00-Preface | 21.33 KB |
Preface
This installation guide describes the procedures for installing and removing the super controller OpenStack plug-ins.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with H3C super controller.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Documentation feedback
We appreciate your comments.
