02-QoS commands | 975.00 KB |
display qos policy control-plane
display qos policy control-plane management
display qos policy control-plane management pre-defined
display qos policy control-plane pre-defined
display qos policy user-profile
qos apply policy (user profile view)
reset qos policy control-plane
reset qos policy control-plane management
QoS policy-based traffic rate statistics collection period commands
Traffic policing, GTS, and rate limit commands
Congestion management commands
display qos queue pq interface
display qos queue cq interface
display qos queue rtpq interface
QoS policy commands
Traffic class commands
display traffic classifier
Use display traffic classifier to display traffic classes.
In standalone mode:
display traffic classifier { system-defined | user-defined } [ classifier-name ] [ slot slot-number ]
In IRF mode:
display traffic classifier { system-defined | user-defined } [ classifier-name ] [ chassis chassis-number slot slot-number ]
system-defined: Specifies system-defined traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the traffic classes for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic classes for the global active MPU. (In IRF mode.)
# Display all user-defined traffic classes.
User-defined classifier information:
Classifier: 1 (ID 100)
Operator: AND
Rule(s) :
If-match acl 2000
Classifier: 2 (ID 101)
Operator: AND
Rule(s) :
If-match protocol ipv6
Classifier: 3 (ID 102)
Operator: AND
Rule(s) :
-none-
# Display the system-defined traffic class (default-class).
<Sysname> display traffic classifier system-defined default-class
System-defined classifier information:
Classifier: default-class (ID 0)
Operator: AND
Rule(s) :
If-match any
Classifier |
Traffic class name and its match criteria. |
Operator |
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria. |
Rule(s) |
Match criteria. |
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match [ not ] match-criteria
undo if-match [ not ] match-criteria
No match criterion is configured.
Traffic class view
not: Matches packets that do not conform to the specified criterion.
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option |
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } |
Matches an ACL. The value range for the acl-number argument is as follows: · 2000 to 3999 for IPv4 ACLs. · 2000 to 3999 for IPv6 ACLs. · 4000 to 4999 for Layer 2 ACLs. · 5000 to 5999 for user-defined ACLs. The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all. |
app-group group-name |
Matches an application group. The group-name argument specifies an application group by its name. The application group must have been created. A nonexistent application group cannot match packets. For more information about creating application groups, see APR in Security Configuration Guide. |
application app-name |
Matches an application. The app-name argument specifies a user-created application by its name. |
any |
Matches all packets. |
classifier classifier-name |
Matches a class. The classifier-name argument specifies a class by its name. |
control-plane protocol protocol-name&<1-8> |
Matches control plane protocols. The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3. |
control-plane protocol-group protocol-group-name |
Matches a control plane protocol group. The protocol-group-name argument can be critical, exception, important, management, monitor, normal, or redirect. |
customer-dot1p dot1p-value&<1-8> |
Matches 802.1p priority values in inner VLAN tags of double-tagged packets. The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7. |
destination-mac mac-address |
Matches a destination MAC address. This option takes effect only on Ethernet interfaces. |
dscp dscp-value&<1-8> |
Matches DSCP values. The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5. |
inbound-interface interface-type interface-number |
Matches an input interface specified by its type and number. |
ip-precedence ip-precedence-value&<1-8> |
Matches IP precedence values. The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7. |
local-precedence local-precedence-value&<1-8> |
Matches local precedence values. The local-precedence-value&<1-8> argument specifies a space-separated list of up to eight local precedence values. The value range for the local-precedence-value argument is 0 to 7. |
mpls-exp exp-value&<1-8> |
Matches MPLS EXP values. The exp-value&<1-8> argument specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. For devices that forward packets in software, MPLS packets do not support IP-related match criteria. |
packet-length { min min-value | max max-value } * |
Matches the packet length. The min-value argument specifies the minimum packet length in bytes. The max-value argument specifies the maximum packet length in bytes. The maximum packet length must be greater than or equal to the minimum packet length. |
protocol protocol-name |
Matches a protocol. The protocol-name argument can be arp, ip, bittorrent, or ipv6. |
qos-local-id local-id-value |
Matches a local QoS ID in the range of 1 to 4095. |
rtp payload-type { type-value&<0-16> | audio | video } * |
Matches RTP payload types. The type-value&<0-16> argument specifies a space-separated list of up to 16 RTP payload type values. The value range for the type-value argument is 0 to 127. The audio keyword matches an RTP payload type value in the range of 0 to 23 or 33. The video keyword matches an RTP payload type value in the range of 24 to 34. |
rtp start-port start-port-number end-port end-port-number |
Matches RTP protocol ports. The value ranges for the start-port-number and end-port-number arguments are both 2000 to 65535. This criterion matches RTP packets with an even UDP destination port number in the specified RTP port number range. |
second-mpls-exp exp-value&<1-8> |
Matches inner MPLS EXP values. The exp-value&<1-8> argument is a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7. For devices that forward packets in software, MPLS packets do not support IP-related match criteria. |
source-mac mac-address |
Matches a source MAC address. This option takes effect only on Ethernet interfaces. |
tunnel-dscp dscp-value&<1-8> |
Matches the DSCP value in the outer IP header of VXLAN packets. The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5. |
Table 3 Available system-defined control plane protocols
Protocol |
default |
Protocol packets other than the following packet types |
arp |
ARP packets |
bfd |
BFD packets |
bgp |
BGP packets |
bgp4+ |
IPv6 BGP packets |
ftp |
FTP packets |
http |
HTTP packets |
https |
HTTPS packets |
icmp |
ICMP packets |
icmpv6 |
ICMPv6 packets |
igmp |
IGMP packets |
isis |
IS-IS packets |
ldp |
LDP packets |
ldp6 |
IPv6 LDP packets |
msdp |
MSDP packets |
ntp |
NTP packets |
ospf-multicast |
OSPF multicast packets |
ospf-unicast |
OSPF unicast packets |
ospf3-multicast |
OSPFv3 multicast packets |
ospf3-unicast |
OSPFv3 unicast packets |
pim-multicast |
PIM multicast packets |
pim-unicast |
PIM unicast packets |
pim6-multicast |
IPv6 PIM multicast packets |
pim6-unicast |
IPv6 PIM unicast packets |
radius |
RADIUS packets |
rip |
RIP packets |
ripng |
RIPng packets |
rsvp |
RSVP packets |
snmp |
SNMP packets |
ssh |
SSH packets |
tacacs |
TACACS packets |
telnet |
Telnet packets |
tftp |
TFTP packets |
vrrp |
VRRP packets |
vrrp6 |
IPv6 VRRP packets |
In a traffic class with the logical OR operator, you can configure multiple if match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
· You can specify up to eight values for any of the following match criteria in one if-match command:
¡ Control plane protocol.
¡ 802.1p priority.
¡ DSCP.
¡ IP precedence.
¡ Local precedence.
¡ MPLS EXP.
· If a packet matches one of the specified values, it matches the if-match command.
· To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
· The ACL must already exist.
· The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
You can use both AND and OR operators to define the match relationships between the criteria for a class. For example, you can define relationships among three match criteria in traffic class classA as follows:
traffic classifier classB operator and
if-match criterion 1
if-match criterion 2
traffic classifier classA operator or
if-match criterion 3
if-match classifier classB
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match the packets with a local precedence value of 1 or 6.
[Sysname-classifier-class1] if-match local-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match the RTP packets with even UDP destination port numbers in the range of 16384 to 32767.
[Sysname-classifier-class1] if-match rtp start-port 16384 end-port 32767
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class to match the RTP packets with payload type 1, 8, audio, or video.
[Sysname-behavior-class] if-match rtp payload-type 1 8 audio video
# Define a match criterion for traffic class class1 to match the packets of the application group multimedia.
[Sysname-classifier-class1] if-match app-group multimedia
# Define a match criterion for traffic class class1 to match the packets of the application 3link.
[Sysname-classifier-class1] if-match application 3link
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match packets with the length in the range of 100 to 200 bytes.
[Sysname-classifier-class1] if-match packet-length min 100 max 200
# Define a match criterion for traffic class class1 to match packets with DSCP value 10 in the outer IP header of VXLAN packets.
[Sysname-classifier-class1] if-match tunnel-dscp 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
Traffic behavior commands
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
Traffic behavior view
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 40000000 kbps.
cbs committed-burst-size: Specifies the committed burst size (CBS) in the range of 1000 to 1000000000 bytes. The default value for this argument is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the excess burst size (EBS) in the range of 0 to 1000000000 bytes. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 40000000 kbps. The PIR must be specified in the same unit as the CIR.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-atmclp-pass new-atmclp: Sets the CLP flag bit of the ATM packet to new-atmclp and permits the packet to pass through. The new-atmclp is in the range of 0 to 1.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
· remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
· remark-mpls-exp-pass new-exp: Sets the EXP field value of the MPLS packet to new-exp and permits the packet to pass through. The new-exp argument is in the range of 0 to 7.
· remark-prec-pass new-precedence: Sets the IP precedence of the packet to new-precedence and permits the packet to pass through. The new-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
· Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
· Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
car percent
Use car percent to configure a CAR action in percentage in a traffic behavior.
car cir percent cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
car cir percent cir-percent [ cbs cbs-time ] pir percent pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
undo car
No percentage-based CAR action is configured.
cir percent cir-percent: Specifies the CIR in percentage, in the range of 1 to 100. The actual CIR value is cir-percent × interface bandwidth.
cbs cbs-time: Specifies the CBS in milliseconds. The actual CBS value is cbs-time × the actual CIR value. The value range for the cbs-time argument is 50 to 2000. The default CBS is the product of 62.5 and the CIR.
ebs ebs-time: Specifies the EBS in milliseconds. The actual EBS value is ebs-time × the actual CIR value. The value range for the ebs-time argument is 0 to 2000. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
pir percent pir-percent: Specifies the PIR in percentage, in the range of 1 to 100. The PIR value must be greater than or equal to the CIR value.
green action: Specifies the action to take on packets that conform to the CIR. The default is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default is pass.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-lp-pass new-lp: Sets the local precedence value of the packet to new-lp and permits the packet to pass through. The new-lp argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the car percent command with the pir percent pir-percent option. To use one rate for traffic policing, configure the car percent command without the pir percent pir-percent option.
A QoS policy that uses a traffic behavior configured with percentage-based CAR can be applied in the inbound or outbound direction of an interface.
If you execute the car percent command multiple times in the same traffic behavior, the most recent configuration takes effect.
A QoS policy that uses a behavior configured with percentage-based CAR can be applied only to interfaces.
The actual CIR value is cir-percent × bandwidth. The actual PIR value is pir-percent × bandwidth. For a physical interface, the bandwidth is the actual interface bandwidth. For a virtual interface, you must set its expected bandwidth (the default expected bandwidth is 0 kbps). For more information about the expected bandwidth, see Ethernet interface commands in Interface Management Command Reference. In the policy nesting case, the bandwidth used for the CIR and PIR calculations is determined by using the following rules:
· The top policy uses the interface bandwidth.
· A child policy uses the CIR value in GTS configured in the behavior of the child policy.
· If the CIR value is not available in the behavior, the child policy uses the CIR value in GTS configured in the behavior of the higher-level policy.
· If the CIR value is not available in the behavior of the higher-level policy, the child policy uses the interface bandwidth.
# Configure a CAR action in percentage in traffic behavior database. The CAR parameters are as follows: CIR is 20% and CBS is 100 ms.
[Sysname-behavior-database] car cir percent 20 cbs 100
display traffic behavior
Use display traffic behavior to display traffic behaviors.
In standalone mode:
display traffic behavior { system-defined | user-defined } [ behavior-name ] [ slot slot-number ]
In IRF mode:
display traffic behavior { system-defined | user-defined } [ behavior-name ] [ chassis chassis-number slot slot-number ]
system-defined: Specifies system-defined traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays traffic behaviors for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic behaviors for the global active MPU. (In IRF mode.)
# Display all user-defined traffic behaviors.
User-defined behavior information:
Behavior: 1 (ID 100)
Marking:
Remark dscp 3
Committed Access Rate:
CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Primap pre-defined table: dscp-dp
Assured Forwarding:
Bandwidth 30 (kbps)
Discard Method: Tail
Behavior: 2 (ID 101)
Accounting enable: Packet
Filter enable: Permit
Marking:
Remark mpls-exp 4
Redirecting:
Redirect to the CPU
Mirroring:
Mirror to the VLAN: VLAN 1000
Expedited Forwarding:
Bandwidth 50 (kbps) CBS 1250 (Bytes)
Behavior: 3 (ID 102)
-none-
# Display all system-defined traffic behaviors.
<Sysname> display traffic behavior system-defined
System-defined behavior information:
Behavior: be (ID 0)
-none-
Behavior: af (ID 1)
Assured Forwarding:
Bandwidth 20 (%)
Behavior: ef (ID 2)
Bandwidth 20 (%) Cbs-ratio 25
Behavior: be-flow-based (ID 3)
Flow based Weighted Fair Queue:
Max number of hashed queues: 256
Discard Method: IP Precedence based WRED
Exponential Weight: 9
Pre Low High Dis-prob
0 10 30 10
1 10 30 10
2 10 30 10
3 10 30 10
4 10 30 10
5 10 30 10
6 10 30 10
7 10 30 10
Behavior |
Name and contents of a traffic behavior. |
Marking |
Information about priority marking. |
Remark dscp |
Action of setting the DSCP value for packets. |
Committed Access Rate |
Information about the CAR action. |
Green action |
Action to take on green packets. |
Yellow action |
Action to take on yellow packets. |
Red action |
Action to take on red packets. |
Assured Forwarding |
Assure forwarding (AF) information. |
Bandwidth |
Bandwidth of the queue. |
Filter enable |
Traffic filtering action. |
none |
No other traffic behavior is configured. |
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
gts
Use gts to configure a GTS action in absolute value in a traffic behavior.
Use undo gts to restore the default.
gts cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
undo gts
No GTS action is configured.
cir committed-information-rate: Sets the CIR in kbps, which specifies the average traffic rate. The value range for committed-information-rate is 8 to 40000000.
cbs committed-burst-size: Sets the CBS in bytes, which specifies the size of bursty traffic when the actual average rate is not greater than the CIR. The value range for committed-burst-size is 1000 to 1000000000. The default CBS is the product of 62.5 and the CIR.
ebs excess-burst-size: Sets the EBS in bytes. The value range for peak-information-rate is 0 to 1000000000. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
queue-length queue-length: Sets the maximum number of packets allowed in the queue. The default is 50. The value range for queue-length is 1 to 1024.
A QoS policy that uses a behavior configured with GTS can be applied only to the outbound direction of an interface.
A QoS policy that uses a behavior configured with GTS overwrites the qos gts command on the interface, if both are configured.
If you execute the gts command multiple times in the same traffic behavior, the most recent configuration takes effect.
To use two rates for traffic shaping, configure the gts command with the pir peak-information-rate option. To use one rate for traffic shaping, configure the gts command without the pir peak-information-rate option.
# Configure a GTS action in absolute value in traffic behavior database. The GTS parameters are as follows: CIR is 200 kbps, CBS is 51200 bytes, EBS is 0, and the maximum queue length is 100.
[Sysname-behavior-database] gts cir 200 cbs 51200 ebs 0 queue-length 100
gts percent
gts percent
Use gts percent to configure a GTS action in percentage in a traffic behavior.
gts percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ queue-length queue-length ]
undo gts
No percentage-based GTS action is configured.
cir cir-percent: Specifies the CIR in percentage, in the range of 1 to 100. The actual CIR value is cir-percent × interface bandwidth.
cbs cbs-time: Specifies the CBS in milliseconds. The default cbs-time is 500 milliseconds. The actual CBS value is cbs-time × the actual CIR value. The value range for cbs-time is 1 to 100. The default CBS is the product of 62.5 and the CIR.
ebs ebs-time: Specifies the EBS in milliseconds. The default ebs-time is 0 milliseconds. The actual EBS value is ebs-time × the actual CIR value. The value range for ebs-time is 0 to 2000. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
queue-length queue-length: Specifies the maximum number of packets allowed in the queue. The default is 50. The value range for queue-length is 1 to 1024.
A QoS policy that uses a behavior configured with percentage-based GTS can be applied only to the outbound direction of an interface.
A QoS policy that uses a behavior configured with percentage-based GTS overwrites the qos gts command on the interface, if both configured.
If you execute the gts percent command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a GTS action in percentage in traffic behavior database. The GTS parameters are as follows: CIR is 50 and CBS is 200 ms.
[Sysname-behavior-database] gts percent cir 50 cbs 200
gts
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark dot1p dot1p-value
undo remark dot1p
No 802.1p priority marking is configured.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
remark dscp dscp-value
undo remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
On devices that forward packets in hardware, the remark dscp and remark tunnel-dscp commands are mutually exclusive with each other in the same traffic behavior.
If you execute the remark dscp command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with DSCP 6.
remark ip-precedence
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to restore the default.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
On devices that forward packets in hardware, the remark ip-precedence and remark tunnel-dscp commands are mutually exclusive with each other in the same traffic behavior.
If you execute the remark ip-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark local-precedence local-precedence-value
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
remark service-class
Use remark service-class to configure an MPLS TE service class marking action in a traffic behavior.
Use undo remark service-class to restore the default.
remark service-class service-class-value
No MPLS TE service class marking action is configured.
service-class-value: Specifies the MPLS TE service class to be marked for packets. The value range for this argument is 0 to 127.
This command is used only in CBTS to mark the MPLS TE service class for packets. For more information about CBTS, see MPLS TE in MPLS Configuration Guide.
You can use the mpls te service-class command to set an MPLS TE service class value for a tunnel. For more information about this command, see MPLS TE commands in MPLS Command Reference.
If the remark service-class command is configured in a QoS policy:
· On a device that forward packets in software, the QoS policy can be applied only to the inbound direction of an interface.
· On a device that forward packets in hardware, the QoS policy can be applied only to an interface. The remark service-class command takes effect only in the inbound direction of an interface. You can use the display qos policy interface command to display the traffic behaviors that do not take effect.
If you execute the remark service-class command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure the action of marking MPLS TE service class 2 for packets.
[Sysname-behavior-data] remark service-class 2
remark tunnel-dscp
Use remark tunnel-dscp to configure an outer DSCP marking action in a traffic behavior.
Use undo remark tunnel-dscp to restore the default.
remark tunnel-dscp dscp-value
No outer DSCP marking action is configured.
dscp-value: Specifies the DSCP value to be set for the outer IP header of tunneled packets. The DSCP value can be a number from 0 to 63 or a keyword in Table 5.
This command takes effect on the following packets:
· GRE packets.
· VXLAN packets.
· IPv4 over IPv4 tunneled packets.
· IPv6 over IPv4 tunneled packets.
· IPv6 tunneled packets.
· MPLS TE tunneled packets.
The outer DSCP value marking action takes effect only when the QoS policy is applied to an interface.
On devices that forward packets in hardware, the remark tunnel-dscp command is mutually exclusive with the remark dscp or remark ip-precedence command in one traffic behavior.
If you execute the remark tunnel-dscp command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior data to mark matching packets with DSCP value 2 in the outer IP header of tunneled packets.
[Sysname-behavior-data] remark tunnel-dscp 2
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
traffic-policy
Use traffic-policy to nest a policy in a traffic behavior.
Use undo traffic-policy to remove child policies from a traffic behavior.
traffic-policy policy-name
undo traffic-policy
No policy is nested in a traffic behavior.
policy-name: Specifies a policy by its name, a string of 1 to 31 characters. If the policy does not exist, it is automatically created.
After you nest a child policy in a behavior of a parent policy, the system performs the following operations:
· Performs the associated behavior defined in the parent policy for a class of traffic.
· Uses the child policy to further classify the class of traffic and performs the behaviors defined in the child policy.
When you nest QoS policies, follow these guidelines:
· A parent policy can nest up to two layers of child policies. This child policy cannot be the parent policy itself.
· You can nest only one child policy at one layer of a behavior.
· To configure CBQ in the child policy successfully, configure GTS in the parent policy. Make sure the configured GTS bandwidth is greater than CBQ bandwidth configured in the child policy.
· If GTS bandwidth is set in percentage in the parent policy, you must set CBQ bandwidth in percentage in the child policy. If GTS bandwidth is set as an absolute value in the parent policy, you can set CBQ bandwidth in either format in the child policy.
· A child policy cannot contain GTS actions.
· Policy nesting is available for IPv4 and IPv6 packets.
· To delete the child policy after you apply the parent policy to an interface, first remove the child policy from the parent policy.
· Policy nesting is not supported on the following elements on a FIP-680 card:
¡ PVCs.
¡ POS interfaces.
¡ Fixed ports if enhanced queuing is enabled for the card.
# Nest child policy child in traffic behavior database of the parent policy.
[Sysname-behavior-database] traffic-policy child
traffic behavior
traffic classifier
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode { dcbx | qppb-manipulation } | insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode qppb-manipulation: Specifies that the class-behavior association applies only to QPPB. The if-match qos-local-id command in the class sets the same local QoS ID as the apply qos-local-id command in the BGP routing policy. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
The undo classifier default-class command performs the following operations:
· Deletes the existing class-behavior association for the system-defined class default-class.
· Associates the system-defined class default-class with the system-defined behavior be.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and specify that the class-behavior association applies only to QPPB.
[Sysname-qospolicy-user1] classifier database behavior test mode qppb-manipulation
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
# (In standalone mode.) Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
Use control-plane management to enter control-plane management view.
A QoS policy applied in control-plane management view takes effect on the packets sent from the management interface to the control plane.
# Enter control-plane management view.
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy
Use display qos policy to display QoS policies.
In standalone mode:
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
In IRF mode:
display qos policy { system-defined | user-defined } [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
system-defined: Specifies system-defined QoS policies.
user-defined: Specifies user-defined QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the QoS policies for the global active MPU. (In IRF mode.)
# Display all user-defined QoS policies.
User-defined QoS policy information:
Policy: 1 (ID 100)
Behavior: 1
Marking:
Remark dscp 3
CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
Green action : pass
Behavior: 2
Marking:
Remark dot1p 4
Behavior: 3
-none-
# Display the system-defined QoS policy (default).
<Sysname> display qos policy system-defined
System-defined QoS policy information:
Policy: default (ID 0)
Behavior: be
-none-
Classifier: ef (ID 1)
Behavior: ef
Classifier: af1 (ID 2)
Behavior: af
Assured Forwarding:
Bandwidth 20 (%)
Classifier: af2 (ID 3)
Behavior: af
Assured Forwarding:
Bandwidth 20 (%)
Classifier: af3 (ID 4)
Behavior: af
Assured Forwarding:
Bandwidth 20 (%)
Classifier: af4 (ID 5)
Behavior: af
Assured Forwarding:
Bandwidth 20 (%)
Table 6 Command output
User-defined QoS policy information |
Information about a user-defined QoS policy. |
System-defined QoS policy information |
Information about a system-defined QoS policy. |
Policy |
User-defined QoS policy name or system-defined QoS policy name. |
For the description of other fields, see Table 1 and Table 4.
display qos policy advpn
Use display qos policy advpn to display QoS policies applied to hub-spoke tunnels on a tunnel interface.
display qos policy advpn tunnel number [ ipv4-address | ipv6-address ] [ outbound ]
number: Specifies a tunnel interface by its number in the range of 0 to 20479.
ipv4-address: Specifies the spoke's private IPv4 address of a hub-spoke tunnel.
ipv6-address: Specifies the spoke's private IPv6 address of a hub-spoke tunnel.
outbound: Specifies the QoS policies applied to the outbound direction. If you do not specify this keyword, the command displays both the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction.
If you do not specify a spoke's private IP address of a hub-spoke tunnel, this command displays the QoS policy information for all hub-spoke tunnels on a tunnel interface. For information about hub-spoke tunnels, see ADVPN in Layer 3—IP Services Configuration Guide.
For configuration commands for tunnel interfaces, see tunnel commands in Layer 3—IP Services Command Reference.
# Display the QoS policy applied to the outgoing traffic of all hub-spoke tunnels on tunnel interface 1.
<Sysname> display qos policy advpn tunnel 1 outbound
Session: Tunnel1 192.168.0.3
Direction: Outbound
Policy: finance
Matched : 0 (Packets) 0 (Bytes)
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: finance
Matched : 123713988 (Packets) 13608538380 (Bytes)
Operator: AND
Rule(s) :
If-match any
Behavior: finance
CIR 1500 (kbps), CBS 93750 (Bytes), EBS 0 (Bytes)
Green action : pass
Green packets : 14980239 (Packets) 1647826290 (Bytes)
Yellow packets: 0 (Packets) 0 (Bytes)
Red packets : 108733781 (Packets) 11960715910 (Bytes)
Session: Tunnel1 192.168.0.4 (inactive)
Direction: Outbound
Policy: business
Table 7 Command output
Session |
Hub-spoke tunnel information. A hub-spoke tunnel is uniquely identified by a tunnel interface and the spoke's private IPv4 or IPv6 address. The word inactive indicates that a QoS policy fails to be applied to the hub-spoke tunnel or the applied QoS policy does not exist. |
Direction |
Direction to which a QoS policy is applied on the hub-spoke tunnel. |
Use display qos policy control-plane to display QoS policies applied to a control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Red packets : 0 (Packets) 0 (Bytes)
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 8 Command output
Direction |
Direction in which the QoS policy is applied. |
Green packets |
Statistics about green packets. |
Yellow packets |
Statistics about yellow packets. |
Red packets |
Statistics about red packets. |
Use display qos policy control-plane management to display the QoS policies applied in control-plane management view.
# Display the QoS policy applied in control-plane management view.
<Sysname> display qos policy control-plane management
Control plane management
Direction: Inbound
Policy: a
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: a
Matched : 3 (Packets) 180 (Bytes)
Operator: OR
Rule(s) :
If-match control-plane protocol arp
If-match control-plane protocol rip
If-match control-plane protocol-group critical
If-match acl 3001
If-match control-plane protocol bgp
If-match control-plane protocol bgp4+
If-match control-plane protocol ftp
If-match control-plane protocol http https icmp icmp6 ripng snmp
Behavior: a
CIR 128 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Green packets : 3 (Packets) 180 (Bytes)
Table 9 Command output
Direction |
Green packets |
Yellow packets |
Red packets |
Use display qos policy control-plane management pre-defined to display the predefined QoS policy applied in control-plane management view.
# Display the predefined QoS policy applied in control-plane management view.
<Sysname> display qos policy control-plane management pre-defined
Pre-defined control plane policy management
Protocol Priority Bandwidth Group
Default N/A 100000 (bps) N/A
ARP N/A 128 (bps) normal
BGP N/A 256 (bps) critical
BGPv6 N/A 256 (bps) critical
HTTP N/A 512 (bps) management
HTTPS N/A 512 (bps) management
ICMP N/A 128 (bps) monitor
ICMPv6 N/A 128 (bps) monitor
OSPF Multicast N/A 256 (bps) critical
OSPF Unicast N/A 256 (bps) critical
OSPFv3 Multicast N/A 256 (bps) critical
OSFPv3 Unicast N/A 256 (bps) critical
RIP N/A 1024 (bps) critical
RIPng N/A 256 (bps) critical
SNMP N/A 512 (bps) management
SSH N/A 512 (bps) management
TELNET N/A 512 (bps) management
FTP N/A 512 (bps) management
TFTP N/A 512 (bps) management
Table 10 Command output
Pre-defined control plane policy management |
Predefined QoS policy applied in control-plane management view. |
Protocol |
System-defined protocol packet type. |
Group |
Protocol group to which the protocol belongs. |
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
In standalone mode:
In IRF mode:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the predefined control plane QoS policies for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays predefined control plane QoS policies for all cards. (In IRF mode.)
# (In standalone mode.) Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
Protocol Priority Bandwidth (kbps)
ARP 1 1000
ARP Snooping 2 2000
BGP 3 3000
BGPv6 4 4000
BPDU Tunnel 5 5000
CDP 6 6000
CFD 7 7000
DHCP 0 8000
DHCP Snooping 1 9000
DHCPv6 2 10000
# (In IRF mode.) Display the predefined control plane QoS policy of slot 3 in chassis 1.
<Sysname> display qos policy control-plane pre-defined chassis 1 slot 3
Pre-defined control plane policy chassis 1 slot 3
ARP 1 1000
ARP Snooping 2 2000
BGP 3 3000
BGPv6 4 4000
BPDU Tunnel 5 5000
CDP 6 6000
CFD 7 7000
DHCP 0 8000
DHCPv6 2 10000
Table 11 Command output
Pre-defined control plane policy |
Contents of the predefined control plane QoS policy. |
For descriptions of other fields, see Table 3.
Use display qos policy interface to display the QoS policies applied to interfaces or PVCs.
In standalone mode:
display qos policy interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos policy interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command applies to all PVCs on the ATM interface. When you specify a PVC, you cannot specify the inbound or outbound keyword.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies on the active MPU. Only logical interfaces support this option. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays QoS policies on the global active MPU. Only logical interfaces support this option. (In IRF mode.)
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
If you specify a VT interface, this command displays the QoS policies applied to each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the QoS policy applied to the incoming traffic of GigabitEthernet 2/0/1.
<Sysname> display qos policy interface gigabitethernet 2/0/1 inbound
Interface: GigabitEthernet2/0/1
Direction: Inbound
Policy: 1, Preorder 1
Classifier: 1
5-minute statistics:
Forwarded: 0/0 (pps/bps)
Dropped : 0/0 (pps/bps)
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark dscp 3
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
# Display the QoS policies applied to all interfaces.
Direction: Inbound
Type : Extension
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: GigabitEthernet2/0/2
CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Green action : pass
Interface: GigabitEthernet2/0/3
Direction: Inbound
Policy: b
Classifier: b
Operator: AND
Rule(s) :
If-match any
Behavior: b
Green action : pass
Green packets : 0(Packets)
Direction: Inbound
Type : Extension
Mode : Share
Policy: a
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: GigabitEthernet2/0/4
Green action : pass
Table 12 Command output
Direction |
Policy |
Preorder |
The order a QoS policy is executed. |
Type |
Mode in which the QoS policy is applied to an interface, which can only be Extension. If you do not specify the mode when applying a QoS policy to an interface, this field does not appear. |
Matched |
Number of matching packets. |
Forwarded |
Average rate of successfully forwarded matching packets in a statistics collection period. |
Dropped |
Average rate of dropped matching packets in a statistics collection period. |
Green packets |
Traffic statistics for green packets. |
Yellow packets |
Traffic statistics for yellow packets. |
Red packets |
Traffic statistics for red packets. |
display qos policy l2vpn-pw
Use display qos policy l2vpn-pw to display the QoS policies applied to PWs.
display qos policy l2vpn-pw [ peer ip-address pw-id pw-id ] [ outbound ]
peer ip-address pw-id pw-id: Specifies a PW by its peer PE LSR ID and its PW ID. The ip-address argument represents the LSR ID of the peer PE of the PW. The value range for the pw-id argument is 1 to 4294967295. If you do not specify a PW, this command displays the QoS policies applied to all PWs.
outbound: Specifies the QoS policies applied to outgoing traffic. The command execution results are the same, regardless of whether this keyword is specified.
# Display the QoS policy applied to the outgoing traffic of PW 1 with peer PE IP address 1.1.1.1.
<Sysname> display qos policy l2vpn-pw peer 1.1.1.1 pw-id 1 outbound
L2VPN-PW: peer 1.1.1.1, pw-id 1
Direction: Outbound
Policy: 1
Classifier: 1
Operator: AND
Rule(s) :
If-match acl 2000
Behavior: 1
Marking:
Remark dscp 3
Green action : pass
Classifier: 2
Operator: AND
Rule(s) :
Behavior: 2
Accounting enable:
0 (Packets)
Marking:
Remark mpls-exp 4
Classifier: 3
Operator: AND
Rule(s) :
-none-
Behavior: 3
-none-
Table 13 Command output
L2VPN-PW |
A PW is uniquely identified by a combination of the peer PE IP address and PW ID. |
Direction |
Matched |
5-minute statistics |
Traffic statistics in the last 5 minutes. |
Forwarded |
Average rate of successfully forwarded matching packets during a statistics collection period. |
Dropped |
Average rate of dropped matching packets during a statistics collection period. |
Green packets |
Yellow packets |
Red packets |
Use display qos policy user-profile to display QoS policies applied to user profiles.
In standalone mode:
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify a user profile, this command displays QoS policies applied to all user profiles.
user-id user-id: Specifies an online user by a system-assigned, hexadecimal ID in the range of 0 to fffffffe. If you do not specify an online user, this command displays QoS policies applied to user profiles for all online users.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies applied to user profiles for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays QoS policies applied to user profiles for all cards. (In IRF mode.)
inbound: Specifies QoS policies applied to incoming traffic.
outbound: Specifies QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to user profile abc for a global user.
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
User ID: 0x30000000(global)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# Display the QoS policy applied to user profile abc for a local user.
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
slot 2:
User ID: 0x30000001(local)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# Display the QoS policy applied to user profile abc for all users.
<Sysname> display qos policy user-profile name abc inbound
User-Profile: abc
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
slot 2:
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
slot 3:
User ID: 0x30000002(local)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# Display the QoS policy applied to user profile abc for all users on the card in slot 2.
<Sysname> display qos policy user-profile name abc slot 2
User-Profile: abc
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# Display the QoS policy applied to user profile abc for a user on all cards.
User-Profile: abc
slot 2:
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
slot 3:
Direction: Inbound
Policy: p1
Classifier: default-class
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
# Display the QoS policies applied to all user profiles.
User-Profile: abc
slot 3:
User ID: 0x30000000(local)
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
User-Profile: a12
slot 4:
Direction: Inbound
Policy: p1
Operator: AND
Rule(s) :
If-match any
Behavior: be
-none-
Classifier: a
Operator: AND
Rule(s) :
If-match any
Behavior: a
Mirroring:
Mirror to the interface: GigabitEthernet1/0/1
CIR 112 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
Green action : pass
Table 14 Command output
global |
Indicates a global user, who comes online from a global interface such as an aggregate interface. |
local |
Indicates a local user, who comes online from a physical interface. |
EBS |
EBS in bytes. |
Matched |
Number of packets that meet match criteria. |
Direction |
Green packets |
Yellow packets |
Red packets |
qos apply policy (interface view, PVC view, control plane view, control-plane management view, PW view)
Use qos apply policy to apply a QoS policy to an interface, PVC, control plane, or PW.
Use undo qos apply policy to remove an applied QoS policy.
qos apply policy policy-name { inbound | outbound } [ preorder preorder-value ]
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view/control-plane management view
Cross-connect PW view/VSI LDP PW view/VSI static PW view
Interface view
PVC view
inbound: Applies the QoS policy to incoming traffic. This keyword is not supported in PW view.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in control plane view, or control-plane management view.
preorder preorder-value: Specifies the order in which QoS policies applied to the same direction of an interface are executed. The greater the value, the higher the priority. The value of the preorder-value argument can only be 1. A QoS policy configured with this option is executed before a QoS policy that is not configured with this option.
When you apply a QoS policy to an interface, PVC, or PW, follow these rules:
· The bandwidth assigned to AF and EF queues in the QoS policy must be smaller than the available bandwidth of the interface, PVC, or PW. Otherwise, the QoS policy cannot be successfully applied to the interface or PVC.
· If you modify the available bandwidth of the interface, PVC, or PW to be smaller than the bandwidth for AF and EF queues, the applied QoS policy is removed.
· An inbound QoS policy cannot contain a GTS action or any of these queuing actions: queue ef, queue af, or queue wfq.
A QoS policy configured with CBQ is not supported in control plane view or control-plane management view.
The preorder preorder-value option is supported only on Layer 3 Ethernet interfaces and Layer 3 aggregate interfaces, but not on Layer 2 Ethernet interfaces or Layer 2 aggregate interfaces.
You can use the following commands to match protocol packets sent to the CPU for a QoS policy applied to a control plane:
· if-match control-plane protocol
· if-match control-plane protocol-group
· if-match acl
When you use the if-match acl command to match protocol packets sent to the CPU, follow these restrictions and guidelines:
¡ The used ACL must be an advanced ACL.
¡ You must specify TCP or UDP for the protocol argument in the rule.
¡ You must specify a source port or destination port by using the eq operator in the rule.
For example, an IPv4 advanced ACL that contains a rule permit tcp source-port eq 80 statement can match TCP packets sent to the CPU.
# Apply QoS policy USER1 to the incoming traffic of GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos apply policy USER1 inbound
# Apply QoS policy aaa to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy aaa inbound
# Apply QoS policy bbb to the incoming traffic of the management interface control plane.
[Sysname-cp-management] qos apply policy bbb inbound
# Apply a QoS policy to the outgoing traffic of PW 1 with peer PE IP address 1.1.1.1.
[Sysname] xconnect-group a
[Sysname-xcg-a] connection a
[Sysname-xcg-a-a] peer 1.1.1.1 pw-id 1
[Sysname-xcg-a-a-1.1.1.1-1] qos apply policy 1 outbound
qos apply policy (user profile view)
Use qos apply policy to apply a QoS policy to a user profile.
Use undo qos apply policy to remove a QoS policy applied to a user profile.
No QoS policy is applied to a user profile.
User profile view
inbound: Applies the QoS policy to the incoming traffic of the device (traffic sent by online users).
outbound: Applies the QoS policy to the outgoing traffic of the device (traffic received by online users).
Deleting a user profile also removes the QoS policies applied to the user profile.
# Apply QoS policy test to incoming traffic of user profile user.
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policies exist.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
classifier behavior
qos apply policy
reset qos policy advpn
Use reset qos policy advpn to clear the statistics for QoS policies applied to hub-spoke tunnels on a tunnel interface.
reset qos policy advpn tunnel number [ ipv4-address | ipv6-address ] [ outbound ]
outbound: Specifies the QoS policies applied to the outbound direction. If you do not specify this keyword, the command clears for both the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction.
If you do not specify a spoke's private IP address of a hub-spoke tunnel, this command clears the QoS policy statistics for all hub-spoke tunnels on a tunnel interface. For information about hub-spoke tunnels, see ADVPN in Layer 3—IP Services Configuration Guide.
The device only supports clearing the statistics for QoS policies applied to the outbound direction of tunnel interfaces.
# Clear the statistics for the QoS policy applied to the outgoing traffic of the hub-spoke tunnel with spoke's IPv4 address 192.168.0.3 on tunnel interface 1.
<Sysname> reset qos policy advpn tunnel 1 192.168.0.3 outbound
reset qos policy control-plane
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
In standalone mode:
In IRF mode:
reset qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
# (In IRF mode.) Clear the statistics of the QoS policy applied to the control plane of slot 3 in chassis 1.
<Sysname> reset qos policy control-plane chassis 1 slot 3
reset qos policy control-plane management
Use reset qos policy control-plane management to clear the statistics of the QoS policy applied in control-plane management view.
# Clear the statistics of the QoS policy applied in control-plane management view.
<Sysname> reset qos policy control-plane management
QoS policy-based traffic rate statistics collection period commands
qos flow-interval
Use qos flow-interval to set the QoS policy-based traffic rate statistics collection period for an interface.
Use undo qos flow-interval to restore the default.
qos flow-interval interval
The QoS policy-based traffic rate statistics collection period is 5 minutes on an interface.
Interface view
interval: Sets the QoS policy-based traffic rate statistics collection period in minutes. The value range for this argument is 1 to 10.
You can enable collection of per-class traffic statistics over a period of time, including the average forwarding rate and drop rate. For example, if you set the statistics collection period to 10 minutes, the system performs the following operations:
· Collects traffic statistics for the most recent 10 minutes.
· Refreshes the statistics every 10/5 minutes, 2 minutes.
The traffic rate statistics collection period of a subinterface is the same as the period configured on the main interface.
# Set the QoS policy-based traffic rate statistics collection period to 10 minutes on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos flow-interval 10
Traffic policing, GTS, and rate limit commands
Traffic policing commands
display qos car interface
Use display qos car interface to display the CAR configuration and statistics for interfaces.
display qos car interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the CAR configuration and statistics for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
If you specify a VT interface, this command displays the CAR configuration and statistics of each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the CAR configuration and statistics for GigabitEthernet 2/0/1.
<Sysname> display qos car interface gigabitethernet 2/0/1
Direction: inbound
Rule: If-match any
CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
Green action : pass
Green packets : 0 (Packets), 0 (Bytes)
Yellow packets: 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
# Display the CAR information on GigabitEthernet 2/0/2.
<Sysname> display qos car interface gigabitethernet 2/0/2
Interface: GigabitEthernet2/0/2
Direction: inbound
Rule: If-match any
CIR 50 (%), CBS 600 (ms), EBS 0 (ms), PIR 50 (%)
Green action : pass
Table 15 Command output
Interface name, including interface type and interface number. |
Direction |
Direction in which traffic policing is applied. |
Rule |
Match criteria. |
Green action |
Yellow action |
Red action |
display qos carl
Use display qos carl to display CAR lists.
In standalone mode:
display qos carl [ carl-index ] [ slot slot-number ]
In IRF mode:
display qos carl [ carl-index ] [ chassis chassis-number slot slot-number ]
carl-index: Specifies a CAR list by its number in the range of 1 to 199. If you do not specify a CAR list, this command displays all CAR lists.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CAR lists for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the CAR lists for the global active MPU. (In IRF mode.)
# Display all CAR lists.
<Sysname> display qos carl
List Rules
1 destination-ip-address range 1.1.1.1 to 1.1.1.2 per-address shared-bandwidth
2 destination-ip-address subnet 1.1.1.1 22 per-address shared-bandwidth
4 dscp 1 2 3 4 5 6 7 cs1
5 mac 0000-0000-0000
6 mpls-exp 0 1 2
9 precedence 0 1 2 3 4 5 6 7
10 source-ip-address range 1.1.1.1 to 1.1.1.2
11 source-ip-address subnet 1.1.1.1 31
qos car
Use qos car to configure a CAR policy on an interface.
Use undo qos car to delete a CAR policy from an interface.
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index }
No CAR policy is configured.
Interface view
inbound: Performs CAR for incoming packets on the interface.
outbound: Performs CAR for outgoing packets on the interface.
any: Performs CAR for all IP packets in the specified direction.
acl [ ipv6 ] acl-number: Performs CAR for packets matching an ACL specified by its number. The value range for the acl-number argument is 2000 to 2999 for basic ACLs and 3000 to 3999 for advanced ACLs. If you do not specify ipv6, this option specifies an IPv4 ACL. If you specify ipv6, this option specifies an IPv6 ACL.
carl carl-index: Performs CAR for packets matching a CAR list specified by its number in the range of 1 to 199.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 10000000.
cbs committed-burst-size: Specifies the CBS in bytes, which is the size of bursty traffic when the actual average rate is not greater than the CIR. The value range for committed-burst-size is 512 to 128000000. The default CBS is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 128000000. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 64 to 1000000.
green: Specifies the action to take on packets when the traffic rate conforms to the CIR. The default is pass.
red: Specifies the action to take on packets when the traffic rate conforms to neither CIR nor PIR. The default is discard.
yellow: Specifies the action to take on packets when the traffic rate exceeds the CIR but conforms to the PIR. The default is pass.
action: Specifies the action to take on packets:
· continue: Continues to process the packet by using the next CAR policy.
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-continue new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and continues to process the packet by using the next CAR policy. The new-cos argument is in the range of 0 to 7.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-continue new-dscp: Remarks the packet with a new DSCP value and continues to process the packet by using the next CAR policy. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-mpls-exp-continue new-exp: Sets the EXP field value of the MPLS packet to new-exp and continues to process the packet by using the next CAR policy. The new-exp argument is in the range of 0 to 7.
· remark-mpls-exp-pass new-exp: Sets the EXP field value of the MPLS packet to new-exp and permits the packet to pass through. The new-exp argument is in the range of 0 to 7.
· remark-prec-continue new-precedence: Remarks the packet with a new IP precedence and continues to process the packet by using the next CAR policy. The new-precedence argument is in the range of 0 to 7.
· remark-prec-pass new-precedence: Remarks the packet with a new IP precedence and permits the packet to pass through. The new-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the qos car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the qos car command without the pir peak-information-rate option.
You can configure multiple qos car commands on an interface to define multiple CAR policies. These CAR policies are executed in their configuration order.
# Perform CAR for all packets in the outbound direction of GigabitEthernet 2/0/1. The CAR parameters are as follows:
· CIR is 200 kbps.
· CBS is 5120 bytes.
· EBS is 0.
· Conforming packets are transmitted.
· Excess packets are set with an IP precedence of 0 and transmitted.
[Sysname-GigabitEthernet2/0/1] qos car outbound any cir 200 cbs 5000 ebs 0 green pass red remark-prec-pass 0
qos carl
qos car any
Use qos car any to configure a CAR policy for all packets of a user profile.
Use undo qos car to delete a CAR policy from a user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
User profile view
inbound: Performs CAR for incoming traffic. This keyword is not supported in session group profile view.
outbound: Performs CAR for outgoing traffic.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 40000000.
cbs committed-burst-size: Specifies the committed burst size (CBS) in the range of 1000 to 1000000000 bytes. The default CBS is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 1000000000 bytes. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 40000000.
The conforming traffic is permitted to pass through, and the excess traffic is dropped.
If you execute the qos car command multiple times for the same user profile or session group profile, the most recent configuration takes effect.
# Perform CAR for packets received by user profile user. The CAR parameters are as follows:
· The CIR is 200 kbps.
· The CBS is 51200 bytes.
[Sysname-user-profile-user] qos car outbound any cir 200 cbs 51200
qos carl
Use qos carl to create or modify a CAR list.
Use undo qos carl to delete a CAR list.
qos carl carl-index { dscp dscp-list | mac mac-address | mpls-exp mpls-exp-value | precedence precedence-value | { destination-ip-address | source-ip-address } { range start-ip-address to end-ip-address | subnet ip-address mask-length } [ per-address [ shared-bandwidth ] ] }
undo qos carl carl-index
No CAR list is configured.
dscp dscp-list: Specifies a list of DSCP values. A DSCP value can be a number from 0 to 63 or any of the following keywords af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef. You can configure up to eight DSCP values in one command line. If the same DSCP value is specified multiple times, the system considers the values to be one value. If a packet matches one of the defined DSCP values, it matches the if-match clause.
mac mac-address: Specifies a MAC address in hexadecimal format.
mpls-exp mpls-exp-value: Specifies an MPLS EXP value in the range of 0 to 7. You can configure up to eight MPLS EXP values in one command line. If the same MPLS EXP value is specified multiple times, the system considers the values to be one value. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
precedence precedence: Specifies a precedence value in the range of 0 to 7. You can configure up to eight IP precedence values in one command line. If the same IP precedence value is specified multiple times, the system considers the values to be one value. If a packet matches one of the defined IP precedence values, it matches the if-match clause.
destination-ip-address: Configures a destination IP address-based CAR list.
source-ip-address: Configures a source IP address-based CAR list.
range start-ip-address to end-ip-address: Specifies an IP address range by the start address and end address. The value for end-ip-address must be greater than the value for start-ip-address.
subnet ip-address mask-length: Specifies a subnet by the IP subnet address and IP subnet address mask length.
per-address: Performs per-IP address rate limiting within the network segment. When this keyword is specified, the CIR is dedicated bandwidth for each IP address and is not shared by any other IP address. If you do not specify this keyword, the following events occur:
· Rate limiting is performed for the entire network segment.
· All of the CIR is allocated among all IP addresses in proportion to the traffic load of each IP address.
shared-bandwidth: Specifies that traffic of all IP addresses within the network segment shares the remaining bandwidth (the CIR). If you specify this keyword, all of the CIR is allocated evenly among all IP addresses with traffic load.
You can create a CAR list based on IP precedence, MAC address, MPLS EXP, DSCP, or IP network segment.
If you execute this command multiple times for the same CAR list, the most recent configuration takes effect. If you execute this command multiple times for different CAR lists, multiple CAR lists are created.
To perform rate limiting for a single IP address, use the qos car acl command in interface view.
# Apply CAR list 1 to the outbound direction of GigabitEthernet 2/0/1 to meet the following requirements:
· The rate of each host on the subnet 1.1.1.0/24 is limited to 512 kbps.
· Traffic of IP addresses in the subnet does not share the remaining bandwidth.
[Sysname] qos carl 1 source-ip-address subnet 1.1.1.0 24 per-address
[Sysname-GigabitEthernet2/0/1] qos car outbound carl 1 cir 512 cbs 5120 ebs 0 green pass red discard
# Apply CAR list 2 to the outbound direction of GigabitEthernet 2/0/1 to meet the following requirements:
· The rate of each host in the IP address range of 1.1.2.100 to 1.1.2.199 is limited to 5 Mbps.
· Traffic of IP addresses in the subnet shares the remaining bandwidth.
[Sysname] qos carl 2 source-ip-address range 1.1.2.100 to 1.1.2.199 per-address shared-bandwidth
[Sysname-GigabitEthernet2/0/1] qos car outbound carl 2 cir 5120 cbs 51200 ebs 51200 green pass red discard
# Apply CAR list 3 to the outbound direction of GigabitEthernet 2/0/1 to meet the following requirements:
· The rate of each host in object group work-group is limited to 256 kbps during time range work-time.
· Traffic of IP addresses in the object group does not share the remaining bandwidth.
[Sysname] qos carl 3 source-ip-address object-group work-group per-address time-range work-time
[Sysname-GigabitEthernet2/0/1] qos car outbound carl 3 cir 256 cbs 6250 ebs 0 green pass red discard
display qos carl
qos car
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration and statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration and statistics for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
If you specify a VT interface, this command displays the GTS configuration and statistics of each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the GTS configuration for all interfaces.
Rule: If-match acl 2001
CIR 512 (kbps), CBS 51200 (Bytes), PIR 5120 (kbps), EBS 0 (Bytes)
Queue Length: 100 (Packets)
Queue Size: 70 (Packets)
Passed : 0 (Packets) 0 (Bytes)
Discarded: 0 (Packets) 0 (Bytes)
Delayed : 0 (Packets) 0 (Bytes)
CIR 64 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
Table 16 Command output
Interface name, including the interface type and interface number. |
Rule |
Match criteria. |
Queue Length |
Number of packets that the buffer can hold. |
Queue Size |
Number of packets in the buffer. |
Passed |
Number and bytes of packets that have been forwarded. |
Discarded |
Number and bytes of dropped packets. |
Delayed |
Number and bytes of delayed packets. |
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
qos gts { any | acl [ ipv6 ] acl-number } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts { any | acl [ ipv6 ] acl-number } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo qos gts { any | acl [ ipv6 ] acl-number }
No GTS parameters are configured.
Interface view
any: Shapes all packets.
acl [ ipv6 ] acl-number: Performs GTS for packets matching an ACL specified by its number. The value range for the acl-number argument is 2000 to 3999. If you do not specify ipv6, this option specifies an IPv4 ACL. If you specify ipv6, this option specifies an IPv6 ACL.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 1000000.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 1875 to 134217727. The default CBS is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in bytes, which is the traffic exceeding CBS when two token buckets are used. The value range for excess-burst-size is 0 to 134217727. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
queue-length queue-length: Specifies the maximum number of packets allowed in the queue. The value range for queue-length is 1 to 1024.
To use two rates for traffic shaping, configure the qos gts command with the pir peak-information-rate option. To use one rate for traffic shaping, configure the qos gts command without the pir peak-information-rate option.
# Shape the packets matching ACL 2001 on GigabitEthernet 2/0/1. The GTS parameters are as follows:
· The EBS is 0.
· The maximum buffer queue length is 100.
[Sysname-GigabitEthernet2/0/1] qos gts acl 2001 cir 200 cbs 51200 ebs 0 queue-length 100
Rate limit commands
display qos lr
Use display qos lr to display the rate limit configuration and statistics for interfaces or PWs.
display qos lr { interface [ interface-type interface-number ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration and statistics for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
peer ip-address pw-id pw-id: Specifies a PW by its peer PE LSR ID and its PW ID. The ip-address argument represents the LSR ID of the peer PE of the PW. The value range for the pw-id argument is 1 to 4294967295. If you do not specify a PW, this command displays the rate limit configuration and statistics for all PWs.
If you specify a VT interface, this command displays the rate limit configuration and statistics of each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the rate limit configuration for all interfaces.
Direction: Outbound
CIR 2000 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
Passed : 1000 (Packets) 1000 (Bytes)
Discarded: 1000 (Packets) 1000 (Bytes)
Delayed : 1000 (Packets) 1000 (Bytes)
Active shaping: No
Direction: Outbound
CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes)
Active shaping: No
# Display the rate limit information for all PWs.
<Sysname> display qos lr l2vpn-pw
L2VPN-PW: peer 1.2.3.4, pw-id 1
Direction: Outbound
CIR 1024 (kbps), CBS 64000 (Bytes), EBS 0 (Bytes)
Active shaping: No
Table 17 Command output
L2VPN-PW |
Direction |
Direction in which the rate limit configuration is applied. |
Passed |
Number and bytes of packets that have passed. |
Discarded |
Delayed |
Active shaping |
Indicates whether the rate limit configuration is activated: · Yes—Activated. · No—Not activated. |
qos lr
Use qos lr to configure rate limiting on an interface or PW.
Use undo qos lr to delete the rate limit configuration on an interface or PW.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
undo qos lr outbound
No rate limit is configured.
Interface view
outbound: Limits the rate of outgoing packets.
# Limit the rate of outgoing packets on GigabitEthernet 2/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-GigabitEthernet2/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces or PVCs.
display qos queue interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the queuing information for all PVCs on the ATM interface.
If you specify a VT interface, this command displays the queuing information of each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
Output queue - Weighted Fair queuing: Size/Length/Discards 0/64/0
Weight: IP Precedence
Queues: Active/Max active/Total 0/0/128
Table 18 Command output
Output queue |
Type of the current output queue. |
Group |
Number of the group that holds the queue. |
Weight |
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
Byte-count |
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm. |
display qos queue l2vpn-pw
Use display qos queue l2vpn-pw to display the queuing information for PWs.
display qos queue l2vpn-pw [ peer ip-address pw-id pw-id ]
peer ip-address pw-id pw-id: Specifies a PW by its peer PE LSR ID and its PW ID. The ip-address argument represents the LSR ID of the peer PE of the PW. The value range for the pw-id argument is 1 to 4294967295. If you do not specify a PW, this command displays the queuing information for all PWs.
# Display the queuing information for all PWs.
<Sysname> display qos queue l2vpn-pw
L2VPN-PW: peer 2.2.2.2 pw-id 2
Table 19 Command output
L2VPN-PW |
Size |
Total number of bytes of packets in all queues. |
Length |
Number of packets allowed in each queue. |
Discards |
Number of packets dropped. |
Weight |
Weight type: · IP Precedence. · DSCP. |
Active |
Number of active WFQ queues. |
Max active |
Maximum number of active WFQ queues that was reached. |
Total |
Total number of configured WFQ queues. |
qos-queue enhanced
Use qos-queue enhanced to enable enhanced queuing for a card.
Use undo qos-queue enhanced to disable enhanced queuing for a card.
In standalone mode:
qos-queue enhanced slot slot-number
undo qos-queue enhanced slot slot-number
In IRF mode:
qos-queue enhanced chassis chassis-number slot slot-number
undo qos-queue enhanced chassis chassis-number slot slot-number
Enhanced queuing is disabled for a card.
Only RT-FIP-680 base cards support this command. This command takes effect on fixed ports on the base card, but not on interfaces on subcards installed in the base card.
After this command is configured, the router processes queue scheduling in hardware, which improves queue scheduling performance.
After you enable or disable enhanced queuing for a card, you must reboot the card for the configuration to take effect.
# Enable enhanced queuing for the card in slot 5.
[Sysname] qos-queue enhanced slot 5
Please reboot slot 5 to make the command take effect.
reset qos statistics l2vpn-pw
Use reset qos statistics l2vpn-pw to clear the QoS statistics for PWs.
reset qos statistics l2vpn-pw [ peer ip-address pw-id pw-id ]
peer ip-address pw-id pw-id: Specifies a PW by its peer PE LSR ID and its PW ID. The ip-address argument represents the LSR ID of the peer PE of the PW. The value range for the pw-id argument is 1 to 4294967295. If you do not specify a PW, this command clears QoS statistics for all PWs.
# Clear the QoS statistics for PW 1 with peer PE IP address 1.1.1.1.
<Sysname> reset qos statistics l2vpn-pw peer 1.1.1.1 pw-id 1
FIFO queuing commands
This feature is not supported on PVCs on an RT-FIP-680 card..
display qos queue fifo
Use display qos queue fifo to display the FIFO information for interfaces, PVCs, or PWs.
display qos queue fifo interface { [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the FIFO information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the FIFO information for all PVCs on the ATM interface.
peer ip-address pw-id pw-id: Specifies a PW by its peer PE LSR ID and its PW ID. The ip-address argument represents the LSR ID of the peer PE of the PW. The value range for the pw-id argument is 1 to 4294967295. If you do not specify a PW, this command displays the FIFO information for all PWs.
If you specify a VT interface, this command displays the FIFO information of each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the FIFO information for all interfaces.
<Sysname> display qos queue fifo interface
# Display the FIFO information for all PWs.
<Sysname> display qos queue fifo l2vpn-pw
Table 20 Command output
L2VPN-PW |
Size |
Length |
Discards |
qos fifo queue-length
Use qos fifo queue-length to set the FIFO queue length for an interface, PVC, or PW.
Use undo qos fifo queue-length to restore the default.
qos fifo queue-length queue-length
The FIFO queue length is 75.
Interface view
PVC view
queue-length: Specifies the maximum number of packets allowed in the FIFO queue, in the range of 1 to 1024.
For FIFO queuing to take effect on a subinterface, you must configure the rate limit on the subinterface.
# Set the FIFO queue length to 100.
[Sysname-GigabitEthernet2/0/1] qos fifo queue-length 100
PQ commands
This feature is not supported on the following interfaces on an RT-FIP-680 card:
· PVCs.
· POS interfaces.
· Fixed ports if enhanced queuing is enabled for the card.
display qos pql
Use display qos pql to display the PQ list configuration.
In standalone mode:
display qos pql [ pql-index ] [ slot slot-number ]
In IRF mode:
display qos pql [ pql-index ] [ chassis chassis-number slot slot-number ]
pql-index: Specifies a PQ list by its number in the range of 1 to 16.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the PQ list configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the PQ list configuration for the global active MPU. (In IRF mode.)
# Display the configuration of all PQ lists.
<Sysname> display qos pql
Current PQL configuration:
List Queue Parameters
1 Top Protocol ip less-than 1000
2 Normal Length 80
2 Bottom Length 40
3 Middle Inbound-interface GigabitEthernet2/0/1
4 Top Local-precedence 7
display qos queue pq interface
Use display qos queue pq interface to display the PQ information for interfaces or PVCs.
display qos queue pq interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the PQ information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the PQ information for all PVCs on the ATM interface.
If you specify a VT interface, this command displays the PQ information for all VA interfaces of the VT interface. It does not display QoS information about the VT interface.
# Display the PQ information for GigabitEthernet 2/0/1.
<Sysname> display qos queue pq interface gigabitethernet 2/0/1
Output queue - Priority queuing: PQL 1 Size/Length/Discards
Top: 0/20/0 Middle: 0/40/0 Normal: 0/60/0 Bottom: 0/80/0
Table 21 Command output
Priority queuing: PQL 1 |
PQL 1 indicates the PQ list in use. |
Size |
Length |
Discards |
Number of dropped packets. |
Top |
Top priority queue. |
Middle |
Middle priority queue. |
Normal |
Normal priority queue. |
Bottom |
Bottom priority queue. |
qos pq
Use qos pq to apply a PQ list to an interface or PVC.
Use undo qos pq to restore the default.
qos pq pql pql-index
undo qos pq
An interface or PVC uses FIFO queuing.
Interface view
PVC view
pql pql-index: Specifies a PQ list by its number in the range of 1 to 16.
If you execute this command multiple times on an interface or PVC, the most recent configuration takes effect.
Multiple match criteria can be configured for a PQ list. When a packet arrives, it is examined against match criteria in their configuration order.
· If a match is found, the packet is assigned to the corresponding queue, and the matching process ends.
· If no match is found, the packet is assigned to the default queue.
You must configure the rate limit for the queuing feature to take effect on the following interfaces:
· Tunnel interfaces.
· Subinterfaces.
· Layer 3 aggregate interfaces.
· HDLC link bundle interfaces.
· RPR logical interfaces.
· VT and dialer interfaces configured with PPPoE, PPPoA, PPPoEoA, PPPoFR, or MPoFR (Frame Relay interfaces are not enabled with FRTS).
# Apply PQ list 12 to GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos pq pql 12
qos pql default-queue
Use qos pql default-queue to specify a priority queue as the default queue for a PQ list.
Use undo qos pql default-queue to restore the default.
qos pql pql-index default-queue { bottom | middle | normal | top }
undo qos pql pql-index default-queue
The normal queue is the default queue for a PQ list.
top: Specifies the top queue.
middle: Specifies the middle queue.
normal: Specifies the normal queue.
bottom: Specifies the bottom queue.
If a packet does not match any criteria in a PQ list, the packet is assigned to the default queue of the PQ list.
If you execute this command multiple times for the same PQ list, the most recent configuration takes effect.
# Specify the bottom queue as the default queue for PQ list 12.
[Sysname] qos pql 12 default-queue bottom
qos pql inbound-interface
Use qos pql inbound-interface to configure an assignment rule for a PQ list to assign packets received on the specified interface to a priority queue.
Use undo qos pql inbound-interface to delete an assignment rule based on the specified input interface from a PQ list.
qos pql pql-index inbound-interface interface-type interface-number queue { bottom | middle | normal | top }
undo qos pql pql-index inbound-interface interface-type interface-number
No assignment rule is configured for a PQ list.
interface-type interface-number: Specifies an input interface by its type and number.
You can configure this command multiple times for the same PQ list to establish multiple assignment rules based on input interfaces.
# In PQ list 12, assign packets received on GigabitEthernet 2/0/1 to the middle queue.
[Sysname] qos pql 12 inbound-interface gigabitethernet 2/0/1 queue middle
qos pql local-precedence
Use qos pql local-precedence to configure an assignment rule for a PQ list to assign packets with any of the specified local precedence values to a priority queue.
Use undo qos pql local-precedence to delete an assignment rule based on the specified local precedence values from a PQ list.
qos pql pql-index local-precedence local-precedence-list queue { bottom | middle | normal | top }
undo qos pql pql-index local-precedence local-precedence-list
local-precedence-list: Specifies a space-separated list of up to eight local precedence values. The value range is 0 to 7.
You can configure this command multiple times for the same PQ list to establish multiple assignment rules based on local precedence values.
# In PQ list 12, assign packets with local precedence 3 to the middle queue.
[Sysname] qos pql 12 local-precedence 3 queue middle
qos pql protocol
Use qos pql protocol to configure an assignment rule for a PQ list to assign packets of the specified protocol type to a priority queue.
Use undo qos pql protocol to delete an assignment rule based on the specified protocol type from a PQ list.
qos pql pql-index protocol { ip | ipv6 } [ queue-key key-value ] queue { bottom | middle | normal | top }
undo qos pql pql-index protocol { ip | ipv6 } [ queue-key key-value ]
queue-key key-value: Matches specific IP or IPv6 packets. If you specify neither the queue-key argument nor the key-value argument, all IP or IPv6 packets are matched.
Table 22 Values of the queue-key argument and the key-value argument
queue-key |
key-value |
acl |
ACL number in the range of 2000 to 3999 |
Packets matching a specific ACL are enqueued. |
fragments |
N/A |
Fragmented packets are enqueued. |
greater-than |
Length in the range of 0 to 65535 |
Packets greater than a specific size are enqueued. |
less-than |
Packets smaller than a specific size are enqueued. |
tcp |
Port number in the range of 0 to 65535 or port name |
Packets with a specific source or destination TCP port number are enqueued. |
udp |
Packets with a specific source or destination UDP port number are enqueued. |
When classifying a packet, the system matches the packet against match criteria in the order configured. When a match is found, the matching process ends.
You can configure this command multiple times for the same PQ list to establish multiple assignment rules based on protocol types.
# In PQ list 5, assign IP packets matching ACL 3100 to the top queue.
[Sysname] qos pql 5 protocol ip acl 3100 queue top
qos pql protocol mpls exp
Use qos pql protocol mpls exp to configure an assignment rule for a PQ list to assign packets with any of the specified MPLS EXP values to a priority queue.
Use undo qos pql protocol mpls exp to delete an assignment rule based on the specified MPLS EXP values from a PQ list.
qos pql pql-index protocol mpls exp exp-list queue { bottom | middle | normal | top }
undo qos pql pql-index protocol mpls exp exp-list
exp-list: Specifies a space-separated list of up to eight MPLS EXP values. The value range is 0 to 7.
You can configure this command multiple times for the same PQ list to establish multiple assignment rules based on MPLS EXP values.
# In PQ list 5, assign packets with MPLS EXP value 2 or 4 to the top queue.
[Sysname] qos pql 5 protocol mpls exp 2 4 queue top
qos pql queue
Use qos pql queue to specify the length of a priority queue in a PQ list.
Use undo qos pql queue to restore the default length for a priority queue in a PQ list.
qos pql pql-index queue { bottom | middle | normal | top } queue-length queue-length
undo qos pql pql-index queue { bottom | middle | normal | top } queue-length
The queue length values for top, middle, normal, and bottom queues are 20, 40, 60, and 80, respectively.
queue-length: Specifies the maximum number of packets allowed in the queue, in the range of 1 to 1024.
If a queue is full, all subsequent packets to this queue are dropped.
# In PQ list 10, set the length of the top queue to 10.
[Sysname] qos pql 10 queue top queue-length 10
CQ commands
· PVCs.
· POS interfaces.
display qos cql
Use display qos cql to display the CQ list configuration.
In standalone mode:
display qos cql [ cql-index ] [ slot slot-number ]
In IRF mode:
display qos cql [ cql-index ] [ chassis chassis-number slot slot-number ]
cql-index: Specifies a CQ list by its number in the range of 1 to 16. If you do not specify a CQ list, this command displays the configuration of all CQ lists.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CQ list configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the CQ list configuration for the global active MPU. (In IRF mode.)
# Display the configuration of all CQ lists.
<Sysname> display qos cql
Current CQL configuration:
2 3 Protocol ip fragments
3 6 Length 100
3 1 Inbound-interface GigabitEthernet2/0/1
4 5 Local-precedence 7
display qos queue cq interface
Use display qos queue cq interface to display the CQ information for interfaces or PVCs.
display qos queue cq interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the CQ information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the CQ information for all PVCs on the ATM interface.
If you specify a VT interface, this command displays the CQ information for all VA interfaces of the VT interface. It does not display QoS information about the VT interface.
# Display the CQ information for GigabitEthernet 2/0/1.
<Sysname>display qos queue cq interface gigabitethernet 2/0/1
Output queue - Custom queuing: CQL 1 Size/Length/Discards
1: 0/20/0 2: 0/20/0 3: 0/20/0
4: 0/20/0 5: 0/20/0 6: 0/20/0
7: 0/20/0 8: 0/20/0 9: 0/20/0
10: 0/20/0 11: 0/20/0 12: 0/20/0
13: 0/20/0 14: 0/20/0 15: 0/20/0
16: 0/20/0
Table 23 Command output
Size |
Length |
Discards |
qos cq
Use qos cq to apply a CQ list to an interface or PVC.
Use undo qos cq to restore the default.
qos cq cql cql-index
undo qos cq
Interface view
PVC view
cql cql-index: Specifies a CQ list by its number in the range of 1 to 16.
Multiple match criteria can be configured for a CQ list. When a packet arrives, it is examined against match criteria in their configuration order.
· Subinterfaces.
· VT and dialer interfaces configured with PPPoE, PPPoA, PPPoEoA, PPPoFR, or MPoFR. (To configure MPoFR, make sure the Frame Relay interface in MPoFR is not enabled with FRTS.)
# Apply CQ list 5 to GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos cq cql 5
qos cql default-queue
Use qos cql default-queue to specify a custom queue as the default queue for a CQ list.
Use undo qos cql default-queue to restore the default.
qos cql cql-index default-queue queue-id
undo qos cql cql-index default-queue
Queue 1 is the default queue.
queue-id: Specifies a custom queue by its ID in the range of 1 to 16.
If a packet does not match any criteria in a CQ list, the packet is assigned to the default queue of the CQ list.
# Specify queue 2 as the default queue for CQ list 5.
[Sysname] qos cql 5 default-queue 2
qos cql inbound-interface
Use qos cql inbound-interface to configure an assignment rule for a CQ list to assign packets received on the specified interface to a custom queue.
Use undo qos cql inbound-interface to delete an assignment rule based on the specified input interface from a CQ list.
qos cql cql-index inbound-interface interface-type interface-number queue queue-id
undo qos cql cql-index inbound-interface interface-type interface-number
No assignment rule is configured for a CQ list.
You can configure this command multiple times for the same CQ list to establish multiple assignment rules based on input interfaces.
# In CQ list 5, assign packets received from GigabitEthernet 2/0/1 to custom queue 3.
[Sysname] qos cql 5 inbound-interface gigabitethernet 2/0/1 queue 3
qos cql local-precedence
Use qos cql local-precedence to configure an assignment rule for a CQ list to assign packets with any of the specified local precedence values to a custom queue.
Use undo qos cql local-precedence to delete an assignment rule based on the specified local precedence values from a CQ list.
qos cql cql-index local-precedence local-precedence-list queue queue-id
undo qos cql cql-index local-precedence local-precedence-list
You can configure this command multiple times for the same CQ list to establish multiple assignment rules based on local precedence values.
# In CQ list 5, assign packets with local precedence 4 to custom queue 3.
[Sysname] qos cql 5 local-precedence 4 queue 3
qos cql protocol
Use qos cql protocol to configure an assignment rule for a CQ list to assign packets of the specified protocol type to a custom queue.
Use undo qos cql protocol to delete an assignment rule based on the specified protocol type from a CQ list.
qos cql cql-index protocol { ip | ipv6 } [ queue-key key-value ] queue queue-id
undo qos cql cql-index protocol { ip | ipv6 } [ queue-key key-value ]
Table 24 Values of the queue-key argument and the key-value argument
queue-key |
key-value |
acl |
fragments |
N/A |
greater-than |
less-than |
tcp |
udp |
When classifying a packet, the system matches the packet against match criteria in their configuration order. When a match is found, the matching process ends.
You can configure this command multiple times for the same CQ list to establish multiple assignment rules based on protocol types.
# In CQ list 5, assign IP packets matching ACL 3100 to custom queue 3.
[Sysname] qos cql 5 protocol ip acl 3100 queue 3
qos cql protocol mpls exp
Use qos cql protocol mpls exp to configure an assignment rule for a CQ list to assign packets with any of the specified MPLS EXP values to a custom queue.
Use undo qos cql protocol mpls exp to delete an assignment rule based on the specified MPLS EXP values from a CQ list.
qos cql cql-index protocol mpls exp exp-list queue queue-id
undo qos cql cql-index protocol mpls exp exp-list
You can configure this command multiple times for the same CQ list to establish multiple assignment rules based on MPLS EXP values.
# In CQ list 5, assign packets with MPLS EXP value 2 or 4 to custom queue 3.
[Sysname] qos cql 5 protocol mpls exp 2 4 queue 3
qos cql queue
Use qos cql queue to specify the length of a custom queue in a CQ list.
Use undo qos cql queue to restore the default length for a custom queue in a CQ list.
qos cql cql-index queue queue-id queue-length queue-length
undo qos cql cql-index queue queue-id queue-length
The queue length is 20 for each queue.
queue-length: Specifies the maximum number of packets allowed in a custom queue, in the range of 1 to 1024.
# In CQ list 5, set the length of custom queue 4 to 40.
[Sysname] qos cql 5 queue 4 queue-length 40
qos cql queue serving
Use qos cql queue serving to specify the number of bytes forwarded from a queue during a cycle.
Use undo qos cql queue serving to restore the default.
qos cql cql-index queue queue-id serving byte-count
undo qos cql cql-index queue queue-id serving
The number of bytes forwarded from a queue during a cycle is 1500 bytes.
byte-count: Specifies the number of bytes forwarded from a queue during a cycle of queue scheduling. The value range for the byte-count argument is 1 to 16777215 bytes.
# In CQ list 5, set the byte count to 1400 for queue 2.
[Sysname] qos cql 5 queue 2 serving 1400
WFQ commands
· PVCs.
· POS interfaces.
display qos queue wfq
Use display qos queue wfq to display the WFQ information for interfaces, PVCs, or PWs.
display qos queue wfq interface { [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ] | l2vpn-pw [ peer ip-address pw-id pw-id ] }
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the WFQ information for all PVCs on the ATM interface.
peer ip-address pw-id pw-id: Specifies a PW by its peer PE LSR ID and its PW ID. The ip-address argument represents the LSR ID of the peer PE of the PW. The value range for the pw-id argument is 1 to 4294967295. If you do not specify a PW, this command displays the WFQ information for all PWs.
If you specify a VT interface, this command displays the WFQ information for all VA interfaces of the VT interface. It does not display QoS information about the VT interface.
# Display the WFQ information for GigabitEthernet 2/0/1.
<Sysname> display qos queue wfq interface gigabitethernet 2/0/1
Interface: GigabitEthernet2/0/1
# Display the WFQ information for all PWs.
<Sysname> display qos queue wfq l2vpn-pw
L2VPN-PW: peer 1.1.1.1, pw-id 1
Table 25 Command output
A PW is uniquely identified by a combination of the peer PE IP address and PW ID. |
Size |
Length |
Discards |
Weight |
Active |
Max active |
Total |
qos wfq
Use qos wfq to apply WFQ to an interface, PVC, or PW, or modify WFQ parameters.
Use undo qos wfq to restore the default.
qos wfq [ dscp | precedence ] [ queue-number total-queue-number | queue-length max-queue-length ] *
undo qos wfq
An interface, PVC, or PW uses FIFO queuing.
Interface view
PVC view
dscp: Specifies DSCP as the weight type.
precedence: Specifies IP precedence as the weight type. This is the default weight type.
queue-length max-queue-length: Specifies the maximum number of packets a queue can hold. The value range for the max-queue-length argument is 1 to 1024, and the default is 64.
queue-number total-queue-number: Specifies the total number of queues, which can be 16, 32, 64, 128, 256, 512, 1024, 2048, or 4096. The default is 256.
· Subinterfaces.
# Apply WFQ to GigabitEthernet 2/0/1, and set the maximum queue length to 100 and the total number of queues to 512.
[Sysname-GigabitEthernet2/0/1] qos wfq queue-length 100 queue-number 512
RTPQ commands
· PVCs.
· POS interfaces.
display qos queue rtpq interface
Use display qos queue rtpq interface to display the RTPQ information for interfaces or PVCs.
display qos queue rtpq interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the RTPQ information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the RTPQ information for all PVCs on the ATM interface.
If you specify a VT interface, this command displays the RTPQ information for all VA interfaces of the VT interface. It does not display QoS information about the VT interface.
# Display the RTPQ information for GigabitEthernet 2/0/1.
<Sysname> display qos queue rtpq interface
Output queue - RTP queuing: Size/Max/Outputs/Discards 0/0/0/0
Table 26 Command output
Size |
Number of packets in a queue. |
Max |
Historical maximum number of packets in the queue. |
Outputs |
Number of sent packets. |
Discards |
qos rtpq
Use qos rtpq to enable RTPQ on an interface or PVC for RTP packets to specific UDP ports.
Use undo qos rtpq to restore the default.
qos rtpq start-port first-rtp-port-number end-port last-rtp-port-number bandwidth bandwidth [ cbs committed-burst-size ]
undo qos rtpq
RTPQ is disabled on an interface or PVC.
Interface view
PVC view
start-port first-rtp-port-number: Specifies the start UDP port number in the range of 2000 to 65535.
end-port last-rtp-port-number: Specifies the end UDP port number in the range of 2000 to 65535.
bandwidth bandwidth: Specifies the maximum bandwidth allowed for the RTP priority queue, in the range of 8 to 1000000 kbps.
cbs committed-burst-size: Specifies the CBS in the range of 1500 to 2000000 bytes.
You must configure the rate limit for the RTPQ feature to take effect on the following interfaces:
· Subinterfaces.
This command provides preferential service for delay-sensitive applications, such as real-time voice traffic transmission.
Set the bandwidth argument to a value greater than the required bandwidth for real-time applications to allow bursts of traffic.
# Enable RTPQ on GigabitEthernet 2/0/1 for RTP packets with a destination UDP port number in the range of 16384 to 32767.
[Sysname-GigabitEthernet2/0/1] qos rtpq start-port 16384 end-port 32767 bandwidth 64
Packet information pre-extraction commands
qos pre-classify
Use qos pre-classify to enable packet information pre-extraction on an interface.
Use undo qos pre-classify to disable packet information pre-extraction on an interface.
qos pre-classify
Packet information pre-extraction is disabled on an interface.
Tunnel interface view
# Enable packet information pre-extraction on Tunnel 1.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] qos pre-classify
Congestion avoidance commands
Congestion avoidance is not supported on the following elements on an RT-FIP-680 base card:
· PVCs.
· POS interfaces.
· Fixed ports if the RT-FIP-680 base card is enabled with enhanced queuing.
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces or PVCs.
display qos wred interface [ interface-type interface-number [ pvc { pvc-name | vpi/vci } ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide.
pvc { pvc-name | vpi/vci }: Specifies a PVC by its name or VPI/VCI value. You can specify a PVC only for an ATM interface. When you specify an ATM interface but do not specify a PVC, this command displays the WRED information for all PVCs on the ATM interface.
If you specify a VT interface, this command displays the WRED information for all VA interfaces of the VT interface. It does not display QoS information about the VT interface.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
Interface: GigabitEthernet2/0/4
Exponent: 9 (1/512)
Pre Low High Dis-prob Random-discard Tail-discard
0 10 30 10 0 0
1 10 30 10 0 0
2 10 30 10 0 0
3 10 30 10 0 0
4 10 30 10 0 0
5 10 30 10 0 0
6 10 30 10 0 0
7 10 30 10 0 0
Interface: GigabitEthernet2/0/3
Current WRED configuration:
Applied WRED table name: q1
Table 27 Command output
Interface type and interface number. |
Exponent |
Exponent for average queue length calculation. |
Pre |
IP precedence of packets. |
Low |
Lower limit for packets. |
High |
Higher limit for packets. |
Dis-prob |
Denominator for drop probability calculation. |
Random-discard |
Number of packets dropped by WRED. |
Tail-discard |
Number of packets dropped by tail drop. |
qos wred dscp
Use qos wred dscp to set the lower limit, upper limit, and drop probability denominator for a DSCP value.
Use undo qos wred dscp to restore the default.
qos wred dscp dscp-value low-limit low-limit high-limit high-limit discard-probability discard-prob
undo qos wred dscp dscp-value
The lower limit is 10, the upper limit is 30, and the drop probability denominator is 10.
Interface view
PVC view
dscp-value: Specifies a DSCP value in the range of 0 to 63. This argument can also be represented by using one of the keywords listed in Table 5.
low limit low-limit: Specifies the lower WRED limit (in packets) in the range of 1 to 1024.
high-limit high-limit: Specifies the upper WRED limit (in packets) in the range of 1 to 1024.
discard-probability discard-prob: Specifies the denominator for drop probability calculation, in the range of 1 to 255.
Before configuring this command, enable DSCP-based WRED on the interface or PVC with the qos wred dscp enable command. The upper and lower limits restrict the average queue length.
# Configure the following parameters for packets with DSCP value 63 on GigabitEthernet 2/0/1: lower limit 20, upper limit 40, and drop probability denominator 15.
[Sysname-GigabitEthernet2/0/1] qos wred dscp enable
[Sysname-GigabitEthernet2/0/1] qos wred dscp 63 low-limit 20 high-limit 40 discard-probability 15
qos wred enable
qos wred enable
Use qos wred enable to enable WRED on an interface or PVC.
Use undo qos wred enable to restore the default.
qos wred [ dscp | ip-precedence ] enable
undo qos wred [ dscp | ip-precedence ] enable
An interface or PVC uses tail drop.
Interface view
PVC view
dscp: Uses the DSCP values for calculating the drop probability.
ip-precedence: Uses the IP precedence for calculating the drop probability. This is the default.
You must enable WFQ on the interface before configuring the qos wred enable command.
# Enable WRED on GigabitEthernet 2/0/1, and use the IP precedence for drop probability calculation.
[Sysname-GigabitEthernet2/0/1] qos wred ip-precedence enable
Use qos wred ip-precedence to set the lower limit, upper limit, and drop probability denominator for an IP precedence value.
Use undo qos wred ip-precedence to restore the default.
qos wred ip-precedence ip-precedence low-limit low-limit high-limit high-limit discard-probability discard-prob
undo qos wred ip-precedence ip-precedence
Interface view
PVC view
ip-precedence precedence: Specifies an IP precedence value in the range of 0 to 7.
Before configuring this command, enable IP precedence-based WRED on the interface or PVC with the qos wred enable command.
# Configure the following parameters for packets with IP precedence value 3 on GigabitEthernet 2/0/1: lower limit 20, upper limit 40, and drop probability denominator 15.
[Sysname-GigabitEthernet2/0/1] qos wred ip-precedence 3 low-limit 20 high-limit 40 discard-probability 15
qos wred enable
qos wred weighting-constant
Use qos wred weighting-constant to set the exponent for WRED to calculate the average queue size.
Use undo qos wred weighting-constant to restore the default.
qos wred weighting-constant exponent
The exponent for WRED to calculate the average queue size is 9.
Interface view
PVC view
exponent: Specifies the exponent for average queue length calculation, in the range of 1 to 16.
Before configuring this command, enable WRED on the interface or PVC with the qos wred enable command.
If you execute the qos wred weighting-constant command multiple times, the most recent configuration takes effect.
# Set the exponent for the average queue size calculation to 6 on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos wred enable
[Sysname-GigabitEthernet2/0/1] qos wred weighting-constant 6
qos wred enable
QPPB commands
bgp-policy
Use bgp-policy to enable QPPB, which transmits the apply ip-precedence and apply qos-local-id configuration through BGP routing policies.
Use undo bgp-policy to restore the default.
bgp-policy { destination | source } { ip-prec-map | ip-qos-map } *
undo bgp-policy { destination | source } [ ip-prec-map | ip-qos-map ] *
QPPB is disabled.
Interface view
destination: Searches the routing table by destination IP address.
source: Searches the routing table by source IP address. If the source keyword is specified, the source IP address is used as the destination address for inverse lookup.
ip-prec-map: Sets an IP precedence value for matching packets.
ip-qos-map: Sets a local QoS ID for matching packets.
The bgp-policy command applies only to the incoming traffic of an interface.
In an MPLS L3VPN, the bgp-policy command is executed after the QoS features are performed in the inbound direction of the PE's public network interface. In any other case, the bgp-policy command is executed before the QoS features.
If you configure either of the following bgp-policy command pairs, both commands in the pair take effect:
· bgp-policy destination ip-prec-map and bgp-policy source ip-qos-map.
· bgp-policy source ip-prec-map and bgp-policy destination ip-qos-map.
If you configure either of the following bgp-policy command pairs, the command with the destination keyword in the pair takes effect:
· bgp-policy destination ip-prec-map and bgp-policy source ip-prec-map.
· bgp-policy destination ip-qos-map and bgp-policy source ip-qos-map.
# Configure GigabitEthernet 2/0/1 to get the IP precedence and local QoS ID by looking up routes based on source IP address.
[Sysname-GigabitEthernet2/0/1] bgp-policy source ip-prec-map ip-qos-map
apply ip-precedence (Layer 3—IP Routing Command Reference)
apply qos-local-id (Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
