- 03-Layer 2-LAN Switching Command Reference
- 01-Ethernet interface commands
- 02-Loopback, null, and inloopback interface
- 03-Bulk interface commands
- 04-MAC address table commands
- 05-Ethernet link aggregation commands
- 06-Port isolation commands
- 07-Spanning tree commands
- 08-Loop detection commands
- 09-VLAN commands
- 10-MVRP commands
- 11-QinQ commands
- 12-VLAN mapping commands
- 13-LLDP commands
- 14-L2PT commands
01-Ethernet interface commands | 188.67 KB |
Common Ethernet interface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
# Set the expected bandwidth of GigabitEthernet 1/0/1 to 1000 kbps.
[Sysname-GigabitEthernet1/0/1] bandwidth 1000
speed
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the broadcast-suppression command can suppress broadcast storms on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain broadcast command and the broadcast-suppression command on an interface.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
· If the configured value is smaller than 64, the value of 64 takes effect.
· If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
For the suppression threshold that takes effect, see the prompt on the device.
# Set the broadcast suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port GigabitEthernet1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
multicast-suppression
unicast-suppression
combo enable
Use combo enable to activate the copper or fiber combo port of a combo interface.
combo enable { auto | copper | fiber }
In Release 6126P20 and earlier, the copper combo port is active.
In Release 6127 and later, the interface automatically identifies the media inserted and activates the corresponding combo port.
auto: Automatically identifies the media inserted and activates the corresponding combo port.
copper: Activates the copper combo port. In this case, use twisted pairs to connect the port.
fiber: Activates the fiber combo port. In this case, use optical fibers to connect the port.
A combo interface is a logical interface that physically contains one fiber combo port and one copper combo port on the device panel. The two ports share one forwarding interface. As a result, they cannot work simultaneously. When you activate either port, the other port is automatically disabled. You can select to activate the copper combo port or fiber combo port.
If you execute the combo enable auto command on a combo interface and the combo interface is connected to cables or optical fibers, you can use the display interface command to display the interface information.
· If the display interface command output contains "Media type is twisted pair," the copper combo port is activated.
· Otherwise, the fiber combo port is activated.
Before using this command, perform the following tasks according to the marks on the device panel:
· Determine the combo interfaces on your device.
· Identify the two physical interfaces that belong to each combo interface.
The auto keyword is supported only in Release 6127 and later.
# Activate the copper combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable copper
# Activate the fiber combo port of combo interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] combo enable fiber
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
· The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
· The configured suppress limit is lower than or equal to the ceiling.
· The ceiling is lower than or equal to the maximum suppress limit supported.
This command, the link-delay command, and the port link-flap protect enable command are mutually exclusive on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with RRPP, MSTP, or Smart Link enabled. The S5000E-X, S5110V2-SI, and S5000V3-EI switches do not support RRPP or Smart Link.
After an interface in down state is dampened, the interface state displayed through the display interface command is always down.
# Enable interface dampening on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dampening
# Enable interface dampening on GigabitEthernet 1/0/1, and set the following parameters:
· Half life time to 2 seconds.
· Reuse value to 800.
· Suppression threshold to 3000.
· Maximum suppression interval to 5 seconds.
[Sysname-GigabitEthernet1/0/1] dampening 2 800 3000 5
display interface
link-delay
default
Use default to restore the default settings for an interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network. |
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] default
description
The description of an interface is the interface name plus Interface (for example, GigabitEthernet1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of GigabitEthernet 1/0/1 to lan-interface.
[Sysname-GigabitEthernet1/0/1] description lan-interface
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
This command displays traffic statistics within a statistics polling interval specified by using the flow-interval command.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
GE1/0/1 100 100 0 0
GE1/0/2 Overflow Overflow Overflow Overflow
Overflow: More than 14 digits (7 digits for column "Err").
--: Not supported.
Abbreviated interface name. |
Total (pkts) |
Total number of packets received or sent through the interface. |
Broadcast (pkts) |
Total number of broadcast packets received or sent through the interface. |
Multicast (pkts) |
Total number of multicast packets received or sent through the interface. |
Err (pkts) |
Total number of error packets received or sent through the interface. |
Overflow: More than 14 digits (7 digits for column "Err") |
The command displays Overflow when any of the following conditions exist: · The data length of an Err field value is greater than 7 decimal digits. · The data length of a non-Err field value is greater than 14 decimal digits. |
--: Not supported |
The statistical item is not supported. |
flow-interval
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
To set the statistics polling interval, use the flow-interval command.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface Usage (%) Total (pps) Broadcast (pps) Multicast (pps)
GE1/0/1 0 0 -- --
Overflow: More than 14 digits.
--: Not supported.
Usage (%) |
Bandwidth usage (in percentage) of the interface for the last statistics polling interval. |
Total (pkts/sec) |
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval. |
Broadcast (pkts/sec) |
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval. |
Multicast (pkts/sec) |
Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. . |
Overflow: more than 14 decimal digits |
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits. |
--: not supported |
flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
display ethernet statistics slot slot-number
slot slot-number: Specifies an IRF member device by its member ID.
# Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
Totalnum : 10447 ETHIINum : 4459
SNAPNum : 0 RAWNum : 0
LLCNum : 0 UnknownNum : 0
ForwardNum : 4459 ARP : 0
MPLS : 0 ISIS : 0
ISIS2 : 0 IP : 0
IPV6 : 0
ETH receive error statistics:
NullPoint : 0 ErrIfindex : 0
ErrIfcb : 0 IfShut : 0
ErrAnalyse : 5988 ErrSrcMAC : 5988
ErrHdrLen : 0
ETH send packet statistics:
L3OutNum : 211 VLANOutNum : 0
FastOutNum : 155 L2OutNum : 0
ETH send error statistics:
MbufRelayNum : 0 NullMbuf : 0
ErrAdjFwd : 0 ErrPrepend : 0
ErrHdrLen : 0 ErrPad : 0
ErrQoSTrs : 0 ErrVLANTrs : 0
ErrEncap : 0 ErrTagVLAN : 0
IfShut : 0 IfErr : 0
Table 3 Output description
ETH receive packet statistics |
Statistics about the Ethernet packets received by the Ethernet module: · Totalnum—Total number of received packets. · ETHIINum—Number of packets encapsulated by using Ethernet II. · SNAPNum—Number of packets encapsulated by using SNAP. · RAWNum—Number of packets encapsulated by using RAW. · ISISNum—Number of packets encapsulated by using ISIS. This field is not supported in the current software version. · LLCNum—Number of packets encapsulated by using LLC. · UnknownNum—Number of packets encapsulated by using unknown methods. · ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU. · ARP—Number of ARP packets. · MPLS—Number of MPLS packets. This field is not supported in the current software version. · ISIS—Number of IS-IS packets. This field is not supported in the current software version. · ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS. This field is not supported in the current software version. · IP—Number of IP packets. · IPv6—Number of IPv6 packets. |
ETH receive error statistics |
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include: · NullPoint—Number of packets that include null pointers. · ErrIfindex—Number of packets that include incorrect interface indexes. · ErrIfcb—Number of packets that include incorrect interface control blocks. · IfShut—Number of packets that are being received when the interface is shut down. · ErrAnalyse—Number of packets that include packet parsing errors. · ErrSrcMAC—Number of packets that include incorrect source MAC addresses. · ErrHdrLen—Number of packets that include header length errors. |
ETH send packet statistics |
Statistics about the Ethernet packets sent by the Ethernet module: · L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces. · VLANOutNum—Number of packets sent out of VLAN interfaces. · FastOutNum—Number of packets fast forwarded. · L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces. · MbufRelayNum—Number of packets transparently sent. |
ETH send error statistics |
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module: · NullMbuf—Number of packets with null pointers. · ErrAdjFwd—Number of packets with adjacency table errors. · ErrPrepend—Number of packets with extension errors. · ErrHdrLen—Number of packets with header length errors. · ErrPad—Number of packets with padding errors. · ErrQoSTrs—Number of packets that failed to be sent by QoS. · ErrVLANTrs—Number of packets that failed to be sent in VLANs. · ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures. · ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures. · IfShut—Number of packets that are being sent when the interface is shut down. · IfErr—Number of packets with incorrect outgoing interfaces. |
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display detailed information about Layer 2 interface GigabitEthernet 1/0/1.
<Sysname> display interface gigabitethernet 1/0/1
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters: 14:34:09 Tue 11/01/2011
Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
Last 300 second input: 0 packets/sec 0 bytes/sec -%
Last 300 second output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command. · mac-address moving down—The interface has been shut down by the MAC address move suppression feature. · MAD ShutDown—The interface has been shut down by IRF MAD. This state occurs if the interface is on an IRF fabric placed in Recovery state after an IRF split. · OFP DOWN—The interface has been shut down by OpenFlow. · Storm-Constrain—The interface has been shut down because the storm control feature detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. · DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include: ¡ DLDP—Shuts down the data link layer when it detects that the link is unidirectional. ¡ OAM—Shuts down the data link layer when it detects a remote link failure. ¡ LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports. ¡ BFD—Shuts down the data link layer when it detects a link failure. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the interface. |
Port priority |
Port priority of the interface. |
Loopback is set internal |
An internal loopback test is running on the interface. This field depends on your configuration. |
Loopback is set external |
An external loopback test is running on the interface. This field depends on your configuration. |
Loopback is not set |
No loopback test is running on the interface. This field depends on your configuration. |
10Mbps-speed mode |
The interface is operating at 10 Mbps. This field depends on your configuration and the link parameter negotiation result. |
100Mbps-speed mode |
The interface is operating at 100 Mbps. This field depends on your configuration and the link parameter negotiation result. |
1000Mbps-speed mode |
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result. |
10Gbps-speed mode |
The interface is operating at 10 Gbps. This field depends on your configuration and the link parameter negotiation result. |
Unknown-speed mode |
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected. |
half-duplex mode |
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result. |
full-duplex mode |
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result. |
unknown-duplex mode |
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected. |
Link speed type is autonegotiation |
The interface is configured with the speed auto command. |
Link speed type is force link |
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command. |
link duplex type is autonegotiation |
The interface is configured with the duplex auto command. |
link duplex type is force link |
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command. |
Flow-control is not enabled |
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result. |
Maximum frame length |
Maximum length of Ethernet frames allowed to pass through the interface. |
Allow jumbo frame to pass |
The interface allows jumbo frames to pass through. |
Broadcast max- |
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration. |
Multicast max- |
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration. |
Unicast max- |
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration. |
PVID |
Port VLAN ID (PVID) of the interface. |
MDI type |
MDIX mode of the interface: · automdix. · mdi. · mdix. |
Port link-type |
Link type of the interface: · access. · trunk. · hybrid. |
Tagged VLANs |
VLANs for which the interface sends packets without removing VLAN tags. |
Untagged VLANs |
VLANs for which the interface sends packets after removing VLAN tags. |
VLAN Passing |
VLANs whose packets can be forwarded by the port. The VLANs must have been created. |
VLAN permitted |
VLANs whose packets are permitted by the port. |
Trunk port encapsulation |
Encapsulation protocol type for the trunk port. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 second input: 0 packets/sec 0 bytes/sec 0% Last 300 second output: 0 packets/sec 0 bytes/sec 0% |
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth. A hyphen (-) indicates that the statistical item is not supported. |
Input(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of inbound unicast packets. · Number of inbound broadcasts. · Number of inbound multicasts. · Number of inbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Input(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of inbound normal unicast packets. · Number of inbound normal broadcasts. · Number of inbound normal multicasts. · Number of inbound normal pause frames. A hyphen (-) indicates that the statistical item is not supported. |
input errors |
Statistics of incoming error packets. |
runts |
Number of inbound frames meeting the following conditions: · Shorter than 64 bytes. · In correct format. · Containing valid CRCs. |
giants |
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface. For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows: · 1518 bytes (without VLAN tags). · 1522 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface. |
throttles |
Number of inbound frames that had a non-integer number of bytes. |
CRC |
Total number of inbound frames that had a normal length, but contained CRC errors. |
frame |
Total number of inbound frames that contained CRC errors and a non-integer number of bytes. |
overruns |
Number of packets dropped because the input rate of the port exceeded the queuing capability. |
aborts |
Total number of illegal inbound packets: · Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value. · Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length). ¡ For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags). ¡ For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface. · Symbol error frames—Frames that contained a minimum of one undefined symbol. · Unknown operation code frames—Non-pause MAC control frames. · Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes). |
ignored |
Number of inbound frames dropped because the receiving buffer of the port ran low. |
parity errors |
Total number of frames with parity errors. |
Output(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of outbound unicast packets. · Number of outbound broadcasts. · Number of outbound multicasts. · Number of outbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Output(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of outbound normal unicast packets. · Number of outbound normal broadcasts. · Number of outbound normal multicasts. · Number of outbound normal pause frames. A hyphen (-) indicates that the statistical item is not supported. |
output errors |
Number of outbound packets with errors. |
underruns |
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly. |
buffer failures |
Number of packets dropped because the transmitting buffer of the interface ran low. |
aborts |
Number of packets that failed to be transmitted, for example, because of Ethernet collisions. |
deferred |
Number of frames that the interface deferred to transmit because of detected collisions. |
collisions |
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission. |
late collisions |
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions. |
lost carrier |
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces. |
no carrier |
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces. |
Peak input rate |
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred. |
Peak output rate |
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred. |
# Display brief information about all interfaces.
Protocol: (s) – spoofing
Loop0 UP UP(s) 2.2.2.9
NULL0 UP UP(s) --
Vlan1 UP DOWN --
Vlan999 UP UP 192.168.1.42
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
GE1/0/2 DOWN auto A A 1
GE1/0/3 UP auto F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about GigabitEthernet 1/0/3, including the complete description of the interface.
<Sysname> display interface gigabitethernet 1/0/3 brief description
Speed: (a) - auto
GE1/0/3 UP auto F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
Interface Link Cause
Vlan2 DOWN Not connected
GE1/0/2 DOWN Not connected
Table 5 Command output
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Description of the interface. |
Brief information of interfaces in bridge mode: |
Brief information about Layer 2 interfaces. |
Type: A - access; T - trunk; H – hybrid |
Link type options for interfaces. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
PVID |
Port VLAN ID. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down. · DOWN (Loopback detection down)—The loopback detection module has detected loops. · DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down. · MAD ShutDown—The interface is on an IRF fabric placed by IRF MAD in Recovery state after an IRF split. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). · Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · Port Security Disabled—The interface has been shut down by the intrusion detection mechanism because the interface received illegal packets. · OFP DOWN—The interface has been shut down by OpenFlow. · Standby—The interface is a backup interface in standby state. |
display link-flap protection
Use display link-flap protection to display information about link flapping protection on an interface.
display link-flap protection [ interface interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays information about link flapping protection on all interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays information about link flapping protection on all interfaces of the specified type.
This command is supported only in Release 6127 and later.
# Display information about link flapping protection on all interfaces.
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface Link-flap Status Interval Threshold
GE1/0/1 Enabled Down 10 5
GE1/0/2 Disabled N/A -- --
Link-flap protection |
Status of global link flapping protection: · Enabled—Link flapping protection is enabled globally. · Disabled—Link flapping protection is disabled globally. |
Link-flap |
Status of link flapping protection on an interface: · Enabled—Link flapping protection is enabled on an interface. · Disabled—Link flapping protection is disabled on an interface. |
Status |
Status of an interface: · Down—The interface has been shut down by the link flapping protection feature. · N/A—The interface status is not affected by the link flapping protection feature. |
Interval |
Link flapping detection interval for an interface. |
Threshold |
Link flapping detection threshold for an interface. |
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full | half }
undo duplex
An Ethernet interface operates in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time. Fiber ports, 1000-Mbps Ethernet interfaces, and 10000-Mbps Ethernet interfaces do not support this keyword.
# Configure GigabitEthernet 1/0/1 to operate in full duplex mode.
[Sysname-GigabitEthernet1/0/1] duplex full
eee enable
IMPORTANT: Fiber ports do not support this command. |
Use eee enable to enable Energy Efficient Ethernet (EEE) on an interface.
Use undo eee enable to disable EEE on an interface.
eee enable
undo eee enable
EEE is disabled.
With EEE enabled, a link-up interface enters low power state if it has not received any packet for a period of time. The time period depends on the chip specifications and is not configurable. When a packet arrives later, the interface restores to the normal state.
# Enable EEE on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] eee enable
flow-control
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable TxRx-mode generic flow control on the Ethernet interface.
flow-control
undo flow-control
TxRx-mode generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames:
· When congested, the interface sends a flow control frame to its peer.
· Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control on a link, enable generic flow control at both ends of the link.
# Enable TxRx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-control
flow-control receive enable
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable Rx-mode generic flow control on an Ethernet port.
undo flow-control
Rx-mode generic flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
· When the interface receives a flow control frame from its peer, it suspends sending packets to the peer.
· When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
# Enable Rx-mode generic flow control on GigabitEthernet 1/0/1.
[Sysname-gigabitethernet 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] flow-interval 100
interface
Use interface to enter interface view.
# Enter the view of GigabitEthernet 1/0/1.
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within 10240 bytes to pass through.
size: Sets the maximum length of (in bytes) Ethernet frames that are allowed to pass through. The value range for this argument is 1522 to 10240.
# Allow jumbo frames to pass through GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
link-delay [ msec ] delay-time [ mode { up | updown } ]
undo link-delay [ msec ] delay-time [ mode { up | updown } ]
Each time the physical link of a port goes up or comes down, the interface immediately reports the change to the CPU.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
· If you do not specify the msec keyword, the value range is 0 to 30 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
mode up: Suppresses the link-up events.
mode updown: Suppresses both the link-up and link-down events.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
· To suppress only link-down events, configure the link-delay [ msec ] delay-time command.
· To suppress only link-up events, configure the link-delay [ msec ] delay-time mode up command.
· To suppress both link-down and link-up events, configure the link-delay [ msec ] delay-time mode updown command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you configure the link-delay command multiple times for link-up or link-down events, the most recent configuration takes effect.
Do not configure this command on an interface that has RRPP, spanning tree protocols, or Smart Link enabled. The S5000E-X, S5110V2-SI, and S5000V3-EI switches do not support RRPP or Smart Link.
This command, the dampening command, and the port link-flap protect enable command are mutually exclusive on an Ethernet interface.
# Set the link-down event suppression interval to 8 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-delay 8
# Set the link-up event suppression interval to 800 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] link-delay msec 800 mode up
dampening
Use link-flap protect enable to enable link flapping protection globally.
Use undo link-flap protect enable to disable link flapping protection globally.
Link flapping on any interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when the interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, execute this command.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
Link flapping protection takes effect only when it is enabled in both system view and interface view.
# Enable link flapping protection globally.
[Sysname] link-flap protect enable
loopback
Use loopback to enable loopback testing on an Ethernet interface.
Loopback testing is disabled on an Ethernet interface.
external: Enables external loopback testing on the Ethernet interface.
internal: Enables internal loopback testing on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
An Ethernet interface in a loopback test cannot correctly forward data packets.
You cannot perform a loopback test on Ethernet interfaces manually brought down (displayed as in ADM or Administratively DOWN state).
The speed, duplex, and shutdown commands cannot be configured on an Ethernet interface in a loopback test.
# Enable internal loopback testing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] loopback internal
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the multicast-suppression command can suppress multicast storms on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain multicast command and the multicast-suppression command on an interface.
To determine the suppression threshold that takes effect, see the prompts on the switch.
# Set the multicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] multicast-suppression kbps 10000
unicast-suppression
port auto-power-down
Use port auto-power-down to enable auto power-down on an Ethernet interface.
Use undo port auto-power-down to disable auto power-down on an Ethernet interface.
Auto power-down is disabled on Ethernet interfaces.
When an interface with auto power-down enabled has been down for a specific period of time, both of the following events occur:
· The device automatically stops supplying power to the interface.
· The interface enters the power save mode.
When the interface comes up, both of the following events occur:
· The device automatically restores the power supply to the interface.
· The interface restores to its normal state.
# Enable auto power-down on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port auto-power-down
Use port link-flap protect enable to enable link flapping protection on an interface.
Use undo port link-flap protect enable to disable link flapping protection on an interface.
port link-flap protect enable [ interval interval | threshold threshold ] *
undo port link-flap protect enable [ interval | threshold ]
interval: Specifies the link flapping detection interval in seconds. The value range for this argument is 10 to 60. The default value for this argument is 10.
threshold: Specifies the link flapping detection threshold in the range of 5 to 10. The default value for this argument is 5.
If you do not specify the interval interval or threshold threshold option when you execute the port link-flap protect enable command, the command uses the default settings.
If you specify the interval or threshold keyword when you execute the undo port link-flap protect enable command, the command restores the default setting for the keyword.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
This command, the dampening command, and the link-delay command are mutually exclusive on an Ethernet interface.
# Enable link flapping protection on an interface. Set the link flapping detection interval to 10 seconds, and set the link flapping detection threshold to 5.
[Sysname-GigabitEthernet 1/0/1] port link-flap protect enable interval 10 threshold 5
dampening
link-delay
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number ] ]
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for GigabitEthernet 1/0/1.
<Sysname> reset counters interface gigabitethernet 1/0/1
display counters interface
display counters rate interface
display interface
Use reset ethernet statistics to clear the Ethernet module statistics.
reset ethernet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics for all IRF member devices.
# Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
Ethernet interfaces are in up state.
Some interface configurations might require an interface restart before taking effect.
The shutdown command cannot be configured on an interface in a loopback test.
# Shut down and then bring up GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] shutdown
[Sysname-GigabitEthernet1/0/1] undo shutdown
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | auto }
undo speed
An Ethernet interface negotiates a speed with its peer.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module.
Support of an interface for the keywords depends on the interface type. For more information, use the speed ? command in interface view.
# Configure GigabitEthernet 1/0/1 to autonegotiate the speed.
[Sysname-GigabitEthernet1/0/1] speed auto
speed auto downgrade
Use speed auto downgrade to enable automatic negotiation for speed downgrading.
Use undo speed auto downgrade to disable automatic negotiation for speed downgrading.
Automatic negotiation for speed downgrading is enabled.
This command takes effect after you configure it on the interface at either end of a link and the two interfaces are configured to automatically negotiate the speed.
This command is applicable only to GE interfaces.
# Enable automatic negotiation for speed downgrading on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] speed auto downgrade
speed auto
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to disable unknown unicast storm suppression.
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
Both the storm-constrain command and the unicast-suppression command can suppress unknown unicast storms on a port. The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress unknown unicast traffic.
For the unknown unicast traffic suppression result to be determined, do not configure both the storm-constrain unicast command and the unicast-suppression command on an interface.
# Set the unknown unicast storm suppression threshold to 10000 kbps on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] unicast-suppression kbps 10000
Layer 2 Ethernet interface commands
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
unicast: Displays unknown unicast storm control settings and statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays storm control settings and statistics for all storm control-enabled interfaces.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC - unicast
KNUC - known unicast; FW - forwarding
Flow Statistic Interval: 5 (in seconds)
Port Type Lower Upper Unit CtrlMode Status Trap Log SwitchNum
GE1/0/1 MC 100 200 kbps shutdown shutdown off on 10
Table 7 Command output
Flow Statistic Interval |
Traffic polling interval (in seconds) of the storm control module. |
Port |
Type |
Type of traffic subjected to storm control: · BC—Broadcast packets. · MC—Multicast packets. · UC—Unknown unicast packets. · KNUC—Known unicast packets. This field is not supported in the current software version. |
Lower |
Lower storm control threshold, in pps, kbps, or percentage. |
Upper |
Upper storm control threshold, in pps, kbps, or percentage. |
Unit |
Storm control threshold unit: · pps. · kbps. · percentage. |
CtrlMode |
Action (block or shutdown) taken on the interface when the upper threshold is reached. N/A indicates that no action is configured. |
Status |
Packet forwarding status: · forwarding—The port is forwarding traffic correctly. · shutdown—The port has been shut down. · block—The port drops the type of traffic. |
Trap |
Status of the storm control threshold event trap switch: · on—The port sends threshold event traps. · off—The port does not send threshold event traps. |
Log |
Status of the storm control threshold event log switch: · on—The port sends threshold event log messages. · off—The port does not send threshold event log messages. |
SwitchNum |
Number of forwarding state changes of the interface. When the SwitchNum field reaches 65535, it resets automatically. |
mdix-mode
Use mdix-mode to configure the Medium Dependent Interface Cross-Over (MDIX) mode of an Ethernet interface.
Use undo mdix-mode to restore the default.
mdix-mode { automdix | mdi| mdix }
undo mdix-mode
Ethernet interfaces operate in automdix mode.
automdix: Specifies that the interface negotiates pin roles with its peer.
mdi: Specifies that pins 1 and 2 are transmit pins and pins 3 and 6 are receive pins.
mdix: Specifies that pins 1 and 2 are receive pins and pins 3 and 6 are transmit pins.
# Configure GigabitEthernet 1/0/1 to operate in automdix mode.
[Sysname-GigabitEthernet1/0/1] mdix-mode automdix
port bridge enable
Use port bridge enable to enable bridging on an Ethernet interface.
Use undo port bridge enable to disable bridging on an Ethernet interface.
port bridge enable
Bridging is disabled on an Ethernet interface.
By default, the device drops packets whose outgoing interface and incoming interface are the same.
To enable the device to forward such packets rather than drop them, configure this command in Ethernet interface view. After the device receives a broadcast or unknown unicast packet, the device forwards the packet through all interfaces in the VLAN to which the incoming interface of the packet belongs.
Do not add interfaces configured with this command to an aggregation group.
# Enable bridging on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port bridge enable
speed auto
Use speed auto to set options for speed autonegotiation.
speed auto { 10 | 100 | 1000 } *
undo speed
No option is set for speed autonegotiation.
100-Mbps or 1000-Mbps Layer 2 Ethernet interface view
10: Configures 10 Mbps as an option for speed autonegotiation.
100: Configures 100 Mbps as an option for speed autonegotiation.
1000: Configures 1000 Mbps as an option for speed autonegotiation.
The speed command and the speed auto command supersede each other. The most recent command that you configure takes effect. For example:
· If you configure speed auto 100 1000 and then speed 100 on the interface, the interface speed is forcibly set to 100 Mbps.
· If you configure speed 100 and then speed auto 100 1000 on the interface, the interface negotiates with its peer for a speed. The negotiated speed is either 100 Mbps or 1000 Mbps.
Speed autonegotiation enables an Ethernet interface to negotiate with its peer for the highest speed that both ends support. You can narrow down the speed option list for negotiation. To avoid negotiation failures, make sure a minimum of one speed option is supported at both ends.
# Configure GigabitEthernet 1/0/1 to use 10 Mbps and 1000 Mbps for speed negotiation.
[Sysname-GigabitEthernet1/0/1] speed auto 10 1000
speed
storm-constrain
Use storm-constrain to enable storm control and set thresholds for broadcast, multicast, or unknown unicast packets on an Ethernet interface.
Use undo storm-constrain to disable storm control for broadcast, multicast, unknown unicast, or all types of traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
Traffic storm control is disabled.
all: Disables storm control for all types of traffic: broadcast, multicast, and unknown unicast.
broadcast: Enables or disables broadcast storm control.
multicast: Enables or disables multicast storm control.
unicast: Enables or disables unknown unicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
· If you specify the pps keyword, the value range for the upperlimit argument is 0 to 1.4881 × the interface bandwidth.
· If you specify the kbps keyword, the value range for the upperlimit argument is 0 to the interface bandwidth.
· If you specify the ratio keyword, the value range for the upperlimit argument is 0 to 100.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
· If you specify the pps keyword, the value range for the lowerlimit argument is 0 to 1.4881 × the interface bandwidth.
· If you specify the kbps keyword, the value range for the lowerlimit argument is 0 to the interface bandwidth.
· If you specify the ratio keyword, the value range for the lowerlimit argument is 0 to 100.
After you configure storm control for a type of traffic, the device collects the statistics for the type of traffic at the interval configured by using the storm-constrain interval command. When the type of traffic exceeds its upper threshold, the interface takes an action configured by using the storm-constrain control command.
The storm-constrain, broadcast-suppression, multicast-suppression, and unicast-suppression commands can suppress storms on an interface. The broadcast-suppression, multicast-suppression, and unicast-suppression commands use the chip to physically suppress traffic. They have less influence on the device performance than the storm-constrain command, which uses software to suppress traffic.
For the traffic suppression result to be determined, do not configure both storm control and storm suppression for the same type of traffic.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable unknown unicast storm control on GigabitEthernet 1/0/1 and set the upper and lower thresholds to 200 pps and 150 pps, respectively.
[Sysname-GigabitEthernet1/0/1] storm-constrain unicast pps 200 150
# Enable broadcast storm control on GigabitEthernet 1/0/2, and set the upper and lower thresholds to 2000 kbps and 1500 kbps, respectively.
[Sysname-GigabitEthernet1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on GigabitEthernet 1/0/3, and set the upper and lower thresholds to 80% and 15%, respectively.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] storm-constrain multicast ratio 80 15
Use storm-constrain control to set the action to take on an Ethernet interface when a type of traffic (unknown unicast, multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic and forwards other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the port begins to forward the traffic.
shutdown: Goes down automatically. The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not forward the traffic. To bring up the interface, use the undo shutdown command or disable storm control on the interface.
# Configure GigabitEthernet 1/0/1 to block a specific type of traffic when the type of traffic exceeds the upper storm control threshold.
[Sysname-GigabitEthernet1/0/1] storm-constrain control block
storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to output log messages when it detects storm control threshold events.
Use undo storm-constrain enable log to disable an Ethernet interface from outputting log messages for storm control threshold events.
An Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable GigabitEthernet 1/0/1 to output log messages when it detects storm control threshold events.
[Sysname-GigabitEthernet1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable an Ethernet interface from sending storm control threshold event traps.
An interface sends out storm control threshold event traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable GigabitEthernet 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-GigabitEthernet1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval interval
The storm control module polls traffic statistics every 10 seconds.
interval: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds. To ensure network stability, as a best practice, do not use a traffic polling interval shorter than 10 seconds.
The traffic polling interval set by using the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
storm-constrain
virtual-cable-test
IMPORTANT: This command is not available on fiber ports. |
Use virtual-cable-test to test the cable connection of an Ethernet interface and display the test result.
virtual-cable-test
When an interface is up and operates at 1000 Mbps, the cable connection test result is not accurate. The cable connection test is not supported on an interface operating at 10 Mbps or 100 Mbps, and the test result is invalid.
The cable connection test is not supported on an interface manually shut down by using the shutdown command.
The test result is for reference only. The cable length detection error is up to 5 m (about 16 ft).
If a test item is not available, a hyphen (-) is displayed.
# Test the cable connection of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] virtual-cable-test
Cable status: abnormal(open), 140 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: - db
Table 8 Command output
Cable status |
Cable status: · Normal—The cable is in good condition. · Abnormal—The cable is abnormal. · Abnormal (open)—An open circuit is detected. · Abnormal (short)—A short circuit is detected. · Failure—The test failed. |
n metre(s) |
If the cable connection is working correctly, this field displays the total length of the cable. If the cable connection fails, this field displays the length from the local port to the faulty point. |
