- 03-Layer 2—LAN Switching Command Reference
- 01-Ethernet interface commands
- 02-Loopback, null, and inloopback interface commands
- 03-Bulk interface commands
- 04-MAC address table commands
- 05-Ethernet link aggregation commands
- 06-Port isolation commands
- 07-Spanning tree commands
- 08-Loop detection commands
- 09-VLAN commands
- 10-MVRP commands
- 11-QinQ commands
- 12-VLAN mapping commands
- 13-LLDP commands
- 14-Cut-through forwarding commands
08-Loop detection commands | 47.98 KB |
display loopback-detection
Use display loopback-detection to display the loop detection configuration and status.
Example
# Display the loop detection configuration and status.
<Sysname> display loopback-detection
Loopback detection is enabled.
Loopback detection interval is 30 second(s).
Loopback is detected on following interfaces:
Interface Action mode
Ten-GigabitEthernet1/0/1 Block
Ten-GigabitEthernet1/0/2 Shutdown
Ten-GigabitEthernet1/0/3 None
Ten-GigabitEthernet1/0/4 No-learning
Action mode |
Loop protection action: · Block—When a loop is detected on a port, the device generates a log, disables the port from learning MAC addresses, and blocks inbound traffic on the port. · None—When a loop is detected on a port, the device generates a log but performs no action on the port. · No-learning—When a loop is detected on a port, the device generates a log and disables the port from learning MAC addresses. · Shutdown—When a loop is detected on a port, the device generates a log and shuts down the port to disable it from receiving and sending any frames. The device automatically brings up the port after the detection timer expires. You can use the shutdown-interval command to set the detection timer. For more information, see Fundamentals Command Reference. |
loopback-detection action
Use loopback-detection action to configure the loop protection action on a port.
Use undo loopback-detection action to restore the default.
In Layer 2 Ethernet interface view:
loopback-detection action { block | no-learning | shutdown }
In Layer 2 aggregate interface view:
loopback-detection action shutdown
When the device detects a loop on a port, it generates a log but performs no action on the port.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
block: Enables the block mode. If a loop is detected, the device disables MAC address learning and blocks inbound traffic on the port, in addition to generating a log. Layer 2 aggregate interfaces do not support this keyword.
no-learning: Enables the no-learning mode. If a loop is detected, the device generates a log and disables MAC address learning on the port. Layer 2 aggregate interfaces do not support this keyword.
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the port. The device automatically brings up the port after the detection timer expires. You can use the shutdown-interval command to set the detection timer. For more information, see Fundamentals Command Reference.
To configure the loop protection action globally, use the loopback-detection global action command.
The global configuration applies to all ports. The per-port configuration applies to the individual ports. The per-port configuration takes precedence over the global configuration.
Example
# Set the loop protection action to shutdown on port Ten-GigabitEthernet 1/0/1.
[System-Ten-GigabitEthernet1/0/1] loopback-detection action shutdown
· display loopback-detection
· loopback-detection global action
loopback-detection enable
Use loopback-detection enable to enable loop detection on a port.
Use undo loopback-detection enable to disable loop detection on a port.
loopback-detection enable vlan { vlan-list | all }
undo loopback-detection enable vlan { vlan-list | all }
The loop detection function is disabled on ports.
vlan-list: Specifies a VLAN list, in the format of { vlan-id [ to vlan-id ] }&<1-10>, where vlan-id represents the VLAN ID in the range of 1 to 4094, and &<1-10> indicates that you can specify up to 10 vlan-id [ to vlan-id ] parameters.
all: Specifies all existing VLANs.
To enable loop detection globally, use the loopback-detection global enable command.
The loop protection action on a port can be triggered even if loop detection is disabled on the port when the following requirements are met:
· Loop detection is enabled globally or on any other port on the device.
· The port receives a loop detection frame of any VLAN.
Example
# Enable loop detection on port Ten-GigabitEthernet 1/0/1 for VLAN 10 through VLAN 20.
[System-Ten-GigabitEthernet1/0/1] loopback-detection enable vlan 10 to 20
· loopback-detection global enable
Use loopback-detection global action to configure the global loop protection action.
Use undo loopback-detection global action to restore the default.
loopback-detection global action shutdown
To configure the loop protection action on a per-port basis, use the loopback-detection action command in interface view.
Example
# Set the global loop protection action to shutdown.
[System] loopback-detection global action shutdown
· loopback-detection action
Use loopback-detection global enable to enable loop detection globally.
Use undo loopback-detection global enable to disable loop detection globally.
loopback-detection global enable vlan { vlan-list | all }
undo loopback-detection global enable vlan { vlan-list | all }
The loop detection function is globally disabled.
To enable loop detection on a per-port basis, use the loopback-detection enable command in interface view.
Example
# Globally enable loop detection for VLAN 10 through VLAN 20.
[System] loopback-detection global enable vlan 10 to 20
· loopback-detection enable
loopback-detection interval-time
Use loopback-detection interval-time to set the loop detection interval.
Use undo loopback-detection interval-time to restore the default.
loopback-detection interval-time interval
The loop detection interval is 30 seconds.
interval: Sets the loop detection interval in the range of 1 to 300 seconds.
With loop detection enabled, the device sends loop detection frames at the specified interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
Example
# Set the loop detection interval to 10 seconds.
[Sysname] loopback-detection interval-time 10
