02-QoS commands | 399.58 KB |
display qos policy control-plane
display qos policy control-plane pre-defined
reset qos policy control-plane
Congestion management commands
display qos queue sp interface
display qos queue wrr interface
qos wrr { byte-count | weight }
display qos queue wfq interface
qos wfq { byte-count | weight }
Queue scheduling profile commands
display qos qmprofile configuration
display qos qmprofile interface
QoS policy commands
Traffic class commands
description
Use description to configure a description for a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
display traffic classifier
Use display traffic classifier to display traffic classes.
In standalone mode:
In IRF mode:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the traffic classes for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic classes for the global active MPU. (In IRF mode.)
# Display all user-defined traffic classes.
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
Classifier |
Traffic class name and its match criteria. |
Operator |
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria. |
Rule(s) |
Match criteria. |
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option |
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } |
Matches an ACL. The value range for the acl-number argument is as follows: · 2000 to 3999 for IPv4 ACLs. · 2000 to 3999 for IPv6 ACLs. · 4000 to 4999 for Layer 2 MAC ACLs. · 5000 to 5999 for user-defined ACLs. The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all. |
any |
Matches all packets. |
control-plane protocol protocol-name&<1-8> |
Matches control plane protocols. The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3. This option is not supported on PEXs in an IRF 3.1 system. |
control-plane protocol-group protocol-group-name |
Matches a control plane protocol group. The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect. This option is not supported on PEXs in an IRF 3.1 system. |
customer-dot1p dot1p-value |
Matches 802.1p priority values in inner VLAN tags of double-tagged packets. The dot1p-value argument specifies an 802.1p priority value in the range of 0 to 7. |
customer-vlan-id vlan-id-list |
Matches VLAN IDs in inner VLAN tags of double-tagged packets. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. |
destination-mac mac-address |
Matches a destination MAC address. This option takes effect only on Ethernet interfaces. |
dscp dscp-value |
Matches DSCP values. The dscp-value argument specifies a DSCP value. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5. |
forwarding-layer route |
Matches Layer 3 forwarded packets. |
ip-precedence ip-precedence-value |
Matches IP precedence values. The ip-precedence-value argument specifies an IP precedence value in the range of 0 to 7. |
protocol protocol-name |
Matches a protocol. The protocol-name argument can be ip or ipv6. |
qos-local-id local-id-value |
Matches a local QoS ID in the range of 1 to 4095. The switch supports the range 1 to 3999. |
service-dot1p dot1p-value |
Matches 802.1p priority values in outer VLAN tags. The dot1p-value argument specifies an 802.1p priority value in the range of 0 to 7. |
service-vlan-id vlan-id-list |
Matches VLAN IDs in outer VLAN tags. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. You can use this option to match single-tagged packets. |
source-mac mac-address |
Matches a source MAC address. This option takes effect only on Ethernet interfaces. |
tunnel-id tunnel-id |
Matches a VXLAN tunnel ID. For the traffic class to take effect, the tunnel must be a VXLAN tunnel. |
vxlan { any | vxlan-id } |
Matches a VXLAN ID. The device acting as a P device or VTEP in a VXLAN network does not support matching the VXLAN ID of packets if the following conditions exist: · The VXLAN has been created on the device. · The device is not the destination of the packets. |
Table 3 Available system-defined control plane protocols
Protocol |
arp |
ARP packets |
arp-snooping |
ARP snooping packets |
bfd |
BFD packets |
bgp |
BGP packets |
bgp4+ |
IPv6 BGP packets |
dhcp |
DHCP packets |
dhcp-snooping |
DHCP snooping packets |
dhcpv6 |
IPv6 DHCP packets |
dldp |
DLDP packets |
dot1x |
802.1X packets |
icmp |
ICMP packets |
icmpv6 |
ICMPv6 packets |
igmp |
IGMP packets |
ip-option |
IPv4 packets with the Options field |
ipv6-option |
IPv6 packets with the Options field |
snmp |
SNMP packets |
isis |
IS-IS packets |
lacp |
LACP packets |
lldp |
LLDP packets |
mvrp |
MVRP packets (including GVRP packets) |
ospf-multicast |
OSPF multicast packets |
ospf-unicast |
OSPF unicast packets |
ospf3-multicast |
OSPFv3 multicast packets |
ospf3-unicast |
OSPFv3 unicast packets |
pvst |
PVST packets |
ssh |
SSH packets |
stp |
STP packets |
telnet |
Telnet packets |
vrrp |
VRRP packets |
vrrp6 |
IPv6 VRRP packets |
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
· You can specify up to eight values for any of the following match criteria in one if-match command:
¡ Control plane protocol.
¡ VLAN ID.
· If a packet matches one of the specified values, it matches the if-match command.
· To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
· The ACL must already exist.
· Before defining a criterion to match the inner packet information of VXLAN packets in a traffic class, you must use the if-match vxlan command to define a VXLAN ID match criterion.
· An ACL can only match the following inner packet information:
¡ Source IP address.
¡ Destination IP address.
¡ Source port number.
¡ Destination port number.
¡ Transport protocol type.
· If a traffic class includes two ACL match criteria that match inner and outer packet information, follow these restrictions:
¡ Each ACL can contain only one rule.
¡ The rule in the ACL for matching the outer packet information can match only source IP addresses.
· The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1.
[Sysname-classifier-class1] if-match dscp 1
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1.
[Sysname-classifier-class1] if-match ip-precedence 1
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
[Sysname] traffic classifier class1 operator or
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match the VXLAN packets with tunnel ID 2.
[Sysname-classifier-class1] if-match tunnel-id 2
# Define a match criterion for traffic class class1 to match the packets with VXLAN 10.
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
Traffic behavior commands
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting [ byte | packet ]
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, the device counts traffic in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 160000000 kbps, in increments of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 160000000 kbps, in increments of 8.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
· remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
hierarchy-car-name: Specifies the name of the used hierarchical CAR action.
mode: Specifies the collaborating mode of the hierarchical CAR action and the common CAR action:
· and: Specifies the AND mode (the default mode). In this mode, the traffic rate of a flow is limited by both the common CAR and the total traffic rate defined with hierarchical CAR.
· or: Specifies the OR mode. In this mode, a flow can perform one of the following operations:
¡ Pass through at the rate equal to the common CAR applied to it.
¡ Pass through at a higher rate if the total traffic rate of all flows does not exceed the hierarchical CAR.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
· Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
· Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior
Use display traffic behavior to display traffic behaviors.
In standalone mode:
In IRF mode:
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays traffic behaviors for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic behaviors for the global active MPU. (In IRF mode.)
# Display all user-defined traffic behaviors.
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 200 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Behavior: 2 (ID 101)
Accounting enable:
Filter enable: Permit
Marking:
Remark dot1p 1
Behavior: 3 (ID 102)
-none-
Behavior |
Name and contents of a traffic behavior. |
Marking |
Information about priority marking. |
Remark dscp |
Action of setting the DSCP value for packets. |
Committed Access Rate |
Information about the CAR action. |
Green action |
Action to take on green packets. |
Yellow action |
Action to take on yellow packets. |
Red action |
Action to take on red packets. |
Filter enable |
Traffic filtering action. |
none |
No other traffic behavior is configured. |
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets. The permitted packets can be processed by other class-behavior associations in the same QoS policy.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number [ track-oap ] | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | next-hop }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number. On an IRF fabric connected through multiple IRF physical interfaces, the incoming interface and the interface to which the traffic is redirected must be on the same member device. For information about IRF, see Virtual Technologies Configuration Guide.
track-oap: Associates the redirecting action with the status of the OAP client if you have specified the internal interface that connects to an OAP module or an interface that connects to a standalone service component. The device redirects traffic to the specified interface only if the OAP client is registered with the OAP manager. For more information about the internal interface and standalone service component, see OAP module configuration and OAP configuration in OAA Configuration Guide, respectively.
next-hop: Redirects traffic to a next hop. For successful traffic redirection, make sure the next hop IP address is reachable. If both primary and secondary next hop IP addresses are specified, make sure a minimum of one IP address is reachable. The redirection feature periodically looks up the routing table to verify the reachability of next hop IP addresses. If track entries are specified, the redirection feature verifies the reachability of the next hop IP addresses based on the Track detection result. If both primary and secondary next hop IP addresses are unreachable, traffic redirection to a next hop does not take effect.
ipv4-add1: Specifies the primary next hop IPv4 address. If traffic fails to be redirected to this IPv4 address, the traffic is redirected to the secondary IPv4 address.
ipv4-add2: Specifies the secondary next hop IPv4 address.
ipv6-add1: Specifies the primary next hop IPv6 address. If traffic fails to be redirected to this IPv6 address, the traffic is redirected to the secondary IPv6 address.
ipv6-add2: Specifies the secondary next hop IPv6 address.
track track-entry-number: Specifies a track entry by its ID in the range of 1 to 1024. Different track entries can be specified for primary and secondary IP addresses. By specifying track entries, you can associate traffic redirection with detection modules, such as NQA and BFD (see High Availability Configuration Guide).
fail-action: Specifies the action to take on packets when the next hop IP address does not exist.
discard: Discards packets.
forward: Forwards packets.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
The switch supports applying a QoS policy containing a redirecting action only to a Layer 2 Ethernet interface.
Do not configure both redirecting to the next hop and marking the local QoS ID in one traffic behavior. Both actions in the traffic behavior do not take effect after the QoS policy is applied.
# Configure redirecting traffic to Ten-GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
classifier behavior
monitoring-group (Network Management and Monitoring Command Reference)
qos policy
traffic behavior
remark customer-vlan-id
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to restore the default.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
A QoS policy that contains a CVLAN marking action does not take effect on PEXs in an IRF 3.1 system.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior. The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p dot1p-value command multiple times for the same color, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A drop priority marking action takes effect only when the QoS policy is applied to the inbound direction.
If you execute the remark drop-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
A QoS policy that contains a drop priority marking action does not take effect on PEXs in an IRF 3.1 system.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
# Configure traffic behavior database to mark matching traffic with DSCP 6.
remark ip-precedence
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to restore the default.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
A local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
A QoS policy that contains a local precedence marking action does not take effect on PEXs in an IRF 3.1 system.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095. The switch supports the range 1 to 3999.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
A QoS policy that contains a local QoS ID marking action does not take effect on PEXs in an IRF 3.1 system.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
A QoS policy that contains an SVLAN marking action does not take effect on PEXs in an IRF 3.1 system.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode dcbx | insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode dcbx: Specifies that the class-behavior association applies only to the DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
In an IRF 3.1 system, you cannot specify a PEX for the chassis chassis-number slot slot-number option.
# (In standalone mode.) Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy
Use display qos policy to display QoS policies.
In standalone mode:
display qos policy user-defined [ accounting | mirroring | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
In IRF mode:
display qos policy user-defined [ accounting | mirroring | remarking ] [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined QoS policies.
accounting: Specifies accounting-type QoS policies.
mirroring: Specifies mirroring-type QoS policies.
remarking: Specifies marking-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the QoS policies for the global active MPU. (In IRF mode.)
If you do not specify the accounting, mirroring, or remarking keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Classifier: 2 (ID 101)
Behavior: 2
Accounting enable:
184057187 (Packets)
844575 (pps)
Marking:
Remark dot1p 4
Behavior: 3
-none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
Accounting policy: 1 (ID 100)
Behavior: 1
Accounting enable:
184057187 (Packets)
844575 (pps)
# Display user-defined mirroring-type QoS policies.
<Sysname> display qos policy user-defined mirroring
Mirroring policy: 1 (ID 100)
Behavior: 1
Mirroring:
Mirror to the CPU
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
Marking policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
Table 6 Command output
User-defined QoS policy information |
Information about a user-defined QoS policy. |
System-defined QoS policy information |
Information about a system-defined QoS policy. |
Policy |
User-defined generic QoS policy name. |
Accounting policy |
User-defined accounting-type QoS policy name. |
Mirroring policy |
User-defined mirroring-type QoS policy name. |
Marking policy |
User-defined marking-type QoS policy name. |
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
If-match protocol ipv6
Behavior: 2
Accounting enable:
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 7 Command output
Direction |
Direction in which the QoS policy is applied. |
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
In standalone mode:
In IRF mode:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the predefined control plane QoS policies for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays predefined control plane QoS policies for all cards. (In IRF mode.)
# (In standalone mode.) Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
Protocol Priority Bandwidth Group
IS-IS 29 512 (kbps) critical
VRRP 36 512 (kbps) important
OSPF Multicast 30 1024 (kbps) critical
OSPF Unicast 30 1024 (kbps) critical
PIM Multicast 24 128 (kbps) critical
PIM Unicast 24 128 (kbps) critical
IGMP 18 512 (kbps) important
PIMv6 Multicast 24 64 (kbps) critical
PIMv6 Unicast 24 64 (kbps) critical
OSPFv3 Unicast 30 1024 (kbps) critical
OSPFv3 Multicast 30 1024 (kbps) critical
VRRPv6 36 512 (kbps) important
ARP 12 768 (kbps) normal
DHCP Snooping 18 256 (kbps) redirect
DHCP 18 768 (kbps) normal
802.1x 12 128 (kbps) important
STP 36 256 (kbps) critical
LACP 36 64 (kbps) critical
MVRP 18 256 (kbps) critical
BGP 24 256 (kbps) critical
ICMP 9 512 (kbps) monitor
IPOPTION 18 384 (kbps) normal
BGPv6 24 256 (kbps) critical
IPOPTIONv6 18 64 (kbps) normal
LLDP 24 64 (kbps) important
DLDP 24 64 (kbps) critical
TELNET 8 512 (kbps) management
SSH 8 512 (kbps) management
HTTP 12 64 (kbps) management
HTTPS 12 64 (kbps) management
TACACS 12 64 (kbps) management
RADIUS 12 64 (kbps) management
ARP Snooping 18 256 (kbps) redirect
ICMPv6 8 512 (kbps) monitor
PVST 35 2560 (kbps) critical
DHCPv6 18 256 (kbps) normal
BFD 31 12800 (kbps) critical
Table 8 Command output
Pre-defined control plane policy |
Contents of the predefined control plane QoS policy. |
Default |
Protocols other than those listed. |
Group |
Protocol group of the protocol. |
For descriptions of other fields, see Table 3.
display qos policy global
Use display qos policy global to display QoS policies applied globally.
In standalone mode:
display qos [ accounting | mirroring | remarking ] policy global [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos [ accounting | mirroring | remarking ] policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays global QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays global QoS policies for the global active MPU. (In IRF mode.)
If you do not specify the accounting, mirroring, or remarking keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display generic QoS policies applied globally.
<Sysname> display qos policy global
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
184057187 (Packets)
844575 (pps)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# Display information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy global
Direction: Inbound
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Accounting enable:
184057187 (Packets)
844575 (pps)
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Table 9 Command output
Direction |
Policy |
Accounting policy |
Mirroring policy |
Marking policy |
Green packets |
Statistics about green packets. |
Red packets |
Statistics about red packets. |
display qos policy interface
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos [ accounting | mirroring | remarking ] policy interface [ interface-type interface-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify the accounting, mirroring, or remarking keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the generic QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
184057187 (Packets)
844575 (pps)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# Display information about the accounting-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos accounting policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Accounting Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Accounting enable:
184057187 (Packets)
844575 (pps)
# Display information about the marking-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos remarking policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Marking policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
# Display information about the mirroring-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos mirroring policy interface ten-gigabitethernet 1/0/1 inbound
Direction: Inbound
Mirroring policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Mirroring:
Mirror to the CPU
# Display the generic QoS policies applied to all interfaces.
Direction: Inbound
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: Ten-GigabitEthernet1/0/2
CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: Ten-GigabitEthernet1/0/3
Direction: Inbound
Policy: b
Classifier: b
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Interface: Ten-GigabitEthernet1/0/4
Direction: Inbound
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: Ten-GigabitEthernet1/0/5
Green action : pass
Table 10 Command output
Direction |
Policy |
Accounting policy |
Mirroring policy |
Marking policy |
Green packets |
Traffic statistics for green packets. |
Red packets |
Traffic statistics for red packets. |
fail-action |
Action to take on packets when the next hop IP address does not exist: discard or forward. |
display qos vlan-policy
Use display qos vlan-policy to display QoS policies applied to VLANs.
In standalone mode:
In IRF mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies applied to VLANs for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays QoS policies applied to VLANs for the global active MPU. (In IRF mode.)
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
184057187 (Packets)
844575 (pps)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 11 Command output
Direction |
Green packets |
Red packets |
qos apply policy
Use qos apply policy to apply a QoS policy to an interface or control plane.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ accounting | mirroring | remarking ] policy policy-name { inbound | outbound }
undo qos apply [ accounting | mirroring | remarking ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Interface view
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view.
mirroring: Specifies a mirroring-type QoS policy. This keyword is supported only in interface view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic.
Layer 2 aggregate interfaces and Layer 3 aggregate interfaces/subinterfaces do not support QoS policy application. If a Layer 3 aggregate interface has subinterfaces, the member ports of the Layer 3 aggregate interface do not support QoS policy application.
Mirroring-type QoS policies and marking-type QoS policies cannot be applied to the outbound direction.
A maximum of four QoS policies can be applied to one direction of an interface: one accounting-type, one marking-type, one mirroring-type, and one generic. The actions in QoS policies of different types can be taken on the same traffic class.
# Apply generic QoS policy TEST1 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
# Apply accounting-type QoS policy TEST2 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply accounting policy TEST2 outbound
# Apply mirroring-type QoS policy TEST3 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply mirroring policy TEST3 outbound
# Apply marking-type QoS policy TEST4 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply remarking policy TEST4 outbound
# Apply generic QoS policy TEST5 to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy TEST5 inbound
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ accounting | mirroring | remarking ] policy policy-name global { inbound | outbound }
undo qos apply [ accounting | mirroring | remarking ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
A maximum of four QoS policies (one generic, one accounting-type, one mirroring-type, and one marking-type) can be applied to one direction globally.
If you do not specify the accounting, mirroring, or remarking keyword, this command applies a generic QoS policy globally.
# Globally apply generic QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
# Globally apply mirroring-type QoS policy user2 to the incoming traffic.
[Sysname] qos apply mirroring policy user2 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ accounting | mirroring | remarking ] policy policy-name
undo qos [ accounting | mirroring | remarking ] policy policy-name
No QoS policies exist.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
mirroring: Identifies the QoS policy as a mirroring-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
If you do not specify the accounting, mirroring, or remarking keyword when creating a QoS policy, a generic QoS policy is created.
QoS policies of different types cannot use the same policy name.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An accounting-type QoS policy can be applied to only interfaces or globally and can contain only class-based accounting actions. A mirroring-type QoS policy can only be applied to interfaces or globally and can contain only mirroring actions. A marking-type QoS policy can be applied to only interfaces or globally and can contain only marking actions.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a generic QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# Create a mirroring-type QoS policy named user4.
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
In standalone mode:
In IRF mode:
reset qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
reset qos policy global
Use reset qos policy global to clear statistics for QoS policies applied globally.
reset qos [ accounting | mirroring | remarking ] policy global [ inbound | outbound ]
inbound: Specifies the QoS policy applied to the inbound direction globally.
outbound: Specifies the QoS policy applied to the outbound direction globally.
If you do not specify a direction, this command clears statistics for the global QoS policies in both directions.
If you do not specify the accounting, mirroring, or remarking keyword, this command clears statistics for generic QoS policies.
# Clear statistics for the generic QoS policy applied to the inbound direction globally.
<Sysname> reset qos policy global inbound
# Clear statistics for the mirroring-type QoS policy applied to the inbound direction globally.
<Sysname> reset qos mirroring policy global inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dp | dscp-dscp | exp-dot1p ]
The device provides the following types of priority map.
Priority mapping |
dot1p-dp |
802.1p-drop priority map. |
dot1p-exp |
802.1p-EXP priority map. |
dot1p-lp |
802.1p-local priority map. |
dscp-dp |
DSCP-drop priority map. |
dscp-dscp |
DSCP-DSCP priority map. |
exp-dot1p |
EXP-802.1p priority map. |
exp-dscp |
EXP-DSCP priority map. |
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
Table 13 Command output
MAP-TABLE NAME |
Name of the priority map. |
TYPE |
Type of the priority map. |
IMPORT |
Input values of the priority map. |
EXPORT |
Output values of the priority map. |
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
map export
Use map export to manipulate 802.1p-to-EXP mapping application to outgoing MPLS labels.
Use undo map export to restore the default.
map export mpls-exp
undo map export
The 802.1p-to-EXP mappings are applied to the two added MPLS labels of a packet if the packet comes from a private network and does not have MPLS labels. The 802.1p-to-EXP mappings are applied to the topmost (first) MPLS label if the packet comes from the public network and has two MPLS labels.
Priority map view
mpls-exp: Applies 802.1p-to-EXP mappings to the first MPLS label.
This command applies 802.1p-to-EXP mappings to outgoing MPLS labels of a packet as follows:
· Applies 802.1p-to-EXP mappings to the first MPLS label and sets the EXP value in the second MPLS label to 0 if the packet comes from a private network and does not have MPLS labels.
· Applies 802.1p-to-EXP mappings to neither of the MPLS labels if the packet comes from the public network and has two MPLS labels.
# Map 802.1p priorities 4 and 5 to EXP value 1, and apply the 802.1p-to-EXP mappings to the first outgoing MPLS label of packets coming from a private network.
[Sysname] qos map-table dot1p-exp
[Sysname-maptbl-dot1p-exp] import 4 5 export 1
[Sysname-maptbl-dot1p-exp] map export mpls-exp
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dp | dscp-dscp | exp-dot1p }
For the description of other keywords, see Table 12.
# Enter 802.1p-local priority map view.
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
Port priority trust information
Port priority:4
Port priority trust type: dscp
Table 14 Command output
Interface type and interface number. |
Port priority |
Port priority set for the interface. |
Port priority trust type |
Priority trust mode on the interface: · dot1p—Uses the 802.1p priority of received packets for mapping. · dscp—Uses the DSCP precedence of received IP packets for mapping. |
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface trusts the 802.1p priority.
Interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
Transport-facing interfaces in a VXLAN network do not support the priority trust mode dscp. For information about VXLAN, see VXLAN Configuration Guide.
This command does not take effect on interfaces of PEXs in an IRF 3.1 system.
# Set the priority trust mode to 802.1p priority on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0, and the DSCP value of packets is not modified.
Interface view
priority-value: Specifies a port priority value. If the dscp keyword is not specified, this argument specifies the port priority in the range of 0 to 7. If the dscp keyword is specified, this argument specifies the DSCP value to be set for packets, in the range of 0 to 63.
This command does not take effect on PEXs in an IRF 3.1 system.
When no priority trust mode is configured for an interface, the interface uses the port priority as the 802.1p priority for priority mapping. If the DSCP port priority is configured, the interface modifies the DSCP value of Layer 3 packets in addition to performing priority mapping.
If the DSCP port priority is configured, the dscp-dp priority map configured on the interface loses effect.
If both the DSCP port priority and the priority trust mode DSCP are configured on an interface, the DSCP port priority does not take effect.
If both the port priority and the DSCP port priority are configured, the port priority does not take effect.
All member ports in an aggregation group must be configured with the same port priority type and port priority value.
# Set the port priority of Ten-GigabitEthernet 1/0/1 to 2.
[Sysname-Ten-GigabitEthernet1/0/1] qos priority 2
GTS and rate limit commands
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
Rule: If-match queue 1
CIR 1000 (kbps), CBS 62976 (Bytes)
Rule: If-match queue 4
CIR 400 (kbps), CBS 25088 (Bytes)
Table 15 Command output
Interface name, including the interface type and interface number. |
Rule |
Match criteria. |
CIR |
CIR in kbps (if the CIR is specified in absolute value) or in percentage (if the CIR is specified in percentage). |
CBS |
CBS in bytes (if the CBS is specified in absolute value) or in ms (if the CBS is specified in milliseconds). When the CBS is specified in milliseconds, the actual CBS value is cbs-time × the actual CIR value. |
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
Interface view
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 1000000 for GE interfaces, 8 to 10000000 for 10-GE interfaces, 8 to 40000000 for 40-GE interfaces, 8 to 100000000 for 100-GE interfaces. The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 16000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 16000000 is converted to 16000000.
# Shape the packets of queue 1 on Ten-GigabitEthernet 1/0/1 (CIR 6400 kbps and CBS 51200 bytes).
[Sysname-Ten-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration for all interfaces.
Direction: Outbound
CIR 2000 (kbps), CBS 20480 (Bytes)
Table 16 Command output
Direction |
Direction in which the rate limit configuration is applied. |
CIR |
CBS |
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration on an interface.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
No rate limit is configured.
Interface view
outbound: Limits the rate of outgoing packets.
cir committed-information-rate: Specifies the CIR in kbps. The committed-information-rate argument has the following value ranges:
· 8 to 1000000 for GE interfaces.
· 8 to 10000000 for 10-GE interfaces.
· 8 to 40000000 for 40-GE interfaces.
· 8 to 100000000 for 100-GE interfaces.
The specified value must be an integral multiple of 8. The maximum value for interfaces on an LSUM1CQGS32SF0 interface module cannot exceed 1000000.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 128000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 128000000 is converted to 128000000.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
Output queue: Strict Priority queuing
Interface: Ten-GigabitEthernet1/0/2
Interface: Ten-GigabitEthernet1/0/5
Interface: Ten-GigabitEthernet1/0/6
Table 17 Command output
Output queue |
Type of the current output queue. |
Group |
Number of the group that holds the queue. |
Weight |
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Byte-count |
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
Table 18 Command output
Output queue |
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
Interface view
# Enable SP queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 1
2 af2 1 1
3 af3 1 1
4 af4 1 1
5 ef 1 1
6 cs6 1 1
7 cs7 sp N/A
Table 19 Command output
Output queue |
Group |
ID of the group a queue is assigned to. |
Weight |
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Byte count |
Byte-count scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
Interface view
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
Interface view
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 20.
Table 20 The number-keyword map for the queue-id argument
Number |
Keyword |
0 |
be |
1 |
af1 |
2 |
af2 |
3 |
af3 |
4 |
af4 |
5 |
ef |
6 |
cs6 |
7 |
cs7 |
group { 1 | 2 }: Specifies WRR group 1 or 2. If you do not specify a group, group 1 applies. Group 1 has higher scheduling priority than group 2. Queues in group 2 are serviced only when all queues in group 1 are empty. WRR group 2 is not supported in the current software version.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 15.
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
Interface view
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos wfq interface ten-gigabitethernet 1/0/1
Output queue: Hardware Weighted Fair Queuing
Queue ID Queue name Group Byte count Min Bandwidth
0 be 1 1 64
1 af1 1 1 64
2 af2 1 1 64
3 af3 1 1 64
4 af4 1 1 64
5 ef 1 1 64
6 cs6 1 1 64
7 cs7 1 1 64
Table 21 Command output
Output queue |
Group |
ID of the group that holds the queue. |
Byte-count |
Weight |
Packet-count queue scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Min Bandwidth |
Minimum guaranteed bandwidth for the queue. |
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth is not set.
Interface view
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The bandwidth-value argument has the following value ranges:
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
Interface view
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-count WFQ on Ten-GigabitEthernet 1/0/1.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
Interface view
group { 1 | 2 }: Specifies WFQ group 1 or 2. If you do not specify a group, group 1 applies. Group 1 has higher scheduling priority than group 2. Queues in group 2 are serviced only when all queues in group 1 are empty. WFQ group 2 is not supported in the current software version.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1, assign queue 0 to WFQ group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
All queues on a WFQ-enabled interface are in WFQ group 1.
Interface view
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
Queue scheduling profile view
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
You must configure a queue as a WFQ queue before you set the minimum guaranteed bandwidth for the queue.
# Configure queue 0 as a WFQ queue, and set the minimum guaranteed bandwidth to 100 kbps for queue 0.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
In standalone mode:
In IRF mode:
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the queue scheduling profile configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the queue scheduling profile configuration for the global active MPU. (In IRF mode.)
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID Type Group Schedule Schedule Min Max
unit value bandwidth bandwidth
be SP N/A N/A N/A 0 N/A
af1 WFQ 1 weight 1 200 N/A
af2 WFQ 1 weight 1 0 N/A
af3 WFQ 1 weight 2 0 N/A
af4 WFQ 1 weight 2 0 N/A
ef WFQ 1 weight 3 0 N/A
cs6 WFQ 1 weight 4 0 N/A
cs7 WFQ 1 weight 3 0 N/A
Table 22 Command output
Queue management profile |
Queue scheduling profile name. |
Type |
Queue scheduling type: · SP. · WRR. · WFQ. |
Group |
Priority group to which the queue belongs. N/A indicates this field is ignored. |
Schedule unit |
Scheduling unit: weight or byte-count. N/A indicates that this field is ignored. |
Schedule value |
This field indicates: · Number of packets for the weight scheduling unit. · Number of bytes for the byte-count scheduling unit. N/A indicates that this field is ignored. |
Min bandwidth |
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored. |
Max bandwidth |
Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored. |
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Direction: Outbound
Table 23 Command output
Direction |
Direction in which the queue scheduling profile is applied. |
Name of the queue scheduling profile applied to the interface. |
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
Interface view
You can apply only one queue scheduling profile to one direction of an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile use SP queuing.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies the scheduling weight. The value range for this argument is 1 to 16 for WFQ and 1 to 15 for WRR.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
· The WRR queuing is used.
· The WRR group is group 1.
· The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Congestion avoidance commands
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
Current WRED configuration:
Applied WRED table name: q1
Table 24 Command output
display qos wred table
Use display qos wred table to display the WRED table configuration.
In standalone mode:
In IRF mode:
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the WRED table configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the WRED table configuration for the global active MPU. (In IRF mode.)
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 100 1000 10 100 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 100 1000 10 100 1000 10 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 100 1000 10 100 1000 10 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Table 25 Command output
Table name |
Name of a WRED table. |
Table type |
Type of a WRED table. |
QID |
Queue ID. |
gmin |
Lower limit for green packets. |
gmax |
Upper limit for green packets. |
gprob |
Drop probability for green packets. |
ymin |
Lower limit for yellow packets. |
ymax |
Upper limit for yellow packets. |
yprob |
Drop probability for yellow packets. |
rmin |
Lower limit for red packets. |
rmax |
Upper limit for red packets. |
rprob |
Drop probability for red packets. |
exponent |
Exponent for average queue length calculation. |
ECN |
Indicates whether ECN is enabled for the queue: · Y—Enabled. · N—Disabled. |
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
Interface view
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
qos wred queue table
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
The lower limit is 100, the upper limit is 1000, and the drop probability is 10%.
WRED table view
all: Specifies all queues.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 16383 cell resources. A cell resource is 208 bytes.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit is 0 to 16383 cell resources. A cell resource is 208 bytes.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
· The drop level is 1.
· The lower limit for the average queue length is 10.
· The upper limit for the average queue length is 20.
· The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is disabled for a queue.
WRED table view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
ECN takes effect only on known unicast packets on TCP connections.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 1 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Global CAR commands
car name
Use car name to use a global CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
No global CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
hierarchy-car hierarchy-car-name: Specifies a hierarchical CAR action by its name, a case-sensitive string of 1 to 31 characters. This argument must start with a letter.
mode: Specifies a collaborating mode between the hierarchical CAR action and the aggregate CAR action, which can be AND (the default) or OR. If you do not specify a collaborating mode, the AND mode applies.
· and: Specifies the AND mode (the default mode). In this mode, the rate of a flow is limited by both aggregate CAR and the total traffic rate defined with hierarchical CAR.
· or: Specifies the OR mode. In this mode, a flow can perform one of the following operations:
¡ Pass through at the rate equal to the aggregate CAR applied to it.
¡ Pass through at a higher rate if the total traffic rate of all flows does not exceed the hierarchical CAR.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
# Configure traffic behavior be1 to use aggregate CAR action aggcar-1 and hierarchical CAR action hcar, with the collaborating mode as or.
[Sysname-behavior-be1] car name aggcar-1 hierarchy-car hcar mode or
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command displays information about all global CAR actions, including aggregate CAR actions and hierarchical CAR actions.
# (In standalone mode.) Display information about all global CAR actions.
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Mode: hierarchy
CIR 64 (kbps) CBS: 2048 (Bytes)
Table 26 Command output
Name |
Name of the global CAR action. |
Mode |
Type of the CAR action, which can be aggregative or hierarchy. |
CIR CBS PIR EBS |
Parameters for the CAR action. |
Green action |
Action to take on green packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Yellow action |
Action to take on yellow packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Red action |
Action to take on red packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
qos car
Use qos car aggregative to configure an aggregate or hierarchical CAR action.
Use undo qos car to delete an aggregate or hierarchical CAR action.
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate or hierarchical CAR action is configured.
car-name: Specifies the name of the global CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
aggregative: Specifies the global CAR action as an aggregate CAR action.
hierarchy: Specifies the global CAR action as a hierarchical CAR action.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000, in increments of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000. This option is supported only in an aggregate CAR action.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 160000000, in increments of 8. This option is supported only in an aggregate CAR action.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass. This option is supported only in an aggregate CAR action.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard. This option is supported only in an aggregate CAR action.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass. This option is supported only in an aggregate CAR action.
action: Specifies the action to take on packets:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is used in a QoS policy.
A hierarchical CAR action takes effect only after it is used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
# Configure hierarchical CAR action h-car, where CIR is 120 and CBS is 51200.
[Sysname] qos car h-car hierarchy cir 120 cbs 51200
reset qos car name
Use reset qos car name to clear the statistics about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command clears statistics for all global CAR actions, including aggregate CAR actions and hierarchical CAR actions.
# Clear the statistics about global CAR action aggcar-1.
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
Direction: outbound
Forwarded: 0 packets, 0 bytes
Dropped: 0 packets, 0 bytes
Queue 0
Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
Current queue length: 0 packets
Queue 1
Queue 2
Queue 3
Queue 4
Queue 5
Queue 6
Queue 7
Table 27 Command output
Interface for which queue-based traffic statistics are displayed. |
Direction |
Direction of traffic for which statistics are collected. |
Forwarded |
Counts forwarded traffic both in packets and in bytes. |
Dropped |
Counts dropped traffic both in packets and in bytes. |
Current queue length |
Current number of packets in the queue. |
reset counters interface (Interface Command Reference)
