06-IP Multicast Configuration Examples
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration ExamplesH3C S10500X Switch Series Configuration Examples-R7595-6W10006-IP Multicast Configuration Examples
07-H3C_Multicast_VPN_Configuration_Examples
07-H3C_Multicast_VPN_Configuration_Examples 208.93 KB
H3C Multicast VPN
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides multicast VPN configuration examples.
This document assumes that you have basic knowledge of multicast VPN.
Example: Configuring intra-AS MDT-based MVPN
As shown in Figure 1:
·     Customer A has two branches that connect to the MPLS L3VPN network of a service provider.
·     PIM-SM runs within the two branches.
·     The multicast source and the receiver host are in different branches.
Configure intra-AS MDT-based MVPN so that the receiver host can receive the multicast data from the source.
Figure 1 Network diagram
Device
IP address
Device
IP address
S 1
10.11.3.2/24
PE 2
Vlan-int3
192.168.2.2/24
PE 1
Vlan-int2
192.168.1.2/24
PE 2
Vlan-int12
10.11.2.1/24
PE 1
Vlan-int11
10.11.1.1/24
PE 2
Loop1
1.1.1.2/32
PE 1
Loop1
1.1.1.1/32
CE a1
Vlan-int10
10.11.3.1/24
P
Vlan-int2
192.168.1.1/24
CE a1
Vlan-int11
10.11.1.2/24
P
Vlan-int3
192.168.2.1/24
CE a1
Loop0
2.2.2.2/32
P
Loop1
3.3.3.3/32
CE a2
Vlan-int20
10.11.4.1/24
R 1
10.11.4.2/24
CE a2
Vlan-int12
10.11.2.2/24
Analysis
To meet the network requirement, you must run PIM on the devices of the public network, and configure MDT-based MVPN on each PE. In addition, make sure the PIM protocol on the public network is independent from the PIM protocol for the VPN instance.
When you configure the intra-AS MDT-based MVPN, follow these restrictions and guidelines:
·     The MTI interfaces take effect only after the default-group and the MVPN source interface are specified and the MVPN source interface obtains the public IP address.
·     To ensure correct MTI forwarding, you must create a service loopback group and specify the multicast tunnel service type by using the service-loopback group command. For more information about this command, see H3C S10500X Switch Series Layer 2—LAN Switching Command Reference.
·     You must enable the same PIM mode on all interfaces that belong to the same VPN instance (including the interfaces associated with the VPN instance on the PEs).
·     You must specify the same default-group for the same VPN instance on different PEs.
·     The IP address of the MVPN source interface must be the same as the source address used for establishing BGP peer relationship. Otherwise, correct routing information cannot be obtained.
Procedures
1.     Assign an IP address and subnet mask to each interface on CE a1, as shown in Table 1.
<CEa1> system-view
[CEa1] interface vlan-interface 10
[CEa1-Vlan-interface10] ip address 10.11.3.1 24
[CEa1-Vlan-interface10] quit
[CEa1] interface loopback 0
[CEa1-LoopBack0] ip address 2.2.2.2 32
[CEa1-LoopBack0] quit
[CEa1] interface vlan-interface 11
[CEa1-Vlan-interface11] ip address 10.11.1.2 24
[CEa1-Vlan-interface11] quit
# Configure PE 1, P, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
2.     Configure a unicast routing protocol and basic MPLS VPN on all devices so that all devices are interoperable at the network layer. (Details not shown.)
For more information about configuring basic MPLS VPN, see H3C S10500X Switch Series MPLS Configuration Guide.
3.     Enable IP multicast routing on the public network, and enable PIM-SM on the public network interfaces (including Loopback interfaces):
# On PE 1, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[PE1] multicast routing
[PE1-mrib] quit
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] pim sm
[PE1-Vlan-interface2] quit
[PE1] interface loopback 1
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# On P, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[P] multicast routing
[P-mrib] quit
[P] interface vlan-interface 2
[P-Vlan-interface2] pim sm
[P-Vlan-interface2] quit
[P] interface vlan-interface 3
[P-Vlan-interface3] pim sm
[P-Vlan-interface3] quit
[P] interface loopback 1
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[P] pim
[P-pim] c-bsr 3.3.3.3
[P-pim] c-rp 3.3.3.3
[P-pim] quit
# On PE 2, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[PE2] multicast routing
[PE2-mrib] quit
[PE2] interface vlan-interface 3
[PE2-Vlan-interface3] pim sm
[PE2-Vlan-interface3] quit
[PE2] interface loopback 1
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
4.     Enable IP multicast routing for the VPN instance, enable PIM-SM on the private network interfaces, and enable IGMP on interfaces that have receiver hosts attached:
# On CE a1, enable IP multicast routing, and enable PIM-SM on each interface.
[CEa1] multicast routing
[CEa1-mrib] quit
[CEa1-Vlan-interface10] pim sm
[CEa1-Vlan-interface11] pim sm
[CEa1-LoopBack0] pim sm
# Configure Loopback 0 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 2.2.2.2
[CEa1-pim] c-rp 2.2.2.2
[CEa1-pim] quit
# On CE a2, enable IP multicast routing, enable PIM-SM on VLAN-interface 12, and enable IGMP on the receiver-side interface VLAN-interface 20.
[CEa2] multicast routing
[CEa2-mrib] quit
[CEa2] interface vlan-interface 12
[CEa2-Vlan-interface12] pim sm
[CEa2-Vlan-interface12] quit
[CEa2] interface vlan-interface 20
[CEa2-Vlan-interface20] igmp enable
[CEa2-Vlan-interface20] quit
# On PE 1, create a VPN instance named customerA.
[PE1] ip vpn-instance customerA
[PE1-vpn-instance-customerA] route-distinguisher 100:1
[PE1-vpn-instance-customerA] vpn-target 111:1
[PE1-vpn-instance-customerA] quit
# Associate VLAN-interface 11 with VPN instance customerA.
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip binding vpn-instance customerA
[PE1-Vlan-interface11] quit
# Enable IP multicast routing for VPN instance customerA.
[PE1] multicast routing vpn-instance customerA
[PE1-mrib-customerA] quit
# Enable PIM-SM on VLAN-interface 11.
[PE1-Vlan-interface11] pim sm
# On PE 2, create a VPN instance named customerA.
[PE2] ip vpn-instance customerA
[PE2-vpn-instance-customerA] route-distinguisher 100:1
[PE2-vpn-instance-customerA] vpn-target 111:1
[PE2-vpn-instance-customerA] quit
# Associate VLAN-interface 12 with VPN instance customerA.
[PE2-Vlan-interface12] ip binding vpn-instance customerA
[PE2-Vlan-interface12] quit
[PE2] multicast routing vpn-instance customerA
[PE2-mrib-customerA] quit
# Enable PIM-SM on VLAN-interface 12.
[PE2-Vlan-interface12] pim sm
5.     Configure the MVPN for the VPN instance:
# On PE 1, create service loopback group 1 and specify the multicast tunnel service.
[PE1] service-loopback group 1 type multicast-tunnel
# Assign Ten-GigabitEthernet 1/0/4 to service loopback group 1.
[PE1] interface ten-gigabitethernet 1/0/4
[PE1-Ten-GigabitEthernet1/0/4] port service-loopback group 1
[PE1-Ten-GigabitEthernet1/0/4] quit
# Create an MDT-based MVPN for VPN instance customerA.
[PE1] multicast-vpn vpn-instance customerA mode mdt
# Create an MVPN IPv4 address family for VPN instance customerA.
[PE1-mvpn-customerA] address-family ipv4
# Specify the default group, MVPN source interface, and data group range for VPN instance customerA.
[PE1-mvpn-customerA-ipv4] default-group 239.1.1.1
[PE1-mvpn-customerA-ipv4] source loopback 1
[PE1-mvpn-customerA-ipv4] data-group 225.2.2.0 28
[PE1-mvpn-customerA-ipv4] quit
[PE1-mvpn-customerA] quit
# On PE 2, create service loopback group 1 and specify the multicast tunnel service.
[PE2] service-loopback group 1 type multicast-tunnel
[PE2] interface ten-gigabitethernet 1/0/4
[PE2-Ten-GigabitEthernet1/0/4] port service-loopback group 1
[PE2-Ten-GigabitEthernet1/0/4] quit
[PE2] multicast-vpn vpn-instance customerA mode mdt
[PE2-mvpn-customerA] address-family ipv4
[PE2-mvpn-customerA-ipv4] default-group 239.1.1.1
[PE2-mvpn-customerA-ipv4] source loopback 1
[PE2-mvpn-customerA-ipv4] data-group 225.2.2.0 28
[PE2-mvpn-customerA-ipv4] quit
[PE2-mvpn-customerA] quit
# Verify the establishment of the default-MDT for the public network on PEs and P. The following example shows PIM routing table for the public network on P.
[P] display pim routing-table
 Total 1 (*, G) entries; 2 (S, G) entries
 (*, 239.1.1.1)
     RP: 3.3.3.3 (local)
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Register
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Total number of downstreams: 2
         1: Vlan-interface2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: -
         2: Vlan-interface3
             Protocol: pim-sm, UpTime: 02:33:57, Expires: -
 (1.1.1.1, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
     Upstream interface: Vlan-interface2
         Upstream neighbor: 192.168.1.2
         RPF prime neighbor: 192.168.1.2
     Downstream interface(s) information: None
(1.1.1.2, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
     Upstream interface: Vlan-interface3
         Upstream neighbor: 192.168.2.2
         RPF prime neighbor: 192.168.2.2
The output shows that an RPT for (*, 239.1.1.1), an SPT for (1.1.1.1, 239.1.1.1), and an SPT for (1.1.1.2, 239.1.1.1) have been established on the public network. The RPT and SPTs constitute the default-MDT for the public network.
Configuration files
·     PE 1:
 vpn-target 111:1 import-extcommunity
 vpn-target 111:1 export-extcommunity
vlan 2
vlan 11
interface LoopBack1
 ip address 1.1.1.1 255.255.255.255
 pim sm
interface Vlan-interface2
 ip address 192.168.1.2 255.255.255.0
 pim sm
interface Vlan-interface11
 ip address 10.11.1.1 255.255.255.0
 pim sm
interface Ten-GigabitEthernet1/0/4
 port link-mode bridge
multicast routing
 address-family ipv4
  source LoopBack1
  data-group 225.2.2.0 255.255.255.240
·     PE 2:
vlan 3
vlan 12
interface LoopBack1
 ip address 1.1.1.2 255.255.255.255
 pim sm
interface Vlan-interface3
 ip address 192.168.2.2 255.255.255.0
 pim sm
interface Vlan-interface12
 ip address 10.11.2.1 255.255.255.0
 pim sm
multicast routing
 address-family ipv4
  source LoopBack1
·     P:
vlan 2 to 3
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
 pim sm
 pim sm
 ip address 192.168.2.1 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 3.3.3.3
 c-rp 3.3.3.3
·     CE a1:
vlan 10 to 11
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 pim sm
interface Vlan-interface10
 ip address 10.11.3.1 255.255.255.0
 pim sm
 ip address 10.11.1.2 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 2.2.2.2
 c-rp 2.2.2.2
·     CE a2:
vlan 12
vlan 20
 ip address 10.11.2.2 255.255.255.0
 pim sm
interface Vlan-interface20
 ip address 10.11.4.1 255.255.255.0
 igmp enable
multicast routing
Example: Configuring inter-AS option A MDT-based MVPN
As shown in Figure 2:
·     Customer A has two branches that separately connect to AS 100 and AS 200.
·     ASBR-PE 1 and ASBR-PE 2 are interconnected by using the inter-AS option A solution.
Configure inter-AS option A MDT-based MVPN so that the receiver host can receive the multicast data from the source.
Figure 2 Network diagram
Device
IP address
Device
IP address
S 1
10.11.3.2/24
R 1
10.11.4.2/24
PE 1
Vlan-int2
192.168.1.2/24
ASBR-PE 2
Vlan-int4
192.168.3.2/24
PE 1
Vlan-int11
10.11.1.1/24
ASBR-PE 2
Vlan-int3
192.168.2.2/24
PE 1
Loop1
1.1.1.1/32
ASBR-PE 2
Loop1
1.1.1.3/32
ASBR-PE 1
Vlan-int2
192.168.1.1/24
ASBR-PE 2
Loop2
22.22.22.22/32
ASBR-PE 1
Vlan-int3
192.168.2.1/24
PE 2
Vlan-int4
192.168.3.1/24
ASBR-PE 1
Loop1
1.1.1.2/32
PE 2
Vlan-int12
10.11.2.1/24
ASBR-PE 1
Loop2
11.11.11.11/32
PE 2
Loop1
1.1.1.4/32
CE a1
Vlan-int10
10.11.3.1/24
CE a2
Vlan-int20
10.11.4.1/24
CE a1
Vlan-int11
10.11.1.2/24
CE a2
Vlan-int12
10.11.2.2/24
CE a1
Loopback 0
2.2.2.2/32
Analysis
To meet the network requirement, you must create a separate MDT-based MVPN for each AS.
When you configure the inter-AS option A MDT-based MVPN, follow these restrictions and guidelines:
·     You must enable the same PIM mode for all interfaces that belong to the same VPN instance (including the interface associated with the VPN instance). You may enable different PIM modes for the public network in different ASs.
·     You must specify the same default-group for the same VPN instance in the same AS. You may specify different default-groups for the same VPN instance in different ASs.
Procedures
1.     Assign an IP address and subnet mask to each interface on CE a1, as shown in Table 2.
<CEa1> system-view
# Configure PE 1, ASBR-PE 1, ASBR-PE2, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
2.     Configure a unicast routing protocol and MPLS L3VPN inter-AS option A on all devices so that all devices in the ASs are interoperable at the network layer. (Details not shown)
[PE1-mrib] quit
# On ASBR-PE 1, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[ASBR-PE1] multicast routing
[ASBR-PE1-mrib] quit
[ASBR-PE1] interface vlan-interface 2
[ASBR-PE1-Vlan-interface2] pim sm
[ASBR-PE1-Vlan-interface2] quit
[ASBR-PE1] interface loopback 1
[ASBR-PE1-LoopBack1] pim sm
[ASBR-PE1-LoopBack1] quit
[ASBR-PE1] interface loopback 2
[ASBR-PE1-LoopBack2] pim sm
[ASBR-PE1-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and a C-RP.
[ASBR-PE1] pim
[ASBR-PE1-pim] c-bsr 11.11.11.11
[ASBR-PE1-pim] c-rp 11.11.11.11
[ASBR-PE1-pim] quit
[PE2-mrib] quit
[PE2] interface vlan-interface 4
[PE2-Vlan-interface4] pim sm
[PE2-Vlan-interface4] quit
# On ASBR-PE 2, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[ASBR-PE2] multicast routing
[ASBR-PE2-mrib] quit
[ASBR-PE2] interface vlan-interface 4
[ASBR-PE2-Vlan-interface4] pim sm
[ASBR-PE2-Vlan-interface4] quit
[ASBR-PE2] interface loopback 1
[ASBR-PE2-LoopBack1] pim sm
[ASBR-PE2-LoopBack1] quit
[ASBR-PE2] interface loopback 2
[ASBR-PE2-LoopBack2] pim sm
[ASBR-PE2-LoopBack2] quit
[ASBR-PE2] pim
[ASBR-PE2-pim] c-bsr 22.22.22.22
[ASBR-PE2-pim] c-rp 22.22.22.22
[ASBR-PE2-pim] quit
4.     Enable IP multicast routing for the VPN instances, enable PIM-SM on the VPN instance interfaces, and enable IGMP on the interfaces that have receiver hosts attached:
The route targets for the same VPN instance on the ASBRs and PEs within the same AS must match. Those within different ASs do not need to match.
# On CE a1, enable IP multicast routing, enable PIM-SM on each interface.
[CEa1-mrib] quit
[CEa1] pim
[CEa1-pim] quit
# On CE a2, enable IP multicast routing, enable PIM-SM on VLAN-interface 12, and enable IGMP on VLAN-interface 20.
[CEa2-mrib] quit
[PE1-vpn-instance-customerA] vpn-target 100:1 both
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on VLAN-interface 11.
[PE2-vpn-instance-customerA] route-distinguisher 12:12
[PE2-vpn-instance-customerA] vpn-target 3:3 import-extcommunity
[PE2-vpn-instance-customerA] vpn-target 3:3 export-extcommunity
[PE2-vpn-instance] quit
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on VLAN-interface 12.
# On ASBR-PE 1, create a VPN instance named customerA.
[ASBR-PE1] ip vpn-instance customerA
[ASBR-PE1-vpn-instance-customerA] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-customerA] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-customerA] quit
# Associate VLAN-interface 3 with VPN instance customerA.
[ASBR-PE1] interface vlan-interface 3
[ASBR-PE1-Vlan-interface3] ip binding vpn-instance customerA
[ASBR-PE1-Vlan-interface3] quit
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on VLAN-interface 3.
[ASBR-PE1] multicast routing vpn-instance customerA
[ASBR-PE1-mrib-customerA] quit
[ASBR-PE1-Vlan-interface3] pim sm
# On ASBR-PE 2, create a VPN instance named customerA.
[ASBR-PE2] ip vpn-instance customerA
[ASBR-PE2-vpn-vpn-customerA] route-distinguisher 200:1
[ASBR-PE2-vpn-vpn-customerA] vpn-target 200:1 both
[ASBR-PE2-vpn-vpn-customerA] quit
[ASBR-PE2] interface vlan-interface 3
[ASBR-PE2-Vlan-interface3] ip binding vpn-instance customerA
[ASBR-PE2-Vlan-interface3] quit
[ASBR-PE2] multicast routing vpn-instance customerA
[ASBR-PE2-mrib-customerA] quit
[ASBR-PE2-Vlan-interface3] pim sm
5.     Configure the MDT-based MVPN for the VPN instance:
# On ASBR-PE 1, create service loopback group 1 and specify the multicast tunnel service.
[ASBR-PE1] service-loopback group 1 type multicast-tunnel
[ASBR-PE1] interface ten-gigabitethernet 1/0/4
[ASBR-PE1-Ten-GigabitEthernet1/0/4] port service-loopback group 1
[ASBR-PE1-Ten-GigabitEthernet1/0/4] quit
[ASBR-PE1] multicast-vpn vpn-instance customerA mode mdt
[ASBR-PE1-mvpn-customerA] address-family ipv4
[ASBR-PE1-mvpn-customerA-ipv4] default-group 239.1.1.1
[ASBR-PE1-mvpn-customerA-ipv4] source loopback 1
[ASBR-PE1-mvpn-customerA-ipv4] data-group 225.2.2.0 28
[ASBR-PE1-mvpn-customerA-ipv4] quit
[ASBR-PE1-mvpn-customerA] quit
# On ASBR-PE 2, create service loopback group 1 and specify the multicast tunnel service.
[ASBR-PE2] service-loopback group 1 type multicast-tunnel
[ASBR-PE2] interface ten-gigabitethernet 1/0/4
[ASBR-PE2-Ten-GigabitEthernet1/0/4] port service-loopback group 1
[ASBR-PE2-Ten-GigabitEthernet1/0/4] quit
[ASBR-PE2] multicast-vpn vpn-instance customerA mode mdt
[ASBR-PE2-mvpn-customerA] address-family ipv4
[ASBR-PE2-mvpn-customerA-ipv4] default-group 239.1.1.1
[ASBR-PE2-mvpn-customerA-ipv4] source loopback 1
[ASBR-PE2-mvpn-customerA-ipv4] data-group 225.2.2.0 28
[ASBR-PE2-mvpn-customerA-ipv4] quit
[ASBR-PE2-mvpn-customerA] quit
# Verify that the default-MDT has been established on the public network in each AS on PEs and ASBR-PEs. The following example shows PIM routing table for the public network on ASBR-PE 1.
[ASBR-PE1]display pim routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 239.1.1.1)
     RP: 11.11.11.11 (local)
     UpTime: 02:54:43
         1: Vlan-interface2
     UpTime: 01:57:13
The output shows that an RPT for (*, 239.1.1.1) and an SPT for (1.1.1.1, 239.1.1.1) have been established on the public network. The RPT and SPT constitute the default-MDT for the public network.
Configuration files
·     PE 1:
 vpn-target 100:1 import-extcommunity
 vpn-target 100:1 export-extcommunity
vlan 2
vlan 11
interface LoopBack1
 pim sm
 pim sm
 pim sm
multicast routing
 address-family ipv4
  source LoopBack1
·     PE 2:
 route-distinguisher 200:2
 vpn-target 200:2 import-extcommunity
 vpn-target 200:2 export-extcommunity
vlan 4
vlan 12
interface LoopBack1
 ip address 1.1.1.4 255.255.255.255
 pim sm
interface Vlan-interface4
 ip address 192.168.3.1 255.255.255.0
 pim sm
 pim sm
multicast routing
 address-family ipv4
  source LoopBack1
·     ASBR-PE 1:
vlan 2 to 3
interface LoopBack1
 pim sm
interface LoopBack2
 ip address 11.11.11.11 255.255.255.255
 pim sm
 pim sm
 pim sm
multicast routing
pim
 c-bsr 11.11.11.11
 c-rp 11.11.11.11
 address-family ipv4
  source LoopBack1
·     ASBR-PE 2:
 vpn-target 200:1 import-extcommunity
 vpn-target 200:1 export-extcommunity
vlan 3 to 4
interface LoopBack1
 ip address 1.1.1.3 255.255.255.255
 pim sm
interface LoopBack2
 ip address 22.22.22.22 255.255.255.255
 pim sm
 pim sm
 ip address 192.168.3.2 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 22.22.22.22
 c-rp 22.22.22.22
 address-family ipv4
  source LoopBack1
·     CE a1:
vlan 10 to 11
interface LoopBack0
 pim sm
 pim sm
 pim sm
multicast routing
pim
 c-bsr 2.2.2.2
 c-rp 2.2.2.2
·     CE a2:
vlan 12
vlan 20
 pim sm
 igmp enable
multicast routing
Example: Configuring inter-AS option C MDT-based MVPN
As shown in Figure 3:
·     ASBR-PE 1 and ASBR-PE 2 are interconnected by using the inter-AS option C solution.
Configure inter-AS option C MDT-based MVPN so that the receiver host can receive the multicast data from the source.
Figure 3 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.11.3.2/24
R 1
10.11.4.2/24
PE 1
Vlan-int2
192.168.1.2/24
ASBR-PE2
Vlan-int4
192.168.3.2/24
PE 1
Vlan-int11
10.11.1.1/24
ASBR-PE2
Vlan-int3
192.168.2.2/24
PE 1
Loop1
1.1.1.1/32
ASBR-PE2
Loop1
1.1.1.3/32
ASBR-PE1
Vlan-int2
192.168.1.1/24
ASBR-PE2
Loop2
22.22.22.22/32
ASBR-PE1
Vlan-int3
192.168.2.1/24
PE 2
Vlan-int4
192.168.3.1/24
ASBR-PE1
Loop1
1.1.1.2/32
PE 2
Vlan-int12
10.11.2.1/24
ASBR-PE1
Loop2
11.11.11.11/32
PE 2
Loop1
1.1.1.4/32
CE a1
Vlan-int10
10.11.3.1/24
CE a2
Vlan-int20
10.11.4.1/24
CE a1
Vlan-int11
10.11.1.2/24
CE a2
Vlan-int12
10.11.2.2/24
CE a1
Loop0
2.2.2.2/32
Analysis
To meet the network requirement, you must perform the following tasks:
·     Create the same MDT-based MVPN for each AS.
·     Establish MSDP peering relationships between the RPs in the ASs to share the multicast source information in different PIM-SM domains.
Procedures
1.     Assign an IP address and subnet mask to each interface on CE a1, as shown in Table 3.
<CEa1> system-view
# Configure PE 1, ASBR-PE 1, ASBR-PE 2, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
2.     Configure a unicast routing protocol and basic MPLS VPN on all devices so that all devices are interoperable at the network layer. (Details not shown)
3.     Enable IP multicast routing on the public network in each AS, enable PIM-SM on the public network interfaces (including Loopback interfaces), and configure PIM-SM domain boarders:
[PE1-mrib] quit
[ASBR-PE1] pim
[ASBR-PE1-pim] quit
# Configure VLAN-interface 3 as a PIM-SM domain boarder.
[ASBR-PE1-Vlan-interface3] pim bsr-boundary
[PE2-mrib] quit
[ASBR-PE2] pim
[ASBR-PE2-pim] quit
[ASBR-PE2-Vlan-interface3] pim bsr-boundary
4.     Establish MSDP peering relationships between the RPs on the public network in the ASs:
# On ASBR-PE 1, specify an MSDP peer.
[ASBR-PE1] msdp
[ASBR-PE1-msdp] encap-data-enable
[ASBR-PE1-msdp] peer 192.168.2.2 connect-interface vlan-interface 3
# On ASBR-PE 2, specify an MSDP peer.
[ASBR-PE2] msdp
[ASBR-PE2-msdp] encap-data-enable
[ASBR-PE2-msdp] peer 192.168.2.1 connect-interface vlan-interface 3
5.     Enable IP multicast routing for the VPN instance, enable PIM-SM on the private network interfaces, and enable IGMP on the interfaces that have receiver hosts attached:
[CEa1-mrib] quit
[CEa1] pim
[CEa1-pim] quit
[CEa2-mrib] quit
[PE1-vpn-instance-customerA] route-distinguisher 11:11
[PE1-vpn-instance-customerA] vpn-target 3:3 import-extcommunity
[PE1-vpn-instance-customerA] vpn-target 3:3 export-extcommunity
6.     Create the same MDT-based MVPN for the ASs, and specify the default-group, MVPN source interface, and data-group for the MVPN:
 (*, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 02:54:43
         1: Vlan-interface2
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
(1.1.1.4, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
The output shows that an RPT for (*, 239.1.1.1), an SPT for (1.1.1.1, 239.1.1.1), and an SPT for (1.1.1.4, 239.1.1.1) have been established on the public network. The RPT and SPTs constitute the default-MDT for the public network.
Configuration files
·     PE 1:
vlan 2
vlan 11
interface LoopBack1
 pim sm
 pim sm
 pim sm
multicast routing
 address-family ipv4
  source LoopBack1
·     PE 2:
vlan 4
vlan 12
interface LoopBack1
 pim sm
 pim sm
 pim sm
multicast routing
 address-family ipv4
  source LoopBack1
·     ASBR-PE 1:
vlan 2 to 3
interface LoopBack1
 pim sm
interface LoopBack2
 pim sm
 pim sm
 pim sm
 pim bsr-boundary
multicast routing
pim
 c-bsr 11.11.11.11
 c-rp 11.11.11.11
msdp
 encap-data-enable
 peer 192.168.2.2 connect-interface Vlan-interface3
·     ASBR-PE 2:
vlan 3 to 4
interface LoopBack1
 pim sm
interface LoopBack2
 pim sm
 pim sm
 pim bsr-boundary
 pim sm
multicast routing
pim
 c-bsr 22.22.22.22
 c-rp 22.22.22.22
msdp
 encap-data-enable
 peer 192.168.2.1 connect-interface Vlan-interface3
·     CE a1:
vlan 10 to 11
interface LoopBack0
 pim sm
 pim sm
 pim sm
multicast routing
pim
 c-bsr 2.2.2.2
 c-rp 2.2.2.2
·     CE a2:
vlan 12
vlan 20
 pim sm
 igmp enable
multicast routing
Related documentation
·     H3C S10500X Switch Series IP Multicast Command Reference-Release R759X
·     H3C S10500X Switch Series IP Multicast Configuration Guide-Release R759X
·     H3C S10500X Switch Series Layer 2—LAN Switching Command Reference-Release R759X
·     H3C S10500X Switch Series Layer 2—LAN Switching Configuration Guide-Release R759X
·     H3C S10500X Switch Series MPLS Command Reference-Release R759X
·     H3C S10500X Switch Series MPLS Configuration Guide-Release R759X
  • Become a Partner
  • Partner Resources
