- 12-Security Configuration Guide
- 01-Security zone configuration
- 02-AAA configuration
- 03-Portal configuration
- 04-User profile configuration
- 05-Password control configuration
- 06-Keychain configuration
- 07-Public key management
- 08-PKI configuration
- 09-IPsec configuration
- 10-Group domain VPN configuration
- 11-SSH configuration
- 12-SSL configuration
- 13-SSL VPN configuration
- 14-ASPF configuration
- 15-APR configuration
- 16-mGRE configuration
- 17-Session management
- 18-Connection limit configuration
- 19-Object group configuration
- 20-Object policy configuration
- 21-Attack detection and prevention configuration
- 22-ARP attack protection configuration
- 23-uRPF configuration
- 24-Crypto engine configuration
- 25-FIPS configuration
17-Session management | 352.63 KB |
Restrictions and guidelines: Session management configuration
Setting the session aging time for different protocol states
Setting the session aging time for different application layer protocols or applications
Specifying persistent sessions
Enabling session synchronization
Enabling session statistics collection software fast forwarding
Enabling top session statistics
Specifying the mode for session state machine
Display and maintenance commands for session management
Managing sessions
About session management
Session management is a common module, providing basic services for NAT, ASPF, and attack detection and protection to implement their session-based services.
Session management defines packet exchanges at transport layer as sessions. It updates session states and ages out sessions according to data flows from the initiators or responders. Session management allows multiple features to process the same service packet.
Session management operation
Session management tracks the session status by inspecting the transport layer protocol information. It performs unified status maintenance and management of all connections based on session tables and relation tables.
When a connection request passes through the device from a client to a server, the device creates a session entry. The entry can contain the request and response information, such as:
· Source IP address and port number.
· Destination IP address and port number.
· Transport layer protocol.
· Application layer protocol.
· Protocol state of the session.
A multichannel protocol requires that the client and the server negotiate a new connection based on an existing connection to implement an application. Session management enables the device to create a relation entry for each connection during the negotiation phase. The entry is used to associate the connection with the application. Relation entries will be removed after the associated connections are established.
If the destination IP address of a packet is a multicast IP address, the packet will be forwarded out of multiple ports. When a multicast connection request is received on an inbound interface, the device performs the following operations:
· Creates a multicast session entry on the inbound interface.
· Creates a corresponding multicast session entry for each outbound interface.
Unless otherwise stated, "session entry" in this chapter refers to both unicast and multicast session entries.
In actual applications, session management works with security modules to dynamically determine whether a packet can pass the firewall and enter the internal network according to connection status, thus preventing intrusion.
Session management only tracks connection status. It does not block potential attack packets.
Session management functions
Session management enables the device to provide the following functions:
· Creates sessions for protocol packets, updates session states, and sets aging time for sessions in different protocol states.
· Supports port mapping for application layer protocols (see "Configuring APR"), enabling application layer protocols to use customized ports.
· Sets aging time for sessions based on application layer protocols.
· Supports ICMP/ICMPv6 error packet mapping, enabling the device to search for original sessions according to the payloads in the ICMP/ICMPv6 error packets.
Because error packets are generated due to host errors, the mapping can help speed up the aging of the original sessions.
· Supports persistent sessions, which are kept alive for a long period of time.
· Supports session management for the control channels and dynamic data channels of application layer protocols, for example, FTP.
· Supports real-time synchronization for sessions and for dynamic entries of session-based services, such as .
For a TCP session in ESTABLISHED state, the priority order of the associated aging time is as follows:
· Aging time for persistent sessions.
· Aging time for sessions of application layer protocols.
· Aging time for sessions in different protocol states.
If the device has excessive sessions, do not set the aging time shorter than the default for a certain protocol state or an application layer protocol. Short aging time settings can make the device slow in response.
About protocol state-based session aging
If a session in a certain protocol state has no packet hit before the aging time expires, the device automatically removes the session.
1. Enter system view.
2. Set the session aging time for different protocol states.
session aging-time state { fin | icmp-reply | icmp-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
The default aging time for sessions in different protocol states is as follows:
¡ FIN_WAIT: 30 seconds.
¡ ICMP-REPLY: 30 seconds.
¡ ICMP-REQUEST: 60 seconds.
¡ RAWIP-OPEN: 30 seconds.
¡ RAWIP-READY: 60 seconds.
¡ TCP SYN-SENT and SYN-RCV: 30 seconds.
¡ TCP-CLOSE: 2 seconds.
¡ TCP ESTABLISHED: 3600 seconds.
¡ TCP-TIME-WAIT: 2 seconds.
¡ UDP-OPEN: 30 seconds.
¡ UDP-READY: 60 seconds.
About application layer protocol-based session aging
The aging time for sessions of different application layer protocols or applications are valid for TCP sessions in ESTABLISHED state or UDP sessions in READY state. For sessions used by other application layer protocols, the aging time for sessions in different protocol states applies.
Supported application layer protocols or applications specified in this command depend on the APR module. For information about APR, see "Configuring APR."
2. Set the session aging time for different application layer protocols.
session aging-time application application-name time-value
By default, the aging time is 1200 seconds for sessions of application layer protocols or applications except for the following sessions:
¡ BOOTPC sessions: 120 seconds.
¡ BOOTPS sessions: 120 seconds.
¡ DNS sessions: 1 second.
¡ FTP sessions: 3600 seconds.
¡ FTP-DATA sessions: 240 seconds.
¡ GPRS-DATA sessions: 60 seconds.
¡ GPRS-SIG sessions: 60 seconds.
¡ GTP-CONTROL sessions: 60 seconds.
¡ GTP-USER sessions: 60 seconds.
¡ H.225 sessions: 3600 seconds.
¡ H.245 sessions: 3600 seconds.
¡ HTTPS sessions: 600 seconds.
¡ ILS sessions: 3600 seconds.
¡ L2TP sessions: 120 seconds.
¡ MGCP-CALLAGENT sessions: 60 seconds.
¡ MGCP-GATEWAY sessions: 60 seconds.
¡ NETBIOS-DGM sessions: 3600 seconds.
¡ NETBIOS-NS sessions: 3600 seconds.
¡ NETBIOS-SSN sessions: 3600 seconds.
¡ NTP sessions: 120 seconds.
¡ PPTP sessions: 3600 seconds.
¡ QQ sessions: 120 seconds.
¡ RAS sessions: 300 seconds.
¡ RIP sessions: 120 seconds.
¡ RSH sessions: 60 seconds.
¡ RTSP session: 3600 seconds.
¡ SCCP sessions: 3600 seconds.
¡ SIP sessions: 300 seconds.
¡ SNMP sessions: 120 seconds.
¡ SNMPTRAP sessions: 120 seconds.
¡ SQLNET sessions: 600 seconds.
¡ STUN sessions: 600 seconds.
¡ SYSLOG sessions: 120 seconds.
¡ TACACS-DS sessions: 120 seconds.
¡ TFTP sessions: 60 seconds.
¡ WHO sessions: 120 seconds.
¡ XDMCP sessions: 3600 seconds.
About persistent sessions
This task is only for TCP sessions in ESTABLISHED state. You can specify TCP sessions that match the permit statements in the specified ACL as persistent sessions, and set longer lifetime or never-age-out persistent sessions.
A persistent session is not removed until one of the following events occurs:
· The session entry ages out.
· The device receives a connection close request from the initiator or responder.
· You manually clear the session entries.
2. Specify persistent sessions.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
About session synchronization
This feature enables devices to synchronize sessions and dynamic entries of session-based services. Typically, these devices back up each other and use a virtual IP address to communicate with a peer device. When the primary device fails, a backup device takes over to process and forward service traffic. The failover process is transparent to the peer device, and does not interrupt ongoing services.
This feature also provides automatic backup service for the device. The system automatically backs up session tables and relation tables that are generated by applications that use ALG. These applications include H.323, SIP, and ILS.
Enable session synchronization for DNS and HTTP in the following situations:
· Users are aware that the current HTTP or DNS sessions will last for a long time.
· HTTP or DNS session backup is required.
In a network that has asymmetric traffic, heavy service traffic might cause service delay or service unavailable because sessions cannot be backed up timely. For example, one device forwards the TCP SYN packets, and another device forwards its ACK packets. If the session tables of the two devices are not synchronized, the TCP packets will be dropped because of state error. To resolve this issue, enable session synchronization for asymmetric traffic.
On an IRF fabric, the NAT configuration is dependent of session synchronization. If session synchronization is enabled, make sure NAT is configured on global interfaces such as aggregate interfaces and redundant interfaces. If you configure NAT on physical ports, disable session synchronization as a best practice.
2. Enable session synchronization.
session synchronization enable [ asymmetric ]
By default, session synchronization is disabled.
After session synchronization is enabled, session synchronization is enabled for all application layer protocols except DNS and HTTP by default.
3. (Optional.) Enable session synchronization for DNS, HTTP, or both.
session synchronization { dns | http }*
By default, session synchronization is disabled for DNS and HTTP.
About session statistics collection for software fast forwarding
This feature enables the device to collect session-based outbound and inbound packets and bytes. You can display session statistics based on different criteria.
· To display statistics per unicast session, use the display session table command.
· To display statistics per unicast packet type, use the display session statistics command.
· To display statistics per multicast session, use the display session table multicast command.
· To display statistics per multicast packet type, use the display session statistics multicast command.
2. Enable session statistics collection for software fast forwarding.
session statistics enable
By default, session statistics collection is disabled for software fast forwarding.
About top session statistics
This feature collects the number of sessions for session-based services and ranks the sessions by source address and by destination address separately.
2. Enable the top session statistics feature.
session top-statistics enable
By default, the top session statistics feature is disabled.
3. (Optional.) Display top session statistics.
display session top-statistics { last-1-hour | last-24-hours | last-30-days }
About specifying the mode for session state machine
When asymmetric-path traffic exists in a hot backup system operating in session active/standby mode, set the mode of session state machine to loose to avoid abnormal traffic loss.
When asymmetric-path traffic exists in a hot backup system operating in session dual-active mode, set the mode of session state machine to compact for disconnected sessions to age out timely.
As a best practice, change the mode of session state machine only when asymmetric-path traffic exists. This feature degrades performance of session-based security check. Make sure you are fully aware of its impact when you use it on a live network.
2. Specify the mode for session state machine.
session state-machine mode { compact | loose }
By default, session state machine is in strict mode.
Configuring session logging
About session logging
Session logs provide information about user access, IP address translation, and network traffic for security auditing. These logs are sent to the log server or the information center.
The device supports time-based or traffic-based logging:
· Time-based logging—The device outputs session logs regularly.
· Traffic-based logging—The device outputs a session log when the traffic amount of a session reaches a threshold only when the session statistics collection for software fast forwarding feature is enabled. After outputting a session log, the device resets the traffic counter for the session. The traffic-based thresholds can be byte-based and packet-based. If you set both thresholds, the last configuration takes effect.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
If you enable session logging but do not enable logging for session creation or deletion, the device does not output a session log when a session entry is created or removed.
The session logging feature must work with the flow log or fast log output feature to generate session logs. Session logs can be output in flow log or fast log output format. By default, they are output in flow log format. For information about flow log and fast log output, see Network Management and Monitoring.
2. (Optional.) Set the threshold for time-based session logging.
session log time-active time-value
By default, no threshold is set for time-based session logging.
3. (Optional.) Set a threshold for traffic-based logging.
session log { bytes-active bytes-value | packets-active packets-value }
By default, no threshold is set for traffic-based logging.
4. (Optional.) Enable logging for session creation.
session log flow-begin
By default, logging for session creation is disabled.
5. (Optional.) Enable logging for session deletion.
session log flow-end
By default, logging for session deletion is disabled.
6. Enter interface view.
7. Enable session logging.
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
By default, session logging is disabled.
Task |
Command |
Display the aging time for sessions of different application layer protocols. |
display session aging-time application |
Display the aging time for sessions in different protocol states. |
display session aging-time state |
Display relation table entries. |
In standalone mode: display session relation-table { ipv4 | ipv6 } [ slot slot-number ] In IRF mode: display session relation-table { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ] |
Display unicast session statistics. |
In standalone mode: display session statistics [ history-max | summary ] [ slot slot-number ] In IRF mode: display session statistics [ history-max | summary ] [ chassis chassis-number slot slot-number ] |
Display IPv4 unicast session statistics. |
In standalone mode: display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ] In IRF mode: display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ chassis chassis-number slot slot-number ] |
Display IPv6 unicast session statistics. |
In standalone mode: display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ] In IRF mode: display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ chassis chassis-number slot slot-number ] |
Display multicast session statistics. |
In standalone mode: display session statistics multicast [ slot slot-number ] In IRF mode: display session statistics multicast [ chassis chassis-number slot slot-number ] |
Display IPv4 unicast session table entries. |
In standalone mode: display session table ipv4 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ] In IRF mode: display session table ipv4 [ chassis chassis-number slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ] |
Display IPv6 unicast session table entries. |
In standalone mode: display session table ipv6 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ] In IRF mode: display session table ipv6 [ chassis chassis-number slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ] |
Display IPv4 multicast session table entries. |
In standalone mode: display session table multicast ipv4 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ] In IRF mode: display session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ] |
Display IPv6 multicast session table entries. |
In standalone mode: display session table multicast ipv6 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ] In IRF mode: display session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ] |
Display top session statistics. |
display session top-statistics { last-1-hour | last-24-hours | last-30-days } |
Clear relation table entries. |
In standalone mode: reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ] In IRF mode: reset session relation-table [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ] |
Clear unicast session statistics. |
In standalone mode: reset session statistics [ slot slot-number ] In IRF mode: reset session statistics [ chassis chassis-number slot slot-number ] |
Clear multicast session table entries. |
In standalone mode: reset session statistics multicast [ slot slot-number ] In IRF mode: reset session statistics multicast [ chassis chassis-number slot slot-number ] |
Clear IP unicast session table entries. |
In standalone mode: reset session table [ slot slot-number ] In IRF mode: reset session table [ chassis chassis-number slot slot-number ] |
Clear IPv4 unicast session table entries. |
In standalone mode: reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv6 unicast session table entries. |
In standalone mode: reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IP multicast session table entries. |
In standalone mode: reset session table multicast [ slot slot-number ] In IRF mode: reset session table multicast [ chassis chassis-number slot slot-number ] |
Clear IPv4 multicast session table entries. |
In standalone mode: reset session table multicast ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
Clear IPv6 multicast session table entries. |
In standalone mode: reset session table multicast ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] In IRF mode: reset session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ] |
