- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Preprovisioning commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
00-Preface | 81.71 KB |
Preface
This command reference describes commands that help you get started with the device. It includes the commands for the following features and tasks:
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, configuration files, and licenses.
· FTP and TFTP.
· Tcl and Python.
· ISSU and common software upgrade.
· Preprovisioning.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500X-AF switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
