- 12-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-NETCONF configuration
- 07-EAA configuration
- 08-Process monitoring and maintenance configuration
- 09-Sampler configuration
- 10-Mirroring configuration
- 11-NetStream configuration
- 12-IPv6 NetStream configuration
- 13-sFlow configuration
- 14-Information center configuration
- 15-GOLD configuration
- 16-Packet capture configuration
- 17-VCF fabric configuration
- 18-CWMP configuration
- 19-SmartMC configuration
- 20-Ansible configuration
11-NetStream configuration | 172.08 KB |
Feature and hardware compatibility
NetStream configuration task list
Enabling NetStream on an interface
Configuring NetStream filtering
Configuring NetStream sampling
Configuring attributes of the NetStream data export
Configuring the NetStream data export format
Configuring the refresh rate for NetStream version 9 or version 10 template
Configuring NetStream flow aging
Configuring the NetStream traditional data export
Configuring the NetStream aggregation data export
Displaying and maintaining NetStream
NetStream configuration examples
Overview
NetStream is an accounting technology that provides statistics on a per-flow basis. An IPv4 flow is defined by the following 7-tuple elements:
· Destination IP address.
· Source IP address.
· Destination port number.
· Source port number.
· Protocol number.
· ToS.
· Inbound or outbound interface.
NetStream architecture
A typical NetStream system includes the following elements:
· NetStream data exporter—A device configured with NetStream. The NDE provides the following functions:
¡ Classifies traffic flows by using the 7-tuple elements.
¡ Collects data from the classified flows.
¡ Aggregates and exports the data to the NSC.
· NetStream collector—A program running in an operation system. The NSC parses the packets received from the NDEs, and saves the data to its database.
· NetStream data analyzer—A network traffic analyzing tool. Based on the data in NSC, the NDA generates reports for traffic billing, network planning, and attack detection and monitoring. The NDA can collect data from multiple NSCs. Typically, the NDA features a Web-based system for easy operation.
NSC and NDA are typically integrated into a NetStream server.
H3C network devices act as NDEs in the NetStream system. This document focuses on NDE configuration.
Figure 1 NetStream system
Flow aging
NetStream uses flow aging to enable the NDE to export NetStream data to NetStream servers. NetStream creates a NetStream entry for each flow for storing the flow statistics in the cache.
When a flow is aged out, the NDE performs the following operations:
· Exports the summarized data to NetStream servers in a NetStream export format.
· Clears NetStream entry information in the cache.
For more information about flow aging types and configurations, see "Configuring NetStream flow aging."
Traditional data export
Traditional NetStream collects the statistics of each flow and exports the statistics to NetStream servers.
This method consumes more bandwidth and CPU than the aggregation method, and it requires a large cache size.
Aggregation data export
NetStream aggregation merges the flow statistics according to the aggregation criteria of an aggregation mode, and it sends the summarized data to NetStream servers. The NetStream aggregation data export uses less bandwidth than the traditional data export.
Table 1 lists the available aggregation modes. In each mode, the system merges statistics for multiple flows into statistics for one aggregate flow if each aggregation criterion is of the same value. The system records the statistics for the aggregate flow. These aggregation modes work independently and can take effect concurrently.
For example, when the aggregation mode configured on the NDE is protocol-port, NetStream aggregates the statistics of flow entries by protocol number, source port, and destination port. Four NetStream entries record four TCP flows with the same destination address, source port, and destination port, but with different source addresses. In the aggregation mode, only one NetStream aggregation entry is created and sent to NetStream servers.
Table 1 NetStream aggregation modes
Aggregation mode |
Aggregation criteria |
Protocol-port aggregation |
· Protocol number · Source port · Destination port |
Source-prefix aggregation |
· Source AS number · Source address mask length · Source prefix (source network address) · Inbound interface index |
Destination-prefix aggregation |
· Destination AS number · Destination address mask length · Destination prefix (destination network address) · Outbound interface index |
Prefix aggregation |
· Source AS number · Destination AS number · Source address mask length · Destination address mask length · Source prefix · Destination prefix · Inbound interface index · Outbound interface index |
Prefix-port aggregation |
· Source prefix · Destination prefix · Source address mask length · Destination address mask length · ToS · Protocol number · Source port · Destination port · Inbound interface index · Outbound interface index |
ToS-source-prefix aggregation |
· ToS · Source AS number · Source prefix · Source address mask length · Inbound interface index |
ToS-destination-prefix aggregation |
· ToS · Destination AS number · Destination address mask length · Destination prefix · Outbound interface index |
ToS-prefix aggregation |
· ToS · Source AS number · Source prefix · Source address mask length · Destination AS number · Destination address mask length · Destination prefix · Inbound interface index · Outbound interface index |
ToS-protocol-port aggregation |
· ToS · Protocol type · Source port · Destination port · Inbound interface index · Outbound interface index |
If packets are not forwarded according to the BGP routing table, the AS number or BGP next hop cannot be obtained.
NetStream export formats
NetStream exports data in UDP datagrams in one of the following formats:
· Version 5—Exports original statistics collected based on the 7-tuple elements and does not support the NetStream aggregation data export. The packet format is fixed and cannot be extended.
· Version 8—Supports the NetStream aggregation data export. The packet format is fixed and cannot be extended.
· Version 9—Based on templates that can be configured according to the template formats defined in RFCs. Version 9 supports exporting the NetStream aggregation data and collecting BGP next hop statistics.
· Version 10—Similar to version 9. The difference between version 9 and version 10 is that version 10 export format is compliant with the IPFIX standard.
NetStream filtering
NetStream filtering uses an ACL to identify packets. Whether NetStream collects data for identified packets depends on the action in the matching rule.
· NetStream collects data for packets that match permit rules in the ACL.
· NetStream does not collect data for packets that match deny rules in the ACL.
For more information about ACL, see ACL and QoS Configuration Guide.
NetStream sampling
NetStream sampling collects statistics on fewer packets and is useful when the network has a large amount of traffic. NetStream on sampled traffic lessens the impact on the device's performance. For more information about sampling, see "Configuring samplers."
Protocols and standards
RFC 5101, Specification of the IP Flow Information Export (IPFIX) Protocol for the Exchange of IP Traffic Flow Information
The NetStream feature is available only on EC interface modules.
When you configure NetStream, choose the following configurations as needed:
Choose the device on which you want to enable NetStream.
If multiple service flows are passing through the NDE, use an ACL to select the target traffic.
If the network has a large amount of traffic, configure NetStream sampling.
Determine the export format for the NetStream data export.
Configure NetStream flow aging.
To reduce the bandwidth consumption of the NetStream data export, configure NetStream aggregation.
Figure 2 NetStream configuration flow
To configure NetStream, perform the following tasks:
Tasks at a glance |
(Required.) Enabling NetStream on an interface |
(Optional.) Configuring NetStream filtering |
(Optional.) Configuring NetStream sampling |
(Optional.) Configuring attributes of the NetStream data export |
(Optional.) Configuring NetStream flow aging |
(Required.) Perform at least one of the following tasks to configure NetStream data export: |
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
1. Enter interface view. |
N/A |
2. Enable NetStream on the interface. |
ip netstream { inbound | outbound } |
By default, NetStream is disabled on an interface. |
When NetStream filtering and sampling are both configured, packets are filtered first, and then the permitted packets are sampled.
To configure NetStream filtering:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Enable NetStream filtering on the interface. |
ip netstream { inbound | outbound } filter acl ipv4-acl-number |
By default, NetStream filtering is disabled. NetStream collects statistics of all IPv4 packets passing through the interface. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a sampler. |
sampler sampler-name mode fixed packet-interval n-power rate |
For more information about a sampler, see "Configuring samplers." |
3. Enter interface view. |
N/A |
4. Enable NetStream sampling. |
ip netstream { inbound | outbound } sampler sampler-name |
By default, NetStream sampling is disabled. |
You can configure NetStream data export version, and expand the export data to include the following additional information:
· Statistics about source AS, destination AS, and peer ASs.
· Statistics about BGP next hop (available only in version 9 and version 10 formats).
A NetStream entry records the source IP address and destination IP address, and two AS numbers for each IP address. The origin-as and peer-as keywords in the ip netstream export version command specify the AS numbers to be exported.
· origin-as—Specifies the source AS of the source address and the destination AS of the destination address.
· peer-as—Specifies the ASs before and after the AS where the NetStream device resides as the source AS and the destination AS, respectively.
For example, as shown in Figure 3, a flow starts at AS 20, passes AS 21 through AS 23, and then reaches AS 24. NetStream is enabled on the device in AS 22.
· The origin-as keyword defines AS 20 as the source AS and AS 24 as the destination AS.
· The peer-as keyword defines AS 21 as the source AS and AS 23 as the destination AS.
Figure 3 Recorded AS information varies by different keyword configurations
To configure the NetStream data export format:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the NetStream data export format, and specify whether to record AS and BGP next hop information. |
· Configure the version 5 format: · Configure the version 9 format: · Configure the version 10 format: |
By default: · The NetStream data export uses the version 9 format. · The peer AS numbers are exported for the source and destination. · The BGP next hop is not exported. |
Version 9 and version 10 are template-based and support user-defined formats. A NetStream device must send the template to NetStream servers regularly, because the servers do not permanently save the templates.
For a NetStream server to use correct version 9 or version 10 template, configure the time-based or packet count-based refresh rate. If both settings are configured, the template is sent when either of the conditions is met.
To configure the refresh rate for NetStream version 9 or version 10 template:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the refresh rate for NetStream version 9 or version 10 template. |
ip netstream export template refresh-rate { packet packets | time minutes } |
By default, the packet count-based refresh rate is 20 packets, and the time-based refresh interval is 30 minutes. |
Flow aging methods
Periodical aging
Periodical aging uses the following methods:
· Inactive flow aging—A flow is inactive if no packet arrives for this NetStream entry within the period specified by using the ip netstream timeout inactive command. When the inactive flow aging timer expires, the following events occur:
¡ The inactive flow entry is aged out.
¡ The statistics of the flow are sent to NetStream servers and are cleared in the cache. The statistics can no longer be displayed by using the display ip netstream cache command.
When you use the inactive flow aging method, the cache is large enough for new flow entries.
· Active flow aging—A flow is active if packets arrive for the NetStream entry within the period specified by using the ip netstream timeout active command. When the active flow aging timer expires, the statistics of the active flow are exported to NetStream servers. The device continues to collect active flow statistics, which can be displayed by using the display ip netstream cache command. The active flow aging method periodically exports the statistics of active flows to NetStream servers.
Forced aging
To implement forced aging, use the reset ip netstream statistics command. This command ages out all NetStream entries, and exports and clears the statistics.
Configuration procedure
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Configure periodical aging. |
· Set the aging timer for active flows: · Set the aging timer for inactive flows: |
By default: · The aging timer for active flows is 5 minutes. · The aging timer for inactive flows is 300 seconds. |
3. (Optional.) Manually age out NetStream entries. |
a Return to user view: b Age out NetStream entries: |
N/A. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Specify a destination host for NetStream traditional data export. |
ip netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ] |
By default, no destination host is specified. No NetStream traditional data is exported. |
3. (Optional.) Specify the source interface for NetStream data packets sent to NetStream servers. |
ip netstream export source interface interface-type interface-number |
By default, no source interface is specified for NetStream data packets. The packets take the IP address of the output interface as the source IP address. |
4. (Optional.) Limit the data export rate. |
ip netstream export rate rate |
By default, the data export rate is not limited. |
NetStream aggregation can be implemented by software or hardware. Unless otherwise noted, NetStream aggregation refers to software NetStream aggregation.
NetStream hardware aggregation uses hardware to directly merge the flow statistics according to the aggregation mode criteria, and stores the data in the cache. The aging of NetStream hardware aggregation entries is the same as the aging of NetStream traditional data entries. When a hardware aggregation entry is aged out, the data is exported.
NetStream hardware aggregation reduces the resource consumption by NetStream aggregation.
When you configure the NetStream aggregation data export, follow these restrictions and guidelines:
· The NetStream hardware aggregation does not take effect in the following situations:
¡ The destination host is configured for NetStream traditional data export.
¡ The configured aggregation mode is not supported by NetStream hardware aggregation.
· Configurations in NetStream aggregation mode view apply only to the NetStream aggregation data export, and those in system view apply to the NetStream traditional data export. If configurations in NetStream aggregation mode view are not provided, the configurations in system view apply to the NetStream aggregation data export.
· If the version 5 format is configured to export NetStream data, NetStream aggregation data export uses the version 8 format.
To configure the NetStream aggregation data export:
Step |
Command |
Remarks |
system-view |
N/A |
2. (Optional.) Enable the NetStream hardware aggregation. |
ip netstream aggregation advanced |
By default, the NetStream hardware aggregation is disabled. |
3. Specify a NetStream aggregation mode and enter its view. |
ip netstream aggregation { destination-prefix | prefix | prefix-port | protocol-port | source-prefix | tos-destination-prefix | tos-prefix | tos-protocol-port | tos-source-prefix } |
By default, no NetStream aggregation mode is specified. |
4. Specify a destination host for NetStream aggregation data export. |
By default, no destination host is specified. If you expect only NetStream aggregation data, specify the destination host only in the related NetStream aggregation mode view. |
5. (Optional.) Specify the source interface for NetStream data packets sent to NetStream servers. |
By default, no source interface is specified for NetStream data packets. The packets take the IP address of the output interface as the source IP address. Source interfaces in different NetStream aggregation mode views can be different. If no source interface is configured in NetStream aggregation mode view, the source interface configured in system view applies. |
6. Enable the NetStream aggregation mode. |
enable |
By default, NetStream aggregation is disabled. |
Task |
Command |
(In standalone mode.) Display NetStream entry information. |
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | interface interface-type interface-number | source source-ip ] * [ slot slot-number ] |
(In IRF mode.) Display NetStream entry information. |
display ip netstream cache [ verbose ] [ type { ip | ipl2 | l2 | mpls [ label-position1 label-value1 [ label-position2 label-value2 [ label-position3 label-value3 ] ] ] } ] [ destination destination-ip | interface interface-type interface-number | source source-ip ] * [ chassis chassis-number slot slot-number ] |
Display information about the NetStream data export. |
display ip netstream export |
(In standalone mode.) Display NetStream template information. |
display ip netstream template [ slot slot-number ] |
(In IRF mode.) Display NetStream template information. |
display ip netstream template [ chassis chassis-number slot slot-number ] |
Export all NetStream data and clear the cache. |
reset ip netstream statistics |
NetStream traditional data export configuration example
Network requirements
As shown in Figure 4, configure NetStream on Switch A to collect statistics on packets passing through Switch A.
· Enable NetStream for incoming traffic on Gigabitethernet 1/0/1 and outgoing traffic on GigabitEthernet 1/0/2.
· Configure the switch to export NetStream traditional data to UDP port 5000 of the NetStream server.
# Assign an IP address to each interface, as shown in Figure 4. (Details not shown.)
# Configure GigabitEthernet 1/0/1 to operate in Layer 3 mode.
[SwitchA-GigabitEthernet1/0/1] port link-mode route
# Enable NetStream for incoming traffic on GigabitEthernet 1/0/1.
[SwitchA-GigabitEthernet1/0/1] ip netstream inbound
[SwitchA-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/2 to operate in Layer 3 mode.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-mode route
# Enable NetStream for outgoing traffic on GigabitEthernet 1/0/2.
[SwitchA-GigabitEthernet1/0/2] ip netstream outbound
[SwitchA-GigabitEthernet1/0/2] quit
# Specify 12.110.2.2 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[SwitchA] ip netstream export host 12.110.2.2 5000
# Display NetStream entry information.
[SwitchA] display ip netstream cache
IP NetStream cache information:
Active flow timeout : 5 min
Inactive flow timeout : 300 sec
Max number of entries : 16384
IP active flow entries : 2
MPLS active flow entries : 0
L2 active flow entries : 0
IPL2 active flow entries : 0
IP flow entries counted : 0
MPLS flow entries counted : 0
L2 flow entries counted : 0
IPL2 flow entries counted : 0
Last statistics resetting time : Never
IP packet size distribution (0 packets in total):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
Protocol Total Packets Flows Packets Active(sec) Idle(sec)
Flows /sec /sec /flow /flow /flow
Type DstIP(Port) SrcIP(Port) Pro ToS If(Direct) Pkts
DstMAC(VLAN) SrcMAC(VLAN)
TopLblType(IP/MASK) Lbl-Exp-S-List
IP 12.110.2.2 (0) 11.111.2.2 (0) 1 0 GE1/0/1(I) 5
IP 12.110.2.2 (0) 11.111.2.2 (0) 1 0 GE1/0/2(O) 5
# Display information about the NetStream data export.
[SwitchA] display ip netstream export
IP export information:
Flow source interface : Not specified
Flow destination VPN instance : Not specified
Flow destination IP address (UDP) : 12.110.2.2 (5000)
Version 5 exported flow number : 0
Version 5 exported UDP datagrams number (failed): 0 (0)
Version 9 exported flow number : 10
Version 9 exported UDP datagrams number (failed): 10 (0)
Version 10 exported flow number : 0
Version 10 exported UDP datagram number (failed): 0 (0)
L2 export information:
Version 9 exported flow number : 0
Version 9 exported UDP datagram number (failed) : 0 (0)
NetStream aggregation data export configuration example
As shown in Figure 5, all devices in the network are running EBGP. Configure NetStream on Switch A to meet the following requirements:
· Use version 5 format to export NetStream traditional data to port 5000 of the NetStream server at 4.1.1.1/16.
· Perform NetStream aggregation in the modes of protocol-port, source-prefix, destination-prefix, and prefix.
· Export the aggregation data of different modes to 4.1.1.1, with UDP ports 3000, 4000, 6000, and 7000.
# Assign an IP address to each interface, as shown in Figure 5. (Details not shown.)
# Enable NetStream for incoming and outgoing traffic on GigabitEthernet 1/0/1.
[SwitchA-GigabitEthernet1/0/1] ip netstream outbound
# Specify version 5 format to export NetStream traditional data.
<SwitchA> ip netstream export version 5
# Specify 4.1.1.1 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[SwitchA] ip netstream export host 4.1.1.1 5000
# Set the aggregation mode to protocol-port, and specify the destination host for the aggregation data export.
[SwitchA] ip netstream aggregation protocol-port
[SwitchA-ns-aggregation-protport] enable
[SwitchA-ns-aggregation-protport] ip netstream export host 4.1.1.1 3000
[SwitchA-ns-aggregation-protport] quit
# Set the aggregation mode to source-prefix, and specify the destination host for the aggregation data export.
[SwitchA] ip netstream aggregation source-prefix
[SwitchA-ns-aggregation-srcpre] enable
[SwitchA-ns-aggregation-srcpre] ip netstream export host 4.1.1.1 4000
[SwitchA-ns-aggregation-srcpre] quit
# Set the aggregation mode to destination-prefix, and specify the destination host for the aggregation data export.
[SwitchA] ip netstream aggregation destination-prefix
[SwitchA-ns-aggregation-dstpre] enable
[SwitchA-ns-aggregation-dstpre] ip netstream export host 4.1.1.1 6000
[SwitchA-ns-aggregation-dstpre] quit
# Set the aggregation mode to prefix, and specify the destination host for the aggregation data export.
[SwitchA] ip netstream aggregation prefix
[SwitchA-ns-aggregation-prefix] enable
[SwitchA-ns-aggregation-prefix] ip netstream export host 4.1.1.1 7000
[SwitchA-ns-aggregation-prefix] quit
IP 3.1.1.1(0) 3.1.1.2 (0) 1 0 GE1/0/1(I) 5
IP 3.1.1.2 (0) 3.1.1.1 (0) 1 0 GE1/0/1(O) 5
protocol-port aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (3000)
Version 8 exported flow number : 2
Version 8 exported UDP datagrams number (failed): 2 (0)
Version 9 exported UDP datagrams number (failed): 0 (0)
source-prefix aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (4000)
destination-prefix aggregation export information:
Flow destination IP address (UDP) : 4.1.1.1 (6000)
Flow destination IP address (UDP) : 4.1.1.1 (7000)
Flow destination IP address (UDP) : 4.1.1.1 (5000)
Version 5 exported flow number : 10
Version 5 exported UDP datagrams number (failed): 10 (0)
