- 05-Layer 3-IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 policy-based routing configuration
- 12-Routing policy configuration
07-Policy-based routing configuration | 102.49 KB |
Restrictions and guidelines: PBR configuration
Setting match criteria for a node
Configuring actions for a node
Specifying a policy for local PBR
Specifying a policy for interface PBR
Display and maintenance commands for PBR
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs. The parameters include the next hop.
Packet forwarding process
The device forwards received packets using the following process:
1. The device uses PBR to forward matching packets.
2. If one of the following events occurs, the device searches for a route (except the default route) in the routing table to forward packets:
¡ The packets do not match the PBR policy.
¡ The PBR-based forwarding fails.
3. If the forwarding fails, the device uses the default route to forward packets.
PBR types
PBR includes the following types:
· Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
· Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
· Each node is identified by a node number. A smaller node number has a higher priority.
· A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
· A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
PBR supports only the if-match acl clause to set an ACL match criterion. On a node, you can specify only one if-match clause.
Relationship between apply clauses
PBR supports only the apply next-hop clause to set next hops.
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node? |
Match mode |
Permit |
Deny |
Yes. |
· If the node contains apply clauses, PBR executes the apply clauses on the node. If the PBR-based forwarding succeeds, PBR does not compare the packet with the next node. · If the node does not contain apply clauses, the device performs a routing table lookup for the packet. |
The device performs a routing table lookup for the packet. |
No. |
PBR compares the packet with the next node. |
NOTE: A node that has no if-match clauses matches any packet. |
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop.
· When the track entry associated with an object changes to Negative, the apply clause is invalid.
· When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see High Availability Configuration Guide.
PBR tasks at a glance
To configure PBR, perform the following tasks:
b. Setting match criteria for a node
c. Configuring actions for a node
2. Specifying a policy for PBR
¡ Specifying a policy for local PBR
¡ Specifying a policy for interface PBR
Configuring a policy
Creating a node
1. Enter system view.
2. Create a node for a policy, and enter its view.
2. Enter policy node view.
3. Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
An ACL match criterion does not use the permit or deny action and the time range of the specified ACL to match packets.
About apply clauses
You can use the apply next-hop clause set next hops for matching packets on a node.
For outbound PBR, you can specify only one next hop and the next hop must be directly connected.
If you specify a next hop or default next hop, PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
Configuring actions to direct packet forwarding
3. Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no next hop is specified.
On a node, you can specify a maximum of two next hops for backup in one command line or by executing this command multiple times.
About local PBR
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2. Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
About interface PBR
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2. Enter interface view.
3. Specify a policy for interface PBR.
ip policy-based-route policy-name
By default, no interface policy is applied to an interface.
Task |
Command |
Display PBR policy information. |
display ip policy-based-route [ policy policy-name ] |
Display interface PBR configuration and statistics. |
display ip policy-based-route interface interface-type interface-number [ slot slot-number ] |
Display local PBR configuration and statistics. |
display ip policy-based-route local [ slot slot-number ] |
Display PBR configuration. |
display ip policy-based-route setup |
Clear PBR statistics. |
reset ip policy-based-route statistics [ policy policy-name ] |
PBR configuration examples
Example: Configuring packet type-based local PBR
As shown in Figure 1, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2 (Switch B).
1. Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IP addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 1.1.2.1 24
[SwitchA-Vlan-interface20] ip address 1.1.3.1 24
# Configure ACL 3101 to match TCP packets.
[SwitchA] acl advanced 3101
[SwitchA-acl-ipv4-adv-3101] rule permit tcp
[SwitchA-acl-ipv4-adv-3101] quit
# Configure Node 5 for the policy aaa to forward TCP packets to next hop 1.1.2.2.
[SwitchA] policy-based-route aaa permit node 5
[SwitchA-pbr-aaa-5] if-match acl 3101
[SwitchA-pbr-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbr-aaa-5] quit
# Configure local PBR by applying the policy aaa to Switch A.
[SwitchA] ip local policy-based-route aaa
2. Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IP address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ip address 1.1.2.2 24
3. Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IP address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 1.1.3.2 24
# Telnet to Switch B on Switch A. The operation succeeds. (Details not shown.)
# Telnet to Switch C on Switch A. The operation fails. (Details not shown.)
# Ping Switch C from Switch A. The operation succeeds. (Details not shown.)
Telnet uses TCP, and ping uses ICMP. The results show the following:
· All TCP packets sent from Switch A are forwarded to the next hop 1.1.2.2.
· Other packets are forwarded through VLAN-interface 20.
· The local PBR configuration is effective.
Example: Configuring packet type-based interface PBR
As shown in Figure 2, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1.1.2.2 (Switch B).
1. Make sure Switch B and Switch C can reach Host A. (Details not shown.)
2. Configure Switch A:
[SwitchA] vlan 10
[SwitchA] vlan 20
# Configure interface PBR by applying the policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ip address 10.110.0.10 24
[SwitchA-Vlan-interface11] ip policy-based-route aaa
# On Host A, Telnet to Switch B that is directly connected to Switch A. The operation succeeds. (Details not shown.)
# On Host A, Telnet to Switch C that is directly connected to Switch A. The operation fails. (Details not shown.)
# Ping Switch C from Host A. The operation succeeds. (Details not shown.)
· All TCP packets arriving on VLAN-interface 11 of Switch A are forwarded to next hop 1.1.2.2.
· The interface PBR configuration is effective.
