02-H3C_NTP_Configuration_Examples | 253.78 KB |
H3C NTP Configuration Examples
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring the NTP client/server mode
Example: Configuring the NTP broadcast mode
Configuring Switch B, Switch D, and Switch E
Example: Configuring the NTP multicast mode
Example: Configuring NTP authentication in client/server mode
Example: Configuring the IPv6 NTP client/server mode
Example: Configuring the IPv6 NTP multicast mode
Example: Configuring NTP authentication in broadcast mode
Introduction
This document provides NTP configuration examples.
This document assumes that you have basic knowledge of NTP.
As shown in Figure 1, Switch A is an NTP server. For time synchronization on the network, configure the NTP client/server mode so that Switch B and Switch C synchronize with Switch A.
Procedures
Configuring Switch A
# Assign an IP address to VLAN-interface 2.
[SwitchA] interface Vlan-interface 2
[SwitchA-Vlan-interface2] ip address 1.0.1.11 24
# Enable the NTP service.
[SwitchA] ntp-service enable
# Specify the local clock as the reference source, with stratum level 2.
[SwitchA] ntp-service refclock-master 2
# Assign an IP address to VLAN-interface 2. (Details not shown.)
[SwitchB] ntp-service enable
# Specify Switch A as the NTP server of Switch B so that Switch B is synchronized to Switch A.
[SwitchB] ntp-service unicast-server 1.0.1.11
Configuring Switch C
[SwitchC] ntp-service enable
# Specify Switch A as the NTP server of Switch C so that Switch C is synchronized to Switch A.
[SwitchC] ntp-service unicast-server 1.0.1.11
If the configuration is correct, Switch B and Switch C synchronize the time with Switch A. The following uses Switch B as an example to verify the configuration.
# Verify that Switch B has synchronized to Switch A, and the clock stratum level is 3 on Switch B and 2 on Switch A.
[SwitchB] display ntp-service status
Clock status: synchronized
Clock stratum: 3
System peer: 1.0.1.11
Local mode: client
Reference clock ID: 1.0.1.11
Leap indicator: 00
Clock jitter: 0.003479 s
Stability: 0.000 pps
Clock precision: 2^-18
Root delay: 1.95313 ms
Root dispersion: 28.38135 ms
Reference time: d5ed8cd5.577006ea Wed, Sep 25 2019 16:24:53.341
# Verify that an IPv4 NTP association has been established between Switch B and Switch A.
[SwitchB] display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]1.0.1.11 127.127.1.0 2 255 64 38 -10.22 1.9531 3.3416
Total sessions: 1
Configuration files
· Switch A:
interface Vlan-interface2
ip address 1.0.1.11 255.255.255.0
ntp-service enable
· Switch B:
ip address 1.0.1.12 255.255.255.0
ntp-service enable
· Switch C:
ip address 1.0.1.13 255.255.255.0
ntp-service enable
As shown in Figure 2, the devices are on the same network segment (3.0.1.0/24). For time synchronization on the network, configure the NTP broadcast mode so that the devices synchronize with Switch C.
Procedures
[SwitchC] ntp-service refclock-master 2
[SwitchC] interface Vlan-interface 2
[SwitchC-Vlan-interface2] ip address 3.0.1.31 24
# Configure Switch C to operate in broadcast server mode and send broadcast messages from VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service broadcast-server
# Enable the NTP service on Switch A.
# Configure Switch A to operate in broadcast client mode and receive broadcast messages on VLAN-interface 2.
[SwitchA-Vlan-interface2] ntp-service broadcast-client
The configuration procedure is the same for Switch A, Switch B, Switch D, and Switch E. See "Configuring Switch A" for the configuration procedure.
If the configuration is correct, Switch A, Switch B, Switch D, and Switch E synchronize the time with Switch C. The following uses Switch A as an example to verify the configuration.
# Verify that Switch A has synchronized to Switch C, and the clock stratum level is 3 on Switch A and 2 on Switch C.
[SwitchA-Vlan-interface2] display ntp-service status
Clock stratum: 3
System peer: 3.0.1.31
Local mode: bclient
Reference clock ID: 3.0.1.31
Leap indicator: 00
Clock jitter: 0.000061 s
Root delay: 0.00000 ms
Root dispersion: 7951.43127 ms
Reference time: d5ee8d88.2faabed0 Thu, Sep 26 2019 10:40:08.186
# Verify that an IPv4 NTP association has been established between Switch A and Switch C.
[SwitchA-Vlan-interface2] display ntp-service sessions
[1234]3.0.1.31 127.127.1.0 2 254 64 82 -2.190 0.0000 7937.5
Total sessions: 1
Configuration files
· Switch C:
ip address 3.0.1.31 255.255.255.0
ntp-service enable
· Switch A:
ip address 3.0.1.33 255.255.255.0
ntp-service enable
· Switch B:
ip address 3.0.1.30 255.255.255.0
ntp-service enable
· Switch D:
ip address 3.0.1.32 255.255.255.0
ntp-service enable
· Switch E:
ip address 3.0.1.34 255.255.255.0
ntp-service enable
As shown in Figure 3, the devices are on different network segments. For time synchronization on the network, configure the NTP multicast mode so that the devices synchronize with Switch C.
Procedures
# Configure Switch C to operate in multicast server mode and send multicast messages from VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service multicast-server
Configuring Switch D
<SwitchD> system-view
[SwitchD] ntp-service enable
[SwitchD] interface Vlan-interface 2
[SwitchD-Vlan-interface2] ip address 3.0.1.32 24
# Configure Switch D to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD-Vlan-interface2] ntp-service multicast-client
# Configure Switch B to operate in multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchB-Vlan-interface2] ntp-service multicast-client
Because Switch A and Switch C are on different subnets, you must enable the multicast functions on Switch B before Switch A can receive multicast messages from Switch C.
# Enable IP multicast routing and IGMP.
[SwitchB] multicast routing
[SwitchB-Vlan-interface2] pim dm
[SwitchB] vlan 3
[SwitchB-vlan3] port HundredGigE 3/0/1
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] ip address 1.0.1.10 24
[SwitchB-Vlan-interface3] igmp enable
[SwitchB-Vlan-interface3] igmp static-group 224.0.1.1
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
[SwitchB] interface HundredGigE 3/0/1
[SwitchB-HundredGigE3/0/1] igmp-snooping static-group 224.0.1.1 vlan 3
# Assign an IP address to VLAN-interface 3.
[SwitchA] interface Vlan-interface 3
[SwitchA-Vlan-interface3] ip address 1.0.1.11 24
# Configure Switch A to operate in multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service multicast-client
If the configuration is correct, Switch A, Switch B, and Switch D synchronize the time with Switch C. The following uses Switch A as an example to verify the configuration.
[SwitchA-Vlan-interface3] display ntp-service status
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Root delay: 1.69373 ms
Root dispersion: 1950.18005 ms
Reference time: d5ee9b15.2f3a684d Thu, Sep 26 2019 11:37:57.184
Configuration files
· Switch A:
ntp-service enable
interface Vlan-interface3
· Switch B:
ntp-service enable
multicast routing
igmp-snooping
pim dm
ip address 1.0.1.10 255.255.255.0
igmp enable
interface HundredGigE3/0/1
port access vlan 3
· Switch C:
ntp-service enable
· Switch D:
ntp-service enable
As shown in Figure 4, Switch A is an NTP server. For time synchronization on the network, configure the NTP client/server mode so that the devices synchronize with Switch A. Configure NTP authentication so that Switch A is authenticated before synchronizing the devices.
Procedures
# Enable NTP authentication on Switch A.
[SwitchA] ntp-service authentication enable
# Configure a plaintext authentication key, specifying the key ID as 42 and key string as aNiceKey.
[SwitchA] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
# Configure the key as a trusted key.
[SwitchA] ntp-service reliable authentication-keyid 42
# Enable NTP authentication on Switch B.
[SwitchB] ntp-service authentication enable
[SwitchB] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[SwitchB] ntp-service reliable authentication-keyid 42
# Specify Switch A as the NTP server of Switch B, and associate the server with key 42.
[SwitchB] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
# Enable NTP authentication on Switch C.
[SwitchC] ntp-service authentication enable
[SwitchC] ntp-service authentication-keyid 42 authentication-mode md5 simple aNiceKey
[SwitchC] ntp-service reliable authentication-keyid 42
# Specify Switch A as the NTP server of Switch C, and associate the server with key 42.
[SwitchC] ntp-service unicast-server 1.0.1.11 authentication-keyid 42
Clock stratum: 3
Local mode: client
Leap indicator: 00
Clock jitter: 0.005096 s
Root delay: 0.00655 ms
Root dispersion: 1.15869 ms
Reference time: d0c62687.ab1bba7d Mon, Sep 30 2019 16:06:26.764
[1245]1.0.1.11 127.127.1.0 2 1 64 519 -0.0 0.0065 0.0
Total sessions : 1
Configuration files
· Switch A:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$4j3SKCgQWBK3Un41B9U0JXzJX9i7IuNoSqi
· Switch B:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$22eIc8l796cpudZqiaAZ2SLzIfrgzFTVYn8X
· Switch C:
ntp-service enable
ntp-service authentication-keyid 42 authentication-mode md5 cipher $c$3$XJzVmJ1TJbWyYAXpPXxF7JiEOZag8CehibM8
Example: Configuring SNTP
As shown in Figure 5, Switch A is an NTP server. For time synchronization on the network, configure Switch B and Switch C as SNTP clients to synchronize with Switch A.
Procedures
# Enable the SNTP service.
[SwitchB] sntp enable
# Specify Switch A as the NTP server of Switch B.
[SwitchB] sntp unicast-server 1.0.1.11
[SwitchC] sntp enable
# Specify Switch A as the NTP server of Switch C.
[SwitchC] sntp unicast-server 1.0.1.11
# Verify that an SNTP association has been established between Switch B and Switch A, and Switch B has synchronized to Switch A.
[SwitchB] display sntp sessions
SNTP server Stratum Version Last receive time
1.0.1.11 2 4 Thu, Sep 26 2019 17:25:09.121 (Synced)
Configuration files
· Switch A:
ntp-service enable
· Switch B:
sntp enable
· Switch C:
sntp enable
As shown in Figure 1, Switch A is an NTP server on the IPv6 network. For time synchronization on the network, configure the IPv6 NTP client/server mode so that Switch B and Switch C synchronize with Switch A.
Figure 6 Network diagram
Procedures
# Assign an IPv6 address to VLAN-interface 2.
[SwitchA-Vlan-interface2] ipv6 address 3000::34 64
# Assign an IPv6 address to VLAN-interface 2. (Details not shown.)
[SwitchB] ntp-service unicast-server 3000::34
# Specify Switch A as the NTP server of Switch C so that Switch C is synchronized with Switch A.
[SwitchC] ntp-service unicast-server 3000::34
Clock stratum: 3
System peer: 3000::34
Local mode: client
Reference clock ID: 95.197.17.40
Leap indicator: 00
# Verify that an IPv6 NTP association has been established between Switch B and Switch A.
[SwitchB] display ntp-service ipv6 sessions
Source: [12345] 3000::34
Reference: 127.127.1.0 Clock stratum: 2
Reachabilities: 3 Poll interval: 64
Last receive time: 62 Offset: 0.1272
Roundtrip delay: 1.8158 Dispersion: 188.47
Total sessions: 1
Configuration files
· Switch A:
ipv6 address 3000::34/64
ntp-service enable
· Switch B:
ipv6 address 3000::35/64
ntp-service enable
ntp-service ipv6 unicast-server 3000::34
· Switch C:
ipv6 address 3000::36/64
ntp-service enable
As shown in Figure 3, Switch C is an NTP server on the IPv6 network, and the devices are on different network segments. For time synchronization on the network, configure the IPv6 NTP multicast mode so that the devices synchronize with Switch C.
Figure 7 Network diagram
Procedures
Configure routing protocols so that all devices can reach each other. (Details not shown.)
[SwitchC-Vlan-interface2] ipv6 address 3000::2 64
# Configure Switch C to operate in IPv6 multicast server mode and send multicast messages from VLAN-interface 2.
[SwitchC-Vlan-interface2] ntp-service ipv6 multicast-server ff24::1
# Configure Switch D to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchD-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
[SwitchD-Vlan-interface2] quit
# Assign an IP address to VLAN-interface 2 and VLAN-interface 3. (Details not shown.)
# Configure Switch B to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 2.
[SwitchB-Vlan-interface2] ntp-service ipv6 multicast-client ff24::1
Because Switch A and Switch C are on different subnets, you must enable IPv6 multicast functions on Switch B so that Switch A can receive multicast messages from Switch C.
# Enable IPv6 multicast functions.
[SwitchB] ipv6 multicast routing
[SwitchB-mrib6] quit
[SwitchB-Vlan-interface2] ipv6 pim dm
[SwitchB] vlan 3
[SwitchB-Vlan-interface3] mld enable
[SwitchB-Vlan-interface3] mld static-group ff24::1
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
[SwitchB-HundredGigE3/0/1] mld-snooping static-group ff24::1 vlan 3
# Assign an IP address to VLAN-interface 3. (Details not shown.)
# Configure Switch A to operate in IPv6 multicast client mode and receive multicast messages on VLAN-interface 3.
[SwitchA-Vlan-interface3] ntp-service ipv6 multicast-client ff24::1
[SwitchA-Vlan-interface3] quit
[SwitchA] display ntp-service status
Clock stratum: 3
System peer: 3000::2
Local mode: bclient
Reference clock ID: 165.84.121.65
Leap indicator: 00
Clock precision: 2^-14
Configuration files
· Switch A:
ntp-service enable
ipv6 address 2000::1/64
· Switch B:
ntp-service enable
mld-snooping
ipv6 address 3000::1/64
ipv6 pim dm
ipv6 address 2000::2/64
mld enable
port access vlan 3
· Switch C:
ntp-service enable
ipv6 address 3000::2/64
· Switch D:
ntp-service enable
ipv6 address 3000::3/64
As shown in Figure 4, the devices are on the same network segment (3.0.1.0/24). Configure the NTP broadcast mode so that the devices synchronize with Switch C. Configure NTP authentication so that Switch C is authenticated before synchronizing the devices.
Figure 8 Network diagram
Procedures
Configure Switch C
# Enable NTP authentication on Switch C. Configure a plaintext authentication key, specifying the key ID as 88 and key string as 123456. Configure the key as a trusted key.
[SwitchC] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchC] ntp-service reliable authentication-keyid 88
# Specify Switch C as an NTP broadcast server, and associate key 88 with Switch C.
[SwitchC-Vlan-interface2] ntp-service broadcast-server authentication-keyid 88
Configure Switch A
# Enable NTP authentication on Switch A. Configure a plaintext authentication key, specifying the key ID as 88 and key string as 123456. Configure the key as a trusted key.
[SwitchA] ntp-service authentication-keyid 88 authentication-mode md5 simple 123456
[SwitchA] ntp-service reliable authentication-keyid 88
# Configure Switch A to operate in NTP broadcast client mode and receive NTP broadcast messages on VLAN-interface 2.
[SwitchA-Vlan-interface2] ip address 3.0.1.33 24
The configuration procedure is the same for Switch A, Switch B, Switch D, and Switch E. See "Configure Switch A" for the configuration procedure.
If the configuration is correct, Switch A, Switch B, Switch D, and Switch E synchronize the time with Switch C. The following example uses Switch A to verify the configuration.
Clock stratum: 3
Local mode: bclient
Leap indicator: 00
Clock jitter: 0.000092 s
Root delay: 2.42615 ms
Root dispersion: 1950.98877 ms
Reference time: d5eed631.2f498d71 Thu, Sep 26 2019 15:50:09.184
Configuration files
· Switch A, Switch B, Switch D, and Switch E:
ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$pU6KvpS80MadhM2zM
CCSR07HX4qEbJhHvQ==
· Switch C:
ntp-service enable
ntp-service authentication-keyid 88 authentication-mode md5 cipher $c$3$iJudDKiqCVO+gOaG53
63/fz4M3dQvHo2Fw==
ntp-service refclock-master 3
Related documentation
· H3C S12500G-AF Switch Series Network Management and Monitoring Configuration Guide-R759X
· H3C S12500G-AF Switch Series Network Management and Monitoring Command Reference-R759X
