- 12 Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-SNMP commands
- 05-RMON commands
- 06-NETCONF commands
- 07-EAA commands
- 08-Process monitoring and maintenance commands
- 09-Sampler commands
- 10-Mirroring commands
- 11-NetStream commands
- 12-IPv6 NetStream commands
- 13-sFlow commands
- 14-Information center commands
- 15-GOLD commands
- 16-Packet capture commands
- 17-VCF fabric commands
- 18-CWMP commands
- 19-SmartMC commands
13-sFlow commands | 80.83 KB |
sFlow commands
display sflow
Use display sflow to display sFlow configuration and operation information.
display sflow
# Display sFlow configuration and operation information.
<Sysname> display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.10.10.1(CLI)
Source address: 10.0.0.1 2001::1
Collector information:
ID IP Port Aging Size VPN-instance Description
1 22:2:20::10 6535 N/A 1400 netserver
2 192.168.3.5 6543 500 1400 Office
Port counter sampling information:
Interface Instance CID Interval(s)
XGE1/0/1 2 2 100
XGE1/0/1 1 1 200
Port flow sampling information:
Interface Instance FID MaxHLen Rate Mode Status
XGE1/0/1 2 2 128 1000 Random Active
XGE1/0/1 1 1 128 1000 Random Active
sFlow datagram version |
sFlow version, which can only take the value of 5. The device can send only sFlow packets whose sFlow version is 5. |
Global information |
Global sFlow information. |
Agent IP |
IP address of the sFlow agent: · CLI—Manually configured IP address. · Auto—Automatically configured IP address. |
Source address |
Source IP address of sFlow packets. |
Collector information |
sFlow collector information. |
ID |
sFlow collector ID. |
IP |
sFlow collector IP address. |
Port |
sFlow collector port. |
Aging |
Remaining lifetime of the sFlow collector. If this field displays N/A, the sFlow collector never ages out. |
Size |
Maximum length of the sFlow data portion in an sFlow packet. |
VPN-instance |
Name of the VPN instance to which the sFlow collector belongs. |
Description of the sFlow collector. |
Port counter sampling information |
Information about interfaces configured with counter sampling. |
Port flow sampling information |
Information about interfaces configured with flow sampling. |
Interface configured with sFlow. |
Instance |
ID of the sFlow instance for sending counter or flow sampled packets. |
CID |
ID of the sFlow collector for receiving counter sampled packets. If no sFlow collector ID is specified, this field displays 0. |
Interval(s) |
Counter sampling interval, in seconds. |
FID |
ID of the sFlow collector for receiving flow sampled packets. If no sFlow collector ID is specified, this field displays 0. |
MaxHLen |
Maximum number of bytes that can be copied in a sampled packet (starting from the packet header). |
Rate |
Number of packets out of which the interface samples a packet by using flow sampling. |
Mode |
Flow sampling mode: · Determine—Samples a fixed number of packets. This mode is not supported in the current software version. · Random—Samples a random number of packets. |
Status |
sFlow status of the port: · Suspended—The sFlow feature is suspended because the port is down. · Active—The sFlow feature is active because the port is up. |
sflow agent
Use sflow agent to configure an IP address for the sFlow agent.
Use undo sflow agent to restore the default.
sflow agent { ip ipv4-address | ipv6 ipv6-address }
undo sflow agent { ip | ipv6 }
No IP address is configured for the sFlow agent. The device periodically identifies whether the sFlow agent has an IP address. If the sFlow agent does not have an IP address, the device automatically selects an IPv4 address for the sFlow agent. It does not save the IPv4 address in the configuration file.
ip ipv4-address: Specifies an IPv4 address for the sFlow agent.
ipv6 ipv6-address: Specifies an IPv6 address for the sFlow agent.
As a best practice, manually configure an IP address for the sFlow agent.
# Specify IP address 10.10.10.1 for the sFlow agent.
[Sysname] sflow agent ip 10.10.10.1
sflow collector
Use sflow collector to configure parameters for an sFlow collector.
Use undo sflow collector to remove an sFlow collector.
sflow collector collector-id [ vpn-instance vpn-instance-name ] { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ datagram-size size ] [ time-out seconds ] [ description string ]
undo sflow collector collector-id
No sFlow collector information is configured.
collector-id: Specifies an sFlow collector by its ID. The value range for this argument is 1 to 10.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the sFlow collector belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The VPN instance name cannot contain spaces. By default, the sFlow collector belongs to the public network.
ip ipv4-address: Specifies an IPv4 address for the sFlow collector.
ipv6 ipv6-address: Specifies an IPv6 address for the sFlow collector.
port port-number: Specifies the UDP port number of the sFlow collector, in the range of 1 to 65535. The default is 6343.
datagram-size size: Specifies the maximum length of the sFlow data portion in an sFlow packet. The value range for the size argument is 200 to 3000 bytes, and the default value is 1400 bytes. To avoid sampling failures, make sure the value for the size argument is less than or equal to 1500 bytes when the sFlow collector is connected to a management Ethernet interface.
time-out seconds: Specifies the aging timer of the sFlow collector, in the range of 1 to 2147483647 seconds. When the aging timer expires, the sFlow collector settings are deleted. The sFlow collector settings do not age out by default.
description string: Specifies a description, a case-sensitive string of 1 to 127 characters. The default description is "CLI Collector."
# Configure the following parameters for sFlow collector 2:
· IP address—3.3.3.1.
· Port number—Default.
· Description—netserver.
· Aging timer—1200 seconds.
· Maximum length of the sFlow data portion in the sFlow packet—1000 bytes.
[Sysname] sflow collector 2 ip 3.3.3.1 description netserver time-out 1200 datagram-size 1000
sflow counter collector
Use sflow counter collector to specify an sFlow instance and an sFlow collector for counter sampling.
Use undo sflow counter collector to restore the default.
sflow counter [ instance instance-id ] collector collector-id
undo sflow counter [ instance instance-id ] collector
No sFlow instance or sFlow collector is specified for counter sampling.
instance instance-id: Specifies an sFlow instance by its ID in the range of 1 to 4. The default ID for an sFlow instance is 1. If you do not specify an sFlow instance, this command specifies sFlow instance 1 for counter sampling.
This command enables the device to send counter sampling information on an interface to the specified sFlow collector.
On an interface, one sFlow instance has only one sFlow collector. To specify multiple sFlow collectors for counter sampling, execute this command multiple times and use different sFlow instances each time. If you execute this command multiple times but use the same sFlow instance and different sFlow collectors each time, the most recent configuration takes effect.
On an interface, counter sampling and flow sampling are separate from each other. They can have the same sFlow instance but different sFlow collectors specified.
Settings of sFlow instances and sFlow collectors for different interfaces do not affect each other. Configure this command based on actual requirement.
# Specify sFlow instance 2 and sFlow collector 2 on Ten-GigabitEthernet 1/0/1 for counter sampling.
[Sysname-Ten-GigabitEthernet1/0/1] sflow counter instance 2 collector 2
sflow counter interval
Use sflow counter interval to enable counter sampling and set a counter sampling interval.
Use undo sflow counter interval to disable counter sampling.
sflow counter interval interval
Counter sampling is disabled.
interval: Specifies the counter sampling interval in the range of 2 to 86400 seconds.
# Enable counter sampling and set the counter sampling interval to 120 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] sflow counter interval 120
sflow flow collector
Use sflow flow collector to specify an sFlow instance and an sFlow collector for flow sampling.
Use undo sflow flow collector to restore the default.
sflow flow [ instance instance-id ] collector collector-id
undo sflow flow [ instance instance-id ] collector
No sFlow instance or sFlow collector is specified for flow sampling.
instance instance-id: Specifies an sFlow instance by its ID in the range of 1 to 4. The default ID for an sFlow instance is 1. If you do not specify an sFlow instance, this command specifies sFlow instance 1 for flow sampling.
This command enables the device to send flow sampling information on an interface to the specified sFlow collector.
On an interface, one sFlow instance has only one sFlow collector. To specify multiple sFlow collectors for flow sampling, execute this command multiple times and use different sFlow instances each time. If you execute this command multiple times but use the same sFlow instance and different sFlow collectors each time, the most recent configuration takes effect.
# Specify sFlow instance 2 and sFlow collector 2 on Ten-GigabitEthernet 1/0/1 for flow sampling.
[Sysname-Ten-GigabitEthernet1/0/1] sflow flow instance 2 collector 2
sflow flow max-header
Use sflow flow max-header to set the maximum number of bytes (starting from the packet header) that flow sampling can copy per packet.
Use undo sflow flow max-header to restore the default.
sflow flow max-header length
Flow sampling can copy up to 128 bytes of a packet.
length: Specifies the maximum number of bytes that can be copied, in the range of 18 to 512. As a best practice, use the default value.
# Set the maximum number of bytes to 60 for flow sampling to copy per packet on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] sflow flow max-header 60
sflow sampling-mode
Use sflow sampling-mode to specify a flow sampling mode.
Use undo sflow sampling-mode to restore the default.
sflow sampling-mode { determine | random }
Random sampling is used.
determine: Specifies the fixed sampling mode. For example, if the flow sampling interval is set to 4000 (by using the sflow sampling-rate command), the device samples packets as follows:
· The device randomly samples a packet, like the tenth packet, from the first 4000 packets.
· The next time the device samples the 4010th packet, and so on.
This keyword is not supported in the current software version.
random: Specifies the random sampling mode. For example, if the packet sampling interval is set to 4000 (by using the sflow sampling-rate command), the device samples packets randomly as follows:
· The device might sample one packet from the first 4000 packets.
· The device might sample multiple packets from the next 4000 packets.
· The device might sample no packets from the third 4000 packets.
However, the device samples one packet from 4000 packets on average.
# Specify random flow sampling mode on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] sflow sampling-mode random
sflow sampling-rate
sflow sampling-rate
Use sflow sampling-rate to enable flow sampling and specify the number of packets out of which flow sampling will sample a packet.
Use undo sflow sampling-rate to disable flow sampling.
sflow sampling-rate rate
Flow sampling is disabled.
rate: Specifies the number of packets out of which flow sampling will sample a packet on the interface. The value range for this argument is 1000 to 500000. As a best practice, set the sampling interval to 2n that is greater than or equal to 8192, for example, 32768.
# Enable flow sampling to sample a packet out of 32768 packets on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] sflow sampling-rate 32768
sflow sampling-mode
sflow source
Use sflow source to specify the source IP address of sent sFlow packets.
Use undo sflow source to restore the default.
sflow source { ip ipv4-address | ipv6 ipv6-address } *
undo sflow source { ip | ipv6 } *
The source IP address of sent sFlow packets is determined by routing.
ip ipv4-address: Specifies the source IPv4 address of sent sFlow packets.
ipv6 ipv6-address: Specifies the source IPv6 address of sent sFlow packets.
# Specify the source IPv4 address of sent sFlow packets as 10.0.0.1.
[Sysname] sflow source ip 10.0.0.1
