- 11-Network Management and Monitoring Configuration Examples
- 01-H3C_NQA_Configuration_Examples
- 02-H3C_NTP_Configuration_Examples
- 03-H3C_SNMP_Configuration_Examples
- 04-H3C_EAA_Configuration_Examples
- 05-H3C_Mirroring_Configuration_Examples
- 06-H3C_NetStream_Configuration_Examples
- 07-H3C_sFlow_Configuration_Examples
04-H3C_EAA_Configuration_Examples | 115.45 KB |
H3C EAA Configuration Examples
Copyright © 2018 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Example: Configuring an interface event monitor policy by using Tcl
Example: Configuring an interface event monitor policy from the CLI
Example: Configuring a track event monitor policy from the CLI
Introduction
This document provides EAA configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of EAA.
Configure a monitor policy to monitor the incoming traffic statistic on Ten-GigabitEthernet 1/0/1.
Trigger the policy when the following events occur:
· The traffic statistic reaches or exceeds the start threshold (500000000 bps) for the first time.
· The traffic statistic reaches or exceeds the start threshold each time after it reaches or exceeds the restart threshold (200000000 bps).
Configure the policy to execute the following actions when it is triggered:
· Sends the message "XGE1/0/1 input rate exceeded 500000000bps" with a priority of 1 from logging facility local1.
· Displays the current CPU usage statistics, and saves the statistics to the file XGE0_info.txt.
· Displays information about Ten-GigabitEthernet 1/0/1, and saves the information to the file XGE0_info.txt.
Software versions used
This configuration example was created and verified on S10500X-CMW710-R7557.
Procedures
Editing a Tcl script file
# Configure the policy to monitor the incoming traffic on Ten-GigabitEthernet 1/0/1. Set the start and restart thresholds (in bps) to 500000000 and 200000000, respectively.
::comware::rtm::event_register interface ten-gigabitethernet1/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000 user-role network-admin
# Add an action that sends the message "XGE1/0/1 input rate exceeded 500000000bps" with a priority of 1 from the logging facility local1.
::comware::rtm::action syslog priority 1 facility local1 msg "XGE1/0/1 input rate exceeded 500000000bps"
# Enable the action.
::comware::create-cli
# Add an action that displays the current CPU usage statistics and saves the statistics to the file XGE0_info.txt.
::comware::write-cli cli0 "display cpu-usage >> XGE0_info.txt"
# Add an action that displays information about Ten-GigabitEthernet 1/0/1 and saves the information to the file XGE0_info.txt.
::comware::write-cli cli0 "display interface ten-gigabitethernet1/0/1 >> XGE0_info.txt"
::comware::write-cli cli0 "end"
Configuring the device
# Assign an IP address to Ten-GigabitEthernet 1/0/1.
[Device-Ten-GigabitEthernet1/0/1] ip address 192.168.100.66 255.255.255.0
[Device] quit
# Download the Tcl script file test.tcl from the TFTP server at 192.168.100.14.
<Device> tftp 192.168.100.14 get test.tcl
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 189 100 189 0 0 7900 0 --:--:-- --:--:-- --:--:-- 12600
# Create the Tcl-defined policy test and bind it to the Tcl script file. In this example, the script file name is test.tcl.
[Device] rtm tcl-policy test test.tcl
[Device] quit
# Display information about the policy.
<Device> display rtm policy registered
Total number: 1
Type Event TimeRegistered PolicyName
TCL INTERFACE May 05 06:46:20 2014 test
# Verify that XGE0_info.txt was created.
<Device> dir
Directory of cfa0:
0 -rw- 3227 Nov 19 2013 17:28:36 1.cfg
1 -rw- 2296 Apr 26 2013 18:55:08 5660_data.ak
2 -rw- 2304 Apr 26 2013 18:54:56 5660_security.ak
3 -rw- 2298 Apr 26 2013 18:55:16 5660_voice.ak
4 -rw- 3227 Nov 19 2013 17:15:19 STARTUP110.CFG
5 drw- - Mar 10 2013 04:10:10 diagfile
6 -rw- 567 Jul 17 2013 14:25:00 dsakey
7 -rw- 223 Jul 17 2013 14:25:00 ecdsakey
8 -rw- 278 Jul 17 2013 14:25:00 XGE0_info.txt
9 -rw- 735 Jul 17 2013 14:25:00 hostkey
10 -rw- 492 Nov 18 2013 16:40:50 ifindex.dat
11 -rw- 276 Apr 23 2013 19:00:00 lauth.dat
12 drw- - Jul 17 2013 11:26:34 license
13 drw- - Apr 24 2013 12:39:38 logfile
14 -rw- 18839552 Nov 14 2013 16:42:12 msr56-cmw710-boot-r000706.bin
15 -rw- 1150976 Nov 14 2013 16:43:00 msr56-cmw710-data-r000706.bin
16 -rw- 47470592 Nov 14 2013 16:42:24 msr56-cmw710-system-r000706.bin
17 -rw- 2975744 Nov 14 2013 16:42:56 msr56-cmw710-voice-r000706.bin
18 -rw- 70445056 Nov 14 2013 17:41:08 msr56.ipe
19 -rw- 70445056 Nov 14 2013 16:40:00 msr56NN.ipe
20 drw- - Aug 21 2013 16:23:10 pkey
21 -rw- 189 Nov 19 2013 17:49:34 test.tcl
22 drw- - Mar 10 2013 04:10:10 seclog
23 -rw- 591 Jul 17 2013 14:25:00 serverkey
24 -rw- 3227 Nov 18 2013 16:40:50 startup.cfg
507492 KB total (298412 KB free)
# Upload XGE0_info.txt to the TFTP server at 192.168.100.14.
<Device> tftp 192.168.100.14 put XGE0_info.txt
# Verify that XGE0_info.txt contains the CPU usage statistics and information about Ten-GigabitEthernet 1/0/1.
Unit CPU usage:
15% in last 5 seconds
14% in last 1 minute
13% in last 5 minutes
Current state: UP
Line protocol state: UP
Description: Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Internet address: 192.168.100.66/24 (primary)
IP packet frame type: Ethernet II, hardware address: 5cdd-7000-a07c
IPv6 packet frame type: Ethernet II, hardware address: 5cdd-7000-a07c
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T
Port priority: 0
1000Mbps-speed mode, Full-duplex mode
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: 0 hours 0 minutes 14 seconds
Peak input rate: 4 bytes/sec, at 2017-09-21 15:09:37
Peak output rate: 1 bytes/sec, at 2017-09-21 15:09:37
Last 300 seconds input rate: 568710000.25 bytes/sec, 64970 bits/sec, 4.96 packets/sec
Last 300 seconds output rate: 568710000.25 bytes/sec, 64970 bits/sec, 4.96 packets/sec Input (total): 1703 packets, 2336882000 bytes
0 unicasts, 0 broadcasts, 4 multicasts, 0 pauses
Input (normal): 1703 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 1706 packets, 2337062000 bytes
0 unicasts, 5 broadcasts, 0 multicasts, 0 pauses
Output (normal): 1706 packets, - bytes
0 lost carrier, - no carrier
Configuration files
· Tcl script file:
· Device:
port link-mode route
· Sends the message "XGE1/0/1 input rate exceeded 500000000bps" with a priority of 1 from the logging facility local1.
To conserve system resources, limit the policy runtime to 30 seconds. When the runtime is reached, the system stops executing the policy even if the execution is not finished.
When you configure a CLI-defined policy, follow these restrictions and guidelines:
· A monitor policy can contain only one event and one runtime setting. If the monitor policy already contains an event or runtime setting, the new setting replaces the old setting.
· A new action overwrites the previous action with the same ID.
· You must execute the commit command for a CLI-defined policy to take effect. After changing the settings (such as the event, runtime, CLI action, and user role configurations) in the policy, you must re-execute this command for the changes to take effect.
· For EAA to execute an action in a monitor policy, you must assign the policy the user role that has access to the action-specific commands and resources. If EAA lacks access to an action-specific command or resource, EAA does not perform the action and all the subsequent actions.
· You cannot assign a monitor policy user roles that have higher privilege than the user roles you are logged in with.
# Create the CLI-defined policy 1 and enter its view.
[Device] rtm cli-policy 1
[Device-rtm-1] event interface ten-gigabitethernet 1/0/1 monitor-obj rcv-bps start-op ge
# Add an action that sends the message "XGE1/0/1 input rate exceeded 500000000bps" with a priority of 1 from logging facility local1.
[Device-rtm-1] action 1 syslog priority 1 facility local1 msg "XGE1/0/1 input rate exceeded 500000000bps"
[Device-rtm-1] action 2 cli display cpu-usage >> XGE0_info.txt
# Add an action that displays information about Ten-GigabitEthernet 1/0/1, and saves the information to the file XGE0_info.txt.
[Device-rtm-1] action 3 cli display interface ten-gigabitethernet 1/0/1 >> XGE0_info.txt
# Set the policy runtime to 30 seconds.
[Device-rtm-1] running-time 30
# Specify the network-admin user role for executing the policy.
[Device-rtm-1] user-role network-admin
# Enable the policy.
[Device-rtm-1] commit
[Device-rtm-1] quit
Total number: 1
CLI INTERFACE May 04 00:12:40 2014 1
<Device> dir
Directory of cfa0:
# Verify that XGE0_info.txt contains the current CPU usage statistics and information about Ten-GigabitEthernet 1/0/1.
Unit CPU usage:
Current state: UP
Loopback is not set
Port priority: 0
Configuration files
rtm cli-policy 1
event interface Ten-GigabitEthernet1/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000
running-time 30
As shown in Figure 1, Device A has established BGP sessions with Device D and Device E. Traffic from Device D and Device E to the Internet is forwarded through Device A.
Configure a CLI-defined EAA monitor policy on Device A to disconnect the sessions with Device D and Device E when Ten-GigabitEthernet 1/0/1 connected to Device C is down. As a result, traffic from Device D and Device E to the Internet is forwarded through Device B.
# Display BGP peer information for Device A.
<DeviceA> display bgp peer ipv4
BGP local router ID: 1.1.1.1
Local AS number: 100
Total number of peers: 3 Peers in established state: 3
* - Dynamically created peer
10.2.1.2 200 13 16 0 0 00:16:12 Established
10.3.1.2 300 13 16 0 0 00:10:34 Established
10.3.2.2 300 13 16 0 0 00:10:38 Established
# Create track entry 1 and associate it with the link state of Ten-GigabitEthernet 1/0/1.
[DeviceA] track 1 interface ten-gigabitethernet 1/0/1
# Configure a CLI-defined EAA monitor policy so that the system automatically disables session establishment with Device D and Device E when Ten-GigabitEthernet 1/0/1 is down.
[DeviceA] rtm cli-policy test
[DeviceA-rtm-test] event track 1 state negative
[DeviceA-rtm-test] action 0 cli system-view
[DeviceA-rtm-test] action 1 cli bgp 100
[DeviceA-rtm-test] action 2 cli peer 10.3.1.2 ignore
[DeviceA-rtm-test] action 3 cli peer 10.3.2.2 ignore
[DeviceA-rtm-test] user-role network-admin
[DeviceA-rtm-test] commit
[DeviceA-rtm-test] quit
# Shut down Ten-GigabitEthernet 1/0/1.
[H3C-Ten-GigabitEthernet1/0/1] shutdown
# Display BGP peer information.
Total number of peers: 0 Peers in established state: 0
Configuration files
rtm cli-policy test
user-role network-operator
Related documentation
· H3C S10500X Switch Series Network Management and Monitoring Configuration Guide-R7557
· H3C S10500X Switch Series Network Management and Monitoring Command Reference-R7557
