00-Preface | 83.79 KB |
Preface
The H3C S12500-X & S12500X-AF documentation set includes 17 configuration guides. These guides describe the software features for the H3C S12500-X & S12500X-AF Switch Series running Release 1135 and later, and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 3—IP Routing Configuration Guide describes routing fundamentals and configuration. It covers the mainstream routing protocols for IPv4 networks, and describes how to use policies to filter routes and affect routing decisions.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S12500-X & S12500X-AF series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Represents an access point. |
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device. |
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Obtaining documentation
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
