- 03-Layer 2 - LAN Switching Configuration Examples
- 01-H3C_MAC_Address_Table_Configuration_Examples
- 02-H3C_Ethernet_Link_Aggregation_Configuration_Examples
- 03-H3C_Port_Isolation_Configuration_Examples
- 04-H3C_Spanning_Tree_Configuration_Examples
- 05-H3C_VLAN_Configuration_Examples
- 06-H3C_MVRP_Configuration_Examples
- 07-H3C_QinQ_Configuration_Examples
- 08-H3C_VLAN_Mapping_Configuration_Examples
- 09-H3C_DRNI_Configuration_Examples
- 10-H3C_S-MLAG Configuration Examples
03-H3C_Port_Isolation_Configuration_Examples | 60.42 KB |
H3C Port Isolation Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides port isolation configuration examples.
This document assumes that you have basic knowledge of port isolation.
Example: Configuring port isolation
As shown in Figure 1, the company branches Site 1 and Site 2 transfer service traffic in VLAN 2 and VLAN 3. Device A connects to the Internet through HundredGigE 3/0/1.
Configure port isolation on Device A to meet the following requirements:
· All hosts can access the Internet through Device A.
· Host A and Host B are isolated from each other at Layer 2.
· Host C and Host D are isolated from each other at Layer 2.
When you configure port isolation on the device, follow these restrictions and guidelines:
· Before assigning a port to an isolation group, make sure the isolation group already exists.
· You can assign a port to only one isolation group.
Procedures
# Create VLAN 2 and assign ports HundredGigE 3/0/2 and HundredGigE 3/0/3 to the VLAN.
[DeviceA] vlan 2
[DeviceA-vlan2] port hundredgige 3/0/2
[DeviceA-vlan2] port hundredgige 3/0/3
[DeviceA-vlan2] quit
# Create VLAN 3 and assign ports HundredGigE 3/0/4 and HundredGigE 3/0/5 to the VLAN.
[DeviceA] vlan 3
[DeviceA-vlan3] port hundredgige 3/0/4
[DeviceA-vlan3] port hundredgige 3/0/5
[DeviceA-vlan3] quit
# Configure port HundredGigE 3/0/1 as a trunk port and assign it to VLAN 2 and VLAN 3.
[DeviceA] interface hundredgige 3/0/1
[DeviceA-HundredGigE3/0/1] port link-type trunk
[DeviceA-HundredGigE3/0/1] port trunk permit vlan 2 3
[DeviceA-HundredGigE3/0/1] quit
# Create isolation groups 1 and 2.
[DeviceA] port-isolate group 1
[DeviceA-port-isolate-group1] quit
[DeviceA] port-isolate group 2
[DeviceA-port-isolate-group2] quit
# Assign ports HundredGigE 3/0/2 and HundredGigE 3/0/3 to isolation group 1.
[DeviceA] interface hundredgige 3/0/2
[DeviceA-HundredGigE3/0/2] port-isolate enable group 1
[DeviceA-HundredGigE3/0/2] quit
[DeviceA] interface hundredgige 3/0/3
[DeviceA-HundredGigE3/0/3] port-isolate enable group 1
[DeviceA-HundredGigE3/0/3] quit
# Assign ports HundredGigE 3/0/4 and HundredGigE 3/0/5 to isolation group 2.
[DeviceA] interface hundredgige 3/0/4
[DeviceA-HundredGigE3/0/4] port-isolate enable group 2
[DeviceA-HundredGigE3/0/4] quit
[DeviceA] interface hundredgige 3/0/5
[DeviceA-HundredGigE3/0/5] port-isolate enable group 2
[DeviceA-HundredGigE3/0/5] quit
# Display information about all isolation groups.
[DeviceA] display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
HundredGigE3/0/2 HundredGigE3/0/3
Community VLAN ID: None
Group ID: 2
Group members:
HundredGigE3/0/4 HundredGigE3/0/5
The output shows that:
· Ports HundredGigE 3/0/2 and HundredGigE 3/0/3 are in isolation group 1. As a result, Host A and Host B are isolated from each other at Layer 2.
· Ports HundredGigE 3/0/4 and HundredGigE 3/0/4 are in isolation group 2. As a result, Host C and Host D are isolated from each other at Layer 2.
Configuration files
vlan 2 to 3
interface HundredGigE3/0/1
port link-mode bridge
port trunk permit vlan 1 to 3
interface HundredGigE3/0/2
port access vlan 2
interface HundredGigE3/0/3
port access vlan 2
interface HundredGigE3/0/4
port access vlan 3
interface HundredGigE3/0/5
port access vlan 3
Related documentation
· H3C S12500G-AF Switch Series Layer 2—LAN Switching Configuration Guide-R759X
· H3C S12500G-AF Switch Series Layer 2—LAN Switching Command Reference-R759X
