- 10-High Availability Configuration Examples
- 01-H3C_Ethernet_OAM_Configuration_Examples
- 02-H3C_CFD_Configuration_Examples
- 03-H3C_DLDP_Configuration_Examples
- 04-H3C_RRPP_configuration_examples
- 05-H3C_Smart_Link_Configuration_Examples
- 06-H3C_VRRP_Configuration_Examples
- 07-H3C_BFD_Configuration_Examples
05-H3C_Smart_Link_Configuration_Examples | 189.37 KB |
H3C Smart Link Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
General restrictions and guidelines
Example: Configuring Smart Link load sharing
Example: Configuring Smart Link and Monitor Link collaboration
Introduction
This document provides Smart Link configuration examples.
This document assumes that you have basic knowledge of Smart Link, Monitor Link, and IRF.
If you configure a port as both an aggregation group member and a smart link group member, only the aggregation group configuration takes effect. The port is not shown in the output from the display smart-link group command.
As shown in Figure 1, VLAN 10 and VLAN 11 are assigned to the Finance department and the Marketing department of an enterprise, respectively. Traffic of VLAN 10 and VLAN 11 on Device A is dually uplinked to Device D by Device B and Device C. Configure Smart Link to meet the following requirements:
· When the link between Device A and Device B and the link between Device A and Device C are both available, the traffic of the Finance department is forwarded trough the link between Device A and Device B. The traffic of the Marketing department is forwarded through the link between Device A and Device C.
· When one link fails, the traffic on the link is switched to another link. When the link recovers, the traffic is switched back to the link.
Table 1 Interfaces and IP address assignment
Device |
VLAN |
Device |
VLAN |
Device A |
HGE3/0/1 |
10, 11 |
Device C |
HGE3/0/1 |
10, 11 |
HGE3/0/2 |
10, 11 |
HGE3/0/2 |
10, 11 |
HGE3/0/3 |
10 |
Device D |
HGE3/0/1 |
10, 11 |
HGE3/0/4 |
11 |
HGE3/0/2 |
10, 11 |
Device B |
HGE3/0/1 |
10, 11 |
HGE3/0/3 |
10, 11 |
HGE3/0/2 |
10, 11 |
Analysis
To implement load sharing on the two uplinks, create two smart link groups with the same member ports on Device A. The role of each port must be different in the two smart link groups. Use the VLANs of the Finance department and Marketing department as the protected VLANs of the corresponding smart link groups.
For the traffic to switch back to the recovered link, enable role preemption for the two smart link groups.
For the upstream device to refresh MAC address entries and ARP/ND entries when link switchover occurs in a smart link group, perform the following tasks:
· Enable flush message sending on Device A.
· Enable flush message receiving on ports of the primary and secondary links from Device A to Device D.
When you configure Smart Link load sharing, follow these restrictions and guidelines:
· Before you configure a port as a smart link group member, shut down the port to prevent loops. You can bring up the port only after completing the smart link group configuration.
· Disable the spanning tree feature and RRPP on the ports you want to add to a smart link group.
· Make sure the receive control VLAN configured on the upstream device is the same as the transmit control VLAN configured on the smart link device.
· The control VLAN configured for a smart link group must be different from the control VLAN configured for any other smart link groups.
· The control VLAN of a smart link group must also be one of its protected VLANs. Do not remove the control VLAN. Otherwise, flush messages cannot be sent correctly.
Configuring Device A
1. Create VLAN 10 and VLAN 11.
[DeviceA] vlan 10 to 11
2. Configure HundredGigE 3/0/1:
# Configure HundredGigE 3/0/1 as a trunk port.
[DeviceA] interface hundredgige 3/0/1
[DeviceA-HundredGigE3/0/1] port link-type trunk
# Assign the port to VLAN 10 and VLAN 11.
[DeviceA-HundredGigE3/0/1] port trunk permit vlan 10 11
# Remove the port from VLAN 1.
[DeviceA-HundredGigE3/0/1] undo port trunk permit vlan 1
# Disable the spanning tree feature on the port.
[DeviceA-HundredGigE3/0/1] undo stp enable
# Shut down the port.
[DeviceA-HundredGigE3/0/1] shutdown
[DeviceA-HundredGigE3/0/1] quit
3. Configure HundredGigE 3/0/2 in the same way HundredGigE 3/0/1 is configured.
[DeviceA] interface hundredgige 3/0/2
[DeviceA-HundredGigE3/0/2] port link-type trunk
[DeviceA-HundredGigE3/0/2] port trunk permit vlan 10 11
[DeviceA-HundredGigE3/0/2] undo port trunk permit vlan 1
[DeviceA-HundredGigE3/0/2] undo stp enable
[DeviceA-HundredGigE3/0/2] shutdown
[DeviceA-HundredGigE3/0/2] quit
4. Configure HundredGigE 3/0/3:
# Configure HundredGigE 3/0/3 as an access port and assign the port to VLAN 10.
[DeviceA] interface hundredgige 3/0/3
[DeviceA-HundredGigE3/0/3] port access vlan 10
# Bring up the port.
[DeviceA-HundredGigE3/0/3] undo shutdown
[DeviceA-HundredGigE3/0/3] quit
5. Configure HundredGigE 3/0/4:
# Configure HundredGigE 3/0/4 as an access port and assign the port to VLAN 11.
[DeviceA] interface hundredgige 3/0/4
[DeviceA-HundredGigE3/0/4] port access vlan 11
[DeviceA-HundredGigE3/0/4] undo shutdown
[DeviceA-HundredGigE3/0/4] quit
6. Configure the mapping between the VLANs and MSTIs:
# Enter MST region view.
[DeviceA] stp region-configuration
# Map VLAN 10 to MSTI 1, and VLAN 11 to MSTI 2.
[DeviceA-mst-region] instance 1 vlan 10
[DeviceA-mst-region] instance 2 vlan 11
# Activate the MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
7. Configure smart link group 1:
# Create smart link group 1 and configure the VLAN mapped to MSTI 1, VLAN 10, as the protected VLAN.
[DeviceA] smart-link group 1
[DeviceA-smlk-group1] protected-vlan reference-instance 1
# Configure HundredGigE 3/0/1 as the primary port and HundredGigE 3/0/2 as the secondary port.
[DeviceA-smlk-group1] port hundredgige 3/0/1 primary
[DeviceA-smlk-group1] port hundredgige 3/0/2 secondary
# Enable flush message sending, and configure VLAN 10 as the transmit control VLAN.
[DeviceA-smlk-group1] flush enable control-vlan 10
# Enable role preemption and set the preemption delay to 10 seconds.
[DeviceA-smlk-group1] preemption mode role
[DeviceA-smlk-group1] preemption delay 10
[DeviceA-smlk-group1] quit
8. Configure smart link group 2:
# Create smart link group 2 and configure the VLAN mapped to MSTI 2, VLAN 11, as the protected VLAN.
[DeviceA] smart-link group 2
[DeviceA-smlk-group2] protected-vlan reference-instance 2
# Configure HundredGigE 3/0/2 as the primary port and HundredGigE 3/0/1 as the secondary port.
[DeviceA-smlk-group2] port hundredgige 3/0/2 primary
[DeviceA-smlk-group2] port hundredgige 3/0/1 secondary
# Enable flush message sending, and configure VLAN 11 as the transmit control VLAN.
[DeviceA-smlk-group2] flush enable control-vlan 11
[DeviceA-smlk-group2] preemption mode role
[DeviceA-smlk-group2] preemption delay 10
[DeviceA-smlk-group2] quit
9. Bring up the ports:
# Bring up HundredGigE 3/0/1.
[DeviceA-HundredGigE3/0/1] undo shutdown
# Bring up HundredGigE 3/0/2.
[DeviceA-HundredGigE3/0/2] undo shutdown
Configuring Device B
[DeviceB] vlan 10 to 11
[DeviceB] interface hundredgige 3/0/1
[DeviceB-HundredGigE3/0/1] port link-type trunk
[DeviceB-HundredGigE3/0/1] port trunk permit vlan 10 11
[DeviceB-HundredGigE3/0/1] undo port trunk permit vlan 1
# Enable flush message receiving and configure VLAN 10 and VLAN 11 as the receive control VLANs on the port.
[DeviceB-HundredGigE3/0/1] smart-link flush enable control-vlan 10 11
[DeviceB-HundredGigE3/0/1] undo shutdown
[DeviceB-HundredGigE3/0/1] quit
[DeviceB] interface hundredgige 3/0/2
[DeviceB-HundredGigE3/0/2] port link-type trunk
[DeviceB-HundredGigE3/0/2] port trunk permit vlan 10 11
[DeviceB-HundredGigE3/0/2] undo port trunk permit vlan 1
[DeviceB-HundredGigE3/0/2] smart-link flush enable control-vlan 10 11
[DeviceB-HundredGigE3/0/2] undo shutdown
[DeviceB-HundredGigE3/0/2] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10 to 11
[DeviceC] interface hundredgige 3/0/1
[DeviceC-HundredGigE3/0/1] port link-type trunk
[DeviceC-HundredGigE3/0/1] port trunk permit vlan 10 11
[DeviceC-HundredGigE3/0/1] undo port trunk permit vlan 1
[DeviceC-HundredGigE3/0/1] smart-link flush enable control-vlan 10 11
[DeviceC-HundredGigE3/0/1] undo shutdown
[DeviceC-HundredGigE3/0/1] quit
[DeviceC] interface hundredgige 3/0/2
[DeviceC-HundredGigE3/0/2] port link-type trunk
[DeviceC-HundredGigE3/0/2] port trunk permit vlan 10 11
[DeviceC-HundredGigE3/0/2] undo port trunk permit vlan 1
[DeviceC-HundredGigE3/0/2] smart-link flush enable control-vlan 10 11
[DeviceC-HundredGigE3/0/2] undo shutdown
[DeviceC-HundredGigE3/0/2] quit
Configuring Device D
<DeviceD> system-view
[DeviceD] vlan 10 to 11
[DeviceD] interface hundredgige 3/0/1
[DeviceD-HundredGigE3/0/1] port link-type trunk
[DeviceD-HundredGigE3/0/1] port trunk permit vlan 10 11
[DeviceD-HundredGigE3/0/1] undo port trunk permit vlan 1
[DeviceD-HundredGigE3/0/1] smart-link flush enable control-vlan 10 11
[DeviceD-HundredGigE3/0/1] undo shutdown
[DeviceD-HundredGigE3/0/1] quit
[DeviceD] interface hundredgige 3/0/2
[DeviceD-HundredGigE3/0/2] port link-type trunk
[DeviceD-HundredGigE3/0/2] port trunk permit vlan 10 11
[DeviceD-HundredGigE3/0/2] undo port trunk permit vlan 1
[DeviceD-HundredGigE3/0/2] smart-link flush enable control-vlan 10 11
[DeviceD-HundredGigE3/0/2] undo shutdown
[DeviceD-HundredGigE3/0/2] quit
# Configure HundredGigE 3/0/3 as a trunk port
[DeviceD] interface hundredgige 3/0/3
[DeviceD-HundredGigE3/0/3] port link-type trunk
[DeviceD-HundredGigE3/0/3] port trunk permit vlan 10 11
[DeviceD-HundredGigE3/0/3] undo port trunk permit vlan 1
[DeviceD-HundredGigE3/0/3] undo shutdown
[DeviceD-HundredGigE3/0/3] quit
1. Verify the Smart Link configuration when Device A is operating correctly:
# Display information about all smart link groups on Device A.
[DeviceA] display smart-link group all
Smart link group 1 information:
Device ID : 0000-fc00-2500
Preemption mode : ROLE
Preemption delay: 10(s)
Control VLAN : 10
Protected VLAN : Reference Instance 1
Member Role State Flush-count Last-flush-time
HGE3/0/1 PRIMARY ACTIVE 0 NA
HGE3/0/2 SECONDARY STANDBY 2 16:22:40 2019/12/29
Smart link group 2 information:
Control VLAN : 11
Protected VLAN : Reference Instance 2
HGE3/0/2 PRIMARY ACTIVE 2 16:22:40 2019/12/29
HGE3/0/1 SECONDARY STANDBY 0 NA
¡ In smart link group 1, HundredGigE 3/0/1 is active to transmit traffic for MSTI 1.
¡ In smart link group 2, HundredGigE 3/0/2 is active to transmit traffic for MSTI 2.
2. Verify the Smart Link configuration when HundredGigE 3/0/1 on Device A is down:
Control VLAN : 10
HGE3/0/1 PRIMARY DOWN 0 NA
HGE3/0/2 SECONDARY ACTIVE 3 17:43:06 2019/12/29
Control VLAN : 11
HGE3/0/1 SECONDARY DOWN 0 NA
¡ In smart link group 1, HundredGigE 3/0/2 becomes active to transmit traffic for MSTI 1.
¡ In smart link group 2, HundredGigE 3/0/2 remains active to transmit traffic for MSTI 2.
# Display information about the received flush messages on Device B.
[DeviceB] display smart-link flush
Received flush packets : 1
Receiving interface of the last flush packet : HundredGigE3/0/2
Receiving time of the last flush packet : 07:57:22 2019/10/23
Device ID of the last flush packet : 0000-fc00-2500
Control VLAN of the last flush packet : 10
Configuration files
· Device A:
vlan 1
vlan 10 to 11
instance 1 vlan 10
instance 2 vlan 11
smart-link group 1
preemption delay 10
smart-link group 2
preemption delay 10
interface HundredGigE3/0/1
port link-mode bridge
port trunk permit vlan 10 to 11
undo stp enable
port smart-link group 1 primary
port smart-link group 2 secondary
interface HundredGigE3/0/2
undo stp enable
port smart-link group 1 secondary
port smart-link group 2 primary
· Device B:
vlan 1
vlan 10 to 11
monitor-link group 1
smart-link flush enable control-vlan 10 to 11
port monitor-link group 1 downlink
port monitor-link group 1 uplink
· Device C:
vlan 1
vlan 10 to 11
· Device D:
vlan 1
vlan 10 to 11
interface HundredGigE3/0/3
As shown in Figure 2, VLAN 10 and VLAN 11 are assigned to Area A and Area B, respectively. Traffic of VLAN 10 on Device A and traffic of VLAN 11 on Device B are dually uplinked to Device E by Device C and Device D. Configure Smart Link and Monitor Link to meet the following requirements:
· When the link between Device A and Device C and the link between Device A and Device D are both available, the traffic of Area A is forwarded trough the link between Device A and Device C. When the link between Device A and Device C fails, the traffic is switched to the link between Device A and Device D. When the link between Device A and Device C recovers, the traffic switches back to the link.
· When the link between Device B and Device C and the link between Device B and Device D are both available, the traffic of Area B is forwarded trough the link between Device B and Device D. When the link between Device B and Device D fails, the traffic is switched to the link between Device B and Device C. When the link between Device B and Device D recovers, the traffic switches back to the link.
· Configure Monitor Link on Device C and Device D to associate the state of downlink interfaces on Device C and Device D with the state of uplink interfaces. When Monitor link shuts down the downlink interfaces because of an uplink failure, Smart Link triggers a link switchover.
Table 2 Interfaces and IP address assignment
Device |
VLAN |
Device |
VLAN |
Device A |
HGE3/0/1 |
10 |
Device D |
HGE3/0/1 |
11 |
HGE3/0/2 |
10 |
HGE3/0/2 |
10, 11 |
HGE3/0/3 |
10 |
HGE3/0/3 |
10 |
Device B |
HGE3/0/1 |
11 |
Device E |
HGE3/0/1 |
10, 11 |
HGE3/0/2 |
11 |
HGE3/0/2 |
10, 11 |
HGE3/0/3 |
11 |
HGE3/0/3 |
10, 11 |
Device C |
HGE3/0/1 |
10 |
HGE3/0/2 |
10, 11 |
HGE3/0/3 |
11 |
Analysis
To implement dual uplink backup on Device A and Device B, perform the following tasks:
· Create a smart link group on Device A and Device B, respectively.
· Configure the VLANs of Area A and Area B as the protected VLANs of the corresponding smart link groups.
For the upstream device to refresh MAC address forwarding entries and ARP/ND entries when link switchover occurs in a smart link group, perform the following tasks:
· Enable flush message sending on Device A and Device B.
· Enable flush message receiving on the downlink ports on Device C and Device D.
When you configure Smart Link and Monitor Link collaboration, follow these restrictions and guidelines:
· Disable the spanning tree feature and RRPP on the ports you want to add to the smart link group.
· You can assign a port to only one monitor link group.
· Do not use the shutdown command or the undo shutdown command to change the state of the downlink interfaces in a monitor link group.
Procedures
# Assign the port to VLAN 10.
5. Configure the mapping between VLAN 10 and an MSTI:
# Map VLAN 10 to MSTI 1.
6. Configure smart link group 1.
7. Bring up the ports:
# Assign the port to VLAN 11.
[DeviceB-HundredGigE3/0/1] port trunk permit vlan 11
[DeviceB-HundredGigE3/0/1] undo stp enable
[DeviceB-HundredGigE3/0/1] shutdown
[DeviceB-HundredGigE3/0/2] port trunk permit vlan 11
[DeviceB-HundredGigE3/0/2] undo stp enable
[DeviceB-HundredGigE3/0/2] shutdown
# Configure HundredGigE 3/0/3 as an access port and assign the port to VLAN 11.
[DeviceB] interface hundredgige 3/0/3
[DeviceB-HundredGigE3/0/3] port access vlan 11
[DeviceB-HundredGigE3/0/3] undo shutdown
[DeviceB-HundredGigE3/0/3] quit
5. Configure the mapping between VLAN 11 and an MSTI:
[DeviceB] stp region-configuration
# Map VLAN 11 to MSTI 1.
[DeviceB-mst-region] instance 1 vlan 11
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Create smart link group 1 and configure the VLAN mapped to MSTI 1, VLAN 11, as the protected VLAN.
[DeviceB] smart-link group 1
[DeviceB-smlk-group1] protected-vlan reference-instance 1
[DeviceB-smlk-group1] port hundredgige 3/0/1 primary
[DeviceB-smlk-group1] port hundredgige 3/0/2 secondary
[DeviceA-smlk-group1] flush enable control-vlan 11
[DeviceB-smlk-group1] preemption mode role
[DeviceB-smlk-group1] preemption delay 10
[DeviceB-smlk-group1] quit
# Enable flush message receiving and configure VLAN 10 as the receive control VLAN on the port.
3. Configure HundredGigE 3/0/2:
# Configure HundredGigE 3/0/2 as a trunk port.
# Configure HundredGigE 3/0/3 as a trunk port.
[DeviceC] interface hundredgige 3/0/3
[DeviceC-HundredGigE3/0/3] port link-type trunk
[DeviceC-HundredGigE3/0/3] port trunk permit vlan 11
[DeviceC-HundredGigE3/0/3] undo port trunk permit vlan 1
# Enable flush message receiving and configure VLAN 11 as the receive control VLAN on the port.
[DeviceC-HundredGigE3/0/3] smart-link flush enable control-vlan 11
5. Configure monitor link group 1:
# Create monitor link group 1.
[DeviceC] monitor-link group 1
# Configure HundredGigE 3/0/2 as the uplink port and HundredGigE 3/0/1 and HundredGigE 3/0/3 as the downlink ports.
[DeviceC-mtlk-group1] port hundredgige 3/0/2 uplink
[DeviceC-mtlk-group1] port hundredgige 3/0/1 downlink
[DeviceC-mtlk-group1] port hundredgige 3/0/3 downlink
[DeviceC-mtlk-group1] quit
[DeviceD-HundredGigE3/0/1] port trunk permit vlan 11
[DeviceD-HundredGigE3/0/1] smart-link flush enable control-vlan 11
[DeviceD-HundredGigE3/0/3] smart-link flush enable control-vlan 10
[DeviceD] monitor-link group 1
[DeviceD-mtlk-group1] port hundredgige 3/0/2 uplink
[DeviceD-mtlk-group1] port hundredgige 3/0/1 downlink
[DeviceD-mtlk-group1] port hundredgige 3/0/3 downlink
[DeviceD-mtlk-group1] quit
Configuring Device E
<DeviceE> system-view
[DeviceE] vlan 10 to 11
[DeviceE] interface hundredgige 3/0/1
[DeviceE-HundredGigE3/0/1] port link-type trunk
[DeviceE-HundredGigE3/0/1] port trunk permit vlan 10 11
[DeviceE-HundredGigE3/0/1] undo port trunk permit vlan 1
[DeviceE-HundredGigE3/0/1] smart-link flush enable control-vlan 10 11
[DeviceE-HundredGigE3/0/1] undo shutdown
[DeviceE-HundredGigE3/0/1] quit
[DeviceE] interface hundredgige 3/0/2
[DeviceE-HundredGigE3/0/2] port link-type trunk
[DeviceE-HundredGigE3/0/2] port trunk permit vlan 10 11
[DeviceE-HundredGigE3/0/2] undo port trunk permit vlan 1
[DeviceE-HundredGigE3/0/2] smart-link flush enable control-vlan 10 11
[DeviceE-HundredGigE3/0/2] undo shutdown
[DeviceE-HundredGigE3/0/2] quit
[DeviceE] interface hundredgige 3/0/3
[DeviceE-HundredGigE3/0/3] port link-type trunk
[DeviceE-HundredGigE3/0/3] port trunk permit vlan 10 11
[DeviceE-HundredGigE3/0/3] undo port trunk permit vlan 1
[DeviceE-HundredGigE3/0/3] undo shutdown
[DeviceE-HundredGigE3/0/3] quit
1. Verify the configuration when Device A and Device B are operating correctly:
Control VLAN : 10
HGE3/0/1 PRIMARY ACTIVE 1 19:37:49 2019/12/29
HGE3/0/2 SECONDARY STANDBY 3 17:43:06 2019/12/29
The output shows that HundredGigE 3/0/1 in smart link group 1 is active to transmit traffic for MSTI 1.
# Display information about all smart link groups on Device B.
[DeviceB] display smart-link group all
Control VLAN : 11
HGE3/0/1 PRIMARY ACTIVE 2 16:22:40 2019/12/29
HGE3/0/2 SECONDARY STANDBY 0 NA
The output shows that HundredGigE 3/0/1 in smart link group 1 is active to transmit traffic for MSTI 2.
2. Verify the configuration when Device C and Device D are operating correctly:
# Display information about all monitor link groups on Device C.
[DeviceC] display monitor-link group all
Monitor link group 1 information:
Group status : UP
Downlink up-delay: 0(s)
Last-up-time : 10:07:26 2019/10/23
Last-down-time : -
Member Role Status
HGE3/0/2 UPLINK UP
HGE3/0/1 DOWNLINK UP
HGE3/0/3 DOWNLINK UP
The output shows when the uplink port HundredGigE 3/0/2 is up, the status of monitor link group 1 is up.
# Display information about all monitor link groups on Device D.
[DeviceD] display monitor-link group all
Group status : UP
Last-up-time : 19:49:33 2019/12/29
Last-down-time : -
Member Role Status
HGE3/0/2 UPLINK UP
3. Verify the configuration when HundredGigE 3/0/1 on Device A or Device B is down:
Control VLAN : 10
HGE3/0/1 PRIMARY DOWN 1 NA
HGE3/0/2 SECONDAR ACTIVE 3 17:43:06 2019/12/29
The output shows that HundredGigE 3/0/2 in smart link group 1 becomes active to transmit traffic for MSTI 1.
Control VLAN : 11
The output shows that HundredGigE 3/0/2 in smart link group 1 becomes active to transmit traffic for MSTI 2.
# Display information about the received flush messages on Device C.
[DeviceC] display smart-link flush
Receiving interface of the last flush packet : HundredGigE3/0/1
# Display information about the received flush messages on Device D.
[DeviceD] display smart-link flush
Control VLAN of the last flush packet : 11
4. Verify the configuration when the uplink ports on Device C or Device D fail:
Group status : DOWN
Last-down-time : -
Member Role Status
HGE3/0/2 UPLINK DOWN
HGE3/0/1 DOWNLINK DOWN
HGE3/0/3 DOWNLINK DOWN
The output shows that when the uplink port HundredGigE 3/0/2 is down, the status of monitor link group 1 is down.
Group status : DOWN
Last-down-time : -
Member Role Status
Configuration files
· Device A:
vlan 1
vlan 10
instance 1 vlan 10
smart-link group 1
undo stp enable
undo stp enable
port access vlan 10
· Device B:
vlan 1
vlan 11
instance 1 vlan 11
smart-link group 1
undo stp enable
undo stp enable
port access vlan 11
· Device C:
vlan 1
vlan 10 to 11
monitor-link group 2
· Device D:
vlan 1
vlan 10 to 11
· Device E:
vlan 1
vlan 10 to 11
Related documentation
· H3C S12500G-AF Switch Series High Availability Command Reference-R759X
· H3C S12500G-AF Switch Series High Availability Configuration Guide-R759X
· H3C S12500G-AF Switch Series Layer 2—LAN Switching Command Reference-R759X
· H3C S12500G-AF Switch Series Layer 2—LAN Switching Configuration Guide-R759X
· H3C S12500G-AF Switch Series Virtual Technologies Command Reference-R759X
· H3C S12500G-AF Switch Series Virtual Technologies Configuration Guide-R759X
