SWA-MDC2:
area 0.0.0.0
vlan 10
vlan 20
vlan 30
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
ip address 11.1.1.1 255.255.255.0
ip address 13.1.1.1 255.255.255.0
pim sm
interface Vlan-interface30
ip address 15.1.1.1 255.255.255.0
pim sm
interface HundredGigE4/0/1
port access vlan 30
interface HundredGigE4/0/3
port access vlan 10
interface HundredGigE4/0/4
port access vlan 20
bgp 100
group evpn internal
peer evpn connect-interface LoopBack0
peer 2.2.2.2 connect-interface LoopBack0
peer evpn enable
peer 2.2.2.2 enable
multicast routing
pim
c-bsr 1.1.1.1
c-rp 1.1.1.1
static-rp 2.2.2.2
· Switch B:
mdc Admin id 1
mdc SWB-MDC1 id 2
location slot 3
mdc start
allocate interface HundredGigE3/0/1 to HundredGigE3/0/24
mdc SWB-MDC2 id 3
location slot 4
mdc start
allocate interface HundredGigE4/0/1 to HundredGigE4/0/24
· SWB-MDC1:
area 0.0.0.0
vlan 10
vlan 50
interface LoopBack0
ip address 7.7.7.7 255.255.255.255
ip address 20.1.1.7 255.255.255.0
interface Vlan-interface50
ip address 19.1.1.7 255.255.255.0
port access vlan 10
port access vlan 50
· SWB-MDC2:
area 0.0.0.0
vlan 10
vlan 20
vlan 40
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
ip address 14.1.1.2 255.255.255.0
pim sm
ip address 12.1.1.2 255.255.255.0
interface Vlan-interface40
ip address 16.1.1.2 255.255.255.0
pim sm
interface HundredGigE4/0/2
port access vlan 40
port access vlan 10
interface HundredGigE4/0/5
port access vlan 20
bgp 100
group evpn internal
peer 1.1.1.1 connect-interface LoopBack0
peer evpn enable
peer 1.1.1.1 enable
multicast routing
pim
static-rp 2.2.2.2
· Switch C:
address-family ipv4
vpn-target 2:2 import-extcommunity
vpn-target 2:2 export-extcommunity
address-family evpn
vpn-target 1:1 import-extcommunity
vpn-target 1:1 export-extcommunity
area 0.0.0.0
vlan 10
vlan 20
l2vpn enable
vsi vpna
vxlan 10
vpn-target auto export-extcommunity
vpn-target auto import-extcommunity
vsi vpnb
vxlan 20
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
ip address 11.1.1.3 255.255.255.0
ip address 12.1.1.3 255.255.255.0
xconnect vsi vpna
xconnect vsi vpnb
interface HundredGigE3/0/3
port access vlan 10
interface HundredGigE3/0/4
port access vlan 20
interface HundredGigE3/0/5
port access vlan 20
interface Vsi-interface1
mac-address 0001-0001-0001
interface Vsi-interface2
mac-address 0002-0002-0002
interface Vsi-interface3
l3-vni 1000
bgp 100
peer 1.1.1.1 enable
peer 2.2.2.2 enable
· Switch D:
address-family ipv4
address-family evpn
area 0.0.0.0
vlan 10
vlan 20
vlan 30
l2vpn enable
vsi vpna
vxlan 10
vsi vpnb
vxlan 20
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 14.1.1.4 255.255.255.0
pim sm
ip address 13.1.1.4 255.255.255.0
pim sm
ip address 21.1.1.4 255.255.255.0
pim sm
xconnect vsi vpna
xconnect vsi vpnb
port access vlan 10
port access vlan 20
port access vlan 30
l3-vni 1000
bgp 100
peer 1.1.1.1 enable
peer 2.2.2.2 enable
multicast routing
pim
static-rp 2.2.2.2
· Switch E:
address-family ipv4
address-family evpn
area 0.0.0.0
network 22.1.1.0 0.0.0.255
vlan 10
vlan 20
vlan 30
vlan 40
vlan 50
l2vpn enable
interface LoopBack0
ip address 5.5.5.5 255.255.255.255
ip address 22.1.1.5 255.255.255.0
ip address 18.1.1.5 255.255.255.0
pim sm
ip address 15.1.1.5 255.255.255.0
pim sm
ip address 16.1.1.5 255.255.255.0
pim sm
ip address 19.1.1.5 255.255.255.0
port access vlan 30
port access vlan 40
port access vlan 10
interface HundredGigE3/0/17
port access vlan 20
interface HundredGigE3/0/18
port access vlan 50
l3-vni 1000
bgp 100
peer 1.1.1.1 enable
peer 2.2.2.2 enable
import-route static
multicast routing
pim
static-rp 2.2.2.2
· Switch F:
area 0.0.0.0
vlan 10
vlan 20
interface LoopBack0
ip address 9.9.9.9 255.255.255.255
ip address 17.1.1.9 255.255.255.0
pim sm
ip address 10.1.4.1 255.255.255.0
igmp enable
port access vlan 20
port access vlan 10
multicast routing
pim
static-rp 2.2.2.2
Related documentation
· H3C S12500G-AF Switch Series EVPN Command Reference-R759X
· H3C S12500G-AF Switch Series EVPN Configuration Guide-R759X
· H3C S12500G-AF Switch Series MDC Command Reference-R759X
· H3C S12500G-AF Switch Series MDC Configuration Guide-R759X
