04-Layer 3 - IP Services Configuration Examples
HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration ExamplesH3C S7500X Switch Series Configuration Examples-R7595-6W10004-Layer 3 - IP Services Configuration Examples
01-H3C_DHCP_Snooping_Configuration_Examples
01-H3C_DHCP_Snooping_Configuration_Examples 106.43 KB
H3C DHCP Snooping Configuration Examples
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides DHCP snooping configuration examples.
This document assumes that you have basic knowledge of DHCP.
Example: Configuring DHCP snooping
As shown in Figure 1, three groups of hosts are connected to the DHCP server through the DHCP snooping devices. Configure DHCP snooping and DHCP server to meet the following requirements:
·     Hosts in each group obtain IP addresses from the address range assigned to the group. Assign address ranges to the groups as follows:
¡     Address range 192.168.0.2 to 192.168.0.39 for Group 1.
¡     Address range 192.168.0.40 to 192.168.0.99 for Group 2.
¡     Address range 192.168.0.100 to 192.168.0.200 for Group 3.
·     The hosts can obtain IP addresses only from the authorized DHCP server.
·     The hosts cannot access the network through IP addresses that are manually configured.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To make sure the hosts in each group obtain IP addresses from the address range assigned to the group, perform the following tasks:
¡     Configure Option 82 on the DHCP snooping devices.
¡     Create DHCP user classes for the groups and configure match rules based on Option 82 to match the groups on the DHCP server.
·     To make sure the hosts obtain addresses only from the authorized DHCP server, configure ports facing the server as trusted and other ports as untrusted, as shown in Figure 2.
·     To prevent illegal users from using manually configured IP addresses to access the network, perform the following tasks:
¡     Enable ARP detection in the VLANs where the groups reside to check user validity based on DHCP snooping entries.
¡     Enable recording of client information in DHCP snooping entries. To save system resources, you can enable only untrusted ports directly connected to hosts to record DHCP snooping entries, as shown in Figure 2.
Figure 2 Trusted and untrusted ports
To ensure correct DHCP address allocation by using Option 82, you must perform Option 82 configuration on both the DHCP server and the DHCP snooping devices.
Procedures
Configuring Device A
# Enable DHCP snooping.
[DeviceA] dhcp snooping enable
# Enable recording of client information in DHCP snooping entries on interface Ten-GigabitEthernet 1/0/1.
[DeviceA] interface Ten-GigabitEthernet 1/0/1
[DeviceA-Ten-GigabitEthernet1/0/1] dhcp snooping binding record
# Enable DHCP snooping to support Option 82 on interface Ten-GigabitEthernet 1/0/1. Configure the padding content for the Circuit ID sub-option as group1.
[DeviceA-Ten-GigabitEthernet1/0/1] dhcp snooping information enable
[DeviceA-Ten-GigabitEthernet1/0/1] dhcp snooping information circuit-id string group1
# Configure interface Ten-GigabitEthernet 1/0/2 as a trusted port. By default, an interface is an untrusted port.
[DeviceA] interface Ten-GigabitEthernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] dhcp snooping trust
[DeviceA-Ten-GigabitEthernet1/0/2] quit
# Enable ARP detection for user validity check.
[DeviceA] vlan 1
[DeviceA-vlan1] arp detection enable
[DeviceA-vlan1] quit
# Configure interface Ten-GigabitEthernet 1/0/2 as an ARP trusted port. By default, an interface is an ARP untrusted port.
[DeviceA-Ten-GigabitEthernet1/0/2] arp detection trust
Configuring Device B
[DeviceB] dhcp snooping enable
[DeviceB] interface Ten-GigabitEthernet 1/0/1
[DeviceB-Ten-GigabitEthernet1/0/1] dhcp snooping binding record
# Enable DHCP snooping to support Option 82 on interface Ten-GigabitEthernet 1/0/1. Configure the padding content for the Circuit ID sub-option as group2.
[DeviceB-Ten-GigabitEthernet1/0/1] dhcp snooping information enable
[DeviceB-Ten-GigabitEthernet1/0/1] dhcp snooping information circuit-id string group2
[DeviceB] interface Ten-GigabitEthernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] dhcp snooping trust
[DeviceB-Ten-GigabitEthernet1/0/2] quit
# Enable recording of client information in DHCP snooping entries on interface Ten-GigabitEthernet 1/0/3.
[DeviceB] interface Ten-GigabitEthernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] dhcp snooping binding record
# Enable DHCP snooping to support Option 82 on interface Ten-GigabitEthernet 1/0/3. Configure the padding content for the Circuit ID sub-option as group3.
[DeviceB-Ten-GigabitEthernet1/0/3] dhcp snooping information enable
[DeviceB-Ten-GigabitEthernet1/0/3] dhcp snooping information circuit-id string group3
[DeviceB-Ten-GigabitEthernet1/0/3] quit
[DeviceB] vlan 1
[DeviceB-vlan1] arp detection enable
[DeviceB-vlan1] quit
[DeviceB-Ten-GigabitEthernet1/0/2] arp detection trust
Configuring Device C
<DeviceC> system-view
[DeviceC] dhcp snooping enable
[DeviceC] interface Ten-GigabitEthernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] dhcp snooping trust
[DeviceC-Ten-GigabitEthernet1/0/2] quit
Configuring Device D
# Assign interface Ten-GigabitEthernet 1/0/1 to VLAN 2.
<DeviceD> system-view
[DeviceD] vlan 2
[DeviceD-vlan2] port Ten-GigabitEthernet 1/0/1
[DeviceD-vlan2] quit
# Assign an IP address to VLAN-interface 2.
[DeviceD] interface Vlan-interface 2
[DeviceD-Vlan-interface2] ip address 192.168.0.1 24
[DeviceD-Vlan-interface2] quit
# Enable DHCP.
[DeviceD] dhcp enable
# Enable DHCP server on VLAN-interface 2.
[DeviceD] interface vlan-interface 2
[DeviceD-Vlan-interface2] dhcp select server
# Create DHCP user class group1 for hosts in Group 1. Configure match rule 1 to match DHCP requests in which the third to eighth bytes of Option 82 is 0x67726F757031. The string 0x67726F757031 indicates that the content of the Circuit ID sub-option is group1.
[DeviceD] dhcp class group1
[DeviceD-dhcp-class-group1] if-match rule 1 option 82 hex 67726F757031 offset 2 length 6
[DeviceD-dhcp-class-group1] quit
# Create DHCP user class group2 for hosts in Group 2. Configure match rule 1 to match DHCP requests in which the third to eighth bytes of Option 82 is 0x67726F757032. The string 0x67726F757032 indicates that the content of the Circuit ID sub-option is group2.
[DeviceD] dhcp class group2
[DeviceD-dhcp-class-group2] if-match rule 1 option 82 hex 67726F757032 offset 2 length 6
[DeviceD-dhcp-class-group2] quit
# Create DHCP user class group3 for hosts in Group 3. Configure match rule 1 to match DHCP requests in which the third to eighth bytes of Option 82 is 0x67726F757033. The string 0x67726F757033 indicates that the content of the Circuit ID sub-option is group3.
[DeviceD] dhcp class group3
[DeviceD-dhcp-class-group3] if-match rule 1 option 82 hex 67726F757033 offset 2 length 6
[DeviceD-dhcp-class-group3] quit
# Create a DHCP address pool.
[DeviceD] dhcp server ip-pool 1
# Specify the subnet for dynamic address allocation.
[DeviceD-dhcp-pool-1] network 192.168.0.0 mask 255.255.255.0
# Specify address range 192.168.0.2 to 192.168.0.39 for DHCP user class group1.
[DeviceD-dhcp-pool-1] class group1 range 192.168.0.2 192.168.0.39
# Specify address range 192.168.0.40 to 192.168.0.99 for DHCP user class group2.
[DeviceD-dhcp-pool-1] class group2 range 192.168.0.40 192.168.0.99
# Specify address range 192.168.0.100 to 192.168.0.200 for DHCP user class group3.
[DeviceD-dhcp-pool-1] class group3 range 192.168.0.100 192.168.0.200
# Apply the DHCP address pool to VLAN-interface 2.
[DeviceD-Vlan-interface2] dhcp server apply ip-pool 1
# Verify that the hosts in each group can obtain IP addresses from the address range assigned to the group. This example uses a host in Group 2 to verify the configuration.
C:\Documents and Settings\Administrator>ipconfig
Windows IP Configuration
Ethernet adapter bb:
   Connection-specific DNS Suffix  . :
   IP Address. . . . . . . . . . . . : 192.168.0.44
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . :
# Manually assign IP address 192.168.0.66 to a host in Group 2, and verify that it cannot access the external network. (Details not shown.)
Configuration files
·     Device A:
vlan 1
 port link-mode bridge
 arp detection trust
 dhcp snooping trust
·     Device B:
vlan 1
 arp detection trust
 dhcp snooping trust
·     Device C:
 dhcp snooping trust
·     Device D:
 dhcp enable
vlan 2
dhcp class group1
 if-match rule 1 option 82 hex 67726f757031 offset 2 length 6
dhcp class group2
 if-match rule 1 option 82 hex 67726f757032 offset 2 length 6
dhcp class group3
 if-match rule 1 option 82 hex 67726f757033 offset 2 length 6
interface Vlan-interface2
 ip address 192.168.0.1 255.255.255.0
 port access vlan 2
Related documentation
·     H3C S7500X Switch Series Layer 3—IP Services Command Reference-R759X
·     H3C S7500X Switch Series Layer 3—IP Services Configuration Guide-R759X
  • Become a Partner
  • Partner Resources
