01-EPON commands | 593.08 KB |
alarm device-fatal-error enable
alarm oam critical-event enable
alarm oam local-link-fault enable
alarm onu-laser always-on enable
alarm registration-error enable
dba-report queue-set-id queue-id threshold
display epon authentication-mode
display epon fiber-backup group
display epon optics-parameters
multicast call-detail-record cache-limit
multicast call-detail-record enable
multicast call-detail-record record-delay
multicast call-detail-record report-interval
multicast call-detail-record send
ONU remote management commands
bandwidth-downstream policy enable
display onu protocol smart-link uni-bind information
display onu protocol transparent-multicast
display vendor-specific information
multicast-control host-aging-time
onu multicast fast-leave enable
onu protocol igmp-snooping timer
onu protocol igmp-snooping suppression
onu protocol loopback-detection action
onu protocol smart-link flush enable
onu protocol smart-link uni-bind enable
shutdown management-vlan-interface
uni multicast-control multicast-address
uni multicast-strip-tag enable
EPON commands
The device supports the following EPON cards:
· 10G-EPON cards: LSQM1XPT12TSFD0 interface cards.
· 1G-EPON cards: LSQM1PT8TSSC0 and LSQM1PT24TSSC0 interface cards.
Unless otherwise specified, interfaces on 1G-EPON cards are used in this document.
OLT commands
Use alarm device-fatal-error enable to enable the device fatal error alarm.
Use undo alarm device-fatal-error enable to disable the device fatal error alarm.
The device fatal error alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an error that causes system unavailability occurs, such as memory leak and high memory usage.
If you configure this alarm in OLT port view, the configuration takes effect only on the OLT port. If you configure this alarm in FTTH view, the configuration takes effect on all OLT ports.
If you configure this alarm in both OLT port view and FTTH view, the most recent configuration takes effect on the OLT port.
# Enable the device fatal error alarm on OLT 1/0/1.
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] alarm device-fatal-error enable
Use alarm oam critical-event enable to enable the critical event alarm.
Use undo alarm oam critical-event enable to disable the critical event alarm.
The critical event alarm is enabled.
FTTH view
OLT port view
This alarm is sent if the local link fault or dying gasp alarm is sent.
# Enable the critical event alarm on OLT 1/0/1.
[Sysname-Olt1/0/1] alarm oam critical-event enable
alarm oam dying-gasp enable
Use alarm oam dying-gasp enable to enable the dying gasp alarm.
Use undo alarm oam dying-gasp enable to disable the dying gasp alarm.
The dying gasp alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an irrecoverable error occurs, such as a system error and a data loading error.
# Enable the dying gasp alarm on OLT 1/0/1.
[Sysname-Olt1/0/1] alarm oam dying-gasp enable
Use alarm oam local-link-fault enable to enable the local link fault alarm.
Use undo alarm oam local-link-fault enable to disable the local link fault alarm.
The local link fault alarm is enabled.
FTTH view
OLT port view
This alarm is sent if a fault occurs in the inbound direction on the OLT.
# Enable the local link fault alarm on OLT 1/0/1.
[Sysname-Olt1/0/1] alarm oam local-link-fault enable
Use alarm onu-laser always-on enable to enable the ONU laser-always-on alarm.
Use undo alarm onu-laser always-on enable to disable the ONU laser-always-on alarm.
alarm onu-laser always-on enable [ action power-off ]
The ONU laser-always-on alarm is enabled.
FTTH view
OLT port view
action power-off: Generates laser-always-on alarms and powers off the Tx power (Tx power for the transceiver module of a PON port) of an ONU when the OLT detects laser-always-on events on the ONU. If you do not specify this keyword, the OLT only generates laser-always-on alarms when detecting laser-always-on events on an ONU.
With the ONU laser-always-on alarm enabled, this alarm is sent if the OLT detects that an ONU keeps sending optical signals for a long period of time.
# Enable the ONU laser-always-on alarm on OLT 1/0/1.
[Sysname-Olt1/0/1] alarm onu-laser always-on enable
alarm onu-over-limit enable
Use alarm onu-over-limit enable to enable the ONU over limit alarm.
Use undo alarm onu-over-limit enable to disable the ONU over limit alarm.
The ONU over limit alarm is enabled.
FTTH view
OLT port view
This alarm is sent if the number of ONUs connected to the OLT reaches the upper limit.
# Enable the ONU over limit alarm on OLT 1/0/1.
[Sysname-Olt1/0/1] alarm onu-over-limit enable
Use alarm registration-error enable to enable the registration error alarm.
Use undo alarm registration-error enable to disable the registration error alarm.
The registration error alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an error occurs during ONU registration.
# Enable the registration error alarm on OLT 1/0/1.
[Sysname-Olt1/0/1] alarm registration-error enable
authentication-mode
Use authentication-mode to set the ONU authentication mode.
Use undo authentication-mode to delete ONU authentication mode settings.
authentication-mode { mac | loid | loid-password } *
undo authentication-mode [ mac | loid | loid-password ] *
An OLT port uses the MAC mode for ONU authentication.
OLT port view
FTTH view
mac: Specifies the MAC mode. In this mode, an OLT port authenticates ONUs based on the MAC address.
loid: Specifies the logical ONU identifier (LOID) mode. In this mode, an OLT port authenticates ONUs based on the LOID.
loid-password: Specifies the LOID-password mode. In this mode, an OLT port authenticates ONUs based on the LOID and LOID password.
The LOID mode and the LOID-password mode are mutually exclusive. You cannot use them together.
If you execute this command in OLT port view, the configuration takes effect only on the OLT port. If you execute this command in FTTH view, the configuration takes effect on all OLT ports. An OLT port preferentially uses the port-specific ONU authentication mode. If no port-specific ONU authentication mode is available, the OLT port uses the ONU authentication mode configured in FTTH view.
You can execute this command multiple times to add ONU authentication mode settings.
To restore the default, do not specify any keyword when you execute the undo authentication-mode command. To delete an ONU authentication mode setting, specify the corresponding keyword when you execute the undo authentication-mode command. If no ONU authentication mode setting is available in the view of an OLT port and in FTTH view, the OLT port uses the default setting.
# Set the ONU authentication mode to MAC and LOID in FTTH view.
[Sysname] ftth
[Sysname-ftth] authentication-mode mac loid
dba-parameters
Use dba-parameters to set ONU discovery parameters.
Use undo dba-parameters to restore the default.
dba-parameters { discovery-frequency frequency | discovery-length length } *
undo dba-parameters { discovery-frequency | discovery-length } *
An OLT port initiates ONU discovery at an interval of 500 milliseconds, and each ONU discovery process lasts for 3076 TQ.
OLT port view
discovery-frequency frequency: Specifies the ONU discovery interval at which the OLT port broadcasts discovery GATE messages, in the range of 100 to 60000. The unit of the frequency argument is 0.1 millisecond.
discovery-length length: Specifies the duration of each ONU discovery, in the range of 200 to 10240. The unit of the length argument is time quantum (TQ). 1 TQ is equal to 16 ns.
Incorrect DBA settings might interrupt services. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Set the ONU discovery interval to 300 milliseconds on OLT 1/0/1.
[Sysname-Olt1/0/1] dba-parameters discovery-frequency 3000
Use dba-report queue-set-id queue-id threshold to configure the threshold for a queue.
Use undo dba-report queue-set-id to restore the default.
dba-report queue-set-id queue-set-id queue-id queue-id { active | inactive } threshold threshold-value
undo dba-report queue-set-id queue-set-id
The default thresholds are as follows:
· 0 for queues 1 through 3, and the threshold is activated.
· 65535 for queues 4 and 5, and the threshold is activated.
· 0 for queues 6 through 8, and the threshold is not activated.
ONU port view
queue-set-id: Specifies a queue set ID in the range of 1 to 3.
queue-id: Specifies a queue ID in the range of 1 to 8.
threshold-value: Specifies a threshold in the range of 0 to 65535.
active: Activates the threshold.
inactive: Does not activate the threshold.
# Set the threshold to 200 for queue 1 in queue set 1 and activate the threshold on ONU 1/0/1:1.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] dba-report queue-set-id 1 queue-id 1 active threshold 200
dba-report queue-set-number
Use dba-report queue-set-number to set the number of queue sets that ONU REPORT messages support.
Use undo dba-report queue-set-number to restore the default.
dba-report queue-set-number queue-set-number
ONU REPORT messages support two queue sets.
ONU port view
queue-set-number: Specifies the number of queue sets, in the range of 2 to 4.
# Set the number of queue sets to 2 for ONU REPORT messages on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] dba-report queue-set-number 2
display epon alarm history
Use display epon alarm history to display EPON alarm information.
display epon alarm history [ interface interface-type interface-number ] [ count number ] [ from start-time ] [ to end-time ]
interface interface-type interface-number: Specifies an interface by its type (which can be olt or onu) and number. If you do not specify an interface, this command displays EPON alarm information of all OLT ports and ONU ports.
count number: Specifies the maximum number of most recent EPON alarms that can be displayed, in the range of 1 to 2000. The default is 100. If you do not specify this option, this command displays all most recent EPON alarms.
from start-time: Specifies the start time of displayed EPON alarms, in the format of yyyy/mm/dd-hh:mm:ss and in the range of 1970/01/01-00:00:00 to 2100/12/31-23:59:59. If you do not specify this option, the start time is 1970/01/01-00:00:00.
to end-time: Specifies the end time of displayed EPON alarms, in the format of yyyy/mm/dd-hh:mm:ss and in the range of 1970/01/01-00:00:00 to 2100/12/31-23:59:59. The end time must be no earlier than the start time. If you do not specify this option, the end time is 2100/12/31-23:59:59.
The device records a maximum of 2000 most recent EPON alarms in the memory for users to view. The newly generated EPON alarms are preferentially displayed.
When you use this command to display EPON alarm information of an OLT port, this command also displays EPON alarm information of ONU ports corresponding to the OLT port.
# Display all EPON alarms.
<Sysname> disp epon alarm history
2018/09/28-16:03:30:203 Olt1/0/1 OnuSilence Onu silence which mac is 0011-00ff-00dd.
# Display most recent two alarms that occur within the specified time range.
<Sysname> display epon alarm history count 2 from 2018/02/02-10:01:30 to 2018/02/02-13:10:10
2018/02/02-10:15:39:866 Onu1/0/1:1 Uni 20 change to up.
2018/02/02-10:01:30:166 Onu1/0/1:1 Uni 20 change to down.
display epon alarm statistics
Use display epon alarm statistics to display EPON alarm statistics.
display epon alarm statistics [ interface interface-type interface-number ] [ from start-time ] [ to end-time ]
interface interface-type interface-number: Specifies an interface by its type (which can be olt or onu) and number. If you do not specify an interface, this command displays EPON alarm statistics of all OLT ports and ONU ports.
When you use this command to display EPON alarm statistics of an OLT port, this command also displays EPON alarm statistics of ONU ports corresponding to the OLT port.
# Display all EPON alarm statistics.
<Sysname> display epon alarm statistics
Type Count
PortAlarmBer 0
PortAlarmFer 0
Type |
Alarm type. |
Count |
Alarm count. |
Use display epon authentication-mode to display ONU authentication mode settings.
display epon authentication-mode [ interface interface-type interface-number ]
interface: Specifies an OLT port. If you do not specify an OLT port, this command displays all ONU authentication mode settings, including the settings configured in FTTH view and all port-specific settings.
interface-type: Specifies an interface type. The value of this argument must be olt.
# Display all ONU authentication mode settings.
<Sysname> display epon authentication-mode
Ftth authentication mode:-
Interface Authentication-mode
Olt1/0/1 mac and loid
Ftth authentication mode |
ONU authentication mode configured in FTTH view: · If the ONU authentication mode is not configured in FTTH view, this field displays a hyphen (-). In this situation, the default setting applies. · If the ONU authentication mode is configured in FTTH view, this field displays the configured mode settings. Available values are as follows: ? mac—Authenticates ONUs based on the MAC address. ? loid—Authenticates ONUs based on the LOID. ? loid-password—Authenticates ONUs based on the LOID and LOID password. ? mac and loid—Authenticates ONUs based on the MAC address or the LOID. ? mac and loid-password—Authenticates ONUs based on the MAC address, or the LOID and LOID password. |
Authentication-mode |
Port-specific ONU authentication mode: · If the ONU authentication mode is not configured for an OLT port, the OLT port is not displayed. · If the ONU authentication mode is configured for an OLT port, this field displays the configured authentication mode settings. Available values are as follows: ? mac—Authenticates ONUs based on the MAC address. ? loid—Authenticates ONUs based on the LOID. ? loid-password—Authenticates ONUs based on the LOID and LOID password. ? mac and loid—Authenticates ONUs based on the MAC address or the LOID. ? mac and loid-password—Authenticates ONUs based on the MAC address, or the LOID and LOID password. |
Use display epon fiber-backup group to display information about fiber backup groups.
display epon fiber-backup group { group-number | all }
group-number: Specifies a fiber backup group number in the range of 1 to 80.
all: Specifies all fiber backup groups.
# Display information about fiber backup group 1.
<Sysname> display epon fiber-backup group 1
Fiber backup group 1 information:
Member Role State
OLT1/0/1 Master Active
OLT1/0/2 Standby Ready
Role |
OLT port role: · Master—Master port. · Standby—Subordinate port. |
State |
OLT port status: · Active—The master port is active. (The chip is active and the EPON transceiver module is plugged in.) · Ready—The subordinate port is ready, and a master/subordinate switchover can be performed. · Other—Any other condition. |
display epon oam
Use display epon oam to display Operations, Administration and Maintenance (OAM) information for an ONU port.
display epon oam interface interface-type interface-number
interface-type: Specifies an interface type. The value of this argument must be onu.
# Display OAM information for ONU 1/0/1:1.
<Sysname> display epon oam interface onu 1/0/1:1
OAM information:
OAM version: 1
Multiplexer action: Discard non-OAM PDUs
Parser action : Forward non-OAM PDUs to higher layer
Sending variable-length OAM response PDUs: Not supported
Interpreting link events : Not supported
OAM mode : Active
Unidirectional support: Disabled
Loopback support : Disabled
Maximal PDU size : 494 bytes
Identifier : 433348
display epon onu-event
Use display epon onu-event to display ONU registration and deregistration records for an ONU port.
display epon onu-event interface interface-type interface-number
# Display ONU registration and deregistration records for ONU 1/0/1:1.
<Sysname> display epon onu-event interface onu 1/0/1:1
Date Time ONU Event ONU Status
2015/06/24 14:41:18 Registration Up
2015/06/24 14:41:59 Deregistration Down
2015/06/24 14:42:02 Registration Up
2015/06/24 14:42:49 Deregistration Down
Use display epon optics-parameters to display optical parameters for an OLT port.
display epon optics-parameters interface interface-type interface-number
# Display optical parameters for OLT 1/0/1.
<Sysname> display epon optics-parameters interface olt 1/0/1
Optical parameters:
Temperature :37.50 °C
Voltage :3.27 V
Bias :1.74 mA
Transmitter power :4.36 dBm
Table 4 Output description
Bias |
Bias current. For OLT ports on 10G-EPON cards, this field becomes Bias(1G/10G) and displays the bias currents for both 1G-EPON interfaces and 10G-EPON interfaces, for example, 24.36 mA/80.72 mA. |
Transmitter power |
Transmit power. For OLT ports on 10G-EPON cards, this field becomes Transmitter power(1G/10G) and displays the transmit powers for both 1G-EPON interfaces and 10G-EPON interfaces, for example, 4.48 dBm/3.44 dBm. |
display epon parameter
Use display epon parameter to display EPON system parameters.
In standalone mode:
display epon parameter slot slot-number
In IRF mode:
display epon parameter chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
# Display EPON system parameters for the specified slot.
<Sysname> display epon parameter slot 1
Parameters:
OUI: 111111 OAM version:3.0
OUI: 111111 OAM version:2.1
OUI: 111111 OAM version:2.0
OUI: 111111 OAM version:1.3
OUI: 111111 OAM version:1(default)
Key update timer : 10 seconds
OAM discovery timeout timer : 3.0 seconds
display epon statistics
Use display epon statistics to display packet error rates on an ONU port.
display epon statistics interface interface-type interface-number
You can view packet error rates of an ONU port only when the port is up.
This command displays the average error rates for the last sampling interval. An error rate value less than 1e-9 is displayed as 0.
# Display packet error rates on ONU 1/0/1:1.
<Sysname> display epon statistics interface onu 1/0/1:1
ONU statistics:
Bit error rate(in 1e-9 unit) : 0
Frame error rate(in 1e-9 unit): 0
display epon version
Use display epon version to display version information for an OLT or ONU port.
display epon version interface interface-type interface-number
interface-type: Specifies an interface type. The value of this argument must be olt or onu.
You can view version information for an OLT or ONU port only when the port is up.
# Display version information for OLT 1/0/1.
<Sysname> display epon version interface olt 1/0/1
OLT version information:
Firmware major version: 0
Firmware minor version: 3
Hardware major version: 1
Hardware minor version: 1
Supported LLIDs : 63
# Display version information for ONU 1/0/1:1.
<Sysname> display epon version interface onu 1/0/1:1
ONU version information:
Hardware major version: A
Hardware minor version: 0
Supported LLIDs : 1
MAC type of UNI port : MII
CTC version : 2.1
display epon workmode
Use display epon workmode to display the operation mode of an OLT or ONU port.
display epon workmode interface interface-type interface-number
If you specify an OLT port, this command also displays the port's MAC address and DBA algorithm.
You can view the operation mode of an ONU port only when the port has been bound to an ONU.
# Display the operation mode of OLT 1/0/1.
<Sysname> display epon workmode interface olt 1/0/1
Port status: Open
MAC address: 000f-e2a1-1027
DBA mode : Internal
# Display the operation mode of ONU 1/0/1:1.
<Sysname> display epon workmode interface onu 1/0/1:1
Port status: Open
FEC mode : Disabled
Table 5 Command output
Port status |
Port status: · Open. · Closed. · Resetting—The chip is resetting. This value is available for OLT ports. · Pending—The ONU has been registered but fails the authentication. This value is available for ONU ports. · Unknown. |
MAC address |
MAC address of the OLT port. All OLT ports on a device use the same MAC address. |
DBA mode |
DBA algorithm of the OLT port: · Internal—Internal DBA algorithm. · External—External DBA algorithm. |
display interface
Use display interface to display OLT or ONU port information.
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
interface-type: Specifies a port type, which can be olt or onu. If you do not specify an interface type, this command displays information about all interfaces.
interface-number: Specifies an OLT or ONU port number. If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
When you display detailed information about an OLT port on a 10G-EPON card, the following rules apply:
· The Input/Output fields display packet statistics of 1G-EPON interfaces of the OLT port.
· The 10G-EPON Input/Output fields display packet statistics of 10G-EPON interfaces of the OLT port.
# Display information about OLT 1/0/1.
<Sysname> display interface Olt 1/0/1
Olt1/0/1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-511e
Description: Olt1/0/1 Interface
Maximum frame length: 1500
Port hardware type is 1000_BASE_PX_SFP
Flow-control is not enabled
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
Port link-type: Hybrid
Tagged VLANs: None
Untagged VLANs: 1(default vlan)
Current system time:2019-01-05 05:12:35
Last time when physical state changed to up:-
Last time when physical state changed to down:2019-01-04 00:54:04
Last 300 second input: - packets/sec - bytes/sec -%
Last 300 second output: - packets/sec - bytes/sec -%
Input (total): 0 packets, 0 bytes
- unicasts, - broadcasts, - multicasts, 0 pauses
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, - throttles
0 CRC, - frame, - overruns, - aborts
- ignored, - parity errors
Output (total): 100000 packets, 12800000 bytes
Output (normal): 100000 packets, 12800000 bytes
- aborts, - deferred, - collisions, - late collisions
- lost carrier, - no carrier
10G-EPON input (normal): 100000 packets, 12893588 bytes
10G-EPON input: 0 input errors, 0 runts, 0 giants, 0 CRC
10G-EPON output (normal): 100000 packets, 12845974 bytes
10G-EPON output: 0 output errors
# Display detailed information about ONU 1/0/1:1.
<Sysname> display interface Onu 1/0/1:1
Onu1/0/1:1
Current state: DOWN
Description: Onu1/0/1:1 Interface
Loopback is not set
Port hardware type is 1000M_SFF_NO_CONNECTOR
PVID: 1
Port link-type: Access
Tagged VLANs: None
Untagged VLANs: 1
- unicasts, 0 broadcasts, - multicasts, - pauses
Input (normal): - packets, - bytes
- unicasts, - broadcasts, - multicasts, - pauses
Input: 0 input errors, - runts, 0 giants, - throttles
0 CRC, 0 frame, - overruns, - aborts
Output (normal): - packets, - bytes
Output: - output errors, - underruns, 0 buffer failures
# Display brief information about all OLT ports.
<Sysname> display interface Olt brief
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
Olt1/0/1 UP -- -- H 1
Olt1/0/2 DOWN -- -- H 1
Table 6 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the interface. |
Maximum frame length |
Maximum length of Ethernet frames allowed to pass through the interface. |
Flow-control is not enabled |
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result. |
Broadcast max- |
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration. |
Multicast max- |
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration. |
Unicast max- |
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration. |
PVID |
Port VLAN ID (PVID) of the interface. |
Port link-type |
Link type of the interface: · access. · trunk. · hybrid. |
Tagged VLANs |
VLANs for which the interface sends packets without removing VLAN tags. |
Untagged VLANs |
VLANs for which the interface sends packets after removing VLAN tags. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Current system time |
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. |
Last time when physical state changed to up |
Last time when the physical state of the interface changed to up. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. A hyphen (-) indicates that the physical state of the interface has never changed. |
Last time when physical state changed to down |
Last time when the physical state of the interface changed to down. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. A hyphen (-) indicates that the physical state of the interface has never changed. |
Last 300 second input: - packets/sec - bytes/sec -% Last 300 second output: - packets/sec - bytes/sec -% |
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth. A hyphen (-) indicates that the statistical item is not supported. |
Input (total): 0 packets, 0 bytes - unicasts, 0 broadcasts, - multicasts, - pauses |
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of inbound unicast packets. · Number of inbound broadcasts. · Number of inbound multicasts. · Number of inbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of inbound normal unicast packets. · Number of inbound normal broadcasts. · Number of inbound normal multicasts. · Number of inbound normal pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Input |
Statistics of inbound abnormal packets. |
input errors |
Number of inbound errors packets. |
Runts |
Number of inbound runts. |
Giants |
Number of inbound giants. |
throttles |
Number of inbound frames that had a non-integer number of bytes. |
CRC |
Number of inbound frames that had a normal length, but contained CRC errors. |
frame |
Number of inbound frames that contained CRC errors and a non-integer number of bytes. |
overruns |
Number of packets dropped because the input rate of the port exceeded the queuing capability. |
aborts |
Total number of illegal inbound packets: · Fragment frames—CRC error frames shorter than 64 bytes. · Jabber frames—CRC error frames greater than the maximum frame length supported on the interface. · Symbol error frames—Frames that contained a minimum of one undefined symbol. |
ignored |
Number of inbound frames dropped because the receiving buffer of the port ran low. |
parity errors |
Number of frames with parity errors. |
Output(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of outbound unicast packets. · Number of outbound broadcasts. · Number of outbound multicasts. · Number of outbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Output(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of outbound normal unicast packets. · Number of outbound normal broadcasts. · Number of outbound normal multicasts. · Number of outbound normal pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Output |
Statistics of outbound abnormal packets. |
output errors |
Number of outbound packets with errors. |
underruns |
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. |
buffer failures |
Number of packets dropped because the transmitting buffer of the interface ran low. |
aborts |
Number of packets that failed to be transmitted, for example, because of collisions. |
deferred |
Number of frames that the interface deferred to transmit because of detected collisions. |
collisions |
Number of frames that the interface stopped transmitting because collisions were detected during transmission. |
late collisions |
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions. |
lost carrier |
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces. |
no carrier |
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces. |
10G-EPON input (normal): 100000 packets, 12893588 bytes - unicasts, - broadcasts, - multicasts, 0 pauses |
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the 10G-EPON interface. All inbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of inbound unicast packets. · Number of inbound broadcasts. · Number of inbound multicasts. · Number of inbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
10G-EPON input: 0 input errors, 0 runts, 0 giants, 0 CRC |
Statistics of inbound abnormal packets for the 10G-EPON interface, including: · input errors—Number of inbound errors packets. · runts—Number of inbound runts. · giants—Number of inbound giants. · CRC—Number of inbound frames that had a normal length, but contained CRC errors. |
10G-EPON output (normal): 100000 packets, 12845974 bytes - unicasts, - broadcasts, - multicasts, 0 pauses |
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the 10G-EPON interface. All outbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of inbound unicast packets. · Number of inbound broadcasts. · Number of inbound multicasts. · Number of inbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
10G-EPON output: 0 output errors |
Number of outbound packets with errors for the 10G-EPON interface. |
Brief information on interfaces in bridge mode: |
Brief information about Layer 2 interfaces. |
Interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Speed |
Speed of the interface, in bps. |
Duplex |
Duplex mode of the interface. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
PVID |
Port VLAN ID. |
encryption update-time
Use encryption update-time to set the LLID key update interval.
Use undo encryption update-time to restore the default.
In standalone mode:
encryption slot slot-number update-time update-time
undo encryption slot slot-number update-time
In IRF mode:
encryption chassis chassis-number slot slot-number update-time update-time
undo encryption chassis chassis-number slot slot-number update-time
The LLID key update interval is 10 seconds.
FTTH view
update-time update-time: Specifies the LLID key update interval in the range of 1 to 255 seconds.
# Set the LLID key update interval to 100 seconds for the specified slot.
[Sysname] ftth
[Sysname-ftth] encryption slot 1 update-time 100
fiber-backup group
Use fiber-backup group to create a fiber backup group, or enter the view of an existing fiber backup group.
Use undo fiber-backup group to delete a fiber backup group.
fiber-backup group group-number
undo fiber-backup group group-number
No fiber backup groups exist.
FTTH view
# Create fiber backup group 1 and enter its view.
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
member
port fiber-backup group
ftth
Use ftth to enter FTTH view.
ftth
# Enter FTTH view.
[Sysname] ftth
[Sysname-ftth]
grant-filtering enable
Use grant-filtering enable to enable grant filtering on an OLT port.
Use undo grant-filtering enable to disable grant filtering on an OLT port.
Grant filtering is enabled on an OLT port.
OLT port view
# Enable grant filtering on OLT 1/0/1.
[Sysname-Olt1/0/1] grant-filtering enable
interface
Use interface to enter OLT port or ONU port view.
# Enter the view of OLT 1/0/1.
[Sysname-Olt1/0/1]
# Enter the view of ONU 1/0/1:1.
max-rtt
Use max-rtt to set the maximum ONU-OLT RTT.
Use undo max-rtt to restore the default.
max-rtt max-rtt-value
undo max-rtt
The maximum ONU-OLT RTT is 15000 TQ.
OLT port view
max-rtt-value: Specifies an RTT in the range of 2000 to 32000 TQ. 1 TQ is equal to 16 ns.
# Set the maximum ONU-OLT RTT to 25000 TQ on OLT 1/0/1.
[Sysname-Olt1/0/1] max-rtt 25000
member
Use member to assign an OLT port to a fiber backup group.
Use undo member to remove an OLT port from a fiber backup group.
member olt interface-number
undo member olt interface-number
A fiber backup group does not contain any OLT ports.
Fiber backup group view
olt interface-number: Specifies an OLT port by its number.
A fiber backup group contains a maximum of two OLT ports. An OLT port can be assigned to only one fiber backup group. The OLT port assigned first acts as the master port, and the other OLT port acts as the subordinate port. Only the master OLT port forwards traffic.
To assign an OLT port to a fiber backup group in OLT port view, use the port fiber-backup group command.
# Assign OLT 1/0/1 to fiber backup group 1.
[Sysname] ftth
[Sysname-fiber-group1] member olt 1/0/1
fiber-backup group
monitor enable
Use monitor enable to enable alarm monitoring.
Use undo monitor enable to disable alarm monitoring.
monitor enable
undo monitor enable
Alarm monitoring is enabled.
FTTH view
# Enable alarm monitoring.
[Sysname] ftth
[Sysname-ftth] monitor enable
timer monitor
Use multicast call-detail-record cache-limit to set the upper limit for the Call Detail Record (CDR) buffer.
Use undo multicast call-detail-record cache-limit to restore the default.
multicast call-detail-record cache-limit number
The CDR buffer can save a maximum of 32 records.
FTTH view
number: Specifies an upper limit in the range of 16 to 1024.
If the CDR buffer upper limit is reached, the OLT automatically sends the CDR records to the information center module and clears the CDR buffer.
# Set the upper limit of the CDR buffer to 16.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record cache-limit 16
Use multicast call-detail-record enable to enable CDR.
Use undo multicast call-detail-record enable to disable CDR.
CDR is disabled.
FTTH view
CDR takes effect only on ONUs in multicast control mode.
# Enable CDR.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record enable
multicast mode
Use multicast call-detail-record record-delay to set the CDR generation delay.
Use undo multicast call-detail-record record-delay to restore the default.
multicast call-detail-record record-delay delay-time
The CDR generation delay is 30 seconds.
FTTH view
delay-time: Specifies a delay time in the range of 10 to 600 seconds.
After CDR is enabled, the OLT periodically checks the online duration of users. If the online duration of a user is longer than the CDR generation delay, the OLT generates a CDR record and saves it to the CDR buffer.
# Set the CDR generation delay to 20 seconds.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record record-delay 20
Use multicast call-detail-record report-interval to set the CDR sending interval.
Use undo multicast call-detail-record report-interval to restore the default.
multicast call-detail-record report-interval interval
The CDR sending interval is 30 seconds.
FTTH view
interval: Specifies an interval in the range of 30 to 600 seconds.
The OLT sends CDR records to the information center module and clears the CDR buffer at the CDR sending interval.
# Set the CDR sending interval to 40 seconds.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record report-interval 40
Use multicast call-detail-record send to manually send CDR records.
FTTH view
This command allows you to manually send CDR records to the information center module and clears the CDR buffer. You can set CDR record output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
# Manually send CDR records.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record send
oam-discovery-timeout
Use oam-discovery-timeout to set the timeout timer for extended OAM discovery.
Use undo oam-discovery-timeout to restore the default.
In standalone mode:
oam-discovery-timeout slot slot-number value value
undo oam-discovery-timeout slot slot-number value
In IRF mode:
oam-discovery-timeout chassis chassis-number slot slot-number value value
undo oam-discovery-timeout chassis chassis-number slot slot-number value
The timeout timer for extended OAM discovery is 3 seconds.
FTTH view
value value: Specifies a timeout period in the range of 30 to 2550. The unit of the value argument is 100 milliseconds.
The timeout timer for extended OAM discovery determines the timeout period for extended OAM messages during extended OAM discovery.
As a best practice, use the default setting for this timer. Increase this timer on the slot that hosts an OLT port if an ONU connected to the OLT and bound to an ONU port remains down.
# Set the timeout timer for extended OAM discovery to 10 seconds for the specified slot.
[Sysname] ftth
[Sysname-ftth] oam-discovery-timeout slot 1 value 100
olt-mode
Use olt-mode to set the OLT operating mode.
Use undo olt-mode to restore the default.
In standalone mode:
olt-mode slot slot-number { 64-onu | 128-onu }
undo olt-mode slot slot-number
In IRF mode:
olt-mode chassis chassis-number slot slot-number { 64-onu | 128-onu }
undo olt-mode chassis chassis-number slot slot-number
The OLT operating mode is 64-ONU.
FTTH view
64-onu: Specifies the 64-ONU mode. In this mode, up to 64 ONU ports can be created on an OLT port in the specified slot.
128-onu: Specifies the 128-ONU mode. In this mode, up to 128 ONU ports can be created on an OLT port in the specified slot.
Only 10G-EPON cards support this command.
After you change the OLT operating mode for a slot, you must reboot the slot or the whole device to make the OLT operating mode change take effect.
· If the slot is rebooted, all OLT ports in the slot are restored to the default settings, and the ONU ports created on the OLT ports are deleted.
· If the whole device is rebooted and the running configuration is saved, ONU ports numbered from 1 to 64 and OLT ports are not affected. When the OLT operating mode is changed from 128-ONU to 64-ONU, ONU ports numbered more than 64 are deleted.
# Set the OLT operating for slot 1 to 128-ONU.
[Sysname] ftth
[Sysname-ftth] olt-mode slot 1 128-onu
using onu
onu invalid-address mode
Use onu invalid-address mode to set the processing mode for frames with an invalid source MAC address.
Use undo onu invalid-address mode to restore the default.
onu invalid-address mode { abandon | broadcast | unicast }
The abandon mode is enabled for frames with an invalid source MAC address.
FTTH view
abandon: Specifies the abandon mode. In this mode, the OLT drops frames with an invalid source MAC address.
broadcast: Specifies the broadcast mode. In this mode, the OLT forwards frames sourced from an invalid MAC address without learning the source MAC address. When the OLT receives a frame with an invalid destination MAC address, it floods the frame to all interfaces in the frame's VLAN except for the incoming interface.
unicast: Specifies the unicast mode. In this mode, the OLT forwards frames sourced from an invalid MAC address and generates a unicast MAC address entry for the invalid MAC address. The OLT uses the entry for forwarding frames destined for the invalid MAC address.
An invalid MAC address is a MAC address whose seventh bit of the first byte is 1, for example, 02-10-94-00-00-02 (the first byte is 00000010).
The processing mode for frames with an invalid source MAC address does not take effect on the following interfaces:
· OLT ports on 10G-EPON cards.
· GE interfaces that are changed from EPON fiber interfaces.
For more information about changing the type of a fiber interface, see the port-type command.
# Set the processing mode to broadcast for frames with an invalid source MAC address.
[Sysname] ftth
[Sysname-ftth] onu invalid-address mode broadcast
onu snmp port-limit
Use onu snmp port-limit to set the maximum number of ONU E1/UNI/VoIP ports that can be queried by SNMP.
Use undo onu snmp port-limit to restore the default.
onu snmp port-limit { e1 e1-count | uni uni-count | voip voip-count }*
The maximum number of UNI ports that can be queried by SNMP is 4.
The maximum number of E1/VoIP ports that can be queried by SNMP is 0.
FTTH view
e1 e1-count: Specifies the maximum number of ONU E1 ports in the range of 0 to 16.
uni uni-count: Specifies the maximum number of ONU UNI ports in the range of 1 to 79.
voip voip-count: Specifies the maximum number of ONU VoIP ports in the range of 0 to 64.
By decreasing the maximum number of ONU E1/UNI/VoIP ports that can be queried by SNMP, you can reduce the resource consumption of the device.
This command is only for administrators. As a best practice, do not use this feature as a common user.
This command applies to all ONU ports of all OLT ports, and takes effect only on offline ONU ports of ONUs.
# Set the maximum number of ONU UNI ports that can be queried by SNMP to 63.
[Sysname] ftth
[Sysname-ftth] onu snmp port-limit uni 63
Use port fiber-backup group to assign an OLT port to a fiber backup group.
Use undo port fiber-backup group to restore the default.
port fiber-backup group group-number
An OLT port is not assigned to a fiber backup group.
OLT port view
group-number: Specifies a fiber backup group number in the range of 1 to 80. The fiber backup group must already exist.
To assign an OLT port to a fiber backup group in fiber backup group view, use the member command.
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname-Olt1/0/1] port fiber-backup group 1
fiber-backup group
member
port switch-over
Use port switch-over to perform a master/subordinate switchover for a fiber backup group.
port switch-over
For successful command execution, use this command when the subordinate OLT port is in Ready state.
# Perform a master/subordinate switchover for fiber backup group 1.
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
port-type
Use port-type to change the type of a fiber interface.
Use undo port-type to cancel the type change of a fiber interface.
In OLT port view:
port-type gigabitethernet
undo port-type gigabitethernet
In Layer 2 or Layer 3 GigabitEthernet interface view:
port-type olt
undo port-type olt
The type of a fiber interface is OLT.
Layer 2/Layer 3 GigabitEthernet interface view
OLT port view
gigabitethernet: Changes the OLT port to a GigabitEthernet interface. By default, the GigabitEthernet interface is in Layer 2 mode.
olt: Changes the GigabitEthernet interface to an OLT port.
This command is supported only by ports on the LSQM1PT24TSSC0 interface cards.
The fiber interfaces are grouped by port number in order, starting from 1. Each group contains four interfaces. To change the type of an interface in a group, you must change the type of all the four interfaces in the group. For the interface type change to take effect, reboot the interface card.
If you change the type of an interface, the system automatically removes the original interface and then creates the target interface with the same number as the original interface.
# Change GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to OLT ports.
[Sysname] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[Sysname-if-range] port-type olt
timer monitor
Use timer monitor to set the alarm monitoring interval.
Use undo timer monitor to restore the default.
timer monitor seconds
undo timer monitor
The alarm monitoring interval is 80 seconds.
FTTH view
seconds: Specifies an interval in the range of 1 to 3600 seconds.
# Set the alarm monitoring interval to 100 seconds.
[Sysname] ftth
[Sysname-ftth] timer monitor 100
monitor enable
vendor-compatible
Use vendor-compatible to enable compatibility with third-party ONUs.
Use undo vendor-compatible to disable compatibility with third-party ONUs.
In standalone mode:
vendor-compatible slot slot-number
undo vendor-compatible slot slot-number
In IRF mode:
vendor-compatible chassis chassis-number slot slot-number
undo vendor-compatible chassis chassis-number slot slot-number
Compatibility with third-party ONUs is enabled.
FTTH view
To allow non-H3C ONUs to register with an OLT, enable compatibility with third-party ONUs. If this feature is disabled, only H3C ONUs can register with the OLT.
If you bind a non-H3C ONU to an ONU port before this feature is enabled, the non-H3C ONU cannot register with the OLT even if you enable this feature. For successful registration, you must perform one of the following tasks:
· Use the deregister onu command to deregister the ONU.
· Use the shutdown command to shut down the ONU port and then use the undo shutdown command to bring it up.
# Disable compatibility with third-party ONUs on the specified slot.
[Sysname] ftth
[Sysname-ftth] undo vendor-compatible slot 1
NOTE: Support for ONU remote management commands depends on the ONU model. |
alarm enable
Use alarm enable to enable ONU alarms.
Use undo alarm enable to disable ONU alarms.
alarm enable { onu onu-alarm | pon pon-alarm | uni uni-alarm } [ protocol { auto | ctc2.1 | ctc3.0 } ] [ threshold trigger-value clear-value ]
undo alarm enable { onu onu-alarm | pon pon-alarm | uni uni-alarm }
Only the eth-port-loopback alarm is enabled for an ONU.
ONU port view
onu-alarm: Specifies an ONU device alarm. Table 7 shows available ONU device alarms and alarm threshold value ranges.
pon-alarm: Specifies a PON port alarm. Table 8 shows available PON port alarms and alarm threshold value ranges.
uni-alarm: Specifies a UNI alarm. Table 9 shows available UNI alarms and alarm threshold value ranges.
protocol: Specifies a CTC protocol version. If you do not specify a CTC protocol version, the ONU automatically negotiates the CTC protocol version.
auto: Automatically negotiates the CTC protocol version.
ctc2.1: Uses CTC v2.1.
ctc3.0: Uses CTC v3.0 or later.
threshold trigger-value clear-value: Sets the thresholds for the alarm. The trigger-value argument specifies the alarm triggering threshold. The clear-value argument specifies the alarm clearing threshold. The value ranges for the trigger-value and clear-value arguments are shown in Table 7, Table 8, and Table 9. When you set the thresholds, follow these restrictions and guidelines:
· If an alarm does not support threshold configuration, the threshold value range for the alarm is N/A. If an alarm supports thresholds, you must set the thresholds.
· If the input threshold exceeds the number of decimal places supported by the value range, the exceeding decimal places are ignored. For example, if the value can only be an integer and you input 5.9, the actual value that takes effect is 5.
You can specify only one CTC protocol version on an ONU port.
Figure 1 shows the relationships between the triggering threshold trigger-value and clearing threshold clear-value of an alarm.
· For a lower limit alarm, for example, temp-low-alarm, the clearing threshold must be higher than or equal to the triggering threshold. For an upper limit alarm, for example, temp-high-alarm, the triggering threshold must be higher than or equal to the clearing threshold.
· For a pair of upper limit alarm and lower limit alarm, for example, rx-power-high-alarm and rx-power-low-alarm, the following requirements must be met:
? The clearing threshold of the upper limit alarm must be higher than or equal to the triggering threshold of the lower limit alarm.
? The triggering threshold of the upper limit alarm must be higher than or equal to the clearing threshold of the lower limit alarm.
Figure 1 Relationships between the triggering thresholds and clearing thresholds
Table 7, Table 8, and Table 9 list the alarms supported by the device.
Alarm |
Explanation |
Threshold value range |
battery-failure |
The battery cannot be charged. |
N/A |
battery-missing |
The battery is absent. |
N/A |
battery-volt-low |
The battery voltage is low. |
0 to 6.55 V |
equipment-alarm |
An internal interface failure occurs. |
N/A |
iad-connection-failure |
Failure of the connection between the internal IAD and the SS platform occurs. |
N/A |
onu-self-test-failure |
The ONU fails the self-test. |
N/A |
onu-temp-high-alarm |
The internal temperature of the ONU reaches the high-temperature alarm threshold. |
-127 to 127°C |
onu-temp-low-alarm |
The internal temperature of the ONU falls below the low-temperature alarm threshold. |
-127 to 127°C |
physical-intrusion-alarm |
The ONU is intruded. |
N/A |
ponif-switch |
The ONU reports a link failure to the main OLT PON port. |
N/A |
power-alarm |
The power supply is abnormal. |
N/A |
sleep-status-update |
The ONU exits sleep mode and starts operating. |
N/A |
Alarm |
Explanation |
downstream-crc-error-frames-alarm |
The number of downstream CRC error frames exceeds the alarm threshold. |
0 to 4294967295 |
downstream-crc-error-frames-warning |
The number of downstream CRC error frames exceeds the warning threshold. |
0 to 4294967295 |
downstream-discards-alarm |
The number of discarded downstream frames exceeds the alarm threshold. |
0 to 4294967295 |
downstream-discards-warning |
The number of discarded downstream frames exceeds the warning threshold. |
0 to 4294967295 |
downstream-drop-events-alarm |
The number of downstream frame loss events exceeds the alarm threshold. |
0 to 4294967295 |
downstream-drop-events-warning |
The number of downstream frame loss events exceeds the warning threshold. |
0 to 4294967295 |
downstream-errors-alarm |
The number of downstream error frames exceeds the alarm threshold. |
0 to 4294967295 |
downstream-errors-warning |
The number of downstream error frames exceeds the warning threshold. |
0 to 4294967295 |
downstream-fragments-alarm |
The number of downstream fragments exceeds the alarm threshold. |
0 to 4294967295 |
downstream-fragments-warning |
The number of downstream fragments exceeds the warning threshold. |
0 to 4294967295 |
downstream-jabbers-alarm |
The number of downstream jabber frames exceeds the alarm threshold. |
0 to 4294967295 |
downstream-jabbers-warning |
The number of downstream jabber frames exceeds the warning threshold. |
0 to 4294967295 |
downstream-oversize-frames-alarm |
The number of downstream oversized frames exceeds the alarm threshold. |
0 to 4294967295 |
downstream-oversize-frames-warning |
The number of downstream oversized frames exceeds the warning threshold. |
0 to 4294967295 |
downstream-undersize-frames-alarm |
The number of downstream undersized frames exceeds the alarm threshold. |
0 to 4294967295 |
downstream-undersize-frames-warning |
The number of downstream undersized frames exceeds the warning threshold. |
0 to 4294967295 |
rx-power-high-alarm |
The receive power exceeds the high-power alarm threshold. |
-40.00 to 8.10 dBm |
rx-power-high-warning |
The receive power exceeds the high-power warning threshold. |
rx-power-low-alarm |
The receive power falls below the low-power alarm threshold. |
rx-power-low-warning |
The receive power falls below the low-power warning threshold. |
temp-high-alarm |
The internal temperature exceeds the high-temperature alarm threshold. |
-127 to 127°C |
temp-high-warning |
The internal temperature exceeds the high-temperature warning threshold. |
-127 to 127°C |
temp-low-alarm |
The internal temperature falls below the low-temperature alarm threshold. |
-127 to 127°C |
temp-low-warning |
The internal temperature falls below the low-temperature warning threshold. |
-127 to 127°C |
tx-bias-high-alarm |
The bias current exceeds the high-current alarm threshold. |
0 to 131 mA |
tx-bias-high-warning |
The bias current exceeds the high-current warning threshold. |
0 to 131 mA |
tx-bias-low-alarm |
The bias current falls below the low-current alarm threshold. |
0 to 131 mA |
tx-bias-low-warning |
The bias current falls below the low-current warning threshold. |
0 to 131 mA |
tx-power-high-alarm |
The transmit power exceeds the high-power alarm threshold. |
tx-power-high-warning |
The transmit power exceeds the high-power warning threshold. |
tx-power-low-alarm |
The transmit power falls below the low-power alarm threshold. |
tx-power-low-warning |
The transmit power falls below the low-power warning threshold. |
upstream-crc-error-frames-alarm |
The number of upstream CRC error frames exceeds the alarm threshold. |
0 to 4294967295 |
upstream-crc-error-frames-warning |
The number of upstream CRC error frames exceeds the warning threshold. |
0 to 4294967295 |
upstream-discards-alarm |
The number of discarded upstream frames exceeds the alarm threshold. |
0 to 4294967295 |
upstream-discards-warning |
The number of discarded upstream frames exceeds the warning threshold. |
0 to 4294967295 |
upstream-drop-events-alarm |
The number of upstream frame loss events exceeds the alarm threshold. |
0 to 4294967295 |
upstream-drop-events-warning |
The number of upstream frame loss events exceeds the warning threshold. |
0 to 4294967295 |
upstream-errors-alarm |
The number of upstream error frames exceeds the alarm threshold. |
0 to 4294967295 |
upstream-errors-warning |
The number of upstream error frames exceeds the warning threshold. |
0 to 4294967295 |
upstream-fragments-alarm |
The number of upstream fragments exceeds the alarm threshold. |
0 to 4294967295 |
upstream-fragments-warning |
The number of upstream fragments exceeds the warning threshold. |
0 to 4294967295 |
upstream-jabbers-alarm |
The number of upstream jabber frames exceeds the alarm threshold. |
0 to 4294967295 |
upstream-jabbers-warning |
The number of upstream jabber frames exceeds the warning threshold. |
0 to 4294967295 |
upstream-oversize-frames-alarm |
The number of upstream oversized frames exceeds the alarm threshold. |
0 to 4294967295 |
upstream-oversize-frames-warning |
The number of upstream oversized frames exceeds the warning threshold. |
0 to 4294967295 |
upstream-undersize-frames-alarm |
The number of upstream undersized frames exceeds the alarm threshold. |
0 to 4294967295 |
upstream-undersize-frames-warning |
The number of upstream undersized frames exceeds the warning threshold. |
0 to 4294967295 |
vcc-high-alarm |
The internal voltage exceeds the high-voltage alarm threshold. |
0 to 6.55 V |
vcc-high-warning |
The internal voltage exceeds the high-voltage warning threshold. |
0 to 6.55 V |
vcc-low-alarm |
The internal voltage falls below the low-voltage alarm threshold. |
0 to 6.55 V |
vcc-low-warning |
The internal voltage falls below the low-voltage warning threshold. |
0 to 6.55 V |
Alarm |
Explanation |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
e1-los |
A loss of signal event occurs on an E1 interface. |
N/A |
e1-port-failure |
E1 interface failure occurs. |
N/A |
e1-timing-unlock |
N/A |
N/A |
eth-port-auto-neg-failure |
Autonegotiation fails on an Ethernet port. |
N/A |
eth-port-congestion |
Congestion is detected on an Ethernet port. |
N/A |
eth-port-failure |
An Ethernet port fails. |
N/A |
eth-port-loopback |
A loop is detected on an Ethernet port. |
N/A |
eth-port-los |
A loss of signal event occurs on an Ethernet port. |
N/A |
pots-port-failure |
A POTS port fails. |
N/A |
status-change-times-alarm |
The number of port status changes exceeds the alarm threshold. |
0 to 4294967295 |
status-change-times-warning |
The number of port status changes exceeds the warning threshold. |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
0 to 4294967295 |
# Enable the equipment-alarm alarm and configure the ONU to use CTC v3.0 or later on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] alarm enable onu equipment-alarm protocol ctc3.0
bandwidth-downstream
Use bandwidth-downstream to configure the downlink bandwidth limits on an ONU port.
Use undo bandwidth-downstream to restore the default maximum downlink bandwidth or default maximum downlink burst buffer on an ONU port.
bandwidth-downstream { max-bandwidth bandwidth | max-burstsize burstsize } *
undo bandwidth-downstream { max-bandwidth | max-burstsize } *
The maximum downlink bandwidth is 999994 Kbps (9999940 Kbps for 10G-EPON cards), and the maximum downlink burst buffer is 4194240 bytes on an ONU port.
ONU port view
max-bandwidth bandwidth: Specifies the maximum downlink bandwidth in the range of 0 to 999994 Kbps. For 10G-EPON cards, the value range is 0 to 9999940.
max-burstsize burstsize: Specifies the maximum downlink burst buffer in the range of 0 to 4194240 bytes.
For the downlink bandwidth limits to take effect, you must enable the downlink bandwidth allocation policy. The downlink bandwidth limits take effect only on known unicast packets.
# Set the maximum downlink bandwidth to 888 Kbps and the maximum downlink burst buffer to 999 bytes on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] bandwidth-downstream max-bandwidth 888 max-burstsize 999
bandwidth-downstream policy enable
Use bandwidth-downstream policy enable to enable the downlink bandwidth allocation policy on an ONU port.
Use undo bandwidth-downstream policy enable to disable the downlink bandwidth allocation policy on an ONU port.
The downlink bandwidth allocation policy is disabled on an ONU port.
ONU port view
# Enable the downlink bandwidth allocation policy on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] bandwidth-downstream policy enable
bind onu-id
Use bind onu-id to bind an ONU to an ONU port.
Use undo bind onu-id to unbind an ONU from an ONU port.
bind onu-id { mac-address | loid loid | loid-password loid { cipher | simple } password }
undo bind onu-id
No ONU is bound to an ONU port.
ONU port view
mac-address: Specifies an ONU by its MAC address.
loid: Specifies an ONU by its LOID.
loid-password: Specifies an ONU by its LOID and LOID password.
loid: Specifies an LOID, a case-sensitive string of 1 to 24 characters. The LOID cannot contain question marks (?), or begin or end with any of the following characters:
· Character string DEL.
· One of the following special characters: At sign (@), dot (.), comma (,), exclamation point (!), semi-colon (;), colon (:), back quote (`), and double quotes (").
· A hexadecimal number in the range of 0x0 to 0x20.
simple: Specifies a password in plaintext form.
password: Specifies an LOID password, a case-sensitive string of 1 to 12 characters. The LOID password cannot contain question marks (?), or begin or end with any of the following characters:
The ONU attributes (MAC address, LOID, and LOID password) you use for ONU binding are not restricted by the ONU authentication mode set by using the authentication-mode command.
An ONU goes offline when you use the undo bind onu-id command to unbind it from its ONU port.
If fiber backup is not configured, you can create only one-to-one bindings between ONUs and ONU ports. For a fiber backup group, you can bind an ONU to two ONU ports that are on different member OLT ports.
# Bind the ONU with MAC address 11-22-33 to ONU 1/0/2:1.
[Sysname] interface onu 1/0/2:1
[Sysname-Onu1/0/2:1] bind onu-id 11-22-33
deregister onu
Use deregister onu to deregister an ONU.
deregister onu
ONU port view
After you deregister an ONU, the ONU will be re-registered.
# Deregister the ONU bound to ONU 1/0/1:1.
[Sysname] interface ONU 1/0/1:1
[Sysname-Onu1/0/1:1] deregister onu
display dhcp-client
Use display dhcp-client to display IP address assignment information for an ONU that acts as a DHCP client.
display dhcp-client
ONU port view
# Display IP address assignment information for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] display dhcp-client
DHCP client statistic information :
NOTE: Output of this command varies by ONU model. |
display epon multicast
Use display epon multicast to display multicast information for an ONU port in multicast control mode.
ONU port view
You can view multicast information for an ONU port only when the ONU port is up and in multicast control mode.
# Display multicast information for ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] display epon multicast
Multicast control information:
UNI number 1:
Multicast vlan 10
Current channel list:
Multicast IP: 225.0.0.2
Status: Permit
Multicast vlan 10
Multicast IP: 225.0.0.3
Status: Preview
Preview times: 16
Preview remaining time: 144s
Table 10 Command output
Multicast-control information: None. |
No multicast control entries are generated. The causes are as follows: · Multicast control is not configured. · Multicast clients do not send multicast membership reports. |
Status |
Multicast control policy: · Permit—Users are permitted to access the channel. · Preview—Users can only preview the channel. |
display onu
Use display onu to display ONU information.
In standalone mode:
display onu [ silent [ mac | loid ] ] { interface interface-type interface-number | slot slot-number }
In IRF mode:
display onu [ silent [ mac | loid ] ] { interface interface-type interface-number | chassis chassis-number slot slot-number }
silent: Specifies silent ONUs.
mac: Specifies silent ONUs of the MAC address binding type.
loid: Specifies silent ONUs of the LOID binding type.
interface interface-type interface-number: Specifies an OLT port or ONU port by its number. The value of the interface-type argument must be olt or onu.
If you do not specify the mac or loid keyword when you specify the silent keyword, this command displays silent ONUs of the MAC address binding type.
If you do not specify the silent keyword, this command displays all ONUs.
# Display information about all ONUs on OLT 1/0/1.
<Sysname> display onu interface olt 1/0/1
MAC LOID LLID Dist(M) Port Mode
l/Version Sft/Epm State Aging
3c8c-40cf-07f2 N/A N/A Onu1/0/1:2 N/A
N/A Offline N/A
# Display information about all ONUs on the specified slot.
<Sysname> display onu slot 1
---------------------------------- Olt1/0/1 ---------------------------------
N/A Offline N/A
---------------------------------- Olt1/0/2 ---------------------------------
The port is down.
MAC |
ONU MAC address. |
LOID |
ONU LOID. |
LLID |
LLID assigned to the registered ONU. This field displays N/A if the ONU is not registered. |
Dist(M) |
Actual length (in metres) of the optical fiber between the OLT and the ONU. If the optical fiber is shorter than 1 km, this field displays <1000. If the ONU is not registered, this field displays N/A. |
Port |
Bound ONU port number. This field displays N/A if the ONU is not bound to an ONU port. |
Model/Version |
ONU model and PCB version. This field displays N/A if the ONU is not registered. |
Sft/Epm |
ONU software version and EEPROM version. This field displays N/A if the ONU is not registered. |
State |
ONU state: · Silent—The ONU is powered on, and it is not bound to an ONU port. · Offline—The ONU is powered off, and it is bound to an ONU port. · Up—The ONU is powered on, and it is bound to an ONU port. · Down—The ONU is bound to an ONU port, but the ONU port is manually shut down. |
Aging |
Remaining MAC address aging time of an ONU in silent state. This field displays N/A if the ONU is not in silent state. |
display onu loid
Use display onu loid to display information about a legal ONU by specifying its LOID.
display onu loid loid
# Display information about the legal ONU with LOID test.
<Sysname> display onu loid test
3c8c-40cf-07f2 test 10 1200 Onu1/0/1:2 BT/BV
S/E Up N/A
For information about the parameters in the command output, see Table 11.
display onu mac-address
Use display onu mac-address to display information about a legal ONU by specifying its MAC address.
display onu mac-address mac-address
# Display information about the legal ONU with MAC address 000f-e200-0031.
<Sysname> display onu mac-address 000f-e200-0031
000f-e200-0031 N/A N/A Onu1/0/1:2 N/A
N/A Offline N/A
--- 1 entry found ---
display onu protocol
Use display onu protocol to display information about protocols supported by an ONU.
display onu protocol { dhcp-snooping information | igmp-snooping | loopback-detection | pppoe | smart-link | stp }
ONU port view
dhcp-snooping information: Specifies DHCP snooping Option 82.
igmp-snooping: Specifies IGMP snooping.
loopback-detection: Specifies loop detection.
pppoe: Specifies PPPoE+.
smart-link: Specifies Smart Link.
stp: Specifies RSTP.
# Display IGMP snooping information for the ONU bound to ONU 1/0/1:1.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] display onu protocol igmp-snooping
Protocol name: IGMP snooping
Protocol status: Enabled
Total 4 Multicast groups.
Group: 0100-5e01-0140
Port : 9
Group: 0100-5e01-013f
Port : 9
Group: 0100-5e01-013e
Port : 9
Group: 0100-5e01-013d
Port : 9
# Display loop detection information for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] display onu protocol loopback-detection
Protocol name: Loopback detection
Loopback action: Semi-block
Loopback is detected on following interfaces:UNI 1 UNI 4
Table 12 Command output
Protocol status |
Protocol status: · Enabled. · Disabled. · Failed to get. |
Group |
Multicast MAC address. |
Port |
UNI number. |
Loopback action |
Loop protection action: · Semi-block—If a loop is detected on a UNI, the system disables MAC learning on the UNI and blocks the inbound direction of the UNI. · No-learning—If a loop is detected on a UNI, the system disables MAC learning on the UNI. · Shutdown—If a loop is detected on a UNI, the system shuts down the UNI. · No shutdown—If a loop is detected on a UNI, the system does not shut down the UNI. · Failed to get—Failed to get the loop protection action. |
Loopback is detected on following interfaces |
UNIs where loops were detected. |
display onu protocol smart-link uni-bind information
Use display onu protocol smart-link uni-bind information to display information about UNI count-based PON port activation for an ONU.
ONU port view
# Display information about UNI count-based PON port activation for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] display onu protocol smart-link uni-bind information
Protocol name: smart-link uni-bind
onu protocol smart-link uni-bind enable
display onu protocol transparent-multicast
Use display onu protocol transparent-multicast to display unknown multicast packet transparent transmission configuration.
ONU port view
# Display unknown multicast packet transparent transmission configuration.
[Sysname-Onu1/0/1:1] display onu protocol transparent-multicast
Multicast Mac Address VLAN ID
0100-5e00-0001 1000
Table 13 Command output
Multicast Mac Address |
Multicast MAC address enabled with unknown multicast packet transparent transmission. |
VLAN ID |
VLAN ID corresponding to the multicast MAC address. |
display serial-information
Use display serial-information to display information about a serial interface on an ONU.
display serial-information interface-number
ONU port view
interface-number: Specifies a serial interface by its number in the range of 1 to 10.
# Display information about serial interface 1.
[Sysname-Onu1/0/1:1] display serial-information 1
Description: Serial 1 interface
Parameters:
Baud:9600
Databits:8
Parity:none
Stopbits:1
Statistics:
Input total: 0 bytes, Error 0 bytes
Output total: 0 bytes, Error 0 bytes
display uni
Use display uni to display information about a UNI on an ONU.
display uni uni-number
ONU port view
uni-number: Specifies a UNI by its number in the range of 1 to 79.
# Display information about UNI 1.
[Sysname-Onu1/0/1:1] display uni 1
UNI 1
Configuration :
Port status : Undo shutdown
Flow control : Closed
Autonegotiation state: Enable
Port isolation : Disable
MDI type : Automdix
Port policy :
Inbound :
CIR : 0
Bucket depth : 0
Extra burst size : 0
Outbound :
CIR : 0
PIR : 0
Vlan configuration :
VLAN mode : Transparent
Classification & marking :
Multicast VLAN : None
Multicast groups : 64
Multicast VLAN untagging : Disable
Multicast VLAN forwarding info:
Multicast VLAN forwarding index:0
VLAN ID:100
Multicast MAC address:0100-5e00-0002
Current Status :
Link state : DOWN
Local autonegotiation ability :
1000BASE-T UTP PHY
Full duplex 1000BASE-T UTP PHY
100BASE-TX
Full duplex 100BASE-TX
Full duplex 10BASE-T
10BASE-T
Symmetric PAUSE operation for full duplex links
Asymmetric PAUSE operation for full duplex links
Autonegotiation advertisement ability :
1000BASE-T UTP PHY
100BASE-TX
10BASE-T
100Mbps-speed mode, Full-duplex mode
Link speed type is autonegotiation, Link duplex type is autonegotiation
Input(total): 0 packets, 0 bytes
0 broadcasts, 0 multicasts, 0 unicasts, 0 pauses
Input: 0 input errors, 0 runts, 0 giants, 0 InRxErr, 0 CRC
0 buffer failures
Output: 0 output errors, 0 deferred, 0 collisions, 0 InTxErr
Table 14 Command output
Port status |
Port status: · Shutdown—The port has been shut down by using the uni shutdown command. · Undo shutdown—The port is administratively up. |
MDI type |
MDIX mode: · Automdix. · Mdi. · Mdix. |
Port policy |
Traffic policing parameters: · Inbound—Uplink traffic policing parameters, including CIR, bucket depth, and extra burst size. To configure these parameters, use the uni port-policy inbound command. · Outbound—Downlink traffic policing parameters, including CIR and PIR. To configure these parameters, use the uni port-policy outbound command. |
Vlan configuration |
VLAN operation mode of the UNI: · Transparent—Transparent mode. · Add-vlan-tag—Tag mode. · Translation—Translation mode. · 802.1q-in-802.1q—QinQ mode. · Trunk—Trunk mode. · Aggregation—N:1 aggregation mode. Possible fields of the VLAN operation mode are as follows: · PVID—PVID of the port. · Priority—802.1p priority of packets. · Old VLAN—Original VLAN ID of packets. · New VLAN—Translated VLAN ID of packets. · Trunk VLAN—Permitted VLANs of the port. To configure the VLAN operation mode, use the uni vlan-mode command. |
Multicast VLAN forwarding info |
Unknown multicast packet transparent transmission configuration information of the UNI. |
Multicast VLAN forwarding index |
Index of the unknown multicast packet transparent transmission configuration. |
VLAN ID |
Multicast MAC address |
Multicast MAC address with unknown multicast packet transparent transmission enabled. |
Link state |
Link layer status: · UP. · DOWN. |
Input(total) |
Total input packet statistics (in packets and bytes), and the packet counts for input broadcast packets, multicast packets, unicast packets, and pause frames. |
Input |
Counts for the following frames: · Error frames. · Runt frames. · Giant frames. · Frames having the InRxErr error. · Frames having the CRC error. · Frames dropped because of insufficient buffer. |
Output(total) |
Total output packet statistics (in packets and bytes), and the packet counts for output broadcast packets, multicast packets, unicast packets, and pause frames. |
Output |
Counts for the following frames: · Error frames. · Deferred frames. · Collision frames. · Frames having the InTxErr error. |
uni auto-negotiation
uni classification-marking
uni flow-control
uni mdix-mode
uni multicast vlan
uni multicast-group-number
uni multicast-strip-tag enable
uni port-isolate
uni shutdown
uni transparent-multicast
uni vlan-mode
display uni poe
Use display uni poe to display PoE information of a UNI.
display uni uni-number poe
ONU port view
uni-number: Specifies a UNI by its number in the range of 1 to the number of UNIs on the ONU. The maximum number of UNIs supported on an ONU is 79.
# Display PoE information of UNI 1.
[Sysname-Onu1/0/1:1] display uni 1 poe
Capability : Capable
PoE : Enabled
Legacy PD detection : Disabled
Mode : Signal
Priority : High
Max power class : Default
Max power value(mW) : -
Powered device class : Class4
Power supply status : Delivering power
Signal error count : 0
Power denied count : 0
Power overload count : -
Current overload count : 0
Powered device undetected count : -
Max power(mW) : 30000
Current output power(mW) : 26624
Average output power(mW) : -
Peak output power(mW) : -
Table 15 Command output
Capability |
PoE capability of the UNI: · Capable. · Incapable. |
PoE |
PoE status of the UNI: · Disabled. · Enabled. |
Legacy PD detection |
Nonstandard PD detection status of the UNI: · Disabled. · Enabled. |
Mode |
Power transmission mode of the UNI: · Signal—Power is being supplied over signal cables. · Spare—Power is being supplied over spare cables. |
Priority |
Power supply priority of the UNI: · Critical (highest). · High. · Low. |
Max power class |
Maximum power class of the UNI. Options are Class 0 through 4 and Default. When this field displays Default, the maximum power of the UNI depends on the maximum power class of the PD attached to the UNI. |
Max power value(mW) |
Maximum power that can be supplied by the UNI, in microwatts. The maximum power value and maximum power class cannot be both configured for a UNI. When one parameter is configured for the UNI, the other parameter displays a hyphen (-) in the command output. |
Powered device class |
Power class needed by the PD attached to the UNI. Options are Class 0 through 4 and Undefined. |
Power supply status |
Power supply status of the UNI: · No need to supply power. · Searching. · Delivering power. · Forced power. · Forced power failed. · Power failed. |
Signal error count |
Number of PoE signal errors. |
Power denied count |
Times for which the UNI denies supplying power to the PDs. |
Power overload count |
Number of power overload events. |
Current overload count |
Number of current overload events. |
Powered device undetected count |
Times for which PDs are absent. |
Max power(mW) |
Maximum power that takes effect on the UNI, in microwatts. |
Current output power(mW) |
Current supplied power, in microwatts. |
Average output power(mW) |
Average supplied power, in microwatts. |
Peak output power(mW) |
Peak supplied power, in microwatts. |
display vendor-specific information
Use display vendor-specific information to display detailed information about an ONU.
ONU port view
# Display detailed information about the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] display vendor-specific information
Serial number
Vendor ID : H3C
ONU MAC address : 3c8c-40cf-0f12
ONU model : 254
ONU hardware version : A0
ONU software version : 110
ONU extend model :
Firmware version : 0x1
Chipset information :
Vendor ID : 0x4530
Chip model : 6750
Revision version : 0xa0
Design date : 08/03/27
ONU capability :
Gigabit ethernet interface : Support
Fast ethernet interface : Not support
VoIP service : Not support
TDM ces service : Not support
Gigabit ethernet ports number : 4
Gigabit ethernet ports :
0x1
0x2
0x3
0x4
Fast ethernet ports number : 0
POTS ports number : 0
E1 ports number : 0
Upstream queues number : 8
Maximum queues per port upstream : 8
Downstream queues number : 8
Maximum queues per port downstream : 8
Battery backup : Not support
ONU capability(CTC2.1) :
ONU type : SFU
LLID number : 1
Protection type : Not support
Slot number : 0
PON number : 1
Interface type number : 1
VoIP ports number : 0
GE ports number : 4
FE ports number : 0
WLAN ports number : 0
CATV RF ports number : 0
USB ports number : 0
Forward error correction ability : Support
IGMP-snooping fast-leave : Support
Multicast control fast-leave : Support
Forward error correction mode : Disable
DBA-Report parameters :
Queue sets number : 2
Queue set : 1
Queue 1 : State:1 , Value:0
Queue 2 : State:1 , Value:0
Queue 3 : State:1 , Value:0
Queue 4 : State:1 , Value:65535
Queue 5 : State:1 , Value:65535
Queue 6 : State:0 , Value:0
Queue 7 : State:0 , Value:0
Queue 8 : State:0 , Value:0
Queue set : 2
Multicast-fast-leave : Disable
ONU-Isolate state : Disable
Multicast-mode : IGSP
Table 16 Command output
ONU capability(CTC2.1) |
ONU capability (CTC v2.1): · ONU type—ONU type, including: ? SFU—Single family unit. ? HGU—Home gateway unit. ? SBU—Single business unit. ? MDU—Multi-dwelling unit. ? MTU—Multi-tenant unit. · LLID number—Supported number of LLIDs. · Protection type—Supported link protection type, including type c and type d. · Slot number—Number of slots. · PON number—Supported number of PON ports. · Interface type number—Number of port types. · VoIP ports number—Number of VoIP ports. · GE ports number—Number of GE ports. · FE ports number—Number of FE ports. · WLAN ports number—Number of WLAN ports. · CATV RF ports number—Number of CATV RF ports. · USB ports number—Number of USB ports. |
ONU capability(CTC3.0) |
ONU capability (CTC v3.0): · IPV6 supported—IPv6 awareness capability. · Power supply control—Power supply control, including ONU transmit power supply control and ONU receive power supply control. · Service SLA—Service Level Agreement. |
ONU extend model |
Complete ONU model. This field is required for CTC v3.0. |
DBA-Report parameters |
DBA report message parameters: · Queue sets number—Number of queue sets. · Queue set—Queue set ID. · Queue x: State:x , Value:x—State and threshold (Value) of a queue. The State field displays 0 for a disabled queue and 1 for an enabled queue. |
Multicast-fast-leave |
Whether fast-leave processing is enabled for all UNIs on the ONU. |
ONU-Isolate state |
Whether port isolation is enabled for all UNIs on the ONU. |
encryption enable
Use encryption enable to enable downlink traffic encryption for an ONU.
Use undo encryption enable to disable downlink traffic encryption for an ONU.
encryption enable
Downlink traffic encryption is enabled for an ONU.
ONU port view
# Disable downlink traffic encryption for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] undo encryption enable
forward-error-correction
Use forward-error-correction enable to enable Forward Error Correction (FEC) for an ONU.
Use undo forward-error-correction enable to disable FEC for an ONU.
FEC is disabled on an ONU port.
ONU port view
When 10G/10G-EPON ONUs connected to ONU ports on 10G-EPON cards come online, these ONUs support FEC by default and do not need this configuration. The undo forward-error-correction enable command does not take effect on these ONU ports.
# Enable FEC for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] forward-error-correction enable
ip address
Use ip address to assign an IP address to the management VLAN interface of an ONU.
Use undo ip address to restore the default.
ip address { dhcp-alloc | ip-address { mask-length | mask } gateway gateway }
undo ip address
The management VLAN interface of an H3C ONU uses the IP address 192.168.0.240 and subnet mask 255.255.255.0.
ONU port view
dhcp-alloc: Specifies DHCP IP address allocation.
ip-address: Specifies an IP address in dotted decimal format.
mask-length: Specifies the length of the subnet mask, in the range of 1 to 31. The subnet mask length is the number of consecutive 1s in the subnet mask.
mask: Specifies a subnet mask in dotted decimal format.
gateway: Specifies the gateway IP address.
If the management VLAN of an ONU is changed, the IP address of the original management VLAN interface is deleted.
This command belongs to the IP stack feature instead of EPON. You cannot execute this command if a user role rule is configured to deny access to the IP stack feature, for example, rule 1 deny write feature ipstack. For more information about the rule command, see RBAC commands in Fundamentals Command Reference.
# Assign the IP address 192.168.0.1/24 to the management VLAN interface of the ONU bound to ONU 1/0/1:1, and specify the gateway IP address as 192.168.0.99.
[Sysname-Onu1/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
management-vlan
management-vlan
Use management-vlan to specify the management VLAN of an ONU.
Use undo management-vlan to restore the default.
management-vlan vlan-id
The management VLAN of an ONU is VLAN 1.
ONU port view
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If the management VLAN of an ONU is changed, the IP address of the original management VLAN interface is deleted. You must assign an IP address to the new management VLAN interface.
# Specifies the management VLAN as VLAN 10 for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] management-vlan 10
ip address
shutdown management-vlan-interface
multicast mode
Use multicast mode to set the multicast mode of an ONU.
Use undo multicast mode to restore the default.
multicast mode { igmp-snooping | multicast-control }
undo multicast mode
The multicast mode of an ONU is IGMP snooping.
ONU port view
igmp-snooping: Specifies the IGMP snooping mode.
multicast-control: Specifies the multicast control mode.
# Set the multicast mode to multicast control for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] multicast mode multicast-control
multicast vlan-id ip
Use multicast vlan-id ip to map multicast IP addresses to a multicast VLAN.
Use undo multicast vlan-id ip to restore the default.
multicast vlan-id vlan-id ip ip-address-list
undo multicast vlan-id vlan-id
No multicast IP addresses are mapped to a multicast VLAN.
FTTH view
vlan-id: Specifies a multicast VLAN ID in the range of 1 to 4094.
ip-address-list: Specifies a space-separated list of up to 10 multicast IP address items. Each item specifies a multicast IP address or a range of multicast IP addresses in the format of ip-address1 to ip-address2.
When receiving an IGMP report message, the OLT verifies whether the multicast IP address in the message belongs to a multicast VLAN.
· If the address belongs to a multicast VLAN, the OLT generates a multicast forwarding entry for the multicast VLAN.
· If the address does not belong to a multicast VLAN, the OLT drops the message.
A multicast IP address can be mapped to only one multicast VLAN.
# Map the multicast IP address 225.1.2.1 to multicast VLAN 1002.
[Sysname] ftth
[Sysname-ftth] multicast vlan-id 1002 ip 225.1.2.1
multicast-control host-aging-time
Use multicast-control host-aging-time to set the multicast group member port aging timer for an ONU.
Use undo multicast-control host-aging-time to restore the default.
multicast-control host-aging-time host-aging-time
The multicast group member port aging timer is 260 seconds.
ONU port view
host-aging-time: Set the aging timer in the range of 200 to 1000 seconds.
This command is available only on an ONU in multicast control mode.
# Set the multicast mode to multicast control for the ONU bound to ONU 1/0/1:1. Set the multicast group member port aging timer to 500 seconds for the ONU.
[Sysname-Onu1/0/1:1] multicast-control host-aging-time 500
multicast mode
onu authentication-domain
Use onu authentication-domain command to enable ONU authentication for an OLT port and specify the authentication domain for ONU users on the port. Then, users that access through the OLT port are authenticated by using the specified domain.
Use undo onu authentication-domain to disable ONU authentication for an OLT port and remove the authentication domain configuration for ONU users on the OLT port.
onu authentication-domain domain-name
ONU authentication is disabled for an OLT port.
OLT port view
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. The ISP domain name cannot contain any of the following characters:
The authentication domain defines the authentication scheme for ONU users. For more information about authentication domains, see Security Configuration Guide.
The ONU authentication function takes effect only when the automatic ONU binding function is enabled.
# Enable ONU authentication for OLT 1/0/1, and specify the domain named test for ONU users on the OLT port.
[Sysname] interface Olt 1/0/1
[Sysname-Olt1/0/1] onu authentication-domain test
[Sysname-Olt1/0/1] quit
# Enable automatic ONU binding for the specified slot.
[Sysname] ftth
[Sysname-ftth] onu bind auto slot 1
[Sysname-ftth] quit
authentication onu (Security Command Reference)
onu bind auto
onu bind auto
Use onu bind auto to enable automatic ONU binding.
Use undo onu bind auto to disable automatic ONU binding.
In standalone mode:
onu bind auto [ slot slot-number ] [ bind-type { mac | loid | loid-password } * ]
undo onu bind auto [ slot slot-number ] [ bind-type { mac | loid | loid-password } * ]
In IRF mode:
onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | loid | loid-password } * ]
undo onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | loid | loid-password } * ]
Automatic ONU binding is disabled.
FTTH view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables automatic ONU binding for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command enables automatic ONU binding for all cards in the IRF fabric. (In IRF mode.)
bind-type: Specifies an ONU binding type. If you do not specify a binding type, ONU MAC addresses are used for ONU binding.
mac: Specifies MAC address binding.
loid: Specifies LOID binding.
loid-password: Specifies LOID-password binding.
If an ONU is not bound to any ONU port, the ONU cannot be registered. Such an ONU is called a silent ONU. Automatic ONU binding automatically binds ONU ports to existing silent ONUs and ONUs that join the system after this feature is enabled.
Automatic ONU binding applies to an EPON system where ONUs attached to the OLT are completely trustworthy. To unbind an ONU, first use the undo onu bind auto command to disable automatic ONU binding.
You can execute this command multiple times to add ONU binding types.
If you do not specify an ONU binding type when you execute the undo onu bind auto command, automatic ONU binding is disabled. If you specify ONU binding types when you execute the undo onu bind auto command, automatic ONU binding is disabled for the specified binding types.
If you specify LOID binding or LOID-password binding when you execute the onu bind auto command, an online ONU cannot re-register with the OLT after its LOID or LOID password is modified. For successful registration, you must execute the undo bind onu-id command on the corresponding ONU port to remove the ONU binding.
# Enable automatic ONU binding on the specified slot.
[Sysname] ftth
onu bind batch
Use onu bind batch to perform batch ONU binding.
In standalone mode:
onu bind batch [ slot slot-number ] [ bind-type { mac | loid | loid-password } ]
In IRF mode:
onu bind batch [ chassis chassis-number slot slot-number ] [ bind-type { mac | loid | loid-password } ]
Batch ONU binding is not performed.
FTTH view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables batch ONU binding for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command enables batch ONU binding for all cards in the IRF fabric. (In IRF mode.)
Batch ONU binding automatically binds existing silent ONUs to ONU ports at a time. The ONUs that join the system after batch ONU binding is performed will not be bound.
Batch ONU binding applies to a newly established EPON system that contains only legal ONUs. You can use the bind onu-id command to manually bind new ONUs after batch ONU binding is performed.
# Perform batch ONU binding on the specified slot.
[Sysname] ftth
[Sysname-ftth] onu bind batch slot 1
bind onu-id
onu bind one-to-one
Use onu bind one-to-one to enable ONU binding control for OLT ports.
Use undo onu bind one-to-one to disable ONU binding control for OLT ports.
onu bind one-to-one
ONU binding control is disabled on an OLT port.
FTTH view
OLT port view
This feature allows an ONU to be bound to only one ONU port of an OLT port. With this feature enabled on an OLT port, if an ONU has registered with the OLT port, the ONU cannot register with any other OLT port.
Configured in OLT port view, this feature takes effect only on the OLT port. Configured in FTTH view, this feature takes effect on all OLT ports. You cannot configure this feature in both OLT port view and FTTH view.
Enabling this feature does not affect ONUs registered with different OLT ports.
For a fiber backup group to operate properly, do not assign an OLT port with this feature enabled to a fiber backup group. The fiber backup feature requires an ONU to be simultaneously bound to two ONU ports on two OLT ports that back up each other.
When you roll back the configuration by using a configuration file with the onu bind one-to-one command and ONU ports on different OLT ports are bound to the same ONU by using the bind onu-id command, the bind onu-id command configuration is kept for only an ONU port on one OLT port after configuration rollback.
# Enable ONU binding control on OLT 1/0/1.
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] onu bind one-to-one
onu event
Use onu event to enable event reporting for an ONU.
Use undo onu event to disable event reporting for an ONU.
onu event { debug | log | trap } enable level severity
undo onu event { debug | log | trap } enable
Event reporting is disabled for an ONU.
ONU port view
debug: Specifies debugging information.
log: Specifies log information.
trap: Specifies trap information.
level severity: Specifies the severity level threshold. The ONU reports an event to the OLT if the severity level of the event reaches or exceeds this threshold. The following are the severity levels in descending order of priority:
· Emergencies (severity=0).
· Alerts (severity=1).
· Critical (severity=2).
· Errors (severity=3).
· Warnings (severity=4).
· Notifications (severity=5).
· Information (severity=6).
· Debugging (severity=7).
# Enable the ONU bound to ONU 1/0/2:1 to report debugging events with a severity level of alerts or a higher severity level.
[Sysname-Onu1/0/2:1] onu event debug enable level alerts
onu mac-address timer
Use onu mac-address timer to set the aging timer for dynamic MAC address entries for an ONU.
Use undo onu mac-address timer to restore the default.
onu mac-address timer { aging seconds | no-aging }
The aging timer for dynamic MAC address entries is 300 seconds.
ONU port view
aging seconds: Specifies an aging timer value in the range of 1 to 4294967295 seconds.
no-aging: Does not set the aging timer, which means dynamic MAC address entries do not age out.
# Set the aging timer for dynamic MAC address entries to 500 seconds on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu mac-address timer aging 500
onu multicast fast-leave enable
Use onu multicast fast-leave enable to enable fast-leave processing for all UNIs on an ONU.
Use undo onu multicast fast-leave enable to disable fast-leave processing for all UNIs on an ONU.
Fast-leave processing is disabled for all UNIs on an ONU.
ONU port view
Before you use this command on an ONU, set the multicast mode of the ONU to IGMP snooping.
You cannot use this command together with the uni igmp-snooping fast-leave command.
# Enable fast-leave processing for all UNIs on the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu multicast fast-leave enable
multicast mode
onu poe enable
Use onu poe enable to enable PoE for all UNIs of an ONU.
Use undo onu poe enable to disable PoE for all UNIs of an ONU.
onu poe enable
undo onu poe enable
PoE is enabled for UNIs.
ONU port view
On an ONU port, the onu poe enable and uni poe enable commands are mutually exclusive.
# Enable PoE for all UNIs of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu poe enable
uni poe enable
onu poe legacy enable
Use onu poe legacy enable to enable nonstandard PD detection for all UNIs of an ONU.
Use undo onu legacy enable to disable nonstandard PD detection for all UNIs of an ONU.
undo onu poe legacy enable
Nonstandard PD detection is disabled for UNIs.
ONU port view
PDs include standard PDs (which comply with IEEE 802.3af and IEEE 802.3at ) and nonstandard PDs. By default, a PSE supplies power to only standard PDs. For a PSE to supply power to nonstandard PDs, enable nonstandard PD detection.
Nonstandard PDs do not support autonegotiating the maximum power with an ONU. Make sure the maximum power configured for a nonstandard PD does not exceed the maximum power supported by the PD.
On an ONU port, the onu poe legacy enable and uni poe legacy enable commands are mutually exclusive.
# Enable nonstandard PD detection for all UNIs of the ONU attached to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu poe legacy enable
uni poe max-power
onu poe max-power
Use onu poe max-power to configure the maximum power for each UNI of an ONU.
Use undo onu poe max-power to restore the default.
onu poe max-power { class { class0 | class1 | class2 | class3 | class4 | default } | value max-power-value }
The maximum power of a UNI depends on the maximum power class of the PD attached to the UNI.
ONU port view
class0: Specifies the maximum power of the UNI as class 0.
class1: Specifies the maximum power of the UNI as class 1.
class2: Specifies the maximum power of the UNI as class 2.
class3: Specifies the maximum power of the UNI as class 3.
class4: Specifies the maximum power of the UNI as class 4.
default: Specifies the maximum power of the UNI as the maximum power class of the PD attached to the UNI.
max-power-value: Specifies the maximum power of the UNI, in the range of 1000 to 655350 microwatts.
Classes 1 through 4 are in ascending order of supplied power. Class 0 indicates the highest power class.
When the maximum power that the ONU and PD autonegotiate is smaller than the maximum power configured by using this command, the autonegotiated one takes effect.
When the maximum power that the ONU and PD autonegotiate is greater than the maximum power configured by using this command, the ONU denies supplying power to the PD.
On an ONU port, the onu poe max-power and uni poe max-power commands are mutually exclusive.
# Specify the maximum power as class 2 for each UNI on the ONU attached to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu poe max-power class class2
uni poe max-power
onu poe mode
Use onu poe mode to configure a PoE power transmission mode for all UNIs of an ONU.
Use undo onu poe mode to restore the default.
onu poe mode { signal | spare }
undo onu poe mode
The PoE power transmission mode is signal (power over signal cables).
ONU port view
signal: Specifies the PoE power transmission mode as power over signal cables. The system uses pairs 1, 2, 3, and 6 in the Category 3 or Category 5 twisted pair cable to supply DC power.
spare: Specifies the PoE power transmission mode as power over spare cables. The system uses pairs 4, 5, 7, and 8 in the Category 3 or Category 5 twisted pair cable to supply DC power.
On an ONU port, the onu poe mode and uni poe mode commands are mutually exclusive.
# Set the PoE power transmission mode to power over spare cables for all UNIs of the ONU attached to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu poe mode spare
uni poe mode
onu port-isolate enable
Use onu port-isolate enable to assign all UNIs on an ONU to the isolation group.
Use undo onu port-isolate enable to remove all UNIs on an ONU from the isolation group.
A UNI is not in the isolation group.
ONU port view
You cannot use this command together with the uni port-isolate command.
# Assign all UNIs on the ONU bound to ONU 1/0/1:1 to the isolation group.
[Sysname-Onu1/0/1:1] onu port-isolate enable
uni port-isolate
onu protocol enable
Use onu protocol enable to enable a user network management feature on an ONU.
Use undo onu protocol enable to disable a user network management feature on an ONU.
onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
undo onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
Loop detection is enabled, and DHCP snooping, DHCP snooping Option 82, PPPoE+, and RSTP are disabled on an ONU.
ONU port view
dhcp-snooping: Specifies DHCP snooping.
As a best practice, do not enable both RSTP and loop detection on an ONU. These features might operate incorrectly when used together.
# Enable DHCP snooping on the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu protocol dhcp-snooping enable
onu protocol igmp-snooping timer
Use onu protocol igmp-snooping timer to set IGMP snooping timers.
Use undo onu protocol igmp-snooping timer to restore the default.
NOTE: This command is supported by ET704 ONUs. |
onu protocol igmp-snooping timer { host-aging-time host-aging-time | max-response-time max-response-time | router-aging-time router-aging-time }
undo onu protocol igmp-snooping timer { host-aging-time | max-response-time | router-aging-time }
The query response timer is 1 second.
The router port aging timer is 105 seconds.
ONU port view
host-aging-time host-aging-time: Sets the multicast group member port aging timer in the range of 200 to 1000 seconds.
max-response-time max-response-time: Sets the query response timer in the range of 1 to 25 seconds.
router-aging-time router-aging-time: Sets the router port aging timer in the range of 1 to 1000 seconds.
The multicast group member port aging timer determines how often multicast group members are refreshed. If the ONU does not receive an IGMP report from a multicast group member port when this timer expires, the ONU deletes the port. In a network where multicast group members change frequently, set this timer to a small value.
The query response timer sets the response timeout time for group-specific queries. If the ONU does not receive a response before the query response timer expires for the first time, it re-sends group-specific queries and re-starts the query response timer. If the ONU still does not receive a response when the timer expires, the multicast group on the ONU is deleted.
The router port is the port that connects the ONU to the router. The ONU receives IGMP general query messages from the router through this port. If no IGMP general query message is received through the router port when the router port aging timer expires, the ONU determines that the port is not a router port. The router port aging timer must be a value about 2.5 times of the general query interval. For more information about the general query interval, see IGMP in IP Multicast Configuration Guide.
# Set the multicast group member port aging timer to 200 seconds for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu protocol igmp-snooping timer host-aging-time 200
onu protocol igmp-snooping suppression
Use onu protocol igmp-snooping suppression to enable IGMP membership report suppression or IGMP leave suppression.
Use undo onu protocol igmp-snooping suppression to disable IGMP membership report suppression or IGMP leave suppression.
onu protocol igmp-snooping suppression { leave | report }
undo onu protocol igmp-snooping suppression { leave | report }
IGMP leave suppression is enabled, and IGMP membership report suppression is disabled.
ONU port view
# Enable IGMP leave suppression on the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu protocol igmp-snooping suppression leave
onu protocol loopback-detection action
Use onu protocol loopback-detection action to set the loop protection action.
Use undo onu protocol loopback-detection action to restore the default.
onu protocol loopback-detection action { no-learning | semi-block | shutdown }
The loop protection action of an ONU port is semi-block.
ONU port view
no-learning: Disables MAC address learning when a loop is detected.
semi-block: Disables MAC address learning and blocks inbound traffic when a loop is detected.
shutdown: Shuts down the port when a loop is detected.
# Set the loop protection action to semi-block on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu protocol loopback-detection action semi-block
onu protocol smart-link flush enable
Use onu protocol smart-link flush enable to enable an ONU to send flush messages.
Use undo onu protocol smart-link flush enable to disable an ONU from sending flush messages.
onu protocol smart-link flush enable [ control-vlan vlan-id ]
An ONU does not send flush messages.
ONU port view
control-vlan vlan-id: Specifies the control VLAN for receiving flush messages. The VLAN ID is in the range of 1 to 4094, and the default control VLAN is VLAN 1.
# Enable the ONU bound to ONU 1/0/1:1 to send flush messages, and specify the control VLAN as VLAN 2.
[Sysname-Onu1/0/1:1] onu protocol smart-link flush enable control-vlan 2
Use onu protocol smart-link uni-bind enable to enable UNI count-based PON port activation for an ONU.
Use undo onu protocol smart-link uni-bind enable to disable UNI count-based PON port activation for an ONU.
NOTE: This command is supported by ET824-E ONUs. |
UNI count-based PON port activation is disabled for an ONU.
ONU port view
This command enables an ONU to activate the PON port that has more online UNIs if two PON ports are online.
# Enable UNI count-based PON port activation for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu protocol smart-link uni-bind enable
Use onu protocol transparent-multicast to enable unknown multicast packet transparent transmission for all UNIs on an ONU.
Use undo onu protocol transparent-multicast to disable unknown multicast packet transparent transmission for all UNIs on an ONU.
onu protocol transparent-multicast dest-mac mac-address [ vlan vlan-id ]
undo onu protocol transparent-multicast dest-mac mac-address [ vlan vlan-id ]
Unknown multicast packet transparent transmission is disabled for all UNIs on an ONU. The ONU might drop unknown multicast packets.
ONU port view
dest-mac mac-address: Specifies a multicast MAC address. Supported multicast MAC addresses vary by device model.
vlan vlan-id: Specifies a VLAN ID of multicast packets, in the range of 1 to 4094. If you do not specify this option, VLAN 1 is used.
If you execute the undo onu protocol transparent-multicast command without specifying the vlan keyword, this command disables transparent transmission of unknown multicast packets with the specified destination multicast MAC addresses and VLAN ID 1.
This command and the uni transparent-multicast command are mutually exclusive.
You can configure this command for up to eight times on an ONU port. The union of these configurations takes effect.
# Enable transparent transmission of multicast packets with destination multicast MAC address 0100-5e00-0033 and VLAN ID 10 for all UNIs on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu protocol transparent-multicast dest-mac 0100-5e00-0033 vlan 10
onu statistics enable
Use onu statistics enable to enable packet statistics for an ONU.
Use undo onu statistics enable to disable packet statistics for an ONU.
onu statistics enable [ period period-value ]
The packet statistics feature is enabled for an ONU.
ONU port view
period period-value: Specifies a statistic collection interval in the range of 0 to 4294967295 seconds. The default is 4294967295.
# Enable packet statistics and set the statistic collection interval to 1000 seconds on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] onu statistics enable period 1000
display epon statistics
qos cos-local-precedence-map
Use qos cos-local-precedence-map to configure CoS-to-local priority mappings.
Use undo qos cos-local-precedence-map to restore the default.
qos cos-local-precedence-map cos0 cos1 cos2 cos3 cos4 cos5 cos6 cos7
Table 17 shows default CoS-to-local priority mappings.
Table 17 Default CoS-to-local priority mappings
CoS priority |
Local precedence |
0 |
0 |
1 |
0 |
2 |
1 |
3 |
1 |
4 |
2 |
5 |
2 |
6 |
3 |
7 |
3 |
ONU port view
cos0: Specifies the local precedence to be mapped to CoS priority 0, in the range of 0 to 3.
cos1: Specifies the local precedence to be mapped to CoS priority 1, in the range of 0 to 3.
cos2: Specifies the local precedence to be mapped to CoS priority 2, in the range of 0 to 3.
cos3: Specifies the local precedence to be mapped to CoS priority 3, in the range of 0 to 3.
cos4: Specifies the local precedence to be mapped to CoS priority 4, in the range of 0 to 3.
cos5: Specifies the local precedence to be mapped to CoS priority 5, in the range of 0 to 3.
cos6: Specifies the local precedence to be mapped to CoS priority 6, in the range of 0 to 3.
cos7: Specifies the local precedence to be mapped to CoS priority 7, in the range of 0 to 3.
This command takes effect only on downlink data flows.
# Configure CoS-to-local priority mappings on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] qos cos-local-precedence-map 2 2 1 1 3 3 0 0
reboot onu
Use reboot onu to reboot an ONU.
reboot onu
ONU port view
This command takes effect only on online ONUs.
# Reboot the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] reboot onu
reset counters serial
Use reset counters serial to clear packet statistics on a serial interface on an ONU.
reset counters serial interface-number
ONU port view
Before you use this command, make sure the ONU has serial interfaces.
# Clear packet statistics on serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] reset counters serial 1
reset counters uni
Use reset counters uni to clear packet statistics on UNIs of an ONU.
reset counters uni [ uni-number ]
ONU port view
uni-number: Specifies a UNI by its number in the range of 1 to 79. If you do not specify this argument, the command clears packet statistics on all UNIs of the ONU.
# Clear packet statistics on UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] reset counters uni 1
serial databit
Use serial databit to set the number of data bits for a serial interface on an ONU.
Use undo serial databit to restore the default.
serial interface-number databit { 5 | 6 | 7 | 8 }
undo serial interface-number databit
The number of data bits is 8 for an ONU serial interface.
ONU port view
5: Sets the number of data bits to 5.
6: Sets the number of data bits to 6.
7: Sets the number of data bits to 7.
8: Sets the number of data bits to 8.
# Set the number of data bits to 5 for serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] serial 1 databit 5
serial parity
Use serial parity to set the parity type for a serial interface on an ONU.
Use undo serial parity to restore the default.
serial interface-number parity { even | mark | none | odd | space }
undo serial interface-number parity
The parity type of an ONU serial interface is none, which indicates that no parity is used.
ONU port view
even: Uses even parity.
mark: Uses mark parity.
none: Uses no parity.
odd: Uses odd parity.
space: Uses space parity.
# Set the parity type to odd for serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] serial 1 parity odd
serial session protocol-type
Use serial session protocol-type to establish a session on a serial interface of an ONU.
Use undo serial session protocol-type to delete the session on a serial interface of an ONU.
serial interface-number session session-number protocol-type tcp-client server ip-address port port-number
serial interface-number session session-number protocol-type tcp-server listen-port port-number
serial interface-number session session-number protocol-type udp server ip-address port port-number listen-port port-number
undo serial interface-number session session-number protocol-type
No session is established on an ONU serial interface.
ONU port view
protocol-type tcp-client: Uses the ONU as the client of a TCP session.
protocol-type tcp-server: Uses the ONU as the server of a TCP session.
protocol-type udp: Uses the ONU as both the server and client of a UDP session.
server: Specifies a server.
port: Specifies a port on the server.
listen-port: Specifies a local listening port.
session-number: Specifies a session number in the range of 1 to 6.
ip-address: Specifies the IP address of the server.
port-number: Specifies the port number of the server, in the range of 1024 to 65535.
# Establish a TCP session on serial interface 1 of the ONU bound to ONU 1/0/1:1, and configure the ONU as the client of the session.
[Sysname-Onu1/0/1:1] serial 1 session 1 protocol-type tcp-client server 122.100.52.5
2 port 15
# Establish a TCP session on serial interface 1 of the ONU bound to ONU 1/0/1:1, and configure the ONU as the server of the session.
[Sysname-Onu1/0/1:1] serial 1 session 3 protocol-type tcp-server listen-port 2500
# Establish a UDP session on serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] serial 1 session 5 protocol-type udp server 3.3.2.5 port 4500 listen-port 75
# Delete the session on serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname] undo serial 1 session 4 protocol-type
serial speed
Use serial speed to set the baud rate for a serial interface of an ONU.
Use undo serial speed to restore the default.
serial interface-number speed { 300 | 600 | 1200 | 2400 | 4800 | 9600 | 19200 | 38400 | 57600 | 115200 }
undo serial interface-number speed
The baud rate of an ONU serial interface is 9600 bps.
ONU port view
300: Sets the baud rate to 300 bps.
600: Sets the baud rate to 600 bps.
1200: Sets the baud rate to 1200 bps.
2400: Sets the baud rate to 2400 bps.
4800: Sets the baud rate to 4800 bps.
9600: Sets the baud rate to 9600 bps.
19200: Sets the baud rate to 19200 bps.
38400: Sets the baud rate to 38400 bps.
57600: Sets the baud rate to 57600 bps.
115200: Sets the baud rate to 115200 bps.
# Set the baud rate to 300 bps for serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] serial 1 speed 300
serial stopbit
Use serial stopbit to set the number of stop bits for a serial interface of an ONU.
Use undo serial stopbit to restore the default.
serial interface-number stopbit { 1 | 1.5 | 2 }
undo serial interface-number stopbit
The number of stop bits is 1 for an ONU serial interface.
ONU port view
1: Sets the number of stop bits to 1.
1.5: Sets the number of stop bits to 1.5.
2: Sets the number of stop bits to 2.
# Set the number of stop bits to 1.5 for serial interface 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] serial 1 stopbit 1.5
service-sla apply
Use service-sla apply to apply the uplink traffic queue scheduling configuration to an ONU.
Use undo service-sla apply to remove the uplink traffic queue scheduling configuration from an ONU.
service-sla apply
No uplink traffic queue scheduling configuration is applied to an ONU.
ONU port view
The uplink traffic queue scheduling configuration contains the queue scheduling mode (service-sla mode) configuration and the queue parameter (service-sla queue) configuration.
To modify the queue scheduling mode or queue parameters after executing this command, first execute the undo service-sla apply command.
# Apply the uplink traffic queue scheduling configuration to the ONU attached to ONU 1/0/1:1.
[Sysname] interface Onu1/0/1:1
[Sysname-Onu1/0/1:1] service-sla apply
service-sla mode
service-sla queue
service-sla mode
Use service-sla mode to configure the uplink traffic queue scheduling mode for an ONU.
Use undo service-sla mode to restore the default.
service-sla mode { sp | wrr | sp-wrr high-priority-boundary boundary-queue-id } [ cycle-length length ]
No uplink traffic queue scheduling mode is configured for an ONU.
ONU port view
sp: Specifies the Strict Priority (SP) mode.
wrr: Specifies the Weighted Round Robin (WRR) mode.
sp-wrr: Specifies the SP+WRR mode.
high-priority-boundary boundary-queue-id: Specifies the minimum SP queue ID. Queues with this ID and higher are configured as SP queues. Queues with IDs smaller than this ID are configured as WRR queues.
cycle-length length: Specifies the Dynamic Bandwidth Allocation (DBA) polling cycle in the range of 200 to 16777215 time quantums (TQs). A TQ is 16 ns. This keyword is only for administrator use. As a best practice, do not configure this keyword as a common user.
# Configure the uplink traffic queue scheduling mode as SP on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] service-sla mode sp
service-sla apply
service-sla queue
service-sla queue
Use service-sla queue to configure the uplink traffic queue parameters for an ONU.
Use undo service-sla queue to cancel the configuration.
service-sla queue queue-id { sp | wrr weight weight } [ [ fixed-packet-size fixed-packet-size ] fixed-bandwidth fixed-bandwidth ] guaranteed-bandwidth guaranteed-bandwidth best-effort-bandwidth best-effort-bandwidth
undo service-sla queue queue-id
No uplink traffic queue parameters are set for an ONU.
ONU port view
queue queue-id: Specifies a queue by its ID in the range of 0 to 7.
sp: Specifies a queue as an SP queue.
wrr: Specifies a queue as a WRR queue.
weight weight: Specifies a weight for a WRR queue, in the range of 1 to 100. The default is 0.
fixed-packet-size fixed-packet-size: Specifies the TDM packet length in the range of 0 to 2000 bytes. The default is 0, which indicates that the TDM packet length is not limited.
fixed-bandwidth fixed-bandwidth: Specifies the fixed bandwidth in the range of 0 to 9999872 kbps, which must be a multiple of 256. When it is not a multiple of 256, it is rounded down to the nearest multiple of 256. If you dot specify this option for a queue, no fixed bandwidth is configured for the queue.
guaranteed-bandwidth guaranteed-bandwidth: Specifies the guaranteed bandwidth in the range of 0 to 9999872 kbps, which must be a multiple of 256. When it is not a multiple of 256, it is rounded down to the nearest multiple of 256.
best-effort-bandwidth best-effort-bandwidth: Specifies the best-effort bandwidth in the range of 0 to 9999872 kbps, which must be a multiple of 256. When it is not a multiple of 256, it is rounded down to the nearest multiple of 256.
You can execute this command multiple times to configure parameters for multiple queues.
In SP mode, you must configure a minimum of one SP queue.
In WRR mode, you must configure a minimum of one WRR queue.
In SP+WRR mode, you must configure a minimum of one SP queue and one WRR queue.
On an ONU port, the sum of WRR queue weights must be 100.
# Configure the uplink guaranteed bandwidth as 4 Mbps (4096 kbps) and the uplink best-effort bandwidth as 8 Mbps (8192 kbps) for SP queue 1 on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] service-sla queue 1 sp guaranteed-bandwidth 4096 best-effort-bandwidth 8192
service-sla apply
service-sla mode
Use shutdown management-vlan-interface to shut down the management VLAN interface of an ONU.
Use undo shutdown management-vlan-interface to bring up the management VLAN interface of an ONU.
The management VLAN interface of an ONU is down.
ONU port view
You must assign an IP address to a management VLAN interface after you bring it up.
After you execute this command, the status of the management VLAN interface depends on the status of the UNIs in the management VLAN.
· If all UNIs are down, the management VLAN interface is down.
· If a minimum of one UNI is up, the management VLAN interface is up.
# Bring up the management VLAN interface of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] undo shutdown management-vlan-interface
transceiver-txpower
Use transceiver-txpower to set the state of the transmit power supply for transceiver modules of ONU PON ports.
transceiver-txpower { on | off | off seconds } pon { all | main | standby } onu { all | onu-number-list }
The transmit power supply is turned on for transceiver modules of all PON ports on an ONU.
OLT port view
on: Turns on the transmit power supply.
off: Turns off the transmit power supply.
off seconds: Turns off the transmit power supply for a period of time. The seconds argument specifies the period of time when the transmit power supply is off. The value range for the seconds argument is 1 to 65534 seconds. The transmit power supply is turned on automatically after this period of time.
pon: Specifies PON ports.
all: Specifies the main and standby PON ports.
main: Specifies the main PON port.
standby: Specifies the standby PON port.
onu: Specifies ONUs.
all: Specifies all ONUs.
onu-number-list: Specifies a space-separated list of up to 10 ONU port items. Each item specifies an ONU port number or a range of ONU port numbers in the form of onu-number1 [ to onu-number2 ]. The value range for the onu-number1 and onu-number2 arguments is 1 to 64. The value of the onu-number2 argument must be larger than or equal to the value of the onu-number1 argument.
In an EPON system, ONUs cannot transmit upstream traffic simultaneously. If an ONU fails and keeps sending optical signals, the other ONUs in the system cannot transmit upstream traffic because their transmission timeslots are occupied. To locate the faulty ONU, you can use this command to disable the transmit power supply of ONUs.
# Turn off the transmit power supply of the main and standby PON ports on all ONUs for 300 seconds on OLT 1/0/1.
[Sysname-Olt1/0/1] transceiver-txpower off 300 pon all onu all
Use uni auto-negotiation to enable autonegotiation on a UNI.
Use undo uni auto-negotiation to disable autonegotiation on a UNI.
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
Autonegotiation is enabled on a UNI.
ONU port view
On a UNI, do not enable autonegotiation and manually set the duplex mode, MDIX mode, or port rate at the same time.
# Enable autonegotiation on UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 auto-negotiation
Use uni classification-marking to configure priority marking on a UNI.
Use undo uni classification-marking to remove priority marking configuration from a UNI.
uni uni-number classification-marking index index queue qid priority priority { { selector operator matched-value } & <1-4> | always-match | never-match }
undo uni uni-number classification-marking index index
Priority marking is not configured on a UNI.
ONU port view
index: Specifies an index in the range of 1 to 8. The smaller the index, the higher the priority.
qid: Assigns packets to a queue specified by its ID in the range of 0 to 7.
priority: Marks packets with a priority in the range of 0 to 7.
{ selector operator matched-value } & <1-4>: Specifies a maximum of four matching field and rule pairs.
· selector: Specifies a matching field. Table 18 shows the available values.
· operator: Specifies a matching rule. Table 19 shows the available values.
· matched-value: Specifies the value of the matching field if the value of the operator argument is not exist or not-exist.
? ip-address: Specifies an IP address.
? mac-address: Specifies a MAC address. Do not specify an ONU MAC address bound to an ONU port for the dst-mac and src-mac fields.
? port-number: Specifies a port number in the range of 0 to 65535.
? priority: Specifies a CoS priority in the range of 0 to 7.
? eth-type: Specifies an Ethernet frame type in the range of 0 to FFFF.
? ip-dscp: Specifies a ToS priority or DSCP priority in the range of 0 to 63.
? ip-type: Specifies an IP protocol type in the range of 0 to FF.
? vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
always-match: Performs match for traffic classification.
never-match: Does not perform match.
Table 18 Values for the selector argument
selector |
dst-ip |
Matches the destination IP address. |
dst-mac |
Matches the destination MAC address. |
dst-port |
Matches the destination port number. |
eth-pri |
Matches the CoS priority. |
eth-type |
Matches the Ethernet frame type. |
ip-precedence |
Matches the IP precedence. |
ip-tos-dscp |
Matches the ToS priority or DSCP priority. |
ip-type |
Matches the IP protocol type. |
src-ip |
Matches the source IP address. |
src-mac |
Matches the source MAC address. |
src-port |
Matches the source port number. |
vlan-id |
Matches the VLAN ID. |
Table 19 Values for the operator argument
operator |
equal |
The value of the matched-value argument must be equal to the value of the matching field of packets. |
exist |
The packets must contain the matching field. |
not-equal |
The value of the matched-value argument must be different from the value of the matching field of packets. |
not-exist |
The packets cannot contain the matching field. |
greater-equal |
The value of the matched-value argument must be greater than the value of the matching field of packets. |
less-equal |
The value of the matched-value argument must be smaller than the value of the matching field of packets. |
Do not use the uni classification-marking commands together with the qos trust dscp command. For more information about the qos trust command, see ACL and QoS Command Reference.
# Configure UNI 1 of the ONU bound to ONU 1/0/1:1 to modify the priority to 3 for packet tagged with VLAN ID 10.
[Sysname-Onu1/0/1:1] uni 1 classification-marking index 1 queue 3 priority 3 vlan-id
equal 10
uni description
Use uni description to configure the description for a UNI.
Use undo uni description to restore the default.
uni uni-number description text
undo uni uni-number description
A UNI does not have a description.
ONU port view
text: Specifies the description, a string of 1 to 40 characters.
# Configure the description as Test for UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 description Test
uni duplex
Use uni duplex to set the duplex mode of a UNI.
Use undo uni duplex to restore the default.
uni uni-number duplex { auto | full | half }
undo uni uni-number duplex
A UNI is operating in full duplex mode.
ONU port view
auto: Specifies the auto mode.
full: Specifies the full duplex mode.
half: Specifies the half duplex mode.
Before you use this command, make sure autonegotiation is disabled on the UNI.
# Set the duplex mode to auto for UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 duplex auto
uni flow-control
Use uni flow-control to enable flow control for a UNI.
Use undo uni flow-control to disable flow control for a UNI.
uni uni-number flow-control
undo uni uni-number flow-control
Flow control is disabled for a UNI.
ONU port view
# Enable flow control for UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 flow-control
Use uni igmp-snooping fast-leave to enable fast-leave processing for a UNI.
Use undo uni igmp-snooping fast-leave to disable fast-leave processing for a UNI.
uni uni-number igmp-snooping fast-leave
undo uni uni-number igmp-snooping fast-leave
Fast-leave processing is disabled for a UNI.
ONU port view
You cannot use this command together with the onu multicast fast-leave enable command.
# Enable fast-leave processing for UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 igmp-snooping fast-leave
multicast mode
uni mac-address max-mac-count
Use uni mac-address max-mac-count to set the MAC learning limit on a UNI.
Use undo uni mac-address max-mac-count to restore the default.
uni uni-number mac-address max-mac-count count
undo uni uni-number mac-address max-mac-count
The number of MAC addresses that a UNI can learn is not limited.
ONU port view
count: Specifies the maximum number of MAC addresses that the UNI can learn. The value range for this argument is 0 to 65534. If you set this argument to 0, MAC address learning is disabled on the UNI.
# Set the MAC learning limit to 5 on UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 mac-address max-mac-count 5
uni mdix-mode
Use uni mdix-mode to set the MDIX mode for a UNI.
Use undo uni mdix-mode to restore the default.
NOTE: This command is not supported by ET254 ONUs. |
uni uni-number mdix-mode { automdix | mdi | mdix }
undo uni uni-number mdix-mode
The MDIX mode of a UNI is automdix.
ONU port view
automdix: Negotiates pin roles with its peer.
mdi: Uses pins 1 and 2 as transmit pins and pins 3 and 6 as receive pins.
mdix: Uses pins 1 and 2 as receive pins and pins 3 and 6 as transmit pins.
# Set the MDIX mode to automdix for UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 mdix-mode automdix
uni mirroring-port
Use uni mirroring-port to configure a UNI as a mirroring source port.
Use undo uni mirroring-port to remove mirroring source port configuration from a UNI.
uni uni-number mirroring-port { both | inbound | outbound }
undo uni uni-number mirroring-port
A UNI is not a mirroring source port.
ONU port view
both: Specifies both inbound and outbound mirroring.
inbound: Specifies inbound mirroring.
outbound: Specifies outbound mirroring.
A UNI cannot be both a mirroring source port and destination port.
# Configure UNI 1 of the ONU bound to ONU 1/0/1:1 as a mirroring source port and enable both inbound and outbound mirroring.
[Sysname-Onu1/0/1:1] uni 1 mirroring-port both
uni monitor-port
uni monitor-port
Use uni monitor-port to configure a UNI as a mirroring destination port.
Use undo uni monitor-port to restore the default.
uni uni-number monitor-port
undo uni uni-number monitor-port
A UNI is not a mirroring destination port.
ONU port view
An ONU can have only one mirroring destination port. To change the mirroring destination port, first remove the original mirroring destination port.
# Configure UNI 1 of the ONU bound to ONU 1/0/1:1 as a mirroring destination port.
[Sysname-Onu1/0/1:1] uni 1 monitor-port
uni mirroring-port
uni multicast vlan
Use uni multicast vlan to assign a UNI to multicast VLANs on an ONU.
Use undo uni multicast vlan to remove a UNI from the specified or all multicast VLANs on an ONU.
uni uni-number multicast vlan vlan-id-list
undo uni uni-number multicast vlan { vlan-id-list | all }
A UNI is not assigned to any multicast VLANs.
ONU port view
vlan-id-list: Specifies a space-separated list of up to 50 multicast VLAN IDs in the range of 1 to 4094.
all: Specifies all multicast VLAN IDs.
On an ONU, UNIs can be assigned to a maximum of 15 multicast VLANs.
This command is available only on an ONU in IGMP snooping mode.
# Assign UNI 1 of the ONU bound to ONU 1/0/1:1 to multicast VLANs 2000 and 3000.
[Sysname-Onu1/0/1:1] uni 1 multicast vlan 2000 3000
multicast mode
uni multicast-control multicast-address
Use uni multicast-control multicast-address to configure the access to multicast channels on a UNI.
Use undo uni multicast-control multicast-address to restore the default.
uni uni-number multicast-control multicast-address multicast-address-list [ source-ip ip-address [ to ip-address ] ] rule { deny | permit [ channel-limit channel-number ] | preview time-slice preview-time [ preview-interval interval-time | preview-times preview-times [ reset-interval reset-interval-time ] ]* }
undo uni uni-number multicast-control multicast-address [ multicast-address-list ]
The access to multicast channels is not configured on a UNI.
ONU port view
multicast-address-list: Specifies a space-separated list of up to 10 multicast IP address items. Each item specifies a multicast IP address or a range of multicast IP address in the format of multicast-address1 to multicast-address2.
source-ip ip-address [ to ip-address ]: Specifies the IP address range of the multicast sources that issue multicast channels. The ip-address argument indicates the IP address of a multicast source.
deny: Denies user access to the specified multicast channels.
permit: Permits user access to the specified multicast channels.
channel-limit channel-number: Specifies the number of channels that can be accessed at the same time when the permit keyword is specified. The value range for this argument is 1 to 5. If this option is not specified, up to 5 channels can be accessed at the same time.
preview time-slice preview-time: Specifies the preview period during which the users can preview the multicast channels in the range of 1 to 3 minutes.
preview time-slice interval-time: Specifies the preview interval in the range of 1 to 10 minutes.
preview time-slice preview-times: Specifies the times of previews, in the range of 1 to 3.
reset-interval reset-interval-time: Specifies the preview reset interval in the range of 1 to 43200 minutes. If the preset number of previews is reached, you must wait for a preview reset interval before the next preview.
If you specify the source-ip keyword, the OLT processes received IGMPv3 packets as follows:
· For IS_IN, TO_IN, or ALLOW IGMPv3 packets:
? If their multicast IP address and source IP address are in the address range that has multicast rights, the OLT creates multicast entries.
? If this requirement is not met, the OLT drops the packets.
· If the packet type is IS_EX or TO_EX, the OLT drops the packets.
· If the packet type is BLOCK, the OLT directly deletes the corresponding multicast entries without checking the packet rights.
For more information about IS_IN, TO_IN, ALLOW, IS_EX, TO_EX, and BLOCK IGMPv3 packets, see IP Multicast Configuration Guide.
If you assign preview right to multiple multicast channels to users on a UNI, only one of the multicast channels can be previewed at a given time.
# Permit users on UNI 1 of the ONU bound to ONU 1/0/1:1 to access the multicast channel 224.1.1.2.
[Sysname-Onu1/0/1:1] uni 1 multicast-control multicast-address 224.1.1.2 rule permit
multicast mode
uni multicast-group-number
Use uni multicast-group-number to configure the number of multicast channels that users can access at the same time on a UNI.
Use undo multicast-group-number to restore the default.
uni uni-number multicast-group-number number
undo uni uni-number multicast-group-number
The users on a UNI can access 64 multicast channels at the same time.
ONU port view
number: Specifies the number of multicast channels, in the range of 0 to 255.
# Configure the number of multicast channels as 30 on UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 multicast-group-number 30
uni multicast-strip-tag enable
Use uni multicast-strip-tag enable to configure a UNI to remove the VLAN tag of downlink multicast flows.
Use undo uni multicast-strip-tag enable to restore the default.
uni uni-number multicast-strip-tag enable
undo uni uni-number multicast-strip-tag enable
A UNI does not remove the VLAN tag of downlink multicast flows.
ONU port view
When transparent transmission is enabled for unknown multicast packets with the destination MAC address 0100-ffff-ffff on an UNI, the UNI does not support this command.
# Configure UNI 1 of the ONU bound to ONU 1/0/1:1 to remove the VLAN tag of downlink multicast flows.
[Sysname-Onu1/0/1:1] uni 1 multicast-strip-tag enable
uni poe enable
Use uni poe enable to enable PoE for a UNI.
Use undo uni poe enable to disable PoE for a UNI.
uni uni-number poe enable
undo uni uni-number poe enable
PoE is disabled for a UNI.
ONU port view
uni-number: Specifies a UNI by its number in the range of 1 to the number of UNIs on the ONU. The maximum number of UNIs supported on an ONU is 79.
# Enable PoE for UNI 1.
[Sysname-Onu1/0/1:1] uni 1 poe enable
onu poe enable
Use uni poe legacy enable to enable nonstandard PD detection for a UNI.
Use undo uni legacy enable to disable nonstandard PD detection for a UNI.
uni uni-number poe legacy enable
undo uni uni-number poe legacy enable
Nonstandard PD detection is disabled for a UNI.
ONU port view
# Enable nonstandard PD detection for UNI 1.
[Sysname-Onu1/0/1:1] uni 1 poe legacy enable
uni poe max-power
uni poe max-power
Use uni poe max-power to configure the maximum power of a UNI.
Use undo uni poe max-power to restore the default.
uni uni-number poe max-power { class { default | class0 | class1 | class2 | class3 | class4 } | value max-power-value }
undo uni uni-number poe max-power
ONU port view
# Set the maximum power of UNI 1 to class 2.
[Sysname-Onu1/0/1:1] uni 1 poe max-power class class2
onu poe max-power
uni poe mode
Use uni poe mode to configure a PoE power transmission mode for a UNI.
Use undo uni poe mode to restore the default.
uni uni-number poe mode { signal | spare }
undo uni uni-number poe mode
The PoE power transmission mode of a UNI is signal (power over signal cables).
ONU port view
# # Set the PoE power transmission mode to power over spare cables for UNI 1.
[Sysname-Onu1/0/1:1] uni 1 poe mode spare
onu poe mode
uni poe priority
Use uni poe priority to configure the power supply priority for a UNI.
Use undo uni poe priority to restore the default.
uni uni-number poe priority { critical | high | low }
undo uni uni-number poe priority
The power supply priority of a UNI is high.
ONU port view
critical: Sets the power supply priority to critical. The UNI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical UNI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the sum of power supplied to PDs attached to UNIs of an ONU exceeds the maximum power of the ONU, the ONU might disable PoE for some UNIs and operate as follows:
· Power is first supplied to UNIs with higher priority.
· For UNIs with same power supply priority, the UNI with the smallest number is allocated with power first.
# Set the power supply priority to low for UNI 1.
[Sysname-Onu1/0/1:1] uni 1 poe priority low
onu poe priority
uni port-isolate
Use uni port-isolate to assign a UNI to the isolation group.
Use undo uni port-isolate to remove a UNI from the isolation group.
uni uni-number port-isolate
undo uni uni-number port-isolate
ONU port view
An ONU supports only one isolation group. The number of UNIs in the isolation group is not limited.
You cannot use this command together with the onu port-isolate enable command.
# Assign UNI 1 and UNI 2 of the ONU bound to ONU 1/0/1:1 to the isolation group.
[Sysname-Onu1/0/1:1] uni 1 port-isolate
[Sysname-Onu1/0/1:1] uni 2 port-isolate
uni port-policy inbound
Use uni port-policy inbound to configure uplink traffic policing on a UNI.
Use undo uni port-policy inbound to restore the default.
uni uni-number port-policy inbound { bucket-depth bucket-depth-value | cir cir-value | extra-burst-size extra-burst-size-value } *
undo uni uni-number port-policy inbound
The CBS is 1522 bytes, the CIR is 0 kbps, and the EBS is 0 bytes.
ONU port view
bucket-depth bucket-depth-value: Specifies the CBS in the range of 1522 to 65535 bytes. The CBS is the maximum burst bandwidth.
cir cir-value: Specifies the CIR in the range of 64 to 16777152 Kbps. The value of the cir-value argument must be a multiple of 64.
extra-burst-size extra-burst-size-value: Specifies the EBS in the range of 0 to 1522 bytes.
# Configure uplink traffic policing on UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 port-policy inbound cir 640 bucket-depth 2000 extra-burst-size 1000
uni port-policy outbound
Use uni port-policy outbound to configure downlink traffic policing on a UNI.
Use undo uni port-policy outbound to restore the default.
uni uni-number port-policy outbound cir cir-value [ pir pir-value ]
undo uni uni-number port-policy outbound
The CIR is 0 kbps, and the PIR is 0 kbps.
ONU port view
pir pir-value: Specifies the PIR in the range of 64 to 16777152 Kbps. The value of the pir-value argument must be a multiple of 64 and be larger than the CIR.
# Configure downlink traffic policing on UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 port-policy outbound cir 30720
uni qinq
Use uni qinq to add an SVLAN tag for packets with specific CVLAN tags, or enable transparent transmission for VLANs on a UNI.
Use undo uni qinq to remove QinQ configuration from a UNI.
uni uni-number qinq svlan svlan-id cvlan { cvlan-id-list | all }
undo uni uni-number qinq svlan svlan-id
uni uni-number qinq transparent-vlan { cvlan-id-list | all }
undo uni uni-number qinq transparent-vlan { cvlan-id-list | all }
QinQ is not configured on a UNI.
ONU port view
svlan svlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
cvlan-id-list: Specifies a space-separated list of up to 10 CVLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value of vlan-id2 cannot be smaller than the value of vlan-id1. The value range for VLAN IDs is 1 to 4094.
all: Specifies all CVLAN IDs.
Before you can configure QinQ for a UNI, you must set its VLAN operation mode to QinQ.
Enable transparent transmission for VLANs that have special purposes, for example, a VLAN dedicated to a corporation or a management VLAN. When receiving packets tagged with the VLAN ID, the ONU does not add the SVLAN tag to the packets before forwarding them to the service provider network.
# Configure UNI 1 of the ONU bound to ONU 1/0/1:1 to add the SVLAN tag 20 for packets with a CVLAN tag of VLAN 3 or 4.
[Sysname-Onu1/0/1:1] uni 1 qinq svlan 20 cvlan 3 to 4
uni vlan-mode
uni restart auto-negotiation
Use uni restart auto-negotiation to force a UNI to restart autonegotiation.
uni uni-number restart auto-negotiation
ONU port view
This command is available only when autonegotiation is enabled.
# Force UNI 1 of the ONU bound to ONU 1/0/1:1 to restart autonegotiation.
[Sysname-Onu1/0/1:1] uni 1 restart auto-negotiation
uni shutdown
Use uni shutdown to shut down a UNI.
Use undo uni shutdown to bring up a UNI.
uni uni-number shutdown
undo uni uni-number shutdown
A UNI is up.
ONU port view
# Shut down UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 shutdown
uni speed
Use uni speed to set the rate of a UNI.
Use undo uni speed to restore the default.
uni uni-number speed { 10 | 100 | 1000 | auto }
undo uni uni-number speed
The rate of a UNI is 100 Mbps.
ONU port view
10: Sets the UNI rate to 10 Mbps.
100: Sets the UNI rate to 100 Mbps.
1000: Sets the UNI rate to 1000 Mbps.
auto: Enable auto rate negotiation.
# Set the rate to 10 Mbps for UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 speed 10
uni statistics enable
Use uni statistics enable to enable packet statistics for a UNI.
Use undo uni statistics enable to disable packet statistics for a UNI.
uni uni-number statistics enable [ period period-value ]
undo uni uni-number statistics enable
The packet statistics feature is enabled for a UNI.
ONU port view
# Enable packet statistics and set the statistic collection interval to 1000 seconds for UNI 1 on ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 statistics enable period 1000
Use uni transparent-multicast to enable unknown multicast packet transparent transmission for a UNI.
Use undo uni transparent-multicast to disable unknown multicast packet transparent transmission for a UNI.
uni uni-number transparent-multicast dest-mac mac-address [ vlan vlan-id ]
undo uni uni-number uni transparent-multicast dest-mac mac-address [ vlan vlan-id ]
Unknown multicast packet transparent transmission is disabled for a UNI on an ONU. The ONU might drop unknown multicast packets.
ONU port view
uni uni-number: Specifies a UNI by its number in the range of 1 to the number of UNIs on the ONU. An ONU supports a maximum of 79 UNIs.
If you execute the undo uni transparent-multicast command without specifying the vlan keyword, this command disables transparent transmission of unknown multicast packets with the specified destination multicast MAC addresses and VLAN ID 1.
This command and the onu protocol transparent-multicast command are mutually exclusive.
You can configure this command for up to eight times on a UNI. The union of these configurations takes effect.
# Enable transparent transmission of multicast packets with destination MAC address 0100-5e00-0033 and VLAN ID 10 on UNI 1 of ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 transparent-multicast dest-mac 0100-5e00-0033 vlan 10
uni virtual-cable-test
Use uni virtual-cable-test to test the cable connected to a UNI.
uni uni-number virtual-cable-test
ONU port view
# Test the cable connected to UNI 1 of the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 virtual-cable-test
Cable status: abnormal(open), 0 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: 4294967040 db
Table 20 Command output
Cable status |
Cable status: · Normal. · Abnormal. · abnormal(open). · abnormal(short). · failure. |
n metre(s) |
If the cable is operating correctly, this field displays the total length of the cable. If the cable is not operating correctly, this field displays the length of the cable between the UNI and the point of failure. |
Pair skew |
Pair skew. The hyphen (-) indicates that the test item is not supported. |
Pair swap |
Pair swap. The hyphen (-) indicates that the test item is not supported. |
Pair polarity |
Pair polarity. The hyphen (-) indicates that the test item is not supported. |
Insertion loss |
Insertion loss. The hyphen (-) indicates that the test item is not supported. |
Return loss |
Return loss. The hyphen (-) indicates that the test item is not supported. |
Near-end crosstalk |
Near-end crosstalk. The hyphen (-) indicates that the test item is not supported. |
uni vlan-mode
Use uni vlan-mode to set the VLAN operation mode of a UNI.
Use undo uni vlan-mode to restore the default.
· Transparent mode:
uni uni-number vlan-mode transparent
· Tag mode:
uni uni-number vlan-mode tag pvid pvid [ priority priority ]
· Translation mode:
uni uni-number vlan-mode translation pvid pvid [ priority priority ] { original-vlan-id to translated-vlan-id } &<1-15>
· QinQ mode:
uni uni-number vlan-mode qinq pvid pvid [ priority priority ]
· Trunk mode:
uni uni-number vlan-mode trunk pvid pvid [ priority priority ] trunk-vlan-list
· N:1 aggregation mode:
uni uni-number vlan-mode aggregation pvid pvid [ priority priority ] { vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>
undo uni uni-number vlan-mode
The VLAN operation mode of a UNI is transparent.
ONU port view
pvid pvid: Specifies a PVID in the range of 1 to 4094. In tag mode, translation mode, trunk mode, or N:1 aggregation mode, a UNI tags only incoming untagged frames with its PVID. In QinQ mode, a UNI tags all incoming frames with its PVID, regardless of whether the frames already have tags.
priority priority: Specifies an 802.1p precedence in the range of 0 to 7. In tag mode, translation mode, trunk mode, or N:1 aggregation mode, a UNI sets only the 802.1p precedence in the PVID tag that it adds to incoming untagged frames. In QinQ mode, a UNI sets the 802.1p precedence in the outermost PVID tag that it adds to incoming frames.
{ original-vlan-id to translated-vlan-id } &<1-15>: Specifies a maximum of 15 original VLAN ID and translated VLAN ID pairs. The value range for VLAN IDs is 1 to 4094.
trunk-vlan-list: Specifies the permitted VLANs in the format of { vlan-id1 to vlan-id2 }&<1-15>. You can specify a maximum of 15 VLAN ID ranges. In a VLAN ID range, the start VLAN ID cannot be greater than the end VLAN ID. Different VLAN ID ranges cannot overlap. The value range for VLAN IDs is 1 to 4094.
{ vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>: Translates a range of VLANs to an aggregate VLAN. The vlan-id1 to vlan-id2 option specifies the original VLAN range. In the VLAN range, the start VLAN ID cannot be greater than the end VLAN ID. The aggregated-vlan argument specifies the translated aggregate VLAN. You can specify a maximum of 15 original VLAN ID range and aggregate VLAN pairs.
If the link type of all ONU ports on an OLT port is access, you must set the VLAN operation mode to transparent for UNIs of the ONUs. This setting ensures that the ONU ports and users receive only untagged packets.
The VLANs configured by using the uni vlan-mode command takes effect only on unicast packets. As a best practice, make sure the VLANs configured by using the uni vlan-mode command do not overlap with those configured by using the uni multicast vlan command.
If you enable transparent transmission of unknown multicast packets with the destination MAC address 0100-ffff-ffff on an UNI, the VLANs configured by using the uni vlan-mode command also take effect on all unknown multicast packets.
# Set the VLAN operation mode of UNI 1 to transparent for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode transparent
# Set the VLAN operation mode of UNI 1 to tag for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode tag pvid 100 priority 3
# Set the VLAN operation mode of UNI 1 to translation for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
# Set the VLAN operation mode of UNI 1 to QinQ for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode qinq pvid 100 priority 3
[Sysname-Onu1/0/1:1] uni 1 vlan-mode trunk pvid 1 priority 3 2 to 5
# Set the VLAN operation mode of UNI 1 to N:1 aggregation for the ONU bound to ONU 1/0/1:1. Set the PVID to 1, set the 802.1p priority in packets to 3, and translate VLANs 2 through 5 to 100.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode aggregation pvid 1 priority 3 2 to 5 aggregate 100
uni multicast vlan
update onu filename
Use update onu filename to update an ONU or all ONUs on an OLT port.
Use undo update onu to cancel the update configuration for an ONU or all ONUs on an OLT port.
update onu [ protocol-type { h3c | ctc } ] filename filename
undo update onu
ONU port view
protocol-type: Specifies the protocol used for ONU update. If you do not specify a protocol, the H3C protocol is used.
h3c: Specifies the H3C protocol.
ctc: Specifies the CTC protocol.
filename: Specifies a file by its name, a string of 1 to 63 characters. The string can contain only letters, numbers, and special characters in Table 21. The file name is formed by the device name and the ONU update file name. If you do not specify a device name, the name of the Flash on the active MPU is used as the device name. The files on the standby MPU cannot be used for the update.
Character name |
Symbol |
Character name |
Symbol |
Tilde |
Plus sign |
Exclamation point |
Equal sign |
At sign |
Left brace |
Pound sign |
Right brace |
Dollar sign |
Left bracket |
Percent sign |
Right bracket |
Caret |
Backslash |
Ampersand sign |
Semi-colon |
Left parenthesis |
Apostrophe |
Right parenthesis |
Comma |
Hyphen |
Dot |
Underscore |
_ |
As a best practice, use the H3C protocol for H3C ONUs. To update ONUs from other vendors, use the CTC protocol. When the OLT operating mode of a 10G-EPON card is changed to 128-ONU, the ONUs connected to the EPON card do not support using the H3C protocol for upgrading ONUs.
To update a single ONU, use this command in ONU port view. To update all ONUs on an OLT port, use this command in OLT port view.
This command issues the update file to ONUs.
· If an ONU is online and matches the update file, the ONU is updated.
· If an ONU is online but does not match the update file, the ONU is not updated.
· If an ONU that matches the update file is not online, whether the ONU is updated when it comes online depends on the update protocol.
? If the H3C protocol is used, the ONU is updated after it comes online.
? If the CTC protocol is used, the ONU is not updated after it comes online. To update the ONU, first use the undo update onu command to cancel the update, and execute the update onu command when the ONU is online.
After you use this command in OLT port view, whether the OLT updates a matching ONU that newly comes online depends on the creation time of the corresponding ONU port.
· If the ONU port is created before you execute this command, the ONU will be updated.
· If the ONU port is created after you execute this command, the ONU will not be updated.
# Update the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] update onu filename file.app
Update flash:/file.app?[Y/N] Y
update onu type
Use update onu type to update ONUs by type.
Use undo update onu type to cancel the update configuration for an ONU type.
update onu type onu-type [ protocol-type { h3c | ctc } ] filename filename
undo update onu type onu-type
FTTH view
onu-type: Specifies an ONU type, a case-insensitive string of 1 to 16 characters. The string can contain only letters, numbers, and special characters in Table 22.
Character name |
Symbol |
Character name |
Symbol |
Tilde |
Plus sign |
Exclamation point |
Equal sign |
At sign |
Left brace |
Pound sign |
Right brace |
Dollar sign |
Left bracket |
Percent sign |
Right bracket |
Caret |
Backslash |
Ampersand sign |
Semi-colon |
Left parenthesis |
Apostrophe |
Right parenthesis |
Comma |
Hyphen |
Dot |
Underscore |
_ |
filename: Specifies a file by its name, a string of 1 to 63 characters. The string can contain only letters, numbers, and special characters in Table 22. The file name is formed by the device name and the ONU update file name. If you do not specify a device name, the name of the Flash on the active MPU is used as the device name. The files on the standby MPU cannot be used for the update.
This command enables the OLT to automatically update ONUs that match the specified ONU type and do not have an update file. The OLT updates ONUs as follows:
· If a matching ONU is online, the ONU is updated.
You can update a maximum of 64 types of ONUs at the same time.
# Update all ET704-A-L ONUs.
[Sysname] ftth
[Sysname-ftth] update onu type et704-a-l filename file.app
upstream-sla
Use upstream-sla to specify the uplink bandwidth range for an ONU.
Use undo upstream-sla to restore the default.
upstream-sla { fixed-bandwidth fixed-value | minimum-bandwidth min-value | maximum-bandwidth max-value | weight weight-value } *
undo upstream-sla
The fixed uplink bandwidth is 0 kbps, the minimum uplink bandwidth is 2048 kbps, the maximum uplink bandwidth is 23552 kbps, and the bandwidth allocation weight is 1.
ONU port view
fixed-bandwidth fixed-value: Sets the fixed uplink bandwidth in the range of 0 to 14843. The unit of the fixed-value argument is 64 kbps. For 10G-EPON cards, the value range is 0 to 148430.
minimum-bandwidth min-value: Sets the minimum uplink bandwidth in the range of 8 to 15000. The unit of the min-value argument is 64 kbps. For 10G-EPON cards, the value range is 8 to 135781.
maximum-bandwidth max-value: Sets the maximum uplink bandwidth in the range of 8 to 15625. The unit of the max-value argument is 64 kbps. For 10G-EPON cards, the value range is 8 to 156250.
weight weight-value: Specifies the bandwidth allocation weight in the range of 1 to 20.
Make sure the fixed uplink bandwidth is not greater than the minimum uplink bandwidth.
On a 1G-EPON card, the sum of the minimum uplink bandwidth for all ONU ports of a single OLT port cannot exceed 950 Mbps. On a 10G-EPON card, the sum of the minimum uplink bandwidth for all ONU ports of a single OLT port cannot exceed 9500 Mbps.
# Set the maximum uplink bandwidth to 10240 kbps for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] upstream-sla maximum-bandwidth 160
The maximum-bandwidth of upstream is 10240 kbps
using onu
Use using onu to create ONU ports.
Use undo using onu to delete ONU ports.
using onu onu-number-list
undo using onu onu-number-list
No ONU ports exist.
OLT port view
onu-number-list: Specifies a space-separated list of up to 10 ONU port number items. Each item specifies an ONU port number or a range of ONU port numbers in the format of onu-number1 to onu-number2. The value of onu-number2 cannot be smaller than the value of onu-number1. The value range for ONU port numbers is 1 to 64.
# Create ONU port 1 on OLT 1/0/2.
[Sysname] interface olt 1/0/2
[Sysname-Olt1/0/2] using onu 1
voip-port shutdown
Use voip-port shutdown to shut down a VoIP interface on an ONU.
Use undo voip-port shutdown to bring up a VoIP interface on an ONU.
voip-port port-number shutdown
undo voip-port port-number shutdown
A VoIP interface is down on an ONU.
ONU port view
port-number: Specifies a VoIP interface by its number. The value range for this argument is 1 to the number of VoIP interfaces on the ONU.
# Bring up VoIP interface 1 on the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] undo voip-port 1 shutdown
BCMP proxy commands
bcmp-proxy enable
Use bcmp-proxy enable to enable the BCMP proxy feature.
Use undo bcmp-proxy enable to disable the BCMP proxy feature.
bcmp-proxy enable
The BCMP proxy feature is disabled.
An OLT with this feature enabled operates as a BCMP proxy to forward member registration information and configuration between the BCMP server and BCMP clients.
# Enable the BCMP proxy feature.
[Sysname] bcmp-proxy enable
bcmp-proxy server address
Use bcmp-proxy server address to specify the IP address of the BCMP server.
Use undo bcmp-proxy server address to restore the default.
bcmp-proxy server address ip-address
The IP address of the BCMP server is not specified.
For a BCMP proxy to communicate with a BCMP server, you must specify the IP address of the server on the BCMP proxy.
# Specify 1.1.1.1 as the IP address of the BCMP server.
[Sysname] bcmp-proxy server address 1.1.1.1
bcmp-proxy enable
bcmp-proxy server port
Use bcmp-proxy server port to specify the port number of the BCMP server.
Use undo bcmp-proxy server port to restore the default.
bcmp-proxy server port port-number
The port number of the BCMP server is 5000.
port-number: Specifies a port number in the range of 1 to 65535.
Use this command to specify the UDP port number that the BCMP proxy and the BCMP server use to establish a UDP connection. The BCMP proxy and the BCMP server can communicate only after the UDP connection is set up.
# Specify 2000 as the port number of the BCMP server.
[Sysname] bcmp-proxy server port 2000
bcmp-proxy enable
bcmp-proxy vlan
Use bcmp-proxy vlan to specify the BCMP VLAN.
Use undo bcmp-proxy vlan to restore the default.
bcmp-proxy vlan vlan-id
The BCMP VLAN is 4041.
The BCMP proxy communicates with BCMP clients only in the BCMP VLAN.
# Specify VLAN 100 as the BCMP VLAN.
[Sysname] bcmp-proxy vlan 100
bcmp-proxy enable
