- 08-ACL and QoS Configuration Examples
- 01-H3C_ACL_Configuration_Examples
- 02-H3C_Control_Plane-Based_QoS_Policy_Configuration_Examples
- 03-H3C_Traffic_Filtering_Configuration_Examples
- 04-H3C_Traffic_Policing_Configuration_Examples
- 05-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 06-H3C_Congestion_Avoidance_and_Queue_Scheduling_Configuration_Examples
- 07-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
06-H3C_Congestion_Avoidance_and_Queue_Scheduling_Configuration_Examples | 115.09 KB |
H3C Congestion Avoidance and Queue Scheduling |
Configuration Examples |
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
· Voice traffic—Transmitted in VLAN 6 and carries 802.1p priority 6.
· Video traffic—Transmitted in VLAN 4 and carries 802.1p priority 4.
· Data traffic—Transmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
· The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
· WRED drop is used when serious congestion occurs.
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
· To assign different types of traffic to different queues, configure the incoming interface to trust the 802.1p priority in packets.
· To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
· To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Traffic type |
Packet color |
Lower limit |
Upper limit |
Drop probability |
Voice |
Yellow |
1000 |
1500 |
3% |
Red |
500 |
1000 |
30% |
Video |
Yellow |
1000 |
1500 |
2% |
Red |
500 |
1000 |
20% |
Data |
Yellow |
1000 |
1500 |
1% |
Red |
500 |
1000 |
10% |
Procedures
1. Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface ten-gigabitethernet 1/0/3
[Device-Ten-GigabitEthernet1/0/3] port link-type trunk
[Device-Ten-GigabitEthernet1/0/3] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet1/0/3] quit
[Device-Ten-GigabitEthernet1/0/1] port link-type trunk
[Device-Ten-GigabitEthernet1/0/1] port trunk permit vlan 2 4 6
[Device] interface ten-gigabitethernet 1/0/2
[Device-Ten-GigabitEthernet1/0/2] port link-type trunk
[Device-Ten-GigabitEthernet1/0/2] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet1/0/2] quit
2. Configure interface Ten-GigabitEthernet 1/0/3 to trust the 802.1p priority in packets.
[Device-Ten-GigabitEthernet1/0/3] qos trust dot1p
3. Configure WRR on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2:
# Enable weighted-based WRR on Ten-GigabitEthernet 1/0/1.
[Device-Ten-GigabitEthernet1/0/1] qos wrr weight
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device-Ten-GigabitEthernet1/0/1] display qos map-table dot1p-lp
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-Ten-GigabitEthernet1/0/1] qos wrr 1 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/1] qos wrr 4 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/1] qos wrr 6 group 1 weight 1
# Enable weighted-based WRR on GigabitEthernet 1/0/2.
[Device-Ten-GigabitEthernet1/0/2] qos wrr weight
[Device-Ten-GigabitEthernet1/0/2] qos wrr 1 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/2] qos wrr 4 group 1 weight 2
[Device-Ten-GigabitEthernet1/0/2] qos wrr 6 group 1 weight 1
4. Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Device-Ten-GigabitEthernet1/0/1] qos wred apply droppolicy
[Device-Ten-GigabitEthernet1/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Device] display qos queue wrr interface
Interface: display qos queue wrr interface
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 6
6 cs6 1 1
7 cs7 1 8
Interface: Ten-GigabitEthernet1/0/2
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 6
6 cs6 1 1
7 cs7 1 8
# Display the WRED information for interfaces Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2.
[Device] display qos wred interface
Current WRED configuration:
Applied WRED table name: droppolicy
# Display the WRED table configuration.
[Device] display qos wred table
Table name: droppolicy
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 1000 1500 1 500 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 1000 1500 2 500 1000 20 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 1000 1500 3 500 1000 30 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
port link-mode bridge
port trunk permit vlan 1 to 2 4 6
qos wrr weight
qos wrr af1 group 1 weight 2
qos wrr af4 group 1 weight 2
qos wrr cs6 group 1 weight 1
qos wrr weight
return
Related documentation
· H3C S10500X Switch Series ACL and QoS Configuration Guide-R759X
· H3C S10500X Switch Series ACL and QoS Command Reference-R759X
