- 06-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-MLD snooping commands
- 09-IPv6 PIM snooping commands
- 10-IPv6 multicast VLAN commands
- 11-IPv6 multicast routing and forwarding commands
- 12-MLD commands
- 13-IPv6 PIM commands
02-PIM snooping commands | 75.01 KB |
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
pim-snooping graceful-restart join-aging-time
pim-snooping graceful-restart neighbor-aging-time
display pim-snooping neighbor
Use display pim-snooping neighbor to display PIM snooping neighbor information.
display pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping neighbor information for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays PIM snooping neighbor information on the master device.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display detailed PIM snooping neighbor information for VLAN 2.
<Sysname> display pim-snooping neighbor vlan 2 verbose
Total 2 neighbors.
VLAN 2: Total 2 neighbors.
10.1.1.2
Slots (0 in total):
Ports (1 in total):
XGE1/0/1 (02:02:23) LAN Prune Delay(T)
10.1.1.3
Slots (0 in total):
Ports (1 in total):
XGE1/0/2 (00:32:43)
Total 2 neighbors |
Total number of PIM snooping neighbors. |
VLAN 2: Total 2 neighbors |
Total number of PIM snooping neighbors in VLAN 2. |
10.1.1.2 |
IP address of the PIM snooping neighbor. |
Ports (1 in total) |
Ports that have PIM snooping neighbors, and the total number of the ports. |
(02:02:23) |
Remaining aging timer for a PIM snooping neighbor on the port. · For a global port, this field is always displayed. · For a non-global port, this field is displayed if the port is on the master device. Otherwise, you must specify the slot slot-number option to display this field. |
The PIM hello message sent by the PIM snooping neighbor has the LAN_Prune_Delay option. |
The join message suppression feature has been disabled for the PIM snooping neighbor. |
Use display pim-snooping router-port to display PIM snooping router port information.
display pim-snooping router-port [ vlan vlan-id ] [ slot slot-number ]
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping router port information for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays PIM snooping router port information on the master device.
# Display PIM snooping router port information for VLAN 2.
<Sysname> display pim-snooping router-port vlan 2
VLAN 2:
Router slots (0 in total):
Router ports (2 in total):
XGE1/0/1 (00:01:30)
XGE1/0/2 (00:01:32)
VLAN 2 |
VLAN ID. |
Router ports (2 in total) |
Router ports, and the total number of the router ports. |
(00:01:30) |
Remaining aging time for the router port. · For a global port, this field is always displayed. · For a non-global port, this field is displayed if the port is on the master device. Otherwise, you must specify the slot slot-number option to display this field. |
Use display pim-snooping routing-table to display PIM snooping routing entries.
display pim-snooping routing-table [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094. If you do not specify a VLAN, this command displays PIM snooping routing entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays PIM snooping routing entries on the master device.
# Display detailed information about PIM snooping routing entries for VLAN 2.
<Sysname> display pim-snooping routing-table vlan 2 verbose
Total 1 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 2: Total 1 entries.
(172.10.10.1, 225.1.1.1)
Upstream neighbor: 20.1.1.1
FSM information: dummy
Upstream Slots (0 in total):
Upstream Ports (1 in total):
XGE1/0/1
Downstream Slots (0 in total):
Downstream Ports (2 in total):
XGE1/0/2
Expires: 00:03:01, FSM: J
Downstream Neighbors (2 in total):
7.1.1.1
Expires: 00:59:19, FSM: J
7.1.1.11
Expires: 00:59:20, FSM: J
XGE1/0/3
Expires: 00:02:21, FSM: PP
Total 1 entries |
Total number of (S, G) entries and (*, G) entries. |
FSM Flag: NI-no info, J-join, PP-prune pending |
State machine flag of the downstream port: · NI—Initial state. · J—Join. · PP—Prune pending. |
(172.10.10.1, 225.1.1.1) |
(S, G) entry. |
Finite state machine information of the entry: · delete—The entry attributes have been deleted. · dummy—The entry is a new temporary entry. · no info—No entry exists. |
Upstream neighbor |
Upstream neighbor of the (S, G) or (*, G) entry. |
Upstream Ports (1 in total) |
Upstream ports, and the total number of the upstream ports. This field is displayed if the upstream neighbor is on the master device. Otherwise, you must specify the slot slot-number option to display this field. |
Downstream Ports (2 in total) |
Downstream port of the upstream neighbor, and the total number of the downstream ports. |
Downstream neighbors of the downstream port, and the total number of the downstream neighbors. |
Remaining aging time for the downstream port or downstream neighbor, and the finite state machine information. · For a global port, this field is always displayed. · For a non-global port, this field is displayed if the port is on the master device. Otherwise, you must specify the slot slot-number option to display this field. |
Use display pim-snooping statistics to display statistics for the PIM messages learned through PIM snooping.
# Display statistics for the PIM messages learned through PIM snooping.
<Sysname> display pim-snooping statistics
Received PIMv2 hello: 100
Received PIMv2 join/prune: 100
Received PIMv2 error: 0
Received PIMv2 messages in total: 200
Received PIMv1 messages in total: 0
Received PIMv2 hello |
Number of received PIMv2 hello messages. |
Received PIMv2 join/prune |
Number of received PIMv2 join/prune messages. |
Received PIMv2 error |
Number of received PIMv2 messages with errors. |
Received PIMv2 messages in total |
Total number of received PIMv2 messages. |
Received PIMv1 messages in total |
Total number of received PIMv1 messages. |
reset pim-snooping statistics
pim-snooping enable
Use pim-snooping enable to enable PIM snooping for a VLAN.
Use undo pim-snooping enable to disable PIM snooping for a VLAN.
pim-snooping enable
PIM snooping is disabled in a VLAN.
VLAN view
You must enable IGMP snooping globally and for a VLAN before you execute this command the VLAN.
PIM snooping does not take effect on sub-VLANs of a multicast VLAN.
# Enable IGMP snooping globally, and enable IGMP snooping and PIM snooping for VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] pim-snooping enable
· igmp-snooping
· igmp-snooping enable
Use pim-snooping graceful-restart join-aging-time to set the aging time for PIM snooping global downstream ports and global router ports on the new master device in IRF master election.
Use undo pim-snooping graceful-restart join-aging-time to restore the default.
pim-snooping graceful-restart join-aging-time interval
The default setting is 210 seconds.
VLAN view
interval: Specifies an aging time in the range of 210 to 18000 seconds.
A global downstream port or a global router port is a Layer 2 aggregate interface that acts as a downstream port or router port.
You must enable PIM snooping for a VLAN before you execute this command for the VLAN.
# In VLAN 2, set the aging time for PIM snooping global downstream ports and global router ports to 600 seconds on the new master device in IRF master election.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart join-aging-time 600
pim-snooping enable
Use pim-snooping graceful-restart neighbor-aging-time to set the aging time for PIM snooping global neighbor ports on the new master device in IRF master election.
Use undo pim-snooping graceful-restart neighbor-aging-time to restore the default.
pim-snooping graceful-restart neighbor-aging-time interval
The default setting is 105 seconds.
VLAN view
interval: Specifies an aging time in the range of 105 to 18000 seconds.
A global neighbor port is a Layer 2 aggregate interface that acts as a neighbor port.
# In VLAN 2, set the aging time for PIM snooping global neighbor ports to 300 seconds on the new master device in IRF master election.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart neighbor-aging-time 300
pim-snooping enable
Use reset pim-snooping statistics to clear statistics for the PIM messages learned through PIM snooping.
# Clear statistics for the PIM messages learned through PIM snooping.
<Sysname> reset pim-snooping statistics
