16-OpenFlow Configuration Guide
HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration GuidesH3C S7500X Switch Series Configuration Guides-Release758X-6W10016-OpenFlow Configuration Guide
00-Preface
00-Preface 100.82 KB
Preface
This configuration guide describes OpenFlow fundamentals and configuration. OpenFlow separates the data forwarding and routing decision functions. An OpenFlow switch matches and forwards packets by using the flow table entries obtained from a controller.
·           Audience.
·           Conventions.
·           Documentation feedback.
Audience
·           Network planners.
·           Field technical support and servicing engineers.
·           Network administrators working with the S7500E switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
  • Become a Partner
  • Partner Resources
