- 07-MPLS Configuration Examples
- 01-H3C_MCE_Configuration_Examples
- 02-H3C_MPLS_L2VPN_Configuration_Examples
- 03-H3C_MPLS_L3VPN_Configuration_Examples
- 04-H3C_MPLS_TE_Configuration_Examples
- 05-H3C_MPLS_TE_Forwarding_Adjacency_Configuration_Examples
- 06-H3C_Basic_MPLS_Configuration_Examples
- 07-H3C_VPLS_Configuration_Examples
- 08-H3C_GRE Tunnel Access to MPLS L3VPN Configuration Examples
08-H3C_GRE Tunnel Access to MPLS L3VPN Configuration Examples | 178.97 KB |
H3C GRE tunnel access to MPLS L3VPN Configuration Examples
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring GRE tunnel access to MPLS L3VPN
Configuring an IGP on the MPLS backbone
Configuring basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs
Configuring CE 1 access to PE 1
Configuring CE 2 access to PE 2
Establishing EBGP peer relationships between PEs and CEs, and redistributing VPN routes into BGP
Creating an MP-IBGP peer relationship between PEs
Introduction
In an MPLS L3VPN, a CE is typically connected to a PE directly. In some networks, a direct connection might not be available between a CE and a PE. In such scenarios, you can configure a GRE tunnel between the CE and the PE to assume the direct connection between them.
This document assumes that you have basic knowledge of GRE and MPLS L3VPN.
As shown in Figure 1, Customer A and Customer B belong to VPN 1. A network VPN 2 exists between CE 1 and PE 1. Configure MPLS L3VPN for Customer A and Customer B to communicate with each other through VPN.
Analysis
For packets to be transported over the MPLS network, configure an IGP on the MPLS backbone to ensure IP connectivity, and configure LDP to distribute public network labels (outer labels).
To transport VPN routes and distribute private network labels (inner labels), configure MP-BGP and establish BGP peers between the PEs.
For CE1 to access MPLS L3VPN successfully, establish a GRE tunnel between CE 1 and PE 1 to implement logical direct connection between them.
Binding a VPN instance to an interface deletes some configuration (such as the IP address) of the interface. Therefore, bind the VPN instance before configure other settings on an interface.
Procedures
Before configuring GRE and OSPF, configure an IPv4 routing protocol on the gateways so that they can reach one another. (Details not shown.)
This example uses OSPF to implement IP connectivity between the PE and P devices on the MPLS backbone.
1. Configure PE 1:
# Configure interface IP addresses.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] vlan 2
[PE1-vlan2] port ten-gigabitethernet 1/0/2
[PE1-vlan2] quit
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] ip address 10.1.1.1 24
[PE1-Vlan-interface2] quit
# Configure OSPF to advertise backbone network routes.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
2. Configure P:
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] port ten-gigabitethernet 1/0/2
[P-vlan2] quit
[P] vlan 5
[P-vlan5] port ten-gigabitethernet 1/0/3
[P-vlan5] quit
[P] interface vlan-interface 2
[P-Vlan-interface2] ip address 10.1.1.2 24
[P-Vlan-interface2] quit
[P] interface vlan-interface 5
[P-Vlan-interface5] ip address 10.1.4.1 24
[P-Vlan-interface5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
3. Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] vlan 5
[PE2-vlan5] port ten-gigabitethernet 1/0/1
[PE2-vlan5] quit
[PE2] interface vlan-interface 5
[PE2-Vlan-interface5] ip address 10.1.4.2 24
[PE2-Vlan-interface5] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
4. Verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2.
[PE1] display ospf peer verbose
OSPF Process 1 with Router ID 1.1.1.9
Neighbors
Area 0.0.0.0 interface 10.1.1.1(Vlan-interface2)'s neighbors
Router ID: 2.2.2.9 Address: 10.1.1.2 GR State: Normal
State: Full Mode: Nbr is Master Priority: 1
DR: 10.1.1.2 BDR: 10.1.1.1 MTU: 0
Dead timer due in 38 sec
Neighbor is up for 17:30:25
BFD status: Disabled
5. Verify that the PEs have learned the routes to the loopback interfaces of each other.
[PE1] display ip routing-table protocol ospf
Summary Count : 5
Summary Count : 3
2.2.2.9/32 OSPF 10 1 10.1.1.2 Vlan2
3.3.3.9/32 OSPF 10 2 10.1.1.2 Vlan2
10.1.4.0/24 OSPF 10 2 10.1.1.2 Vlan2
Summary Count : 2
1.1.1.9/32 OSPF 10 0 1.1.1.9 Loop0
10.1.1.0/24 OSPF 10 1 10.1.1.1 Vlan2
1. Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
2. Configure P.
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Vlan-interface2] mpls enable
[P-Vlan-interface2] mpls ldp enable
[P-Vlan-interface5] mpls enable
[P-Vlan-interface5] mpls ldp enable
3. Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface5] mpls enable
[PE2-Vlan-interface5] mpls ldp enable
4. Verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2.
[PE1] display mpls ldp peer
Total number of peers: 1
Peer LDP ID State Role GR MD5 KA Sent/Rcvd
2.2.2.9:0 Operational Passive Off Off 5/5
5. Verify that the LSPs have been established by LDP.
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup
FECs: 4 Ingress: 1 Transit: 1 Egress: 3
FEC In/Out Label Nexthop OutInterface
1.1.1.9/32 3/-
-/1151(L)
2.2.2.9/32 -/3 10.1.1.2 Vlan2
1151/3 10.1.1.2 Vlan2
3.3.3.9/32 -/1150 10.1.1.2 Vlan2
1150/1150 10.1.1.2 Vlan2
Configuring VPN instances
1. Configure PE 1:
# Create a VPN instance named VPN1.
[PE1] ip vpn-instance vpn1
# Configure an RD for the VPN instance.
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
# Configure route targets for the VPN instance.
[PE1-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-vpn1] quit
# Bind the VPN instance to VLAN-interface 100.
[PE1] vlan 100
[PE1-vlan100] port ten-gigabitethernet 1/0/1
[PE1-vlan100] quit
[PE1] interface vlan-interface 100
[PE1-Vlan-interface100] ip binding vpn-instance vpn1
[PE1-Vlan-interface100] ip address 200.1.1.2 24
[PE1-Vlan-interface100] quit
2. Configure CE 1:
[CE1] ip vpn-instance vpn1
[CE1-vpn-instance-vpn1] route-distinguisher 100:1
[CE1-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[CE1-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[CE1-vpn-instance-vpn1] quit
# Bind the VPN instance to VLAN-interface 101.
[CE1] vlan 101
[CE1-vlan101] port ten-gigabitethernet 1/0/1
[CE1-vlan101] quit
[CE1] interface vlan-interface 101
[CE1-Vlan-interface101] ip binding vpn-instance vpn1
[CE1-Vlan-interface101] ip address 100.1.1.1 24
[CE1-Vlan-interface101] quit
Configuring a GRE tunnel between CE 1 and PE 1
1. Configure CE 1:
# Create service loopback group 1 and configure the service type as tunnel.
[CE1] service-loopback group 1 type tunnel
# Add interface Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[CE1] interface ten-gigabitethernet 1/0/3
[CE1-Ten-gigabitethernet1/0/3] port service-loopback group 1
[CE1-Ten-gigabitethernet1/0/3] quit
# Create tunnel interface Tunnel 1, and configure the tunnel mode as GRE/IPv4.
[CE1] interface tunnel 1 mode gre
# Specify a VPN instance for the tunnel source address.
[CE1-Tunnel1] ip binding vpn-instance vpn1
# Configure an IP address for the tunnel interface.
[CE1-Tunnel1] ip address 20.1.1.1 255.255.255.0
# Configure the tunnel source address as the IP address of VLAN-interface 101 on CE 1.
[CE1-Tunnel1] source vlan-interface 101
# Configure the tunnel destination address as the IP address of VLAN-interface 100 on PE 1.
[CE1-Tunnel1] destination 200.1.1.2
# Specify a VPN instance for the tunnel destination address.
[CE1-Tunnel1] tunnel vpn-instance vpn1
[CE1-Tunnel1] quit
# Configure a static route to Customer B through interface Tunnel 1.
[CE1] ip route-static vpn-instance vpn1 172.2.0.0 24 tunnel 1
2. Configure PE 1:
[PE1] service-loopback group 1 type tunnel
[PE1] interface ten-gigabitethernet 1/0/3
[PE1-Ten-gigabitethernet1/0/3] port service-loopback group 1
[PE1-Ten-gigabitethernet1/0/3] quit
[PE1] interface tunnel 1 mode gre
[PE1-Tunnel1] ip binding vpn-instance vpn1
[PE1-Tunnel1] ip address 20.1.1.2 255.255.255.0
# Configure the tunnel source address as the IP address of VLAN-interface 100 on PE 1.
[PE1-Tunnel1] source vlan-interface 100
# Configure the tunnel destination address as the IP address of VLAN-interface 101 on CE 1.
[PE1-Tunnel1] destination 100.1.1.1
[PE1-Tunnel1] tunnel vpn-instance vpn1
[PE1-Tunnel1] quit
# Configure a static route to Customer A through interface Tunnel 1.
[PE1] ip route-static vpn-instance vpn1 172.1.0.0 24 Tunnel 1
1. Configure PE 2:
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
# Configure route targets for the VPN instance. Make sure the import and export targets are the same as the export and import targets configured on PE 1.
[PE2-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-vpn1] quit
[PE2] vlan 101
[PE2-vlan101] port ten-gigabitethernet 1/0/2
[PE2-vlan101] quit
[PE2] interface vlan-interface 101
[PE2-Vlan-interface101] ip binding vpn-instance vpn1
[PE2-Vlan-interface101] ip address 101.1.1.1 24
[PE2-Vlan-interface101] quit
2. Configure CE 2:
Configure IP addresses for the CE according to Figure 1. (Details not shown.)
3. Verify the VPN instance configuration on PE 2.
[PE2] display ip vpn-instance
VPN-Instance Name RD Create time
vpn1 100:1 2019/06/22 13:20:08
4. Verify that PE 2 can ping CE 2.
[PE2] ping -vpn-instance vpn1 101.1.1.2
Ping 10.1.4.2 (101.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 101.1.1.2: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 101.1.1.2: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 101.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 101.1.1.2: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 101.1.1.2: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
1. Configure PE 1:
# Create BGP process 100.
[PE1] bgp 100
# Specify CE 1 as a BGP peer, and redistribute the direct routes of PE 1 to the routing table of the BGP VPN instance.
[PE1-bgp-default-vpn1] peer 20.1.1.1 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 20.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] import-route direct
[PE1-bgp-default-vpn1] quit
2. Configure PE 2:
[PE2] bgp 100
# Specify CE 2 as a BGP peer, and redistribute the direct routes of PE 2 to the routing table of the BGP VPN instance.
[PE2-bgp-default-vpn1] peer 101.1.1.2 as-number 65410
[PE2-bgp-default-ipv4-vpn1] peer 101.1.1.2 enable
[PE2-bgp-default-ipv4-vpn1] import-route direct
[PE2-bgp-default-vpn1] quit
3. Configure CE 1:
# Create BGP process 65410 on CE 1, and specify PE 1 as a BGP peer and set the AS number to 100.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 20.1.1.2 as-number 100
# Enable IPv4 unicast route exchange with peer PE 1.
[CE1-bgp-default-ipv4] peer 20.1.1.2 enable
# Redistribute the direct routes of CE 1 into EBGP.
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
4. Configure CE 2:
# Create BGP process 65410 on CE 2, and specify PE 2 as a BGP peer and set the AS number to 100.
<CE2> system-view
[CE2] bgp 65410
[CE2-bgp-default] peer 101.1.1.1 as-number 100
# Enable IPv4 unicast route exchange with peer PE 2.
[CE2-bgp-default-ipv4] peer 101.1.1.1 enable
# Redistribute the direct routes of CE 2 into EBGP.
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
5. Verify that a BGP peer relationship in Established state has been established between a PE and a CE.
This example uses PE 2 and CE 2.
[PE2] display bgp peer ipv4 vpn-instance vpn1
BGP local router ID: 3.3.3.9
Local AS number: 100
Total number of peers: 1 Peers in established state: 1
101.1.1.2 65430 4 4 0 2 13:35:25 Established
1. Configure PE 1:
# Configure PE 2 as a BGP peer, and specify interface Loopback 0 as the source interface for TCP connections to the peer.
[PE1] bgp 100
# Enable BGP VPNv4 route exchange with peer PE 2.
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
2. Configure PE 2:
# Configure PE 1 as a BGP peer, and specify interface Loopback 0 as the source interface for TCP connections to the peer.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
# Enable BGP VPNv4 route exchange with peer PE 1.
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
3. Verify that a BGP peer relationship in Established state has been established between the PEs.
[PE1] display bgp peer vpnv4
BGP local router ID: 1.1.1.9
3.3.3.9 100 8 8 0 0 00:00:08 Established
# Display the VPN routing table of a PE and verify that the PE has a route to the peer CE. (This example uses PE 1.)
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 13 Routes : 13
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
20.1.1.0/24 Direct 0 0 20.1.1.2 Tun0
20.1.1.0/32 Direct 0 0 20.1.1.2 Tun0
20.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
200.1.1.0/24 Direct 0 0 200.1.1.2 Vlan100
200.1.1.0/32 Direct 0 0 200.1.1.2 Vlan100
200.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
200.1.1.255/32 Direct 0 0 100.1.1.2 Vlan100
101.1.1.0/24 BGP 255 0 3.3.3.9 Vlan2
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
Configuration files
· On PE 1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
vlan 2
vlan 100
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Vlan-interface2
mpls enable
mpls ldp enable
interface Vlan-interface100
ip address 200.1.1.2 255.255.255.0
port link-mode bridge
port access vlan 100
port access vlan 2
interface Tunnel1 mode gre
source Vlan-interface100
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
import-route direct
ip route-static vpn-instance vpn1 172.1.0.0 24 Tunnel1
· On P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
vlan 2
vlan 5
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
mpls enable
mpls ldp enable
interface Vlan-interface5
ip address 10.1.4.1 255.255.255.0
mpls enable
mpls ldp enable
port access vlan 2
port access vlan 5
· On PE 2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
lldp global enable
vlan 5
vlan 101
mpls ldp
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 10.1.4.2 255.255.255.0
mpls enable
mpls ldp enable
interface Vlan-interface101
ip address 101.1.1.1 255.255.255.0
port access vlan 5
port access vlan 101
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
import-route direct
· On CE 1:
vlan 101
ip address 100.1.1.1 255.255.255.0
source Vlan-interface101
bgp 65410
import-route direct
ip route-static vpn-instance vpn1 172.2.0.0 24 Tunnel1
· On CE 2:
vlan 101
ip address 101.1.1.2 255.255.255.0
bgp 65410
import-route direct
Related documentation
· H3C S7500X Switch Series MPLS Command Reference-R759X
· H3C S7500X Switch Series MPLS Configuration Guide-R759X
